[QGIS Commit] r11951 - in docs/trunk/english_us/user_guide: . material_wonder
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 7 07:54:57 EST 2009
Author: dassau
Date: 2009-11-07 07:54:56 -0500 (Sat, 07 Nov 2009)
New Revision: 11951
   docs/trunk/english_us/user_guide/material_wonder/user.odt
   docs/trunk/english_us/user_guide/working_with_vector.tex
updated/extended attribute table description.
- Diese und die folgenden Zeilen werden ignoriert --
M    user_guide/material_wonder/user.odt
M    user_guide/working_with_vector.tex
Modified: docs/trunk/english_us/user_guide/material_wonder/user.odt
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2009-11-07 12:04:42 UTC (rev 11950)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2009-11-07 12:54:56 UTC (rev 11951)
@@ -1512,12 +1512,18 @@
 \subsubsection{Working with the Attribute Table}\label{sec:attribute table}\index{editing!working with the attribute table}
-To open the attribute table for a vector layer, make the layer active by clicking on it in the Map legend area.
-Then use \mainmenuopt{Layer} Layer from the main menu and and choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
-from the menu. It is also possible to rightlick on the layer and choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
-from the dropdown menu. This will open a new window which displays the attributes for every feature in the layer
-(figure \ref{fig:attributetable}).
+The attribute table displays features of a selected layer. Each row in the table
+represents one map feature with its attributes shown in several columns. The
+features in the table can be searched, selected, moved or even edited.
+To open the attribute table for a vector layer, make the layer active by clicking
+on it in the map legend area. Then use \mainmenuopt{Layer} from the main menu
+and and choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
+from the menu. It is also possible to rightlick on the layer and
+choose \dropmenuopttwo{mActionOpenTable}{Open Attribute Table} from the
+dropdown menu. This will open a new window which displays the attributes for
+every feature in the layer (figure \ref{fig:attributetable}).
 \begin{figure}[ht]
    \begin{center}
    \caption{Attribute Table for Alaska layer \nixcaption}\label{fig:attributetable}\smallskip
@@ -1525,21 +1531,43 @@
 \end{center}
 \end{figure}
-Each column can be sorted by clicking on its header. A small arrow indicates the sort
-order (downward pointing means descending values from the top row down, upward pointing means
-ascending values from the top rown down).
-For a simple selection by attributes on only one column the \button{Look for} field
-can be used. Select the field (column) from which the search should be performed from
-the dropdown menu and hit the \button{Search} button. For more complex searches use the
-Advanced search \button{...}, which will lauch the Search Query Builder described in
-Section \ref{sec:select_by_query}.
+\minisec{Selecting features in an attribute table}
-To show selected records only, use the checkbox \checkbox{Show selected records only}.
-Using the buttons at the bottom left of the window, selected fields can be removed,
-moved to the top of the table, or the selection can be inverted. Selected features can
-also be copied to the clipboard, which can also be done with \keystroke{Ctrl-C}. You can also zoom
-into the selected features on the map. Toggle editing allows to edit single values of attributes.
+\textbf{A selected row} in the attribute table represents all attributes of a
+selected feature in the layer. The attribute table reflects any changes
+in the layer selection in the main window and vice versa. A changed selection
+in the attribute table also causes a change in the selected feature set in the
+main window and different layer feature selection means different rows are to be
+selected.
+Rows can be selected by clicking on the row number on the left side of the
+row. Selecting a row doesn't change the current cursor position. \textbf{Multiple
+rows} can be marked by holding the \keystroke{Ctrl} key. A \textbf{continuous
+selection} can be made by holding the \keystroke{Shift} key and clicking on several
+row headers on the left side of the rows. All rows between the current cursor
+position and the clicked row are selected.
+Each column can be sorted by clicking on its column header. A small arrow
+indicates the sort order (downward pointing means descending values from the top
+row down, upward pointing means ascending values from the top rown down).
+For a \textbf{simple search by attributes} on only one column the \button{Look for}
+field can be used. Select the field (column) from which the search should be
+performed from the dropdown menu and hit the \button{Search} button. For more
+complex searches use the Advanced search \button{...}, which will lauch the
+Search Query Builder described in Section \ref{sec:select_by_query}.
+To show selected records only, use the checkbox \checkbox{Show selected records only}. To search selected records only, use the checkbox \checkbox{Search selected records only}. The other buttons at the bottom left of the attribute table window provide following functionality:
+\begin{itemize}
+\item \toolbtntwo{mActionOpenTable}{Remove selection}
+\item \toolbtntwo{mActionSelectedToTop}{Move selected to top}
+\item \toolbtntwo{mActionInvertSelection}{Invert selection}
+\item \toolbtntwo{mActionCopySelected}{Copy selected rows to clipboard} also with \keystroke{Ctrl-C}
+\item \toolbtntwo{mActionZoomToSelected}{Zoom map to selected rows} also with \keystroke{Ctrl-J}
+\item \toolbtntwo{mActionToggleEditing}{toggle editing mode} to edit single values of attribute table.
+\end{itemize}
 \begin{Tip}[ht]\caption{\textsc{Manipulating Attribute data}}
 \qgistip{Currently only PostGIS layers are supported for adding or dropping
 attribute columns within this dialog. In future versions of QGIS, other
More information about the QGIS-commit mailing list
