[QGIS Commit] r11991 - in trunk/qgis/src: analysis/interpolation
plugins/gps_importer
svn_qgis at osgeo.org
Sat Nov 7 18:32:12 EST 2009
Author: jef
Date: 2009-11-07 18:32:12 -0500 (Sat, 07 Nov 2009)
New Revision: 11991
trunk/qgis/src/analysis/interpolation/Bezier3D.cc
trunk/qgis/src/analysis/interpolation/Bezier3D.h
trunk/qgis/src/analysis/interpolation/CloughTocherInterpolator.cc
trunk/qgis/src/analysis/interpolation/NormVecDecorator.cc
trunk/qgis/src/analysis/interpolation/NormVecDecorator.h
trunk/qgis/src/analysis/interpolation/TriDecorator.cc
trunk/qgis/src/analysis/interpolation/TriDecorator.h
trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h
fix windows build
Modified: trunk/qgis/src/analysis/interpolation/Bezier3D.cc
--- trunk/qgis/src/analysis/interpolation/Bezier3D.cc 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/Bezier3D.cc 2009-11-07 23:32:12 UTC (rev 11991)
@@ -15,7 +15,7 @@
#include "Bezier3D.h"
-#include <iostream>
+#include "qgslogger.h"
void Bezier3D::calcFirstDer( float t, Vector3D* v )
@@ -31,7 +31,7 @@
return;
- for ( int n = 1;n <= int( mControlPoly->count() - 1 );n++ )
+ for ( int n = 1; n <= int( mControlPoly->count() - 1 ); n++ )
double bernst = MathUtils::calcBernsteinPoly( mControlPoly->count() - 2, n - 1, t );
v->setX( v->getX() + (( *mControlPoly )[n]->getX() - ( *mControlPoly )[n-1]->getX() )*bernst );
@@ -45,7 +45,7 @@
else
- std::cout << "warning: null pointer in Bezier3D::calcFirstDer" << std::endl << std::flush;
+ QgsDebugMsg( "warning: null pointer" );
@@ -58,7 +58,7 @@
p->setY( 0 );
p->setZ( 0 );
- for ( int n = 1;n <= int( mControlPoly->count() );n++ )
+ for ( int n = 1; n <= int( mControlPoly->count() ); n++ )
double bernst = MathUtils::calcBernsteinPoly( mControlPoly->count() - 1, n - 1, t );
p->setX( p->getX() + ( *mControlPoly )[n-1]->getX()*bernst );
@@ -69,7 +69,7 @@
else
- std::cout << "warning: null pointer in Bezier3D::calcPoint" << std::endl << std::flush;
@@ -86,7 +86,7 @@
return;
- for ( int n = 1;n <= int( mControlPoly->count() - 2 );n++ )
+ for ( int n = 1; n <= int( mControlPoly->count() - 2 ); n++ )
double bernst = MathUtils::calcBernsteinPoly( mControlPoly->count() - 3, n - 1, t );
v->setX( v->getX() + (( *mControlPoly )[n+1]->getX() - 2*( *mControlPoly )[n]->getX() + ( *mControlPoly )[n-1]->getX() )*bernst );
@@ -100,7 +100,7 @@
else
- std::cout << "warning: null pointer in Bezier3D::calcSecDer" << std::endl << std::flush;
@@ -110,12 +110,12 @@
if ( mControlPoly )
Point3D** pointer = new Point3D*[mControlPoly->count()];//create an array to temporarily store pointer to the control points
- for ( uint i = 0;i < mControlPoly->count();i++ )//store the points
+ for ( int i = 0; i < mControlPoly->count(); i++ )//store the points
pointer[i] = ( *mControlPoly )[i];
mControlPoly->insert( i, pointer[( mControlPoly->count()-1 )-i] );
@@ -123,7 +123,7 @@
else
- std::cout << "warning: null pointer in Bezier3D::changeDirection" << std::endl << std::flush;
Modified: trunk/qgis/src/analysis/interpolation/Bezier3D.h
--- trunk/qgis/src/analysis/interpolation/Bezier3D.h 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/Bezier3D.h 2009-11-07 23:32:12 UTC (rev 11991)
@@ -17,11 +17,10 @@
#ifndef BEZIER3D_H
#define BEZIER3D_H
-using namespace std;
#include "ParametricLine.h"
#include "Vector3D.h"
#include "MathUtils.h"
/**Class Bezier3D represents a bezier curve, represented by control points. Parameter t is running from 0 to 1. The class is capable to calculate the curve point and the first two derivatives belonging to t.*/
class ANALYSIS_EXPORT Bezier3D: public ParametricLine
@@ -86,12 +85,12 @@
inline void Bezier3D::add( ParametricLine* pl )
- cout << "Error!!!!! A Bezier-curve can not be parent of a ParametricLine." << endl;
+ QgsDebugMsg( "Error!!!!! A Bezier-curve can not be parent of a ParametricLine." );
inline void Bezier3D::remove( int i )
- cout << "Error!!!!! A Bezier-curve has no Childs to remove." << endl;
+ QgsDebugMsg( "Error!!!!! A Bezier-curve has no Childs to remove." );
//-----------------------------------------------setters and getters---------------------------------------------------------------
@@ -127,10 +126,4 @@
mDegree = mControlPoly->count() - 1;
-#endif
+#endif
\ No newline at end of file
Modified: trunk/qgis/src/analysis/interpolation/CloughTocherInterpolator.cc
--- trunk/qgis/src/analysis/interpolation/CloughTocherInterpolator.cc 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/CloughTocherInterpolator.cc 2009-11-07 23:32:12 UTC (rev 11991)
@@ -15,6 +15,7 @@
#include "CloughTocherInterpolator.h"
#ifndef Q_OS_MACX
#include <cmath>
#else
@@ -123,7 +124,7 @@
return true;
- cout << "warning, point outside the triangle in CloughTocherInterpolator::calcNormVec" << endl << flush;
+ QgsDebugMsg( "warning, point outside the triangle" );
result->setX( 0 );//return a vertical normal if failed
result->setY( 0 );
result->setZ( 1 );
@@ -132,7 +133,7 @@
else
- cout << "warning, null pointer in CloughTocherInterpolator::calcPoint" << endl << flush;
+ QgsDebugMsg( "warning, null pointer" );
return false;
@@ -199,7 +200,7 @@
else
- cout << "warning, point outside the triangle in CloughTocherInterpolator::calcPoint" << endl << flush;
result->setX( x );
result->setY( y );
result->setZ( 0 );
@@ -210,7 +211,7 @@
else
return false;
@@ -455,277 +456,279 @@
else
- cout << "warning, null pointer in CloughTocherInterpolator::init" << endl << flush;
-/*void CloughTocherInterpolator::init(double x,double y)//version which has unintended breaklines similar to the Coons interpolator
+#if 0
+void CloughTocherInterpolator::init( double x, double y )//version which has unintended breaklines similar to the Coons interpolator
- Vector3D v1,v2,v3;//normals at the three data points
+ Vector3D v1, v2, v3;//normals at the three data points
int ptn1, ptn2, ptn3;//numbers of the vertex points
NormVecDecorator::pointState state1, state2, state3;//states of the vertex points (NORMAL, BREAKLINE, ENDPOINT possible)
- if(mTIN)
+ if ( mTIN )
+ mTIN->getTriangle( x, y, &point1, &ptn1, &v1, &state1, &point2, &ptn2, &v2, &state2, &point3, &ptn3, &v3, &state3 );
+ if ( point1 == lpoint1 && point2 == lpoint2 && point3 == lpoint3 )//if we are in the same triangle as at the last run, we can leave 'init'
- mTIN->getTriangle(x,y,&point1,&ptn1,&v1,&state1,&point2,&ptn2,&v2,&state2,&point3,&ptn3,&v3,&state3);
+ return;
- if(point1==lpoint1&&point2==lpoint2&&point3==lpoint3)//if we are in the same triangle as at the last run, we can leave 'init'
- return;
+ //calculate the partial derivatives at the data points
+ der1X = -v1.getX() / v1.getZ();
+ der1Y = -v1.getY() / v1.getZ();
+ der2X = -v2.getX() / v2.getZ();
+ der2Y = -v2.getY() / v2.getZ();
+ der3X = -v3.getX() / v3.getZ();
+ der3Y = -v3.getY() / v3.getZ();
- //calculate the partial derivatives at the data points
- der1X=-v1.getX()/v1.getZ();
- der1Y=-v1.getY()/v1.getZ();
- der2X=-v2.getX()/v2.getZ();
- der2Y=-v2.getY()/v2.getZ();
- der3X=-v3.getX()/v3.getZ();
- der3Y=-v3.getY()/v3.getZ();
+ //calculate the control points
+ cp1.setX( point1.getX() + ( point2.getX() - point1.getX() ) / 3 );
+ cp1.setY( point1.getY() + ( point2.getY() - point1.getY() ) / 3 );
+ cp1.setZ( point1.getZ() + ( cp1.getX() - point1.getX() )*der1X + ( cp1.getY() - point1.getY() )*der1Y );
- //calculate the control points
- cp1.setX(point1.getX()+(point2.getX()-point1.getX())/3);
- cp1.setY(point1.getY()+(point2.getY()-point1.getY())/3);
- cp1.setZ(point1.getZ()+(cp1.getX()-point1.getX())*der1X+(cp1.getY()-point1.getY())*der1Y);
+ cp2.setX( point2.getX() + ( point1.getX() - point2.getX() ) / 3 );
+ cp2.setY( point2.getY() + ( point1.getY() - point2.getY() ) / 3 );
+ cp2.setZ( point2.getZ() + ( cp2.getX() - point2.getX() )*der2X + ( cp2.getY() - point2.getY() )*der2Y );
- cp2.setX(point2.getX()+(point1.getX()-point2.getX())/3);
- cp2.setY(point2.getY()+(point1.getY()-point2.getY())/3);
- cp2.setZ(point2.getZ()+(cp2.getX()-point2.getX())*der2X+(cp2.getY()-point2.getY())*der2Y);
+ cp9.setX( point2.getX() + ( point3.getX() - point2.getX() ) / 3 );
+ cp9.setY( point2.getY() + ( point3.getY() - point2.getY() ) / 3 );
+ cp9.setZ( point2.getZ() + ( cp9.getX() - point2.getX() )*der2X + ( cp9.getY() - point2.getY() )*der2Y );
- cp9.setX(point2.getX()+(point3.getX()-point2.getX())/3);
- cp9.setY(point2.getY()+(point3.getY()-point2.getY())/3);
- cp9.setZ(point2.getZ()+(cp9.getX()-point2.getX())*der2X+(cp9.getY()-point2.getY())*der2Y);
+ cp16.setX( point3.getX() + ( point2.getX() - point3.getX() ) / 3 );
+ cp16.setY( point3.getY() + ( point2.getY() - point3.getY() ) / 3 );
+ cp16.setZ( point3.getZ() + ( cp16.getX() - point3.getX() )*der3X + ( cp16.getY() - point3.getY() )*der3Y );
- cp16.setX(point3.getX()+(point2.getX()-point3.getX())/3);
- cp16.setY(point3.getY()+(point2.getY()-point3.getY())/3);
- cp16.setZ(point3.getZ()+(cp16.getX()-point3.getX())*der3X+(cp16.getY()-point3.getY())*der3Y);
+ cp14.setX( point3.getX() + ( point1.getX() - point3.getX() ) / 3 );
+ cp14.setY( point3.getY() + ( point1.getY() - point3.getY() ) / 3 );
+ cp14.setZ( point3.getZ() + ( cp14.getX() - point3.getX() )*der3X + ( cp14.getY() - point3.getY() )*der3Y );
- cp14.setX(point3.getX()+(point1.getX()-point3.getX())/3);
- cp14.setY(point3.getY()+(point1.getY()-point3.getY())/3);
- cp14.setZ(point3.getZ()+(cp14.getX()-point3.getX())*der3X+(cp14.getY()-point3.getY())*der3Y);
+ cp6.setX( point1.getX() + ( point3.getX() - point1.getX() ) / 3 );
+ cp6.setY( point1.getY() + ( point3.getY() - point1.getY() ) / 3 );
+ cp6.setZ( point1.getZ() + ( cp6.getX() - point1.getX() )*der1X + ( cp6.getY() - point1.getY() )*der1Y );
- cp6.setX(point1.getX()+(point3.getX()-point1.getX())/3);
- cp6.setY(point1.getY()+(point3.getY()-point1.getY())/3);
- cp6.setZ(point1.getZ()+(cp6.getX()-point1.getX())*der1X+(cp6.getY()-point1.getY())*der1Y);
+ //set x- and y-coordinates of the central point
+ cp10.setX(( point1.getX() + point2.getX() + point3.getX() ) / 3 );
+ cp10.setY(( point1.getY() + point2.getY() + point3.getY() ) / 3 );
- //set x- and y-coordinates of the central point
- cp10.setX((point1.getX()+point2.getX()+point3.getX())/3);
- cp10.setY((point1.getY()+point2.getY()+point3.getY())/3);
+ //do the necessary adjustments in case of breaklines--------------------------------------------------------------------
- //do the necessary adjustments in case of breaklines--------------------------------------------------------------------
+ //temporary normals and derivatives
+ double tmpx = 0;
+ double tmpy = 0;
+ Vector3D tmp( 0, 0, 0 );
- //temporary normals and derivatives
- double tmpx=0;
- double tmpy=0;
- Vector3D tmp(0,0,0);
+ //point1
+ if ( state1 == NormVecDecorator::BREAKLINE )
+ if ( mTIN->calcNormalForPoint( x, y, ptn1, &tmp ) )
+ tmpx = -tmp.getX() / tmp.getZ();
+ tmpy = -tmp.getY() / tmp.getZ();
+ if ( state3 == NormVecDecorator::NORMAL )
+ cp6.setZ( point1.getZ() + (( point3.getX() - point1.getX() ) / 3 )*tmpx + (( point3.getY() - point1.getY() ) / 3 )*tmpy );
+ if ( state2 == NormVecDecorator::NORMAL )
+ cp1.setZ( point1.getZ() + (( point2.getX() - point1.getX() ) / 3 )*tmpx + (( point2.getY() - point1.getY() ) / 3 )*tmpy );
- //point1
- if(state1==NormVecDecorator::BREAKLINE)
- if(mTIN->calcNormalForPoint(x,y,ptn1,&tmp))
- tmpx=-tmp.getX()/tmp.getZ();
- tmpy=-tmp.getY()/tmp.getZ();
- if(state3==NormVecDecorator::NORMAL)
- cp6.setZ(point1.getZ()+((point3.getX()-point1.getX())/3)*tmpx+((point3.getY()-point1.getY())/3)*tmpy);
- if(state2==NormVecDecorator::NORMAL)
- cp1.setZ(point1.getZ()+((point2.getX()-point1.getX())/3)*tmpx+((point2.getY()-point1.getY())/3)*tmpy);
+ if ( state2 == NormVecDecorator::BREAKLINE )
+ if ( mTIN->calcNormalForPoint( x, y, ptn2, &tmp ) )
+ if ( state1 == NormVecDecorator::NORMAL )
+ cp2.setZ( point2.getZ() + (( point1.getX() - point2.getX() ) / 3 )*tmpx + (( point1.getY() - point2.getY() ) / 3 )*tmpy );
+ cp9.setZ( point2.getZ() + (( point3.getX() - point2.getX() ) / 3 )*tmpx + (( point3.getY() - point2.getY() ) / 3 )*tmpy );
- if(state2==NormVecDecorator::BREAKLINE)
- if(mTIN->calcNormalForPoint(x,y,ptn2,&tmp))
- if(state1==NormVecDecorator::NORMAL)
- cp2.setZ(point2.getZ()+((point1.getX()-point2.getX())/3)*tmpx+((point1.getY()-point2.getY())/3)*tmpy);
- cp9.setZ(point2.getZ()+((point3.getX()-point2.getX())/3)*tmpx+((point3.getY()-point2.getY())/3)*tmpy);
+ if ( state3 == NormVecDecorator::BREAKLINE )
+ if ( mTIN->calcNormalForPoint( x, y, ptn3, &tmp ) )
+ cp14.setZ( point3.getZ() + (( point1.getX() - point3.getX() ) / 3 )*tmpx + (( point1.getY() - point3.getY() ) / 3 )*tmpy );
+ cp16.setZ( point3.getZ() + (( point2.getX() - point3.getX() ) / 3 )*tmpx + (( point2.getY() - point3.getY() ) / 3 )*tmpy );
- if(state3==NormVecDecorator::BREAKLINE)
- if(mTIN->calcNormalForPoint(x,y,ptn3,&tmp))
- cp14.setZ(point3.getZ()+((point1.getX()-point3.getX())/3)*tmpx+((point1.getY()-point3.getY())/3)*tmpy);
- cp16.setZ(point3.getZ()+((point2.getX()-point3.getX())/3)*tmpx+((point2.getY()-point3.getY())/3)*tmpy);
+ //calculate cp3, cp 5 and cp15
+ Vector3D normal;//temporary normal for the vertices on breaklines
- //calculate cp3, cp 5 and cp15
- Vector3D normal;//temporary normal for the vertices on breaklines
+ cp3.setX( point1.getX() + ( cp10.getX() - point1.getX() ) / 3 );
+ cp3.setY( point1.getY() + ( cp10.getY() - point1.getY() ) / 3 );
+ MathUtils::normalFromPoints( &point1, &cp1, &cp6, &normal );
+ //recalculate der1X and der1Y
+ der1X = -normal.getX() / normal.getZ();
+ der1Y = -normal.getY() / normal.getZ();
- cp3.setX(point1.getX()+(cp10.getX()-point1.getX())/3);
- cp3.setY(point1.getY()+(cp10.getY()-point1.getY())/3);
- MathUtils::normalFromPoints(&point1,&cp1,&cp6,&normal);
- //recalculate der1X and der1Y
- der1X=-normal.getX()/normal.getZ();
- der1Y=-normal.getY()/normal.getZ();
+ cp3.setZ( point1.getZ() + ( cp3.getX() - point1.getX() )*der1X + ( cp3.getY() - point1.getY() )*der1Y );
- cp3.setZ(point1.getZ()+(cp3.getX()-point1.getX())*der1X+(cp3.getY()-point1.getY())*der1Y);
+ cp5.setX( point2.getX() + ( cp10.getX() - point2.getX() ) / 3 );
+ cp5.setY( point2.getY() + ( cp10.getY() - point2.getY() ) / 3 );
+ MathUtils::normalFromPoints( &point2, &cp9, &cp2, &normal );
+ //recalculate der2X and der2Y
+ der2X = -normal.getX() / normal.getZ();
+ der2Y = -normal.getY() / normal.getZ();
- cp5.setX(point2.getX()+(cp10.getX()-point2.getX())/3);
- cp5.setY(point2.getY()+(cp10.getY()-point2.getY())/3);
- MathUtils::normalFromPoints(&point2,&cp9,&cp2,&normal);
- //recalculate der2X and der2Y
- der2X=-normal.getX()/normal.getZ();
- der2Y=-normal.getY()/normal.getZ();
+ cp5.setZ( point2.getZ() + ( cp5.getX() - point2.getX() )*der2X + ( cp5.getY() - point2.getY() )*der2Y );
- cp5.setZ(point2.getZ()+(cp5.getX()-point2.getX())*der2X+(cp5.getY()-point2.getY())*der2Y);
+ cp15.setX( point3.getX() + ( cp10.getX() - point3.getX() ) / 3 );
+ cp15.setY( point3.getY() + ( cp10.getY() - point3.getY() ) / 3 );
+ MathUtils::normalFromPoints( &point3, &cp14, &cp16, &normal );
+ //recalculate der3X and der3Y
+ der3X = -normal.getX() / normal.getZ();
+ der3Y = -normal.getY() / normal.getZ();
- cp15.setX(point3.getX()+(cp10.getX()-point3.getX())/3);
- cp15.setY(point3.getY()+(cp10.getY()-point3.getY())/3);
- MathUtils::normalFromPoints(&point3,&cp14,&cp16,&normal);
- //recalculate der3X and der3Y
- der3X=-normal.getX()/normal.getZ();
- der3Y=-normal.getY()/normal.getZ();
+ cp15.setZ( point3.getZ() + ( cp15.getX() - point3.getX() )*der3X + ( cp15.getY() - point3.getY() )*der3Y );
- cp15.setZ(point3.getZ()+(cp15.getX()-point3.getX())*der3X+(cp15.getY()-point3.getY())*der3Y);
+ cp4.setX(( point1.getX() + cp10.getX() + point2.getX() ) / 3 );
+ cp4.setY(( point1.getY() + cp10.getY() + point2.getY() ) / 3 );
- cp4.setX((point1.getX()+cp10.getX()+point2.getX())/3);
- cp4.setY((point1.getY()+cp10.getY()+point2.getY())/3);
+ Point3D midpoint3(( cp1.getX() + cp2.getX() ) / 2, ( cp1.getY() + cp2.getY() ) / 2, ( cp1.getZ() + cp2.getZ() ) / 2 );
+ Vector3D cp1cp2( cp2.getX() - cp1.getX(), cp2.getY() - cp1.getY(), cp2.getZ() - cp1.getZ() );
+ Vector3D odir3( 0, 0, 0 );//direction orthogonal to the line from point1 to point2
+ if (( point2.getY() - point1.getY() ) != 0 )//avoid division through zero
+ odir3.setX( 1 );
+ odir3.setY( -( point2.getX() - point1.getX() ) / ( point2.getY() - point1.getY() ) );
+ odir3.setZ(( der1X + der2X ) / 2 + ( der1Y + der2Y ) / 2*odir3.getY() );//take the linear interpolated cross-derivative
+ else
+ odir3.setY( 1 );
+ odir3.setX( -( point2.getY() - point1.getY() ) / ( point2.getX() - point1.getX() ) );
+ odir3.setZ(( der1X + der2X ) / 2*odir3.getX() + ( der1Y + der2Y ) / 2 );
+ Vector3D midpoint3cp4( 0, 0, 0 );
+ MathUtils::derVec( &cp1cp2, &odir3, &midpoint3cp4, cp4.getX() - midpoint3.getX(), cp4.getY() - midpoint3.getY() );
+ cp4.setZ( midpoint3.getZ() + midpoint3cp4.getZ() );
- Point3D midpoint3((cp1.getX()+cp2.getX())/2,(cp1.getY()+cp2.getY())/2,(cp1.getZ()+cp2.getZ())/2);
- Vector3D cp1cp2(cp2.getX()-cp1.getX(),cp2.getY()-cp1.getY(),cp2.getZ()-cp1.getZ());
- Vector3D odir3(0,0,0);//direction orthogonal to the line from point1 to point2
- if((point2.getY()-point1.getY())!=0)//avoid division through zero
- odir3.setX(1);
- odir3.setY(-(point2.getX()-point1.getX())/(point2.getY()-point1.getY()));
- odir3.setZ((der1X+der2X)/2+(der1Y+der2Y)/2*odir3.getY());//take the linear interpolated cross-derivative
- else
- odir3.setY(1);
- odir3.setX(-(point2.getY()-point1.getY())/(point2.getX()-point1.getX()));
- odir3.setZ((der1X+der2X)/2*odir3.getX()+(der1Y+der2Y)/2);
- Vector3D midpoint3cp4(0,0,0);
- MathUtils::derVec(&cp1cp2,&odir3,&midpoint3cp4,cp4.getX()-midpoint3.getX(),cp4.getY()-midpoint3.getY());
- cp4.setZ(midpoint3.getZ()+midpoint3cp4.getZ());
+ cp13.setX(( point2.getX() + cp10.getX() + point3.getX() ) / 3 );
+ cp13.setY(( point2.getY() + cp10.getY() + point3.getY() ) / 3 );
+ //find the point in the middle of the bezier curve between point2 and point3
+ Point3D midpoint1(( cp9.getX() + cp16.getX() ) / 2, ( cp9.getY() + cp16.getY() ) / 2, ( cp9.getZ() + cp16.getZ() ) / 2 );
+ Vector3D cp9cp16( cp16.getX() - cp9.getX(), cp16.getY() - cp9.getY(), cp16.getZ() - cp9.getZ() );
+ Vector3D odir1( 0, 0, 0 );//direction orthogonal to the line from point2 to point3
+ if (( point3.getY() - point2.getY() ) != 0 )//avoid division through zero
+ odir1.setX( 1 );
+ odir1.setY( -( point3.getX() - point2.getX() ) / ( point3.getY() - point2.getY() ) );
+ odir1.setZ(( der2X + der3X ) / 2 + ( der2Y + der3Y ) / 2*odir1.getY() );//take the linear interpolated cross-derivative
+ else
+ odir1.setY( 1 );
+ odir1.setX( -( point3.getY() - point2.getY() ) / ( point3.getX() - point2.getX() ) );
+ odir1.setZ(( der2X + der3X ) / 2*odir1.getX() + ( der2Y + der3Y ) / 2 );
+ Vector3D midpoint1cp13( 0, 0, 0 );
+ MathUtils::derVec( &cp9cp16, &odir1, &midpoint1cp13, cp13.getX() - midpoint1.getX(), cp13.getY() - midpoint1.getY() );
+ cp13.setZ( midpoint1.getZ() + midpoint1cp13.getZ() );
- cp13.setX((point2.getX()+cp10.getX()+point3.getX())/3);
- cp13.setY((point2.getY()+cp10.getY()+point3.getY())/3);
- //find the point in the middle of the bezier curve between point2 and point3
- Point3D midpoint1((cp9.getX()+cp16.getX())/2,(cp9.getY()+cp16.getY())/2,(cp9.getZ()+cp16.getZ())/2);
- Vector3D cp9cp16(cp16.getX()-cp9.getX(),cp16.getY()-cp9.getY(),cp16.getZ()-cp9.getZ());
- Vector3D odir1(0,0,0);//direction orthogonal to the line from point2 to point3
- if((point3.getY()-point2.getY())!=0)//avoid division through zero
- odir1.setX(1);
- odir1.setY(-(point3.getX()-point2.getX())/(point3.getY()-point2.getY()));
- odir1.setZ((der2X+der3X)/2+(der2Y+der3Y)/2*odir1.getY());//take the linear interpolated cross-derivative
- else
- odir1.setY(1);
- odir1.setX(-(point3.getY()-point2.getY())/(point3.getX()-point2.getX()));
- odir1.setZ((der2X+der3X)/2*odir1.getX()+(der2Y+der3Y)/2);
- Vector3D midpoint1cp13(0,0,0);
- MathUtils::derVec(&cp9cp16,&odir1,&midpoint1cp13,cp13.getX()-midpoint1.getX(),cp13.getY()-midpoint1.getY());
- cp13.setZ(midpoint1.getZ()+midpoint1cp13.getZ());
+ cp11.setX(( point3.getX() + cp10.getX() + point1.getX() ) / 3 );
+ cp11.setY(( point3.getY() + cp10.getY() + point1.getY() ) / 3 );
+ //find the point in the middle of the bezier curve between point3 and point2
+ Point3D midpoint2(( cp14.getX() + cp6.getX() ) / 2, ( cp14.getY() + cp6.getY() ) / 2, ( cp14.getZ() + cp6.getZ() ) / 2 );
+ Vector3D cp14cp6( cp6.getX() - cp14.getX(), cp6.getY() - cp14.getY(), cp6.getZ() - cp14.getZ() );
+ Vector3D odir2( 0, 0, 0 );//direction orthogonal to the line from point 1 to point3
+ if (( point3.getY() - point1.getY() ) != 0 )//avoid division through zero
+ odir2.setX( 1 );
+ odir2.setY( -( point3.getX() - point1.getX() ) / ( point3.getY() - point1.getY() ) );
+ odir2.setZ(( der3X + der1X ) / 2 + ( der3Y + der1Y ) / 2*odir2.getY() );//take the linear interpolated cross-derivative
+ else
+ odir2.setY( 1 );
+ odir2.setX( -( point3.getY() - point1.getY() ) / ( point3.getX() - point1.getX() ) );
+ odir2.setZ(( der3X + der1X ) / 2*odir2.getX() + ( der3Y + der1Y ) / 2 );
+ Vector3D midpoint2cp11( 0, 0, 0 );
+ MathUtils::derVec( &cp14cp6, &odir2, &midpoint2cp11, cp11.getX() - midpoint2.getX(), cp11.getY() - midpoint2.getY() );
+ cp11.setZ( midpoint2.getZ() + midpoint2cp11.getZ() );
- cp11.setX((point3.getX()+cp10.getX()+point1.getX())/3);
- cp11.setY((point3.getY()+cp10.getY()+point1.getY())/3);
- //find the point in the middle of the bezier curve between point3 and point2
- Point3D midpoint2((cp14.getX()+cp6.getX())/2,(cp14.getY()+cp6.getY())/2,(cp14.getZ()+cp6.getZ())/2);
- Vector3D cp14cp6(cp6.getX()-cp14.getX(),cp6.getY()-cp14.getY(),cp6.getZ()-cp14.getZ());
- Vector3D odir2(0,0,0);//direction orthogonal to the line from point 1 to point3
- if((point3.getY()-point1.getY())!=0)//avoid division through zero
- odir2.setX(1);
- odir2.setY(-(point3.getX()-point1.getX())/(point3.getY()-point1.getY()));
- odir2.setZ((der3X+der1X)/2+(der3Y+der1Y)/2*odir2.getY());//take the linear interpolated cross-derivative
- else
- odir2.setY(1);
- odir2.setX(-(point3.getY()-point1.getY())/(point3.getX()-point1.getX()));
- odir2.setZ((der3X+der1X)/2*odir2.getX()+(der3Y+der1Y)/2);
- Vector3D midpoint2cp11(0,0,0);
- MathUtils::derVec(&cp14cp6,&odir2,&midpoint2cp11,cp11.getX()-midpoint2.getX(),cp11.getY()-midpoint2.getY());
- cp11.setZ(midpoint2.getZ()+midpoint2cp11.getZ());
+ cp7.setX( cp10.getX() + ( point1.getX() - cp10.getX() ) / 3 );
+ cp7.setY( cp10.getY() + ( point1.getY() - cp10.getY() ) / 3 );
+ //cp7 has to be in the same plane as cp4, cp3 and cp11
+ Vector3D cp4cp3( cp3.getX() - cp4.getX(), cp3.getY() - cp4.getY(), cp3.getZ() - cp4.getZ() );
+ Vector3D cp4cp11( cp11.getX() - cp4.getX(), cp11.getY() - cp4.getY(), cp11.getZ() - cp4.getZ() );
+ Vector3D cp4cp7( 0, 0, 0 );
+ MathUtils::derVec( &cp4cp3, &cp4cp11, &cp4cp7, cp7.getX() - cp4.getX(), cp7.getY() - cp4.getY() );
+ cp7.setZ( cp4.getZ() + cp4cp7.getZ() );
- cp7.setX(cp10.getX()+(point1.getX()-cp10.getX())/3);
- cp7.setY(cp10.getY()+(point1.getY()-cp10.getY())/3);
- //cp7 has to be in the same plane as cp4, cp3 and cp11
- Vector3D cp4cp3(cp3.getX()-cp4.getX(), cp3.getY()-cp4.getY(), cp3.getZ()-cp4.getZ());
- Vector3D cp4cp11(cp11.getX()-cp4.getX(), cp11.getY()-cp4.getY(), cp11.getZ()-cp4.getZ());
- Vector3D cp4cp7(0,0,0);
- MathUtils::derVec(&cp4cp3,&cp4cp11,&cp4cp7,cp7.getX()-cp4.getX(),cp7.getY()-cp4.getY());
- cp7.setZ(cp4.getZ()+cp4cp7.getZ());
+ cp8.setX( cp10.getX() + ( point2.getX() - cp10.getX() ) / 3 );
+ cp8.setY( cp10.getY() + ( point2.getY() - cp10.getY() ) / 3 );
+ //cp8 has to be in the same plane as cp4, cp5 and cp13
+ Vector3D cp4cp5( cp5.getX() - cp4.getX(), cp5.getY() - cp4.getY(), cp5.getZ() - cp4.getZ() );
+ Vector3D cp4cp13( cp13.getX() - cp4.getX(), cp13.getY() - cp4.getY(), cp13.getZ() - cp4.getZ() );
+ Vector3D cp4cp8( 0, 0, 0 );
+ MathUtils::derVec( &cp4cp5, &cp4cp13, &cp4cp8, cp8.getX() - cp4.getX(), cp8.getY() - cp4.getY() );
+ cp8.setZ( cp4.getZ() + cp4cp8.getZ() );
- cp8.setX(cp10.getX()+(point2.getX()-cp10.getX())/3);
- cp8.setY(cp10.getY()+(point2.getY()-cp10.getY())/3);
- //cp8 has to be in the same plane as cp4, cp5 and cp13
- Vector3D cp4cp5(cp5.getX()-cp4.getX(), cp5.getY()-cp4.getY(), cp5.getZ()-cp4.getZ());
- Vector3D cp4cp13(cp13.getX()-cp4.getX(), cp13.getY()-cp4.getY(), cp13.getZ()-cp4.getZ());
- Vector3D cp4cp8(0,0,0);
- MathUtils::derVec(&cp4cp5,&cp4cp13,&cp4cp8,cp8.getX()-cp4.getX(), cp8.getY()-cp4.getY());
- cp8.setZ(cp4.getZ()+cp4cp8.getZ());
+ cp12.setX( cp10.getX() + ( point3.getX() - cp10.getX() ) / 3 );
+ cp12.setY( cp10.getY() + ( point3.getY() - cp10.getY() ) / 3 );
+ //cp12 has to be in the same plane as cp13, cp15 and cp11
+ Vector3D cp13cp11( cp11.getX() - cp13.getX(), cp11.getY() - cp13.getY(), cp11.getZ() - cp13.getZ() );
+ Vector3D cp13cp15( cp15.getX() - cp13.getX(), cp15.getY() - cp13.getY(), cp15.getZ() - cp13.getZ() );
+ Vector3D cp13cp12( 0, 0, 0 );
+ MathUtils::derVec( &cp13cp11, &cp13cp15, &cp13cp12, cp12.getX() - cp13.getX(), cp12.getY() - cp13.getY() );
+ cp12.setZ( cp13.getZ() + cp13cp12.getZ() );
- cp12.setX(cp10.getX()+(point3.getX()-cp10.getX())/3);
- cp12.setY(cp10.getY()+(point3.getY()-cp10.getY())/3);
- //cp12 has to be in the same plane as cp13, cp15 and cp11
- Vector3D cp13cp11(cp11.getX()-cp13.getX(), cp11.getY()-cp13.getY(), cp11.getZ()-cp13.getZ());
- Vector3D cp13cp15(cp15.getX()-cp13.getX(), cp15.getY()-cp13.getY(), cp15.getZ()-cp13.getZ());
- Vector3D cp13cp12(0,0,0);
- MathUtils::derVec(&cp13cp11,&cp13cp15,&cp13cp12,cp12.getX()-cp13.getX(),cp12.getY()-cp13.getY());
- cp12.setZ(cp13.getZ()+cp13cp12.getZ());
+ //cp10 has to be in the same plane as cp7, cp8 and cp12
+ Vector3D cp7cp8( cp8.getX() - cp7.getX(), cp8.getY() - cp7.getY(), cp8.getZ() - cp7.getZ() );
+ Vector3D cp7cp12( cp12.getX() - cp7.getX(), cp12.getY() - cp7.getY(), cp12.getZ() - cp7.getZ() );
+ Vector3D cp7cp10( 0, 0, 0 );
+ MathUtils::derVec( &cp7cp8, &cp7cp12, &cp7cp10, cp10.getX() - cp7.getX(), cp10.getY() - cp7.getY() );
+ cp10.setZ( cp7.getZ() + cp7cp10.getZ() );
- //cp10 has to be in the same plane as cp7, cp8 and cp12
- Vector3D cp7cp8(cp8.getX()-cp7.getX(), cp8.getY()-cp7.getY(), cp8.getZ()-cp7.getZ());
- Vector3D cp7cp12(cp12.getX()-cp7.getX(), cp12.getY()-cp7.getY(), cp12.getZ()-cp7.getZ());
- Vector3D cp7cp10(0,0,0);
- MathUtils::derVec(&cp7cp8,&cp7cp12,&cp7cp10,cp10.getX()-cp7.getX(),cp10.getY()-cp7.getY());
- cp10.setZ(cp7.getZ()+cp7cp10.getZ());
+ lpoint1 = point1;
+ lpoint2 = point2;
+ lpoint3 = point3;
- lpoint1=point1;
- lpoint2=point2;
- lpoint3=point3;
else
+#endif
Modified: trunk/qgis/src/analysis/interpolation/NormVecDecorator.cc
--- trunk/qgis/src/analysis/interpolation/NormVecDecorator.cc 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/NormVecDecorator.cc 2009-11-07 23:32:12 UTC (rev 11991)
@@ -15,13 +15,14 @@
#include "NormVecDecorator.h"
NormVecDecorator::~NormVecDecorator()
//remove all the normals
if ( mNormVec->count() > 0 )
- for ( unsigned int i = 0; i < mNormVec->count();i++ )
+ for ( int i = 0; i < mNormVec->count(); i++ )
delete( *mNormVec )[i];
@@ -45,7 +46,7 @@
if ( pointno == -100 )//a numerical error occured
- //cout << "warning, numerical error in NormVecDecorator::addPoint" << endl << flush;
+// QgsDebugMsg("warning, numerical error");
return -100;
@@ -73,6 +74,8 @@
return pointno;
+ return -1;
bool NormVecDecorator::calcNormal( double x, double y, Vector3D* result )
@@ -90,7 +93,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::calcNormal" << endl << flush;
return false;
@@ -125,7 +128,7 @@
if ((( vlist->count() ) % 4 ) != 0 )//number of items in vlist has to be a multiple of 4
- cout << "warning, wrong number of items in vlist in NormVecDecorator::calcNormalForPoint" << endl << flush;
+ QgsDebugMsg( "warning, wrong number of items in vlist" );
return false;
@@ -138,7 +141,7 @@
numberofruns++;
if ( numberofruns > limit )
- cout << "warning, a probable endless loop is detected in NormVecDecorator::calcNormalForPoint" << endl << flush;
+ QgsDebugMsg( "warning, a probable endless loop is detected" );
return false;
@@ -185,7 +188,7 @@
if ( pointfound == false )//the point with coordinates x, y was in no triangle
- cout << "warning: point (x,y) was in no triangle (NormVecDecorator::calcNormalForPoint)" << endl << flush;
+ QgsDebugMsg( "warning: point (x,y) was in no triangle" );
return false;
result->standardise();
@@ -220,7 +223,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::calcNormalForPoint" << endl << flush;
return false;
@@ -242,7 +245,7 @@
else
return false;
@@ -273,7 +276,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::getTriangle(double,double,Point3D*,Vector3D*,Point3D*,Vector3D*,Point3D*,Vector3D*" << endl << flush;
delete nr1;
delete nr2;
delete nr3;
@@ -298,7 +301,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::getTriangle" << endl << flush;
return false;
@@ -311,7 +314,7 @@
else
- cout << "warning, number below 0 in NormVecDecorator::getState" << endl << flush;
+ QgsDebugMsg( "warning, number below 0" );
return mPointState->at( 0 );//just to avoid a compiler warning
@@ -345,14 +348,14 @@
else
- cout << "warning, getTriangle returned false in NormVecDecorator::getTriangle" << endl << flush;
+ QgsDebugMsg( "warning, getTriangle returned false" );
return false;
else
return false;
@@ -381,7 +384,7 @@
//something went wrong in getSurroundingTriangles, set the normal to (0,0,0)
if ( mNormVec->size() <= mNormVec->count() )//allocate more memory if neccessary
- cout << "resizing mNormVec from " << mNormVec->size() << " to " << mNormVec->size() + 1 << endl << flush;
+ QgsDebugMsg( QString( "resizing mNormVec from %1 to %2" ).arg( mNormVec->size() ).arg( mNormVec->size() + 1 ) );
mNormVec->resize( mNormVec->size() + 1 );
@@ -401,9 +404,9 @@
return false;
- if ((( vlist->count() ) % 4 ) != 0 )//number of items in vlist has to be a multiple of 4
+ if (( vlist->count() % 4 ) != 0 ) //number of items in vlist has to be a multiple of 4
- cout << "warning, wrong number of items in vlist in NormVecDecorator::estimateFirstDerivatives" << endl << flush;
return false;
@@ -479,7 +482,7 @@
//insert the new calculated vector
@@ -499,7 +502,7 @@
if ( pointno >= mPointState->size() )
- cout << "resizing mPointState from " << mPointState->size() << " to " << mPointState->size() + 1 << endl << flush;
+ QgsDebugMsg( QString( "resizing mPointState from %1 to %2" ).arg( mPointState->size() ).arg( mPointState->size() + 1 ) );
mPointState->resize( mPointState->size() + 1 );
@@ -511,7 +514,7 @@
//weighted method of little
bool NormVecDecorator::estimateFirstDerivatives()
- for ( int i = 0;i < getNumberOfPoints();i++ )
+ for ( int i = 0; i < getNumberOfPoints(); i++ )
estimateFirstDerivative( i );
@@ -535,7 +538,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::eliminateHorizontalTriangles" << endl << flush;
@@ -547,7 +550,7 @@
else
- cout << "warning, pointno>0 in NormVecDecorator::setState" << endl << flush;
+ QgsDebugMsg( "warning, pointno>0" );
@@ -555,7 +558,7 @@
if ( mTIN )
- bool b;
+ bool b = false;
if ( alreadyestimated )
QList<int>* list = getPointsAroundEdge( x, y );
@@ -563,7 +566,7 @@
b = mTIN->swapEdge( x, y );
QList<int>::iterator it;
- for ( it = list->begin();it != list->end();++it )
+ for ( it = list->begin(); it != list->end(); ++it )
estimateFirstDerivative(( *it ) );
@@ -578,7 +581,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::swapEdge" << endl << flush;
return false;
Modified: trunk/qgis/src/analysis/interpolation/NormVecDecorator.h
--- trunk/qgis/src/analysis/interpolation/NormVecDecorator.h 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/NormVecDecorator.h 2009-11-07 23:32:12 UTC (rev 11991)
@@ -17,11 +17,10 @@
#ifndef NORMVECDECORATOR_H
#define NORMVECDECORATOR_H
#include "TriDecorator.h"
#include <TriangleInterpolator.h>
#include <MathUtils.h>
/**Decorator class which adds the functionality of estimating normals at the data points*/
class ANALYSIS_EXPORT NormVecDecorator: public TriDecorator
@@ -99,7 +98,7 @@
else
- cout << "warning, null pointer in NormVecDecorator::getNormal" << endl << flush;
return 0;
Modified: trunk/qgis/src/analysis/interpolation/TriDecorator.cc
--- trunk/qgis/src/analysis/interpolation/TriDecorator.cc 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/TriDecorator.cc 2009-11-07 23:32:12 UTC (rev 11991)
@@ -15,6 +15,7 @@
void TriDecorator::addLine( Line3D* line, bool breakline )
@@ -24,7 +25,7 @@
else
- cout << "warning, null pointer in TriDecorator::addLine" << endl << flush;
@@ -37,7 +38,7 @@
else
- cout << "warning, null pointer in TriDecorator::addPoint" << endl << flush;
return 0;
@@ -50,7 +51,7 @@
else
- cout << "warning, null pointer in TriDecorator::performConsistencyTest" << endl << flush;
@@ -63,7 +64,7 @@
else
- cout << "warning, null pointer in TriDecorator::calcNormal" << endl << flush;
return false;
@@ -77,7 +78,7 @@
else
- cout << "warning, null pointer in TriDecorator::calcPoint" << endl << flush;
return false;
@@ -91,7 +92,7 @@
else
- cout << "warning, null pointer in TriDecorator::getPoint" << endl << flush;
return 0;
@@ -105,7 +106,7 @@
else
- cout << "warning, null pointer in TriDecorator::getTriangle" << endl << flush;
return false;
@@ -119,7 +120,7 @@
else
return false;
@@ -132,7 +133,7 @@
else
- cout << "warning, null pointer in TriDecorator::getNumberOfPoints" << endl << flush;
return false;
@@ -146,7 +147,7 @@
else
- cout << "warning, null pointer in TriDecorator::getOppositePoint" << endl << flush;
return 0;
@@ -160,7 +161,7 @@
else
- cout << "warning, null pointer in TriDecorator::getSurroundingTriangles" << endl << flush;
return 0;
@@ -174,7 +175,7 @@
else
- cout << "warning, null pointer in TriDecorator::getXMax" << endl << flush;
return 0;
@@ -188,7 +189,7 @@
else
- cout << "warning, null pointer in TriDecorator::getXMin" << endl << flush;
return 0;
@@ -201,7 +202,7 @@
else
- cout << "warning, null pointer in TriDecorator::getYMax" << endl << flush;
return 0;
@@ -215,7 +216,7 @@
else
- cout << "warning, null pointer in TriDecorator::getYMin" << endl << flush;
return 0;
@@ -228,7 +229,7 @@
else
- cout << "warning, null pointer in TriDecorator::setForcedCrossBehaviour" << endl << flush;
@@ -240,7 +241,7 @@
else
- cout << "warning, null pointer in TriDecorator::setEdgeColor" << endl << flush;
@@ -252,7 +253,7 @@
else
- cout << "warning, null pointer in TriDecorator::setForcedEdgeColor" << endl << flush;
@@ -264,7 +265,7 @@
else
- cout << "warning, null pointer in TriDecorator::setBreakEdgeColor" << endl << flush;
@@ -276,7 +277,7 @@
else
- cout << "warning, null pointer in TriDecorator::setTriangleInterpolator" << endl << flush;
@@ -288,7 +289,7 @@
else
- cout << "warning, null pointer in TriDecorator::swapHorizontalTriangles" << endl << flush;
@@ -300,7 +301,7 @@
else
- cout << "warning, null pointer in TriDecorator::ruppertRefinement" << endl << flush;
@@ -313,7 +314,7 @@
else
- cout << "warning, null pointer in TriDecorator::pointInside" << endl << flush;
return false;
@@ -327,7 +328,7 @@
else
- cout << "warning, null pointer in TriDecorator::swapEdge" << endl << flush;
return false;
@@ -340,7 +341,7 @@
else
- cout << "warning, null pointer in TriDecorator::getPointsAroundEdge" << endl << flush;
return 0;
Modified: trunk/qgis/src/analysis/interpolation/TriDecorator.h
--- trunk/qgis/src/analysis/interpolation/TriDecorator.h 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/analysis/interpolation/TriDecorator.h 2009-11-07 23:32:12 UTC (rev 11991)
@@ -17,8 +17,6 @@
#ifndef TRIDECORATOR_H
#define TRIDECORATOR_H
#include "Triangulation.h"
/**Decorator class for Triangulations (s. Decorator pattern in Gamma et al.)*/
@@ -81,6 +79,4 @@
mTIN = t;
-#endif
+#endif
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h 2009-11-07 23:27:19 UTC (rev 11990)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h 2009-11-07 23:32:12 UTC (rev 11991)
@@ -58,18 +58,18 @@
void on_pbnDLOutput_clicked();
private:
void populateDeviceComboBox();
void populateULLayerComboBox();
void populateIMPBabelFormats();
void populatePortComboBoxes();
+#if 0
void populateLoadDialog();
void populateDLDialog();
void populateULDialog();
void populateIMPDialog();
void populateCONVDialog();
+#endif
private slots:
void on_pbnRefresh_clicked();
