[QGIS Commit] r10818 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Mon May 18 17:48:54 EDT 2009
Author: borysiasty
Date: 2009-05-18 17:48:54 -0400 (Mon, 18 May 2009)
New Revision: 10818
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
Plugin Installer minor fixes
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-05-18 15:35:13 UTC (rev 10817)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-05-18 21:48:54 UTC (rev 10818)
@@ -14,7 +14,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0"
+ return "Version 1.0.1"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-05-18 15:35:13 UTC (rev 10817)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-05-18 21:48:54 UTC (rev 10818)
@@ -701,6 +701,7 @@
self.mPlugins[key]["status"] = "upgradeable"
else:
self.mPlugins[key]["status"] = "newer"
+ self.markNews()
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-05-18 15:35:13 UTC (rev 10817)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-05-18 21:48:54 UTC (rev 10818)
@@ -88,7 +88,7 @@
repositories.setRepositoryData(key,"state",3)
for i in plugins.obsoletePlugins:
- QMessageBox.warning(self.mainWindow(), QCoreApplication.translate("QgsPluginInstaller","QGIS Plugin Conflict:")+" "+plugins.localCache[i]["name"], QCoreApplication.translate("QgsPluginInstaller","The Plugin Installer has detected an obsolete plugin which masks a newer version shipped with this QGIS version. Probably it is a remainder of an older QGIS installation. Please use the Plugin Installer to remove it in order to unmask the instance shipped with this version of QGIS."))
+ QMessageBox.warning(self.mainWindow(), QCoreApplication.translate("QgsPluginInstaller","QGIS Plugin Conflict:")+" "+plugins.localCache[i]["name"], QCoreApplication.translate("QgsPluginInstaller","The Plugin Installer has detected an obsolete plugin which masks a newer version shipped with this QGIS version. This is likely due to files associated with a previous installation of QGIS. Please use the Plugin Installer to remove that older plugin in order to unmask the newer version shipped with this copy of QGIS."))
