[QGIS Commit] r10802 - in branches/symbology-ng-branch/src:
core/symbology-ng gui gui/symbology-ng ui
svn_qgis at osgeo.org
Fri May 15 18:32:59 EDT 2009
Author: wonder
Date: 2009-05-15 18:32:59 -0400 (Fri, 15 May 2009)
New Revision: 10802
Added:
branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.cpp
branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.h
branches/symbology-ng-branch/src/ui/qgsvectorrandomcolorrampv2dialogbase.ui
branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.cpp
branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.h
branches/symbology-ng-branch/src/gui/CMakeLists.txt
branches/symbology-ng-branch/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
Added random color ramp to as an example of a discrete color ramp.
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.cpp 2009-05-15 21:15:33 UTC (rev 10801)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.cpp 2009-05-15 22:32:59 UTC (rev 10802)
@@ -3,6 +3,8 @@
#include "qgssymbollayerv2utils.h"
+#include <stdlib.h> // for random()
QgsVectorGradientColorRampV2::QgsVectorGradientColorRampV2(QColor color1, QColor color2)
: mColor1(color1), mColor2(color2)
@@ -40,3 +42,75 @@
map["color2"] = QgsSymbolLayerV2Utils::encodeColor(mColor2);
return map;
+QgsVectorRandomColorRampV2::QgsVectorRandomColorRampV2(int count, int hueMin, int hueMax,
+ int satMin, int satMax, int valMin, int valMax )
+ : mCount(count), mHueMin(hueMin), mHueMax(hueMax),
+ mSatMin(satMin), mSatMax(satMax), mValMin(valMin), mValMax(valMax)
+ updateColors();
+QgsVectorColorRampV2* QgsVectorRandomColorRampV2::create(const QgsStringMap& props)
+ int count = DEFAULT_RANDOM_COUNT;
+ int hueMin = DEFAULT_RANDOM_HUE_MIN, hueMax = DEFAULT_RANDOM_HUE_MAX;
+ int satMin = DEFAULT_RANDOM_SAT_MIN, satMax = DEFAULT_RANDOM_SAT_MAX;
+ int valMin = DEFAULT_RANDOM_VAL_MIN, valMax = DEFAULT_RANDOM_VAL_MAX;
+ if (props.contains("count")) count = props["count"].toInt();
+ if (props.contains("hueMin")) hueMin = props["hueMin"].toInt();
+ if (props.contains("hueMax")) hueMax = props["hueMax"].toInt();
+ if (props.contains("satMin")) satMin = props["satMin"].toInt();
+ if (props.contains("satMax")) satMax = props["satMax"].toInt();
+ if (props.contains("valMin")) valMin = props["valMin"].toInt();
+ if (props.contains("valMax")) valMax = props["valMax"].toInt();
+ return new QgsVectorRandomColorRampV2(count, hueMin, hueMax, satMin, satMax, valMin, valMax);
+QColor QgsVectorRandomColorRampV2::color(double value) const
+ int colorCnt = mColors.count();
+ int colorIdx = (int) ( value * colorCnt );
+ if (colorIdx >= 0 && colorIdx < colorCnt)
+ return mColors.at( colorIdx );
+ return QColor();
+QgsVectorColorRampV2* QgsVectorRandomColorRampV2::clone() const
+ return new QgsVectorRandomColorRampV2(mCount, mHueMin, mHueMax, mSatMin, mSatMax, mValMin, mValMax);
+QgsStringMap QgsVectorRandomColorRampV2::properties() const
+ QgsStringMap map;
+ map["count"] = QString::number(mCount);
+ map["hueMin"] = QString::number(mHueMin);
+ map["hueMax"] = QString::number(mHueMax);
+ map["satMin"] = QString::number(mSatMin);
+ map["satMax"] = QString::number(mSatMax);
+ map["valMin"] = QString::number(mValMin);
+ map["valMax"] = QString::number(mValMax);
+ return map;
+void QgsVectorRandomColorRampV2::updateColors()
+ int h,s,v;
+ mColors.clear();
+ for (int i = 0; i < mCount; i++)
+ h = (random() % (mHueMax-mHueMin+1)) + mHueMin;
+ s = (random() % (mSatMax-mSatMin+1)) + mSatMin;
+ v = (random() % (mValMax-mValMin+1)) + mValMin;
+ mColors.append( QColor::fromHsv(h,s,v) );
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.h 2009-05-15 21:15:33 UTC (rev 10801)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsvectorcolorrampv2.h 2009-05-15 22:32:59 UTC (rev 10802)
@@ -50,4 +50,54 @@
QColor mColor1, mColor2;
+#define DEFAULT_RANDOM_COUNT 10
+#define DEFAULT_RANDOM_HUE_MIN 0
+#define DEFAULT_RANDOM_HUE_MAX 359
+#define DEFAULT_RANDOM_VAL_MIN 0
+#define DEFAULT_RANDOM_VAL_MAX 255
+#define DEFAULT_RANDOM_SAT_MIN 0
+#define DEFAULT_RANDOM_SAT_MAX 255
+class QgsVectorRandomColorRampV2 : public QgsVectorColorRampV2
+public:
+ QgsVectorRandomColorRampV2(int count = DEFAULT_RANDOM_COUNT,
+ int hueMin = DEFAULT_RANDOM_HUE_MIN, int hueMax = DEFAULT_RANDOM_HUE_MAX,
+ int satMin = DEFAULT_RANDOM_SAT_MIN, int satMax = DEFAULT_RANDOM_SAT_MAX,
+ int valMin = DEFAULT_RANDOM_VAL_MIN, int valMax = DEFAULT_RANDOM_VAL_MAX );
+ static QgsVectorColorRampV2* create(const QgsStringMap& properties = QgsStringMap());
+ virtual QColor color(double value) const;
+ virtual QString type() const { return "random"; }
+ virtual QgsVectorColorRampV2* clone() const;
+ virtual QgsStringMap properties() const;
+ void updateColors();
+ int count() const { return mCount; }
+ int hueMin() const { return mHueMin; }
+ int hueMax() const { return mHueMax; }
+ int satMin() const { return mSatMin; }
+ int satMax() const { return mSatMax; }
+ int valMin() const { return mValMin; }
+ int valMax() const { return mValMax; }
+ void setCount(int val) { mCount = val; }
+ void setHueMin(int val) { mHueMin = val; }
+ void setHueMax(int val) { mHueMax = val; }
+ void setSatMin(int val) { mSatMin = val; }
+ void setSatMax(int val) { mSatMax = val; }
+ void setValMin(int val) { mValMin = val; }
+ void setValMax(int val) { mValMax = val; }
+protected:
+ int mCount;
+ int mHueMin, mHueMax, mSatMin, mSatMax, mValMin, mValMax;
+ QList<QColor> mColors;
#endif
Modified: branches/symbology-ng-branch/src/gui/CMakeLists.txt
--- branches/symbology-ng-branch/src/gui/CMakeLists.txt 2009-05-15 21:15:33 UTC (rev 10801)
+++ branches/symbology-ng-branch/src/gui/CMakeLists.txt 2009-05-15 22:32:59 UTC (rev 10802)
@@ -9,6 +9,7 @@
symbology-ng/qgssymbolv2selectordialog.cpp
symbology-ng/qgsvectorgradientcolorrampv2dialog.cpp
+symbology-ng/qgsvectorrandomcolorrampv2dialog.cpp
qgisgui.cpp
qgisinterface.cpp
@@ -46,6 +47,7 @@
symbology-ng/qgsstylev2managerdialog.h
symbology-ng/qgssymbolv2selectordialog.h
symbology-ng/qgsvectorgradientcolorrampv2dialog.h
+symbology-ng/qgsvectorrandomcolorrampv2dialog.h
qgscomposerview.h
qgsdetaileditemdelegate.h
Modified: branches/symbology-ng-branch/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
--- branches/symbology-ng-branch/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2009-05-15 21:15:33 UTC (rev 10801)
+++ branches/symbology-ng-branch/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2009-05-15 22:32:59 UTC (rev 10802)
@@ -8,6 +8,7 @@
#include "qgssymbolv2propertiesdialog.h"
#include "qgsvectorgradientcolorrampv2dialog.h"
+#include "qgsvectorrandomcolorrampv2dialog.h"
#include <QFile>
#include <QInputDialog>
@@ -104,9 +105,17 @@
int itemType = currentItemType();
if (itemType < 3)
populateSymbols(itemType);
+ else if (itemType == 3)
+ populateColorRamps();
else
- populateColorRamps();
+ Q_ASSERT(0 && "not implemented");
void QgsStyleV2ManagerDialog::populateSymbols(int type)
@@ -170,11 +179,17 @@
void QgsStyleV2ManagerDialog::addItem()
if (currentItemType() < 3)
addSymbol();
else if (currentItemType() == 3)
addColorRamp();
else
populateList();
populateTypes();
@@ -217,18 +232,15 @@
bool QgsStyleV2ManagerDialog::addColorRamp()
- // TODO: random color ramp
+ // let the user choose the color ramp type
QStringList rampTypes;
rampTypes << "Gradient" << "Random";
bool ok;
- QString rampType = QInputDialog.getItem(this, "Color ramp type",
+ QString rampType = QInputDialog::getItem(this, "Color ramp type",
"Please select color ramp type:", rampTypes, 0, false, &ok);
if (!ok || rampType.isEmpty())
return false;
- QString rampType = "Gradient";
QgsVectorColorRampV2* ramp;
if (rampType == "Gradient")
@@ -241,22 +253,23 @@
ramp = gradRamp;
- else
+ else if (rampType == "Random")
QgsVectorRandomColorRampV2* randRamp = new QgsVectorRandomColorRampV2();
- DlgRandomColorRamp dlg(randRamp, this);
+ QgsVectorRandomColorRampV2Dialog dlg(randRamp, this);
if (!dlg.exec())
delete randRamp;
return false;
ramp = randRamp;
+ else
+ Q_ASSERT(0 && "invalid ramp type");
// get name
- bool ok;
QString name = QInputDialog::getText(this, "Color ramp name",
"Please enter name for new color ramp:", QLineEdit::Normal, "new color ramp", &ok);
if (!ok || name.isEmpty())
@@ -274,11 +287,17 @@
void QgsStyleV2ManagerDialog::editItem()
editSymbol();
editColorRamp();
else
populateList();
@@ -322,10 +341,19 @@
return false;
+ else if (ramp->type() == "random")
+ QgsVectorRandomColorRampV2* randRamp = static_cast<QgsVectorRandomColorRampV2*>(ramp);
+ if (!dlg.exec())
+ delete ramp;
+ return false;
else
- //dlg = DlgRandomColorRamp(ramp, self)
mStyle->addColorRamp(name, ramp);
@@ -336,11 +364,17 @@
void QgsStyleV2ManagerDialog::removeItem()
removeSymbol();
removeColorRamp();
else
populateList();
populateTypes();
Added: branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.cpp
--- branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.cpp (rev 0)
+++ branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.cpp 2009-05-15 22:32:59 UTC (rev 10802)
@@ -0,0 +1,81 @@
+#include "qgsvectorcolorrampv2.h"
+#include <QColorDialog>
+QgsVectorRandomColorRampV2Dialog::QgsVectorRandomColorRampV2Dialog(QgsVectorRandomColorRampV2* ramp, QWidget* parent)
+ : QDialog(parent), mRamp(ramp)
+ setupUi(this);
+ spinCount->setValue( ramp->count() );
+ spinHue1->setValue( ramp->hueMin() );
+ spinHue2->setValue( ramp->hueMax() );
+ spinSat1->setValue( ramp->satMin() );
+ spinSat2->setValue( ramp->satMax() );
+ spinVal1->setValue( ramp->valMin() );
+ spinVal2->setValue( ramp->valMax() );
+ connect(spinCount, SIGNAL(valueChanged(int)), this, SLOT(setCount(int)) );
+ connect(spinHue1, SIGNAL(valueChanged(int)), this, SLOT(setHue1(int)) );
+ connect(spinHue2, SIGNAL(valueChanged(int)), this, SLOT(setHue2(int)) );
+ connect(spinSat1, SIGNAL(valueChanged(int)), this, SLOT(setSat1(int)) );
+ connect(spinSat2, SIGNAL(valueChanged(int)), this, SLOT(setSat2(int)) );
+ connect(spinVal1, SIGNAL(valueChanged(int)), this, SLOT(setVal1(int)) );
+ connect(spinVal2, SIGNAL(valueChanged(int)), this, SLOT(setVal2(int)) );
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::updatePreview()
+ mRamp->updateColors();
+ QSize size(300,40);
+ lblPreview->setPixmap(QgsSymbolLayerV2Utils::colorRampPreviewPixmap(mRamp, size));
+void QgsVectorRandomColorRampV2Dialog::setCount( int val )
+ mRamp->setCount(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setHue1( int val )
+ mRamp->setHueMin(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setHue2( int val )
+ mRamp->setHueMax(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setSat1( int val )
+ mRamp->setSatMin(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setSat2( int val )
+ mRamp->setSatMax(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setVal1( int val )
+ mRamp->setValMin(val);
+ updatePreview();
+void QgsVectorRandomColorRampV2Dialog::setVal2( int val )
+ mRamp->setValMax(val);
+ updatePreview();
Added: branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.h
--- branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.h (rev 0)
+++ branches/symbology-ng-branch/src/gui/symbology-ng/qgsvectorrandomcolorrampv2dialog.h 2009-05-15 22:32:59 UTC (rev 10802)
@@ -0,0 +1,34 @@
+#ifndef QGSVECTORRANDOMCOLORRAMPV2DIALOG_H
+#define QGSVECTORRANDOMCOLORRAMPV2DIALOG_H
+#include <QDialog>
+#include "ui_qgsvectorrandomcolorrampv2dialogbase.h"
+class QgsVectorRandomColorRampV2;
+class QgsVectorRandomColorRampV2Dialog : public QDialog, private Ui::QgsVectorRandomColorRampV2DialogBase
+ Q_OBJECT
+public:
+ QgsVectorRandomColorRampV2Dialog(QgsVectorRandomColorRampV2* ramp, QWidget* parent = NULL);
+public slots:
+ void setCount( int val );
+ void setHue1( int val );
+ void setHue2( int val );
+ void setSat1( int val );
+ void setSat2( int val );
+ void setVal1( int val );
+ void setVal2( int val );
+protected:
+ void updatePreview();
+ QgsVectorRandomColorRampV2* mRamp;
+#endif
Added: branches/symbology-ng-branch/src/ui/qgsvectorrandomcolorrampv2dialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgsvectorrandomcolorrampv2dialogbase.ui (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgsvectorrandomcolorrampv2dialogbase.ui 2009-05-15 22:32:59 UTC (rev 10802)
@@ -0,0 +1,257 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsVectorRandomColorRampV2DialogBase</class>
+ <widget class="QDialog" name="QgsVectorRandomColorRampV2DialogBase">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>429</width>
+ <height>266</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Random color ramp</string>
+ </property>
+ <layout class="QVBoxLayout">
+ <item>
+ <layout class="QGridLayout">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label_8">
+ <property name="text">
+ <string>Hue</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QLabel" name="label">
+ <string>from</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2">
+ <widget class="QSpinBox" name="spinHue1">
+ <property name="maximum">
+ <number>359</number>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3">
+ <widget class="QLabel" name="label_4">
+ <string>to</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="4">
+ <widget class="QSpinBox" name="spinHue2">
+ </property>
+ <property name="value">
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label_9">
+ <string>Saturation</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QLabel" name="label_2">
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="2">
+ <widget class="QSpinBox" name="spinSat1">
+ <number>255</number>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="3">
+ <widget class="QLabel" name="label_5">
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="4">
+ <widget class="QSpinBox" name="spinSat2">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
+ <widget class="QLabel" name="label_10">
+ <string>Value</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QLabel" name="label_3">
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="2">
+ <widget class="QSpinBox" name="spinVal1">
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="3">
+ <widget class="QLabel" name="label_6">
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="4">
+ <widget class="QSpinBox" name="spinVal2">
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <layout class="QHBoxLayout">
+ <item>
+ <widget class="QLabel" name="label_7">
+ <string>Classes</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSpinBox" name="spinCount">
+ <property name="minimum">
+ <number>1</number>
+ </property>
+ <number>100</number>
+ </property>
+ <number>10</number>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer>
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeType">
+ <enum>QSizePolicy::Preferred</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>150</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <spacer>
+ <enum>Qt::Vertical</enum>
+ </property>
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QGroupBox" name="groupBox">
+ <property name="title">
+ <string>Preview</string>
+ </property>
+ <item>
+ <widget class="QLabel" name="lblPreview">
+ <string/>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignCenter</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDialogButtonBox" name="buttonBox">
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsVectorRandomColorRampV2DialogBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>248</x>
+ <y>254</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>316</x>
+ <y>260</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
