[QGIS Commit] r11945 - trunk/qgis/src/plugins/coordinate_capture
svn_qgis at osgeo.org
Sat Nov 7 05:40:53 EST 2009
Author: timlinux
Date: 2009-11-07 05:40:52 -0500 (Sat, 07 Nov 2009)
New Revision: 11945
Added:
trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt
Reinstate ui to prevent compile issues
Modified: trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt
--- trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt 2009-11-07 10:03:58 UTC (rev 11944)
+++ trunk/qgis/src/plugins/coordinate_capture/CMakeLists.txt 2009-11-07 10:40:52 UTC (rev 11945)
@@ -8,6 +8,8 @@
coordinatecapturemaptool.cpp
+SET (coordinatecapture_UIS coordinatecaptureguibase.ui)
SET (coordinatecapture_MOC_HDRS
coordinatecapture.h
coordinatecapturegui.h
@@ -19,6 +21,8 @@
# Build
+QT4_WRAP_UI (coordinatecapture_UIS_H ${coordinatecapture_UIS})
QT4_WRAP_CPP (coordinatecapture_MOC_SRCS ${coordinatecapture_MOC_HDRS})
QT4_ADD_RESOURCES(coordinatecapture_RCC_SRCS ${coordinatecapture_RCCS})
Added: trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
--- trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui (rev 0)
+++ trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui 2009-11-07 10:40:52 UTC (rev 11945)
@@ -0,0 +1,78 @@
+<ui version="4.0" >
+ <class>CoordinateCaptureGuiBase</class>
+ <widget class="QDialog" name="CoordinateCaptureGuiBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>584</width>
+ <height>435</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>QGIS Plugin Template</string>
+ </property>
+ <property name="windowIcon" >
+ <iconset>
+ <normaloff/>
+ </iconset>
+ </property>
+ <layout class="QGridLayout" >
+ <property name="margin" >
+ <number>9</number>
+ </property>
+ <property name="spacing" >
+ <number>6</number>
+ </property>
+ <item row="0" column="0" >
+ <widget class="QLabel" name="txtHeading" >
+ <property name="sizePolicy" >
+ <sizepolicy>
+ <hsizetype>5</hsizetype>
+ <vsizetype>1</vsizetype>
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="font" >
+ <font>
+ <family>Sans Serif</family>
+ <pointsize>24</pointsize>
+ <weight>75</weight>
+ <italic>false</italic>
+ <bold>true</bold>
+ <underline>false</underline>
+ <strikeout>false</strikeout>
+ </font>
+ </property>
+ <property name="text" >
+ <string>Plugin Template</string>
+ </property>
+ <property name="alignment" >
+ <set>Qt::AlignCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QTextBrowser" name="textBrowser" >
+ <property name="openExternalLinks" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok|QDialogButtonBox::SaveAll</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <layoutdefault spacing="6" margin="11" />
+ <resources/>
+ <connections/>
+</ui>
