[QGIS Commit] r10849 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Tue May 26 14:07:37 EDT 2009
Author: cfarmer
Date: 2009-05-26 14:07:37 -0400 (Tue, 26 May 2009)
New Revision: 10849
trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
trunk/qgis/python/plugins/fTools/tools/doVisual.py
trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.py
trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.ui
trunk/qgis/python/plugins/fTools/tools/frmVisual.py
trunk/qgis/python/plugins/fTools/tools/frmVisual.ui
trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
applying patch from ticket #1714: adds option to perform geoprocessing and basic statistics functions on selected features
Modified: trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
--- trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2009-05-26 18:07:37 UTC (rev 10849)
@@ -13,13 +13,33 @@
self.setupUi( self )
self.myFunction = function
QObject.connect( self.btnBrowse, SIGNAL( "clicked()" ), self.outFile )
+ QObject.connect( self.inShapeA, SIGNAL( "currentIndexChanged(QString)" ), self.checkA )
+ QObject.connect( self.inShapeB, SIGNAL( "currentIndexChanged(QString)" ), self.checkB )
if function == 4 or function == 1 or function == 2:
QObject.connect( self.inShapeA, SIGNAL( "currentIndexChanged(QString)" ), self.update )
self.manageGui()
self.success = False
self.cancel_close = self.buttonBox_2.button( QDialogButtonBox.Close )
self.progressBar.setValue (0 )
+ def checkA( self ):
+ inputLayer = unicode( self.inShapeA.currentText() )
+ if inputLayer != "":
+ changedLayer = ftools_utils.getVectorLayerByName( inputLayer )
+ if changedLayer.selectedFeatureCount() != 0:
+ self.useSelectedA.setCheckState( Qt.Checked )
+ else:
+ self.useSelectedA.setCheckState( Qt.Unchecked )
+ def checkB( self ):
+ inputLayer = unicode( self.inShapeB.currentText() )
+ self.useSelectedB.setCheckState( Qt.Checked )
+ else:
+ self.useSelectedB.setCheckState( Qt.Unchecked )
def update( self ):
self.attrib.clear()
@@ -30,56 +50,69 @@
self.attrib.addItem( unicode( changedField[i].name() ) )
if self.myFunction == 4:
self.attrib.addItem( "--- " + self.tr( "Dissolve all" ) + " ---" )
def accept( self ):
if self.inShapeA.currentText() == "":
- QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify an input layer" ) )
+ QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify an input layer" ) )
elif self.inShapeB.isVisible() and self.inShapeB.currentText() == "":
- QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify a difference/intersect/union layer" ) )
+ QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify a difference/intersect/union layer" ) )
elif self.param.isEnabled() and self.param.isVisible() and self.param.text() == "":
QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify valid buffer value" ) )
elif self.attrib.isEnabled() and self.attrib.isVisible() and self.attrib.currentText() == "":
QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify dissolve field" ) )
elif self.outShape.text() == "":
QMessageBox.warning( self, "Geoprocessing", self.tr( "Please specify output shapefile" ) )
- else:
- self.outShape.clear()
- if self.attrib.isEnabled():
- self.geoprocessing( self.inShapeA.currentText(), self.inShapeB.currentText(),
- unicode( self.attrib.currentText() ), self.mergeOutput.checkState() )
+ else:
+ changedLayerA = ftools_utils.getVectorLayerByName( self.inShapeA.currentText() )
+ changedLayerB = ftools_utils.getVectorLayerByName( self.inShapeB.currentText() )
+ # check for selection in layer A
+ if self.useSelectedA.isChecked() and changedLayerA.selectedFeatureCount() == 0:
+ QMessageBox.warning( self, "Geoprocessing", self.tr( "No features selected, please uncheck 'Use selected' or make a selection" ) )
+ # check for selection in layer B
+ elif self.inShapeB.isVisible() and self.useSelectedB.isChecked() and changedLayerB.selectedFeatureCount() == 0:
else:
- if self.param.isEnabled() and self.param.isVisible():
- parameter = float( self.param.text() )
+ self.outShape.clear()
+ if self.attrib.isEnabled():
+ self.geoprocessing( self.inShapeA.currentText(), self.inShapeB.currentText(),
+ unicode( self.attrib.currentText() ), self.mergeOutput.checkState(), self.useSelectedA.checkState(),
+ self.useSelectedB.checkState() )
else:
- parameter = None
- parameter, self.mergeOutput.checkState() )
+ if self.param.isEnabled() and self.param.isVisible():
+ parameter = float( self.param.text() )
+ else:
+ parameter = None
+ parameter, self.mergeOutput.checkState(), self.useSelectedA.checkState(), self.useSelectedB.checkState() )
def outFile( self ):
( self.shapefileName, self.encoding ) = ftools_utils.saveDialog( self )
if self.shapefileName is None or self.encoding is None:
return
self.outShape.setText( QString( self.shapefileName ) )
def manageGui( self ):
if self.myFunction == 1: # Buffer
self.label_2.hide()
self.inShapeB.hide()
+ self.useSelectedB.hide()
self.label_4.hide()
self.setWindowTitle( self.tr( "Buffer(s)" ) )
elif self.myFunction == 2: # Convex hull
self.label_2.hide()
self.rdoBuffer.setText( self.tr( "Create single minimum convex hull" ) )
self.rdoField.setText( self.tr( "Create convex hulls based on input field" ) )
self.label_4.hide()
self.param.hide()
- self.setWindowTitle( self.tr( "Convex hull(s)" ) )
+ self.setWindowTitle( self.tr( "Convex hull(s)" ) )
self.mergeOutput.hide()
elif self.myFunction == 4: # Dissolve
self.label_2.hide()
self.rdoBuffer.hide()
self.attrib.setEnabled( True )
self.param.hide()
@@ -112,19 +145,19 @@
myListA = []
myListB = []
self.inShapeA.clear()
- self.inShapeB.clear()
+ self.inShapeB.clear()
if self.myFunction == 5 or self.myFunction == 8 or self.myFunction == 3:
- myListA = ftools_utils.getLayerNames( [ QGis.Point, QGis.Line, QGis.Polygon ] )
- myListB = ftools_utils.getLayerNames( [ QGis.Polygon ] )
+ myListA = ftools_utils.getLayerNames( [ QGis.Point, QGis.Line, QGis.Polygon ] )
+ myListB = ftools_utils.getLayerNames( [ QGis.Polygon ] )
elif self.myFunction == 7 or self.myFunction == 6:
myListA = ftools_utils.getLayerNames( [ QGis.Polygon ] )
- myListA = ftools_utils.getLayerNames( [ QGis.Polygon ] )
+ myListA = ftools_utils.getLayerNames( [ QGis.Polygon ] )
myListB = []
else:
myListB = ftools_utils.getLayerNames( [ QGis.Point, QGis.Line, QGis.Polygon ] )
self.inShapeA.addItems( myListA )
self.inShapeB.addItems( myListB )
@@ -139,14 +172,14 @@
#7: Symetrical Difference
#8: Clip
- def geoprocessing( self, myLayerA, myLayerB, myParam, myMerge ):
+ def geoprocessing( self, myLayerA, myLayerB, myParam, myMerge, mySelectionA, mySelectionB ):
check = QFile( self.shapefileName )
if check.exists():
if not QgsVectorFileWriter.deleteShapeFile( self.shapefileName ):
QMessageBox.warning( self, "Geoprocessing", self.tr( "Unable to delete existing shapefile." ) )
return
self.testThread = geoprocessingThread( self.iface.mainWindow(), self, self.myFunction, myLayerA,
- myLayerB, myParam, myMerge, self.shapefileName, self.encoding )
+ myLayerB, myParam, myMerge, mySelectionA, mySelectionB, self.shapefileName, self.encoding )
QObject.connect( self.testThread, SIGNAL( "runFinished(PyQt_PyObject)" ), self.runFinishedFromThread )
QObject.connect( self.testThread, SIGNAL( "runStatus(PyQt_PyObject)" ), self.runStatusFromThread )
QObject.connect( self.testThread, SIGNAL( "runRange(PyQt_PyObject)" ), self.runRangeFromThread )
@@ -154,10 +187,10 @@
QObject.connect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
self.testThread.start()
return True
def cancelThread( self ):
self.testThread.stop()
def runFinishedFromThread( self, results ):
self.cancel_close.setText( "Close" )
@@ -183,13 +216,13 @@
def runStatusFromThread( self, status ):
self.progressBar.setValue( status )
def runRangeFromThread( self, range_vals ):
self.progressBar.setRange( range_vals[ 0 ], range_vals[ 1 ] )
class geoprocessingThread( QThread ):
def __init__( self, parentThread, parentObject, function, myLayerA, myLayerB,
- myParam, myMerge, myName, myEncoding ):
+ myParam, myMerge, mySelectionA, mySelectionB, myName, myEncoding ):
QThread.__init__( self, parentThread )
self.parent = parentObject
self.running = False
@@ -198,9 +231,11 @@
self.myLayerB = myLayerB
self.myParam = myParam
self.myMerge = myMerge
+ self.mySelectionA = mySelectionA
+ self.mySelectionB = mySelectionB
self.myName = myName
self.myEncoding = myEncoding
def run( self ):
self.running = True
self.vlayerA = ftools_utils.getVectorLayerByName( self.myLayerA )
@@ -221,16 +256,16 @@
geos, feature, match = self.intersect()
elif self.myFunction == 6:
geos, feature, match = self.union()
- elif self.myFunction == 7:
+ elif self.myFunction == 7:
geos, feature, match = self.symetrical_difference()
- elif self.myFunction == 8:
+ elif self.myFunction == 8:
geos, feature, match = self.clip()
self.emit( SIGNAL( "runFinished(PyQt_PyObject)" ), (geos, feature, match) )
self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
def stop(self):
def buffering( self, useField ):
GEOS_EXCEPT = True
FEATURE_EXCEPT = True
@@ -244,68 +279,130 @@
inFeat = QgsFeature()
inGeom = QgsGeometry()
outGeom = QgsGeometry()
- nFeat = vproviderA.featureCount()
nElement = 0
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
- self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
- if self.myMerge:
- first = True
- vproviderA.rewind()
- add = True
- while vproviderA.nextFeature( inFeat ):
- atMap = inFeat.attributeMap()
- if useField:
- value = atMap[ self.myParam ].toDouble()[ 0 ]
- else:
- value = self.myParam
- inGeom = QgsGeometry( inFeat.geometry() )
+ # there is selection in input layer
+ if self.mySelectionA:
+ nFeat = self.vlayerA.selectedFeatureCount()
+ selectionA = self.vlayerA.selectedFeatures()
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
+ self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
+ # with dissolve
+ if self.myMerge:
+ first = True
+ for inFeat in selectionA:
+ atMap = inFeat.attributeMap()
+ if useField:
+ value = atMap[ self.myParam ].doDouble()[ 0 ]
+ else:
+ value = self.myParam
+ inGeom = QgsGeometry( inFeat.geometry() )
+ try:
+ outGeom = inGeom.buffer( float( value ), 5 )
+ if first:
+ tempGeom = QgsGeometry( outGeom )
+ first = False
+ else:
+ try:
+ tempGeom = tempGeom.combine( outGeom )
+ except:
+ GEOS_EXCEPT = False
+ continue
+ except:
+ continue
+ nElement += 1
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
try:
- outGeom = inGeom.buffer( float( value ), 5 )
- if first:
- tempGeom = QgsGeometry( outGeom )
- first = False
+ outFeat.setGeometry( tempGeom )
+ writer.addFeature( outFeat )
+ except:
+ FEATURE_EXCEPT = False
+ # without dissolve
+ else:
+ if useField:
+ value = atMap[ self.myParam ].toDouble()[ 0 ]
else:
+ try:
try:
- tempGeom = tempGeom.combine( outGeom )
+ outFeat.setGeometry( outGeom )
+ outFeat.setAttributeMap( atMap )
except:
- GEOS_EXCEPT = False
continue
- except:
- continue
- nElement += 1
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
- try:
- outFeat.setGeometry( tempGeom )
- writer.addFeature( outFeat )
- except:
- FEATURE_EXCEPT = False
+ except:
+ continue
+ nElement += 1
+ # there is no selection in input layer
else:
- if useField:
- else:
+ nFeat = vproviderA.featureCount()
+ # with dissolve
+ if self.myMerge:
+ first = True
+ while vproviderA.nextFeature( inFeat ):
+ if useField:
+ else:
+ try:
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ continue
+ except:
+ continue
+ nElement += 1
try:
+ except:
+ else:
+ vproviderA.rewind()
+ if useField:
+ else:
try:
- outFeat.setGeometry( outGeom )
- outFeat.setAttributeMap( atMap )
+ try:
+ except:
+ continue
except:
continue
- except:
- continue
- nElement += 1
+ nElement += 1
del writer
return GEOS_EXCEPT, FEATURE_EXCEPT, True
def convex_hull(self, useField ):
GEOS_EXCEPT = True
@@ -318,66 +415,122 @@
outFeat = QgsFeature()
- if useField:
- unique = ftools_utils.getUniqueValues( vproviderA, self.myParam )
- nFeat = vproviderA.featureCount() * len( unique )
- nElement = 0
- for i in unique:
+ nElement = 0
+ if useField:
+ unique = ftools_utils.getUniqueValues( vproviderA, self.myParam )
+ nFeat = nFeat * len( unique )
+ for i in unique:
+ hull = []
+ first = True
+ outID = 0
+ idVar = atMap[ self.myParam ]
+ if idVar.toString().trimmed() == i.toString().trimmed():
+ if first:
+ outID = idVar
+ first = False
+ points = ftools_utils.extractPoints( inGeom )
+ hull.extend( points )
+ nElement += 1
+ if len( hull ) >= 3:
+ tmpGeom = QgsGeometry( outGeom.fromMultiPoint( hull ) )
+ try:
+ outGeom = tmpGeom.convexHull()
+ (area, perim) = self.simpleMeasure( outGeom )
+ outFeat.addAttribute( 0, QVariant( outID ) )
+ outFeat.addAttribute( 1, QVariant( area ) )
+ outFeat.addAttribute( 2, QVariant( perim ) )
+ except:
+ continue
+ else:
hull = []
- first = True
- outID = 0
- vproviderA.select( allAttrsA )
+ nElement += 1
+ try:
+ except:
+ else:
+ if useField:
+ for i in unique:
+ hull = []
+ first = True
+ outID = 0
+ vproviderA.select( allAttrsA )
+ if first:
+ outID = idVar
+ first = False
+ nElement += 1
+ try:
+ except:
+ continue
+ else:
+ hull = []
vproviderA.rewind()
- idVar = atMap[ self.myParam ]
- if idVar.toString().trimmed() == i.toString().trimmed():
- if first:
- outID = idVar
- first = False
- points = ftools_utils.extractPoints( inGeom )
- hull.extend( points )
nElement += 1
- if len( hull ) >= 3:
- tmpGeom = QgsGeometry( outGeom.fromMultiPoint( hull ) )
- try:
- outGeom = tmpGeom.convexHull()
- (area, perim) = self.simpleMeasure( outGeom )
- outFeat.addAttribute( 0, QVariant( outID ) )
- outFeat.addAttribute( 1, QVariant( area ) )
- outFeat.addAttribute( 2, QVariant( perim ) )
- except:
- continue
- else:
- hull = []
- nElement = 0
- nElement += 1
- try:
- except:
+ try:
+ except:
del writer
def dissolve( self, useField ):
GEOS_EXCEPT = True
@@ -389,69 +542,132 @@
vproviderA.rewind()
nElement = 0
- if not useField:
- first = True
- add = True
- nElement += 1
- if first:
- attrs = inFeat.attributeMap()
- tmpInGeom = QgsGeometry( inFeat.geometry() )
- outFeat.setGeometry( tmpInGeom )
- first = False
- else:
- tmpOutGeom = QgsGeometry( outFeat.geometry() )
- try:
- tmpOutGeom = QgsGeometry( tmpOutGeom.combine( tmpInGeom ) )
- outFeat.setGeometry( tmpOutGeom )
- except:
- continue
- outFeat.setAttributeMap( attrs )
+ if not useField:
+ first = True
+ nElement += 1
+ if first:
+ attrs = inFeat.attributeMap()
+ tmpInGeom = QgsGeometry( inFeat.geometry() )
+ outFeat.setGeometry( tmpInGeom )
+ first = False
+ else:
+ tmpOutGeom = QgsGeometry( outFeat.geometry() )
+ try:
+ tmpOutGeom = QgsGeometry( tmpOutGeom.combine( tmpInGeom ) )
+ outFeat.setGeometry( tmpOutGeom )
+ except:
+ continue
+ outFeat.setAttributeMap( attrs )
+ else:
+ unique = vproviderA.uniqueValues( int( self.myParam ) )
+ for item in unique:
+ first = True
+ add = False
+ nElement += 1
+ tempItem = atMap[ self.myParam ]
+ if tempItem.toString().trimmed() == item.toString().trimmed():
+ add = True
+ if first:
+ QgsGeometry( inFeat.geometry() )
+ first = False
+ else:
+ try:
+ except:
+ add = False
+ if add:
else:
- unique = vproviderA.uniqueValues( int( self.myParam ) )
- nFeat = nFeat * len( unique )
- for item in unique:
+ if not useField:
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
first = True
- add = True
nElement += 1
- tempItem = atMap[ self.myParam ]
- if tempItem.toString().trimmed() == item.toString().trimmed():
- if first:
- QgsGeometry( inFeat.geometry() )
- first = False
- else:
- try:
- except:
- add = False
- if add:
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ continue
+ else:
+ first = True
+ add = True
+ nElement += 1
+ if first:
+ first = False
+ else:
+ try:
+ except:
+ add = False
+ if add:
del writer
def difference( self ):
GEOS_EXCEPT = True
@@ -470,40 +686,140 @@
inFeatB = QgsFeature()
index = ftools_utils.createIndex( vproviderB )
nElement = 0
- while vproviderA.nextFeature( inFeatA ):
- nElement += 1
- add = True
- geom = QgsGeometry( inFeatA.geometry() )
- diff_geom = QgsGeometry( geom )
- atMap = inFeatA.attributeMap()
- intersects = index.intersects( geom.boundingBox() )
- for id in intersects:
- vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
- tmpGeom = QgsGeometry( inFeatB.geometry() )
- try:
- if diff_geom.intersects( tmpGeom ):
- diff_geom = QgsGeometry( diff_geom.difference( tmpGeom ) )
- except:
- add = False
- break
- if add:
- try:
- outFeat.setGeometry( diff_geom )
- except:
- continue
+ # we have selection in overlay layer
+ if self.mySelectionB:
+ selectionB = self.vlayerB.selectedFeaturesIds()
+ for inFeatA in selectionA:
+ nElement += 1
+ add = True
+ geom = QgsGeometry( inFeatA.geometry() )
+ diff_geom = QgsGeometry( geom )
+ atMap = inFeatA.attributeMap()
+ intersects = index.intersects( geom.boundingBox() )
+ for id in intersects:
+ # is intersect feature in selection
+ if id in selectionB:
+ vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
+ tmpGeom = QgsGeometry( inFeatB.geometry() )
+ try:
+ if diff_geom.intersects( tmpGeom ):
+ diff_geom = QgsGeometry( diff_geom.difference( tmpGeom ) )
+ except:
+ add = False
+ break
+ if add:
+ try:
+ outFeat.setGeometry( diff_geom )
+ except:
+ continue
+ # we have no selection in overlay layer
+ else:
+ nElement += 1
+ add = True
+ try:
+ except:
+ add = False
+ break
+ if add:
+ try:
+ except:
+ continue
+ else:
+ while vproviderA.nextFeature( inFeatA ):
+ nElement += 1
+ add = True
+ # now check if id in selection
+ try:
+ except:
+ add = False
+ break
+ if add:
+ try:
+ except:
+ continue
+ else:
+ nElement += 1
+ add = True
+ try:
+ except:
+ add = False
+ break
+ if add:
+ try:
+ except:
+ continue
del writer
return GEOS_EXCEPT, FEATURE_EXCEPT, crs_match
def intersect( self ):
GEOS_EXCEPT = True
@@ -522,41 +838,142 @@
nElement = 0
- nElement += 1
- atMapA = inFeatA.attributeMap()
- try:
- if geom.intersects( tmpGeom ):
- atMapB = inFeatB.attributeMap()
- int_geom = QgsGeometry( geom.intersection( tmpGeom ) )
- if int_geom.wkbType() == 7:
- int_com = geom.combine( tmpGeom )
- int_sym = geom.symDifference( tmpGeom )
- int_geom = QgsGeometry( int_com.difference( int_sym ) )
+ nElement += 1
+ atMapA = inFeatA.attributeMap()
+ try:
+ if geom.intersects( tmpGeom ):
+ atMapB = inFeatB.attributeMap()
+ int_geom = QgsGeometry( geom.intersection( tmpGeom ) )
+ if int_geom.wkbType() == 7:
+ int_com = geom.combine( tmpGeom )
+ int_sym = geom.symDifference( tmpGeom )
+ int_geom = QgsGeometry( int_com.difference( int_sym ) )
+ try:
+ outFeat.setGeometry( int_geom )
+ outFeat.setAttributeMap( ftools_utils.combineVectorAttributes( atMapA, atMapB ) )
+ except:
+ continue
+ except:
+ break
+ # we don't have selection in overlay layer
+ else:
+ nElement += 1
try:
- outFeat.setGeometry( int_geom )
- outFeat.setAttributeMap( ftools_utils.combineVectorAttributes( atMapA, atMapB ) )
+ try:
+ except:
+ EATURE_EXCEPT = False
+ continue
except:
- continue
- except:
- break
+ break
+ else:
+ nElement += 1
+ try:
+ try:
+ except:
+ continue
+ except:
+ break
+ else:
+ nElement += 1
+ try:
+ try:
+ except:
+ continue
+ except:
+ break
del writer
def union( self ):
GEOS_EXCEPT = True
@@ -582,7 +999,7 @@
vproviderA.rewind()
nElement += 1
found = False
@@ -672,7 +1089,7 @@
nElement += 1
del writer
def symetrical_difference( self ):
GEOS_EXCEPT = True
@@ -699,7 +1116,7 @@
vproviderA.rewind()
nElement += 1
add = True
@@ -727,7 +1144,7 @@
vproviderB.rewind()
while vproviderB.nextFeature( inFeatA ):
nElement += 1
add = True
@@ -754,7 +1171,7 @@
continue
del writer
def clip( self ):
GEOS_EXCEPT = True
@@ -773,37 +1190,136 @@
nElement = 0
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
- nElement += 1
- try:
+ nElement += 1
+ try:
+ try:
+ except:
+ continue
+ except:
+ break
+ else:
+ nElement += 1
try:
+ try:
+ except:
+ continue
except:
- continue
- except:
- break
+ break
+ else:
+ nElement += 1
+ try:
+ try:
+ except:
+ continue
+ except:
+ break
+ else:
+ nElement += 1
+ try:
+ try:
+ except:
+ continue
+ except:
+ break
del writer
@@ -850,7 +1366,7 @@
attr2 = pt.y()
else:
measure = QgsDistanceArea()
- attr1 = measure.measure(inGeom)
+ attr1 = measure.measure(inGeom)
if inGeom.type() == QGis.Polygon:
attr2 = self.perimMeasure( inGeom, measure )
else:
Modified: trunk/qgis/python/plugins/fTools/tools/doVisual.py
--- trunk/qgis/python/plugins/fTools/tools/doVisual.py 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/doVisual.py 2009-05-26 18:07:37 UTC (rev 10849)
@@ -38,31 +38,42 @@
changedField = changedLayer.dataProvider().fields()
+ # for Basic statistics (with or without selection)
+ if self.myFunction == 3:
+ self.useSelected.setCheckState( Qt.Checked )
+ else:
+ self.useSelected.setCheckState( Qt.Unchecked )
+ # add all fields in combobox because now we can work with text fields too
for i in changedField:
if changedField[i].type() == QVariant.Int or changedField[i].type() == QVariant.Double:
self.cmbField.addItem( unicode( changedField[i].name() ) )
else:
+ self.cmbField.addItem( unicode( changedField[i].name() ) )
def accept( self ):
if self.inShape.currentText() == "":
QMessageBox.information( self, "Error!", self.tr( "Please specify input vector layer" ) )
elif self.cmbField.isVisible() and self.cmbField.currentText() == "":
QMessageBox.information( self, "Error!", self.tr( "Please specify input field" ) )
else:
- self.visual( self.inShape.currentText(), self.cmbField.currentText() )
+ self.visual( self.inShape.currentText(), self.cmbField.currentText(), self.useSelected.checkState() )
if self.myFunction == 1: # Check geometry validity
self.setWindowTitle( self.tr( "Check geometry validity" ) )
self.cmbField.setVisible( False )
self.label.setVisible( False )
+ self.useSelected.setVisible( False )
self.label_2.setText( self.tr( "Geometry errors" ) )
self.label_4.setText( self.tr( "Total encountered errors" ) )
elif self.myFunction == 2: # List unique values
self.setWindowTitle( self.tr( "List unique values" ) )
self.label_2.setText( self.tr( "Unique values" ) )
self.label_4.setText(self.tr( "Total unique values" ) )
elif self.myFunction == 3: # Basic statistics
self.setWindowTitle( self.tr( "Basics statistics" ) )
self.label_2.setText( self.tr( "Statistics output" ) )
@@ -73,6 +84,7 @@
self.setWindowTitle( self.tr( "Nearest neighbour analysis" ) )
self.label_2.setText( self.tr( "Nearest neighbour statistics" ) )
self.label_4.setVisible( False )
self.lstCount.setVisible( False )
@@ -91,11 +103,11 @@
#2: List unique values
#3: Basic statistics
#4: Nearest neighbour analysis
- def visual( self, myLayer, myField ):
+ def visual( self, myLayer, myField, mySelection ):
vlayer = ftools_utils.getVectorLayerByName( myLayer )
self.lstUnique.clear()
self.lstCount.clear()
- self.testThread = visualThread( self.iface.mainWindow(), self, self.myFunction, vlayer, myField )
+ self.testThread = visualThread( self.iface.mainWindow(), self, self.myFunction, vlayer, myField, mySelection )
@@ -122,13 +134,14 @@
class visualThread( QThread ):
- def __init__( self, parentThread, parentObject, function, vlayer, myField ):
+ def __init__( self, parentThread, parentObject, function, vlayer, myField, mySelection ):
self.vlayer = vlayer
self.myField = myField
+ self.mySelection = mySelection
# self.total = 0
# self.currentCount = 0
@@ -176,46 +189,127 @@
feat = QgsFeature()
sumVal = 0.0
meanVal = 0.0
- stdVal = 0.0
- cvVal = 0.0
nVal = 0.0
values = []
first = True
- nFeat = vprovider.featureCount()
nElement = 0
- while vprovider.nextFeature( feat ):
- atMap = feat.attributeMap()
- value = float( atMap[ index ].toDouble()[ 0 ] )
- if first:
- minVal = value
- maxVal = value
- first = False
- else:
- if value < minVal: minVal = value
- if value > maxVal: maxVal = value
- values.append( value )
- sumVal = float( sumVal + value )
- nElement += 1
- nVal= float( len( values ) )
- if nVal > 0.00:
- meanVal = float( sumVal ) / nVal
- if not meanVal == 0.00:
- for val in values:
- stdVal += float( ( val - meanVal ) * ( val - meanVal ) )
- stdVal = float( math.sqrt( stdVal / nVal ) )
- cvVal = float( stdVal / meanVal )
- lstStats = []
- lstStats.append( "Mean : " + unicode( meanVal ) )
- lstStats.append( "StdDev : " + unicode( stdVal ) )
- lstStats.append( "Sum : " + unicode( sumVal) )
- lstStats.append( "Min : " + unicode( minVal ) )
- lstStats.append( "Max : " + unicode( maxVal ) )
- lstStats.append( "N : " + unicode( nVal ) )
- lstStats.append( "CV : " + unicode( cvVal ) )
- return ( lstStats, [] )
+ # determine selected field type
+ if ftools_utils.getFieldType( vlayer, myField ) == 'String':
+ fillVal = 0
+ emptyVal = 0
+ if self.mySelection: # only selected features
+ selection = vlayer.selectedFeatures()
+ nFeat = vlayer.selectedFeatureCount()
+ for f in selection:
+ atMap = f.attributeMap()
+ lenVal = float( len( atMap[ index ].toString() ) )
+ if first:
+ minVal = lenVal
+ maxVal = lenVal
+ first = False
+ else:
+ if lenVal < minVal: minVal = lenVal
+ if lenVal > maxVal: maxVal = lenVal
+ if lenVal != 0.00:
+ fillVal += 1
+ else:
+ emptyVal += 1
+ values.append( lenVal )
+ sumVal = sumVal + lenVal
+ nElement += 1
+ else: # there is no selection, process the whole layer
+ nFeat = vprovider.featureCount()
+ while vprovider.nextFeature( feat ):
+ atMap = feat.attributeMap()
+ if first:
+ minVal = lenVal
+ maxVal = lenVal
+ first = False
+ else:
+ fillVal += 1
+ else:
+ emptyVal += 1
+ nElement += 1
+ nVal= float( len( values ) )
+ if nVal > 0.00:
+ meanVal = sumVal / nVal
+ lstStats = []
+ lstStats.append( QCoreApplication.translate( "statResult", "Max. len. : " ) + unicode( maxVal ) )
+ lstStats.append( QCoreApplication.translate( "statResult", "Min. len. : " ) + unicode( minVal ) )
+ lstStats.append( QCoreApplication.translate( "statResult", "Mean. len : " ) + unicode( meanVal ) )
+ lstStats.append( QCoreApplication.translate( "statResult", "Filled : " ) + unicode( fillVal ) )
+ lstStats.append( QCoreApplication.translate( "statResult", "Empty : " ) + unicode( emptyVal ) )
+ lstStats.append( QCoreApplication.translate( "statResult", "N : " ) + unicode( nVal ) )
+ return ( lstStats, [] )
+ else: # numeric field
+ stdVal = 0
+ cvVal = 0
+ value = float( atMap[ index ].toDouble()[ 0 ] )
+ if first:
+ minVal = value
+ maxVal = value
+ first = False
+ else:
+ if value < minVal: minVal = value
+ if value > maxVal: maxVal = value
+ values.append( value )
+ sumVal = sumVal + value
+ nElement += 1
+ if first:
+ minVal = value
+ maxVal = value
+ first = False
+ else:
+ nElement += 1
+ if nVal > 0.00:
+ if meanVal != 0.00:
+ for val in values:
+ stdVal += ( ( val - meanVal ) * ( val - meanVal ) )
+ stdVal = math.sqrt( stdVal / nVal )
+ cvVal = stdVal / meanVal
+ lstStats = []
+ lstStats.append( "Mean : " + unicode( meanVal ) )
+ lstStats.append( "StdDev : " + unicode( stdVal ) )
+ lstStats.append( "Sum : " + unicode( sumVal) )
+ lstStats.append( "Min : " + unicode( minVal ) )
+ lstStats.append( "Max : " + unicode( maxVal ) )
+ lstStats.append( "N : " + unicode( nVal ) )
+ lstStats.append( "CV : " + unicode( cvVal ) )
def nearest_neighbour_analysis( self, vlayer ):
vprovider = vlayer.dataProvider()
Modified: trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.py
--- trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.py 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.py 2009-05-26 18:07:37 UTC (rev 10849)
@@ -2,8 +2,8 @@
# Form implementation generated from reading ui file 'frmGeoprocessing.ui'
-# Created: Thu Nov 13 23:17:35 2008
-# by: PyQt4 UI code generator 4.3.3
+# Created: Tue May 26 19:00:00 2009
+# by: PyQt4 UI code generator 4.4.4
# WARNING! All changes made in this file will be lost!
@@ -12,69 +12,54 @@
class Ui_Dialog(object):
def setupUi(self, Dialog):
Dialog.setObjectName("Dialog")
- Dialog.resize(QtCore.QSize(QtCore.QRect(0,0,422,405).size()).expandedTo(Dialog.minimumSizeHint()))
- sizePolicy = QtGui.QSizePolicy(QtGui.QSizePolicy.Minimum,QtGui.QSizePolicy.Preferred)
+ Dialog.resize(422, 405)
+ sizePolicy = QtGui.QSizePolicy(QtGui.QSizePolicy.Minimum, QtGui.QSizePolicy.Preferred)
sizePolicy.setHorizontalStretch(0)
sizePolicy.setVerticalStretch(0)
sizePolicy.setHeightForWidth(Dialog.sizePolicy().hasHeightForWidth())
Dialog.setSizePolicy(sizePolicy)
- self.gridlayout = QtGui.QGridLayout(Dialog)
- self.gridlayout.setObjectName("gridlayout")
+ self.gridLayout = QtGui.QGridLayout(Dialog)
+ self.gridLayout.setObjectName("gridLayout")
self.vboxlayout = QtGui.QVBoxLayout()
self.vboxlayout.setObjectName("vboxlayout")
self.label_1 = QtGui.QLabel(Dialog)
self.label_1.setObjectName("label_1")
self.vboxlayout.addWidget(self.label_1)
self.inShapeA = QtGui.QComboBox(Dialog)
- sizePolicy = QtGui.QSizePolicy(QtGui.QSizePolicy.Minimum,QtGui.QSizePolicy.Fixed)
+ sizePolicy = QtGui.QSizePolicy(QtGui.QSizePolicy.Minimum, QtGui.QSizePolicy.Fixed)
sizePolicy.setHeightForWidth(self.inShapeA.sizePolicy().hasHeightForWidth())
self.inShapeA.setSizePolicy(sizePolicy)
self.inShapeA.setObjectName("inShapeA")
self.vboxlayout.addWidget(self.inShapeA)
- self.gridlayout.addLayout(self.vboxlayout,0,0,1,2)
+ self.gridLayout.addLayout(self.vboxlayout, 0, 0, 1, 2)
self.vboxlayout1 = QtGui.QVBoxLayout()
self.vboxlayout1.setObjectName("vboxlayout1")
self.label_2 = QtGui.QLabel(Dialog)
self.label_2.setObjectName("label_2")
self.vboxlayout1.addWidget(self.label_2)
self.inShapeB = QtGui.QComboBox(Dialog)
sizePolicy.setHeightForWidth(self.inShapeB.sizePolicy().hasHeightForWidth())
self.inShapeB.setSizePolicy(sizePolicy)
self.inShapeB.setObjectName("inShapeB")
self.vboxlayout1.addWidget(self.inShapeB)
- self.gridlayout.addLayout(self.vboxlayout1,1,0,1,2)
+ self.gridLayout.addLayout(self.vboxlayout1, 3, 0, 1, 2)
self.hboxlayout = QtGui.QHBoxLayout()
self.hboxlayout.setObjectName("hboxlayout")
self.hboxlayout1 = QtGui.QHBoxLayout()
self.hboxlayout1.setObjectName("hboxlayout1")
self.rdoBuffer = QtGui.QRadioButton(Dialog)
self.rdoBuffer.setChecked(True)
self.rdoBuffer.setObjectName("rdoBuffer")
self.hboxlayout1.addWidget(self.rdoBuffer)
self.hboxlayout.addLayout(self.hboxlayout1)
self.param = QtGui.QLineEdit(Dialog)
self.param.setEnabled(True)
sizePolicy.setHeightForWidth(self.param.sizePolicy().hasHeightForWidth())
@@ -83,90 +68,85 @@
self.param.setCursorPosition(0)
self.param.setObjectName("param")
self.hboxlayout.addWidget(self.param)
- self.gridlayout.addLayout(self.hboxlayout,2,0,1,2)
+ self.gridLayout.addLayout(self.hboxlayout, 5, 0, 1, 2)
self.vboxlayout2 = QtGui.QVBoxLayout()
self.vboxlayout2.setObjectName("vboxlayout2")
self.hboxlayout2 = QtGui.QHBoxLayout()
self.hboxlayout2.setObjectName("hboxlayout2")
self.rdoField = QtGui.QRadioButton(Dialog)
self.rdoField.setObjectName("rdoField")
self.hboxlayout2.addWidget(self.rdoField)
self.label_4 = QtGui.QLabel(Dialog)
self.label_4.setObjectName("label_4")
self.hboxlayout2.addWidget(self.label_4)
- spacerItem = QtGui.QSpacerItem(40,20,QtGui.QSizePolicy.Expanding,QtGui.QSizePolicy.Minimum)
+ spacerItem = QtGui.QSpacerItem(40, 20, QtGui.QSizePolicy.Expanding, QtGui.QSizePolicy.Minimum)
self.hboxlayout2.addItem(spacerItem)
self.vboxlayout2.addLayout(self.hboxlayout2)
self.attrib = QtGui.QComboBox(Dialog)
self.attrib.setEnabled(False)
sizePolicy.setHeightForWidth(self.attrib.sizePolicy().hasHeightForWidth())
self.attrib.setSizePolicy(sizePolicy)
self.attrib.setObjectName("attrib")
self.vboxlayout2.addWidget(self.attrib)
- self.gridlayout.addLayout(self.vboxlayout2,3,0,1,2)
+ self.gridLayout.addLayout(self.vboxlayout2, 6, 0, 1, 2)
self.hboxlayout3 = QtGui.QHBoxLayout()
self.hboxlayout3.setSpacing(6)
self.hboxlayout3.setMargin(0)
self.hboxlayout3.setObjectName("hboxlayout3")
self.mergeOutput = QtGui.QCheckBox(Dialog)
self.mergeOutput.setEnabled(True)
self.mergeOutput.setObjectName("mergeOutput")
self.hboxlayout3.addWidget(self.mergeOutput)
- self.gridlayout.addLayout(self.hboxlayout3,4,0,1,1)
- spacerItem1 = QtGui.QSpacerItem(20,40,QtGui.QSizePolicy.Minimum,QtGui.QSizePolicy.Expanding)
- self.gridlayout.addItem(spacerItem1,5,0,1,1)
+ self.gridLayout.addLayout(self.hboxlayout3, 7, 0, 1, 1)
+ spacerItem1 = QtGui.QSpacerItem(20, 40, QtGui.QSizePolicy.Minimum, QtGui.QSizePolicy.Expanding)
+ self.gridLayout.addItem(spacerItem1, 8, 0, 1, 1)
self.vboxlayout3 = QtGui.QVBoxLayout()
self.vboxlayout3.setObjectName("vboxlayout3")
self.label_5 = QtGui.QLabel(Dialog)
self.label_5.setObjectName("label_5")
self.vboxlayout3.addWidget(self.label_5)
self.hboxlayout4 = QtGui.QHBoxLayout()
self.hboxlayout4.setObjectName("hboxlayout4")
self.outShape = QtGui.QLineEdit(Dialog)
self.outShape.setReadOnly(True)
self.outShape.setObjectName("outShape")
self.hboxlayout4.addWidget(self.outShape)
self.btnBrowse = QtGui.QPushButton(Dialog)
self.btnBrowse.setObjectName("btnBrowse")
self.hboxlayout4.addWidget(self.btnBrowse)
self.vboxlayout3.addLayout(self.hboxlayout4)
- self.gridlayout.addLayout(self.vboxlayout3,6,0,1,2)
+ self.gridLayout.addLayout(self.vboxlayout3, 9, 0, 1, 2)
self.progressBar = QtGui.QProgressBar(Dialog)
- self.progressBar.setProperty("value",QtCore.QVariant(0))
+ self.progressBar.setProperty("value", QtCore.QVariant(0))
self.progressBar.setAlignment(QtCore.Qt.AlignCenter)
self.progressBar.setOrientation(QtCore.Qt.Horizontal)
self.progressBar.setObjectName("progressBar")
- self.gridlayout.addWidget(self.progressBar,7,0,1,1)
+ self.gridLayout.addWidget(self.progressBar, 10, 0, 1, 1)
self.buttonBox_2 = QtGui.QDialogButtonBox(Dialog)
self.buttonBox_2.setStandardButtons(QtGui.QDialogButtonBox.Close|QtGui.QDialogButtonBox.Ok)
self.buttonBox_2.setObjectName("buttonBox_2")
- self.gridlayout.addWidget(self.buttonBox_2,7,1,1,1)
+ self.gridLayout.addWidget(self.buttonBox_2, 10, 1, 1, 1)
+ self.verticalLayout = QtGui.QVBoxLayout()
+ self.verticalLayout.setObjectName("verticalLayout")
+ self.useSelectedA = QtGui.QCheckBox(Dialog)
+ self.useSelectedA.setObjectName("useSelectedA")
+ self.verticalLayout.addWidget(self.useSelectedA)
+ self.gridLayout.addLayout(self.verticalLayout, 2, 0, 1, 1)
+ self.verticalLayout_2 = QtGui.QVBoxLayout()
+ self.verticalLayout_2.setObjectName("verticalLayout_2")
+ self.useSelectedB = QtGui.QCheckBox(Dialog)
+ self.useSelectedB.setObjectName("useSelectedB")
+ self.verticalLayout_2.addWidget(self.useSelectedB)
+ self.gridLayout.addLayout(self.verticalLayout_2, 4, 0, 1, 1)
self.retranslateUi(Dialog)
- QtCore.QObject.connect(self.rdoField,QtCore.SIGNAL("toggled(bool)"),self.attrib.setEnabled)
- QtCore.QObject.connect(self.rdoBuffer,QtCore.SIGNAL("toggled(bool)"),self.param.setEnabled)
- QtCore.QObject.connect(self.buttonBox_2,QtCore.SIGNAL("rejected()"),Dialog.reject)
- QtCore.QObject.connect(self.buttonBox_2,QtCore.SIGNAL("accepted()"),Dialog.accept)
+ QtCore.QObject.connect(self.rdoField, QtCore.SIGNAL("toggled(bool)"), self.attrib.setEnabled)
+ QtCore.QObject.connect(self.rdoBuffer, QtCore.SIGNAL("toggled(bool)"), self.param.setEnabled)
+ QtCore.QObject.connect(self.buttonBox_2, QtCore.SIGNAL("rejected()"), Dialog.reject)
+ QtCore.QObject.connect(self.buttonBox_2, QtCore.SIGNAL("accepted()"), Dialog.accept)
QtCore.QMetaObject.connectSlotsByName(Dialog)
def retranslateUi(self, Dialog):
@@ -179,4 +159,6 @@
self.mergeOutput.setText(QtGui.QApplication.translate("Dialog", "Dissolve buffer results", None, QtGui.QApplication.UnicodeUTF8))
self.label_5.setText(QtGui.QApplication.translate("Dialog", "Output shapefile", None, QtGui.QApplication.UnicodeUTF8))
self.btnBrowse.setText(QtGui.QApplication.translate("Dialog", "Browse", None, QtGui.QApplication.UnicodeUTF8))
+ self.useSelectedA.setText(QtGui.QApplication.translate("Dialog", "Use only selected features", None, QtGui.QApplication.UnicodeUTF8))
+ self.useSelectedB.setText(QtGui.QApplication.translate("Dialog", "Use only selected features", None, QtGui.QApplication.UnicodeUTF8))
Modified: trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.ui
--- trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.ui 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/frmGeoprocessing.ui 2009-05-26 18:07:37 UTC (rev 10849)
@@ -40,7 +40,7 @@
</item>
</layout>
</item>
- <item row="1" column="0" colspan="2" >
+ <item row="3" column="0" colspan="2" >
<layout class="QVBoxLayout" >
<item>
<widget class="QLabel" name="label_2" >
@@ -61,7 +61,7 @@
</item>
</layout>
</item>
- <item row="2" column="0" colspan="2" >
+ <item row="5" column="0" colspan="2" >
<layout class="QHBoxLayout" >
<item>
@@ -101,7 +101,7 @@
</item>
</layout>
</item>
- <item row="3" column="0" colspan="2" >
+ <item row="6" column="0" colspan="2" >
<item>
@@ -149,7 +149,7 @@
</item>
</layout>
</item>
- <item row="4" column="0" >
+ <item row="7" column="0" >
<property name="spacing" >
<number>6</number>
@@ -169,7 +169,7 @@
</item>
</layout>
</item>
- <item row="5" column="0" >
+ <item row="8" column="0" >
<spacer>
<property name="orientation" >
<enum>Qt::Vertical</enum>
@@ -182,7 +182,7 @@
</property>
</spacer>
</item>
- <item row="6" column="0" colspan="2" >
+ <item row="9" column="0" colspan="2" >
<item>
<widget class="QLabel" name="label_5" >
@@ -211,7 +211,7 @@
</item>
</layout>
</item>
- <item row="7" column="0" >
+ <item row="10" column="0" >
<widget class="QProgressBar" name="progressBar" >
<property name="value" >
<number>0</number>
@@ -224,13 +224,35 @@
</property>
</widget>
</item>
- <item row="7" column="1" >
+ <item row="10" column="1" >
<widget class="QDialogButtonBox" name="buttonBox_2" >
<property name="standardButtons" >
<set>QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
+ <item row="2" column="0" >
+ <layout class="QVBoxLayout" name="verticalLayout" >
+ <item>
+ <widget class="QCheckBox" name="useSelectedA" >
+ <property name="text" >
+ <string>Use only selected features</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="4" column="0" >
+ <layout class="QVBoxLayout" name="verticalLayout_2" >
+ <item>
+ <widget class="QCheckBox" name="useSelectedB" >
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</widget>
<resources/>
Modified: trunk/qgis/python/plugins/fTools/tools/frmVisual.py
--- trunk/qgis/python/plugins/fTools/tools/frmVisual.py 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/frmVisual.py 2009-05-26 18:07:37 UTC (rev 10849)
@@ -2,8 +2,8 @@
# Form implementation generated from reading ui file 'frmVisual.ui'
-# Created: Tue Apr 21 15:10:47 2009
-# by: PyQt4 UI code generator 4.4.3
+# Created: Tue May 26 18:55:54 2009
@@ -13,7 +13,7 @@
Dialog.setWindowModality(QtCore.Qt.NonModal)
- Dialog.resize(374, 485)
+ Dialog.resize(404, 485)
Dialog.setSizeGripEnabled(True)
@@ -34,7 +34,7 @@
self.cmbField = QtGui.QComboBox(Dialog)
self.cmbField.setObjectName("cmbField")
self.vboxlayout1.addWidget(self.cmbField)
- self.gridLayout.addLayout(self.vboxlayout1, 1, 0, 1, 2)
+ self.gridLayout.addLayout(self.vboxlayout1, 4, 0, 1, 2)
@@ -49,7 +49,7 @@
self.lstUnique.setSelectionRectVisible(True)
self.lstUnique.setObjectName("lstUnique")
self.vboxlayout2.addWidget(self.lstUnique)
- self.gridLayout.addLayout(self.vboxlayout2, 2, 0, 1, 2)
+ self.gridLayout.addLayout(self.vboxlayout2, 5, 0, 1, 2)
@@ -59,17 +59,23 @@
self.lstCount.setReadOnly(True)
self.lstCount.setObjectName("lstCount")
self.hboxlayout.addWidget(self.lstCount)
- self.gridLayout.addLayout(self.hboxlayout, 3, 0, 1, 2)
+ self.gridLayout.addLayout(self.hboxlayout, 6, 0, 1, 2)
self.progressBar.setProperty("value", QtCore.QVariant(24))
- self.gridLayout.addWidget(self.progressBar, 4, 0, 1, 1)
+ self.gridLayout.addWidget(self.progressBar, 7, 0, 1, 1)
self.buttonBox_2.setOrientation(QtCore.Qt.Horizontal)
- self.gridLayout.addWidget(self.buttonBox_2, 4, 1, 1, 1)
+ self.gridLayout.addWidget(self.buttonBox_2, 7, 1, 1, 1)
+ self.useSelected = QtGui.QCheckBox(Dialog)
+ self.useSelected.setObjectName("useSelected")
+ self.verticalLayout.addWidget(self.useSelected)
+ self.gridLayout.addLayout(self.verticalLayout, 3, 0, 1, 1)
@@ -83,4 +89,5 @@
self.label_2.setText(QtGui.QApplication.translate("Dialog", "Unique values list", None, QtGui.QApplication.UnicodeUTF8))
self.lstUnique.setSortingEnabled(True)
self.label_4.setText(QtGui.QApplication.translate("Dialog", "Unique value count", None, QtGui.QApplication.UnicodeUTF8))
+ self.useSelected.setText(QtGui.QApplication.translate("Dialog", "Use only selected features", None, QtGui.QApplication.UnicodeUTF8))
Modified: trunk/qgis/python/plugins/fTools/tools/frmVisual.ui
--- trunk/qgis/python/plugins/fTools/tools/frmVisual.ui 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/frmVisual.ui 2009-05-26 18:07:37 UTC (rev 10849)
@@ -1,126 +1,138 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>Dialog</class>
- <widget class="QDialog" name="Dialog" >
- <property name="windowModality" >
+ <widget class="QDialog" name="Dialog">
+ <property name="windowModality">
<enum>Qt::NonModal</enum>
</property>
- <property name="geometry" >
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
- <width>374</width>
+ <width>404</width>
<height>485</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>List Unique Values</string>
</property>
- <property name="sizeGripEnabled" >
+ <property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <layout class="QGridLayout" name="gridLayout" >
- <item row="0" column="0" colspan="2" >
- <layout class="QVBoxLayout" >
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0" colspan="2">
+ <layout class="QVBoxLayout">
<item>
- <widget class="QLabel" name="label_3" >
- <property name="text" >
+ <widget class="QLabel" name="label_3">
+ <property name="text">
<string>Input Vector Layer</string>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="inShape" />
+ <widget class="QComboBox" name="inShape"/>
</item>
</layout>
</item>
+ <item row="4" column="0" colspan="2">
<item>
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
<string>Target field</string>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="cmbField" />
+ <widget class="QComboBox" name="cmbField"/>
</item>
</layout>
</item>
+ <item row="5" column="0" colspan="2">
<item>
- <widget class="QLabel" name="label_2" >
+ <widget class="QLabel" name="label_2">
<string>Unique values list</string>
</property>
</widget>
</item>
<item>
- <widget class="QListWidget" name="lstUnique" >
- <property name="editTriggers" >
+ <widget class="QListWidget" name="lstUnique">
+ <property name="editTriggers">
<set>QAbstractItemView::NoEditTriggers</set>
</property>
- <property name="showDropIndicator" stdset="0" >
+ <property name="showDropIndicator" stdset="0">
<bool>false</bool>
</property>
- <property name="alternatingRowColors" >
+ <property name="alternatingRowColors">
<bool>true</bool>
</property>
- <property name="selectionMode" >
+ <property name="selectionMode">
<enum>QAbstractItemView::ExtendedSelection</enum>
</property>
- <property name="selectionBehavior" >
+ <property name="selectionBehavior">
<enum>QAbstractItemView::SelectRows</enum>
</property>
- <property name="selectionRectVisible" >
+ <property name="selectionRectVisible">
<bool>true</bool>
</property>
- <property name="sortingEnabled" >
+ <property name="sortingEnabled">
<bool>true</bool>
</property>
</widget>
</item>
</layout>
</item>
- <layout class="QHBoxLayout" >
+ <item row="6" column="0" colspan="2">
+ <layout class="QHBoxLayout">
<item>
- <widget class="QLabel" name="label_4" >
+ <widget class="QLabel" name="label_4">
<string>Unique value count</string>
</property>
</widget>
</item>
<item>
- <widget class="QLineEdit" name="lstCount" >
- <property name="readOnly" >
+ <widget class="QLineEdit" name="lstCount">
+ <property name="readOnly">
<bool>true</bool>
</property>
</widget>
</item>
</layout>
</item>
- <widget class="QProgressBar" name="progressBar" >
- <property name="value" >
+ <item row="7" column="0">
+ <widget class="QProgressBar" name="progressBar">
+ <property name="value">
<number>24</number>
</property>
- <property name="alignment" >
+ <property name="alignment">
<set>Qt::AlignCenter</set>
</property>
</widget>
</item>
- <item row="4" column="1" >
- <widget class="QDialogButtonBox" name="buttonBox_2" >
- <property name="orientation" >
+ <item row="7" column="1">
+ <widget class="QDialogButtonBox" name="buttonBox_2">
+ <property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
- <property name="standardButtons" >
+ <property name="standardButtons">
</property>
</widget>
</item>
+ <item row="3" column="0">
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
+ <widget class="QCheckBox" name="useSelected">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</widget>
<resources/>
@@ -131,11 +143,11 @@
<receiver>Dialog</receiver>
<slot>accept()</slot>
<hints>
- <hint type="sourcelabel" >
+ <hint type="sourcelabel">
<x>133</x>
<y>276</y>
</hint>
- <hint type="destinationlabel" >
+ <hint type="destinationlabel">
<x>215</x>
<y>290</y>
</hint>
@@ -147,11 +159,11 @@
<slot>close()</slot>
<hints>
<x>59</x>
<y>276</y>
</hint>
<x>132</x>
<y>239</y>
</hint>
Modified: trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
--- trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2009-05-25 21:05:34 UTC (rev 10848)
+++ trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2009-05-26 18:07:37 UTC (rev 10849)
@@ -19,6 +19,7 @@
# addShapeToCanvas( QString *file path )
# getUniqueValues( QgsVectorDataProvider, int *field id )
# saveDialog( QWidget *parent )
+# getFieldType( QgsVectorLayer, QgsField.name() )
@@ -260,3 +261,9 @@
settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( files.first() ) ).absolutePath() ) )
return ( unicode( files.first() ), unicode( fileDialog.encoding() ) )
+# Return field type from it's name
+def getFieldType(vlayer, fieldName):
+ fields = vlayer.dataProvider().fields()
+ for name, field in fields.iteritems():
+ if field.name() == fieldName:
+ return field.typeName()
