[QGIS Commit] r10866 - trunk/qgis/src/providers/wfs
svn_qgis at osgeo.org
Sun May 31 03:43:16 EDT 2009
Author: mhugent
Date: 2009-05-31 03:43:15 -0400 (Sun, 31 May 2009)
New Revision: 10866
trunk/qgis/src/providers/wfs/qgswfsdata.cpp
trunk/qgis/src/providers/wfs/qgswfsdata.h
trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
Improved handling of attribute types in WFS provider
Modified: trunk/qgis/src/providers/wfs/qgswfsdata.cpp
--- trunk/qgis/src/providers/wfs/qgswfsdata.cpp 2009-05-30 22:17:14 UTC (rev 10865)
+++ trunk/qgis/src/providers/wfs/qgswfsdata.cpp 2009-05-31 07:43:15 UTC (rev 10866)
@@ -36,7 +36,7 @@
QgsCoordinateReferenceSystem* srs,
QList<QgsFeature*> &features,
const QString& geometryAttribute,
- const QSet<QString>& thematicAttributes,
+ const QMap<QString, QPair<int, QgsField> >& thematicAttributes,
QGis::WkbType* wkbType )
: QObject(),
mUri( uri ),
@@ -193,7 +193,6 @@
else if ( elementName == GML_NAMESPACE + NS_SEPARATOR + "featureMember" )
mCurrentFeature = new QgsFeature( mFeatureCount );
- mAttributeIndex = 0;
mParseModeStack.push( QgsWFSData::featureMember );
else if ( elementName == GML_NAMESPACE + NS_SEPARATOR + "Box" && mParseModeStack.top() == QgsWFSData::boundingBox )
@@ -262,15 +261,35 @@
mParseModeStack.pop();
- else if ( localName == mAttributeName )
+ else if ( localName == mAttributeName ) //add a thematic attribute to the feature
if ( !mParseModeStack.empty() )
- mCurrentFeature->addAttribute( mAttributeIndex, QVariant( mStringCash ) );
- ++mAttributeIndex;
+ //find index with attribute name
+ QMap<QString, QPair<int, QgsField> >::const_iterator att_it = mThematicAttributes.find(mAttributeName);
+ if(att_it != mThematicAttributes.constEnd())
+ QVariant var;
+ switch(att_it.value().second.type())
+ case QVariant::Double:
+ var = QVariant(mStringCash.toDouble());
+ break;
+ case QVariant::Int:
+ var = QVariant(mStringCash.toInt());
+ break;
+ case QVariant::LongLong:
+ var = QVariant(mStringCash.toLongLong());
+ break;
+ default: //string type is default
+ var = QVariant( mStringCash );
+ break;
+ mCurrentFeature->addAttribute(att_it.value().first, QVariant( mStringCash ));
else if ( localName == mGeometryAttribute )
Modified: trunk/qgis/src/providers/wfs/qgswfsdata.h
--- trunk/qgis/src/providers/wfs/qgswfsdata.h 2009-05-30 22:17:14 UTC (rev 10865)
+++ trunk/qgis/src/providers/wfs/qgswfsdata.h 2009-05-31 07:43:15 UTC (rev 10866)
@@ -21,6 +21,7 @@
#include "qgsapplication.h"
#include "qgsdataprovider.h"
#include "qgsfeature.h"
+#include "qgsfield.h"
#include "qgspoint.h"
#include <list>
#include <set>
@@ -40,7 +41,7 @@
QGis::WkbType* wkbType );
~QgsWFSData();
@@ -150,7 +151,7 @@
QList<QgsFeature*> &mFeatures;
/**Name of geometry attribute*/
QString mGeometryAttribute;
- const QSet<QString> &mThematicAttributes;
+ const QMap<QString, QPair<int, QgsField> > &mThematicAttributes;
QGis::WkbType* mWkbType;
/**True if the request is finished*/
bool mFinished;
@@ -171,8 +172,6 @@
/**Similar to mCurrentWKB, but only the size*/
std::list< std::list<int> > mCurrentWKBFragmentSizes;
QString mAttributeName;
- /**Index where the current attribute should be inserted*/
- int mAttributeIndex;
QString mTypeName;
QgsApplication::endian_t mEndian;
/**Coordinate separator for coordinate strings. Usually "," */
Modified: trunk/qgis/src/providers/wfs/qgswfsprovider.cpp
--- trunk/qgis/src/providers/wfs/qgswfsprovider.cpp 2009-05-30 22:17:14 UTC (rev 10865)
+++ trunk/qgis/src/providers/wfs/qgswfsprovider.cpp 2009-05-31 07:43:15 UTC (rev 10866)
@@ -234,7 +234,7 @@
int QgsWFSProvider::getFeatureGET( const QString& uri, const QString& geometryAttribute )
-#if 0
+#if 0 //the old and slower method with DOM
//assemble request string
QString request = uri /*+ "&OUTPUTFORMAT=gml3"*/; //use gml2 as it is supported by most wfs servers
QByteArray result;
@@ -265,11 +265,13 @@
return 0;
#endif
- //the new and faster method with the expat parser
- QSet<QString> thematicAttributes;
+ //the new and faster method with the expat SAX parser
+ //allows fast searchings with attribute name. Also needed is attribute Index and type infos
+ QMap<QString, QPair<int, QgsField> > thematicAttributes;
for ( QgsFieldMap::const_iterator it = mFields.begin(); it != mFields.end(); ++it )
- thematicAttributes << it->name();
+ thematicAttributes.insert(it.value().name(), qMakePair(it.key(), it.value()));
QgsWFSData dataReader( uri, &mExtent, &mSourceCRS, mFeatures, geometryAttribute, thematicAttributes, &mWKBType );
@@ -512,7 +514,20 @@
else //todo: distinguish between numerical and non-numerical types
- fields[fields.size()] = QgsField( name, QVariant::String, type );
+ QVariant::Type attributeType = QVariant::String; //string is default type
+ if(type.contains("double", Qt::CaseInsensitive) || type.contains("float", Qt::CaseInsensitive))
+ attributeType = QVariant::Double;
+ else if(type.contains("int", Qt::CaseInsensitive))
+ attributeType = QVariant::Int;
+ else if(type.contains("long", Qt::CaseInsensitive))
+ attributeType = QVariant::LongLong;
+ fields[fields.size()] = QgsField( name, attributeType, type );
return 0;
