[QGIS Commit] r11967 -
docs/trunk/english_us/coding-compilation_guide
svn_qgis at osgeo.org
Sat Nov 7 12:44:37 EST 2009
Author: macho
Date: 2009-11-07 12:44:36 -0500 (Sat, 07 Nov 2009)
New Revision: 11967
docs/trunk/english_us/coding-compilation_guide/install.tex
changes to install.tex regarding grass thanks to stephan meissl
Modified: docs/trunk/english_us/coding-compilation_guide/install.tex
--- docs/trunk/english_us/coding-compilation_guide/install.tex 2009-11-07 17:23:49 UTC (rev 11966)
+++ docs/trunk/english_us/coding-compilation_guide/install.tex 2009-11-07 17:44:36 UTC (rev 11967)
@@ -353,7 +353,7 @@
tarball to unpack it, then cd to the source folder and:
\begin{verbatim}
-./configure
+/configure
make
sudo make install
\end{verbatim}
@@ -368,7 +368,7 @@
Double-click the source tarball to unpack, then cd to the source folder and:
\begin{verbatim}
-./configure
+/configure
make
sudo make install
\end{verbatim}
@@ -458,7 +458,7 @@
\begin{verbatim}
-./configure --prefix=/usr/local
+/configure --prefix=/usr/local
make
sudo make install
\end{verbatim}
@@ -476,7 +476,7 @@
\begin{verbatim}
-./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
+/bootstrap --docdir=/share/doc/CMake --mandir=/share/man
make
sudo make install
\end{verbatim}
@@ -737,7 +737,7 @@
python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
\end{verbatim}
-/!$\backslash$ Debian users should use libgdal-dev above rather
+/!$\backslash$ Debian users may have to use libgdal-dev above rather.
/!$\backslash$ \textbf{*Note:*} For python language bindings SIP $>$= 4.5 and PyQt4 $>$= 4.1 is required! Some stable GNU/Linux
distributions (e.g. Debian or SuSE) only provide SIP $<$ 4.5 and PyQt4 $<$ 4.1. To include support for python
@@ -819,7 +819,7 @@
\end{verbatim}
\subsection{Starting the compile}
-/!$\backslash$ \textbf{*Note:*} The next section describes howto build debian packages
+/!$\backslash$ \textbf{*Note:*} Skip to next section for a description of howto build debian packages
I compile my development version of QGIS into my \~{}/apps directory to avoid
conflicts with Ubuntu packages that may be under /usr. This way for example
@@ -883,7 +883,11 @@
using \texttt{dpkg -r libqgis1-dev}. Otherwise \texttt{dpkg-buildpackage} will complain about a
build conflict.
-The the packages are created in the parent directory (ie. one level up).
+/!$\backslash$ \textbf{*Note:*} There is a debian package build for GRASS support which needs
+GRASS >= 6.4 (\texttt{grass} and \texttt{grass-dev}). Debian packages are available in
+lenny-backports and squeeze.
+The packages are created in the parent directory (ie. one level up).
Install them using dpkg. E.g.:
\begin{verbatim}
@@ -936,7 +940,7 @@
Compile the code with the standard commands
\begin{verbatim}
-./configure
+/configure
make
sudo make install
\end{verbatim}
@@ -978,20 +982,20 @@
and run configure with a few specific parameters
\begin{verbatim}
-./configure --without-grass --with-mrsid=../Geo_DSDK-7.0.0.2167 --without-jp2mrsid
+/configure --without-grass --with-mrsid=../Geo_DSDK-7.0.0.2167 --without-jp2mrsid
\end{verbatim}
at the end of the configuration process you should read something like
\begin{verbatim}
GRASS support: no
ECW support: yes
MrSID support yes
\end{verbatim}
then compile normally
@@ -1051,7 +1055,7 @@
Uncompress the arquive, enter the newly created folder and run configure with a few specific parameters
\begin{verbatim}
-./configure --with-tcltk-includes=/usr/include/tcl8.4 \
+/configure --with-tcltk-includes=/usr/include/tcl8.4 \
--with-proj-share=/usr/share/proj --with-gdal=/usr/local/bin/gdal-config \
--with-python=/usr/bin/python2.5-config
\end{verbatim}
@@ -1108,7 +1112,7 @@
run configure
\begin{verbatim}
-./configure --with-grass=/usr/local/grass-6.4.0RC4
+/configure --with-grass=/usr/local/grass-6.4.0RC4
\end{verbatim}
then as usual
@@ -1298,17 +1302,17 @@
make install
rm /usr/local/lib/libgdal.a
g++ -s -shared -o ./libgdal.dll -L/usr/local/lib -lz -lpng ./frmts/o/*.o \
-./gcore/*.o ./port/*.o ./alg/*.o ./ogr/ogrsf_frmts/o/*.o ./ogr/ogrgeometryfactory.o \
-./ogr/ogrpoint.o ./ogr/ogrcurve.o ./ogr/ogrlinestring.o ./ogr/ogrlinearring.o \
-./ogr/ogrpolygon.o ./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o \
-./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o \
-./ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o ./ogr/ogrfeaturedefn.o \
-./ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o ./ogr/ogrfielddefn.o \
-./ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o ./ogr/ogr_srs_proj4.o \
-./ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_srs_esri.o \
-./ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o ./ogr/ogr_srs_dict.o ./ogr/ogr_srs_panorama.o \
-./ogr/swq.o ./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o \
-./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
+/gcore/*.o ./port/*.o ./alg/*.o ./ogr/ogrsf_frmts/o/*.o ./ogr/ogrgeometryfactory.o \
+/ogr/ogrpoint.o ./ogr/ogrcurve.o ./ogr/ogrlinestring.o ./ogr/ogrlinearring.o \
+/ogr/ogrpolygon.o ./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o \
+/ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o \
+/ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o ./ogr/ogrfeaturedefn.o \
+/ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o ./ogr/ogrfielddefn.o \
+/ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o ./ogr/ogr_srs_proj4.o \
+/ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_srs_esri.o \
+/ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o ./ogr/ogr_srs_dict.o ./ogr/ogr_srs_panorama.o \
+/ogr/swq.o ./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o \
+/ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
install libgdal.dll /usr/local/lib
cd ogr
g++ -s ogrinfo.o -o ogrinfo.exe -L/usr/local/lib -lpng -lz -lgdal
@@ -1335,7 +1339,7 @@
\end{verbatim}
GDAL build procedure can be greatly simplified to use libtool with a libtool line patch:
configure gdal as below:
-./configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/ --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg\_config.exe
+/configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/ --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg\_config.exe
Then fix libtool with:
mv libtool libtool.orig
@@ -1359,7 +1363,7 @@
\begin{verbatim}
export PATH="/usr/local/bin:/usr/local/lib:$PATH"
-./configure --prefix=/usr/local --bindir=/usr/local \
+/configure --prefix=/usr/local --bindir=/usr/local \
--with-includes=/usr/local/include --with-libs=/usr/local/lib --with-cxx \
--without-jpeg --without-tiff --with-postgres=yes \
--with-postgres-includes=/local/pgsql/include --with-pgsql-libs=/local/pgsql/lib \
@@ -1431,7 +1435,7 @@
Now, in MSYS console, go to the source directory and run:
\begin{verbatim}
make
make install
\end{verbatim}
@@ -1467,7 +1471,7 @@
Run from MSYS console in the source directory:
\begin{verbatim}
-./configure
+/configure
make
make install
\end{verbatim}
@@ -1484,7 +1488,7 @@
\begin{verbatim}
-./configure
+/configure
make
make install
\end{verbatim}
