[QGIS Commit] r12035 - in trunk/qgis/src/app: . legend
svn_qgis at osgeo.org
Sun Nov 8 16:44:48 EST 2009
Author: wonder
Date: 2009-11-08 16:44:47 -0500 (Sun, 08 Nov 2009)
New Revision: 12035
Removed:
trunk/qgis/src/app/legend/qgslegendlayerfile.cpp
trunk/qgis/src/app/legend/qgslegendlayerfile.h
trunk/qgis/src/app/legend/qgslegendlayerfilegroup.cpp
trunk/qgis/src/app/legend/qgslegendlayerfilegroup.h
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegend.h
trunk/qgis/src/app/legend/qgslegendgroup.cpp
trunk/qgis/src/app/legend/qgslegendgroup.h
trunk/qgis/src/app/legend/qgslegenditem.h
trunk/qgis/src/app/legend/qgslegendlayer.cpp
trunk/qgis/src/app/legend/qgslegendlayer.h
trunk/qgis/src/app/legend/qgslegendsymbologygroup.cpp
trunk/qgis/src/app/qgisapp.cpp
[UPDATE] remove "layer file" items in legend - feature that was added long time ago but never actually worked well :-)
Hopefully it doesn't break anything...
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/CMakeLists.txt 2009-11-08 21:44:47 UTC (rev 12035)
@@ -88,8 +88,6 @@
legend/qgslegenditem.cpp
- legend/qgslegendlayerfile.cpp
- legend/qgslegendlayerfilegroup.cpp
legend/qgslegendpropertygroup.cpp
legend/qgslegendpropertyitem.cpp
@@ -184,7 +182,6 @@
legend/qgslegend.h
- legend/qgslegendlayerfile.h
ogr/qgsopenvectorlayerdialog.h
ogr/qgsnewogrconnection.h
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -25,8 +25,6 @@
#include "qgslegendlayer.h"
#include "qgslegendpropertygroup.h"
#include "qgslegendsymbologyitem.h"
-#include "qgslegendlayerfile.h"
-#include "qgslegendlayerfilegroup.h"
#include "qgsmapcanvas.h"
#include "qgsmapcanvasmap.h"
#include "qgsmaplayer.h"
@@ -63,7 +61,6 @@
: QTreeWidget( parent ),
mMousePressedFlag( false ),
mItemBeingMoved( 0 ),
- mShowLegendLayerFiles( false ),
mToggleEditingAction( 0 ),
mMapCanvas( 0 ),
mMinimumIconSize( 20, 20 )
@@ -175,8 +172,6 @@
QTreeWidgetItem* theItem = firstItem();
QgsDebugMsg( "called." );
- QgsLegendLayer* lastLL = NULL;
while ( theItem )
QgsLegendItem *li = dynamic_cast<QgsLegendItem *>( theItem );
@@ -184,29 +179,17 @@
// save legend layer (parent of a legend layer file we're going to delete)
QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( li );
- if ( ll ) lastLL = ll;
- QgsLegendLayerFile* llf = qobject_cast<QgsLegendLayerFile *>( li );
- if ( llf )
+ if ( ll && ll->layer() && ll->layer()->getLayerID() == layer_key )
- if ( llf->layer() && llf->layer()->getLayerID() == layer_key )
- //remove the map entry for the checkbox
- mStateOfCheckBoxes.erase( llf );
- removeItem( llf );
- delete llf;
+ //remove the map entry for the checkbox
+ mStateOfCheckBoxes.erase( ll );
+ removeItem( ll );
+ delete ll;
- // delete also parent legend layer if now it's empty
- if ( lastLL->mapLayers().size() == 0 )
- mStateOfCheckBoxes.erase( lastLL );
- removeItem( lastLL );
- delete lastLL;
- break;
+ break;
theItem = nextItem( theItem );
@@ -385,68 +368,9 @@
return;
- QgsLegendItem::LEGEND_ITEM_TYPE originType = origin->type();
- QgsLegendItem::LEGEND_ITEM_TYPE destType = dest->type();
- if ( originType == QgsLegendItem::LEGEND_LAYER_FILE && destType == QgsLegendItem::LEGEND_LAYER_FILE_GROUP )
- QgsDebugMsg( "Legend layer file moved to layer file group" );
- // Not used... delete?
- //QgsMapLayer* origLayer = ((QgsLegendLayerFile*)(origin))->layer();
- if ( dest->childCount() > 1 )
- //find the first layer in the legend layer group != origLayer and copy its settings
- QgsLegendItem* currentItem = dynamic_cast<QgsLegendItem *>( dest->child( 0 ) );
- while ( currentItem )
- if ( currentItem != origin )
- QgsMapLayer* origLayer = (( QgsLegendLayerFile* )( origin ) )->layer();
- QgsMapLayer* currentLayer = (( QgsLegendLayerFile* )( currentItem ) )->layer();
- origLayer->copySymbologySettings( *currentLayer );
- break;
- currentItem = currentItem->nextSibling();
- else if ( originType == QgsLegendItem::LEGEND_LAYER_FILE && destType == QgsLegendItem::LEGEND_LAYER_FILE )
- QgsDebugMsg( "Legend layer file moved to legend layer file" );
- // Not used. Delete?
- // QgsMapLayer* origLayer = ((QgsLegendLayerFile*)(origin))->layer();
- // QgsMapLayer* destLayer = ((QgsLegendLayerFile*)(dest))->layer();
- if ( dest == origin )//origin item has been moved in mouseMoveEvent such that it is under the mouse cursor now
- if ( origin->parent()->childCount() > 1 )
- QTreeWidgetItem* currentItem = dest->parent()->child( 0 );
- break;
- currentItem = dynamic_cast<QgsLegendItem *>( currentItem )->nextSibling();
- else
- QgsMapLayer* destLayer = (( QgsLegendLayerFile* )( dest ) )->layer();
- origLayer->copySymbologySettings( *destLayer );
- else
// Do the actual move here.
- QgsDebugMsg( "Other type of drag'n'drop happened!" );
+ QgsDebugMsg( "Drag'n'drop happened!" );
if ( mDropAction == AFTER ) //over center of item
QgsDebugMsg( "Drop AFTER" );
@@ -506,12 +430,8 @@
if ( li )
- if ( li->type() == QgsLegendItem::LEGEND_LAYER_FILE )
+ if ( li->type() == QgsLegendItem::LEGEND_LAYER )
- ( static_cast<QgsLegendLayerFile*>( li ) )->addToPopupMenu( theMenu, mToggleEditingAction );
- else if ( li->type() == QgsLegendItem::LEGEND_LAYER )
( static_cast<QgsLegendLayer*>( li ) )->addToPopupMenu( theMenu, mToggleEditingAction );
if ( li->parent() )
@@ -537,11 +457,6 @@
theMenu.addAction( QgisApp::getThemeIcon( "/mActionExpandTree.png" ), tr( "&Expand all" ), this, SLOT( expandAll() ) );
theMenu.addAction( QgisApp::getThemeIcon( "/mActionCollapseTree.png" ), tr( "&Collapse all" ), this, SLOT( collapseAll() ) );
- QAction* showFileGroupsAction = theMenu.addAction( tr( "Show file groups" ), this, SLOT( showLegendLayerFileGroups() ) );
- showFileGroupsAction->setCheckable( true );
- showFileGroupsAction->blockSignals( true );
- showFileGroupsAction->setChecked( mShowLegendLayerFiles );
- showFileGroupsAction->blockSignals( false );
theMenu.exec( position );
@@ -576,40 +491,28 @@
return;
- QgsLegendLayer * llayer = new QgsLegendLayer( layer->name() );//generate entry for mStateOfCheckBoxes below
- QgsLegendLayerFileGroup * llfgroup = new QgsLegendLayerFileGroup( llayer, QString( "Files" ) );
- QgsLegendLayerFile * llfile = new QgsLegendLayerFile( llfgroup, QgsLegendLayerFile::nameFromLayer( layer ), layer );
+ QgsLegendLayer* llayer = new QgsLegendLayer( layer );
llayer->updateIcon();
llayer->setToolTip( 0, layer->publicSource() );
//set the correct check states
- if ( llfile->isVisible() )
+ if ( llayer->isVisible() )
- llfile->setCheckState( 0, Qt::Checked );
llayer->setCheckState( 0, Qt::Checked );
- mStateOfCheckBoxes.insert( std::make_pair( llfile, Qt::Checked ) ); //insert the check state into the map to query for changes later
mStateOfCheckBoxes.insert( std::make_pair( llayer, Qt::Checked ) );
else
- llfile->setCheckState( 0, Qt::Unchecked );
llayer->setCheckState( 0, Qt::Unchecked );
- mStateOfCheckBoxes.insert( std::make_pair( llfile, Qt::Unchecked ) ); //insert the check state into the map to query for changes later
mStateOfCheckBoxes.insert( std::make_pair( llayer, Qt::Unchecked ) );
insertTopLevelItem( 0, llayer );
setItemExpanded( llayer, true );
- setItemExpanded( llfgroup, false );
- //only if qsetting for 'legend layer file visible' is not set
- if ( !mShowLegendLayerFiles )
- llfgroup->setHidden( true );
- llfile->updateLegendItem();
refreshLayerSymbology( layer->getLayerID() );
updateMapCanvasLayerSet();
@@ -630,28 +533,22 @@
-QgsLegendLayerFile* QgsLegend::currentLayerFile()
+QgsLegendLayer* QgsLegend::currentLegendLayer()
QgsLegendItem* citem = dynamic_cast<QgsLegendItem *>( currentItem() );
if ( citem )
- QgsLegendLayerFile* llf = qobject_cast<QgsLegendLayerFile *>( citem );
- if ( llf )
- return llf; //the current item is itself a legend layer file
QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( citem );
if ( ll )
- return ll->firstLayerFile(); //the current item is a legend layer, so return its first layer
+ return ll; //the current item is a legend layer, so return it
QgsLegendLayer* lpl = dynamic_cast<QgsLegendLayer *>( citem->parent() );
if ( lpl )
- return lpl->firstLayerFile(); //the parent of the current item is a legend layer, return its first layer
+ return lpl; //the parent of the current item is a legend layer, return it
@@ -660,10 +557,10 @@
QgsMapLayer* QgsLegend::currentLayer()
- QgsLegendLayerFile* llf = currentLayerFile();
- if ( llf )
+ QgsLegendLayer* ll = currentLegendLayer();
+ if ( ll )
- return llf->layer();
+ return ll->layer();
else
@@ -703,45 +600,17 @@
//if the current item is a legend layer: remove all layers of the current legendLayer
QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( currentItem() );
- if ( ll )
- std::list<QgsMapLayer*> maplayers = ll->mapLayers();
- int layerCount = maplayers.size();
+ if ( !ll )
+ return;
- for ( std::list<QgsMapLayer*>::iterator it = maplayers.begin(); it != maplayers.end(); ++it )
- //remove the layer
- if ( *it )
- removeLayer( *it, true );
+ removeLayer( ll->layer(), true );
- if ( layerCount == 0 )
- // delete the item only when it didn't have any child legend layer files
- // (otherwise it is deleted in QgsLegend::removeLayer when deleting last legend layer file)
- mStateOfCheckBoxes.erase( ll );
- removeItem( ll );
- delete ll;
+ removeItem( ll );
+ delete ll;
- adjustIconSize();
- return;
+ adjustIconSize();
- //if the current item is a legend layer file
- QgsLegendLayerFile* llf = dynamic_cast<QgsLegendLayerFile *>( currentItem() );
- if ( llf )
- if ( llf->layer() )
- //the map layer registry emits a signal an this will remove the legend layer
- //from the legend and from memory by calling QgsLegend::removeLayer(QString layer key)
- QgsMapLayerRegistry::instance()->removeMapLayer( llf->layer()->getLayerID() );
- return;
bool QgsLegend::removeLayer( QgsMapLayer* ml, bool askCancelOnEditable )
@@ -807,31 +676,22 @@
QgsLegendItem* li = dynamic_cast<QgsLegendItem *>( currentItem() );
- QgsLegendLayerFile* llf = 0;
if ( !li )
return;
- llf = qobject_cast<QgsLegendLayerFile *>( li );
- QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( li );
- llf = ll->firstLayerFile();
+ if ( li->type() != QgsLegendItem::LEGEND_LAYER )
+ return;
- if ( !llf )
+ QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( li );
+ if ( !ll )
return;
//QgsDebugMsg("Showing layer properties dialog");
- QgsMapLayer* ml = llf->layer();
+ QgsMapLayer* ml = ll->layer();
TODO: Consider reusing the property dialogs again.
@@ -875,7 +735,7 @@
delete vlp; // delete since dialog cannot be reused without updating code
- llf->updateLegendItem();
+ ll->updateIcon();
@@ -890,18 +750,12 @@
if ( !li )
return;
- if ( !llf ) return;
- llf->showInOverview();
- if ( !ll ) return;
- ll->showInOverview();
+ return;
+ if ( !ll ) return;
+ ll->showInOverview();
void QgsLegend::expandAll()
@@ -933,7 +787,6 @@
QDomElement legendsymbolnode;
QDomElement legendpropertynode;
QDomElement legendlayerfilenode;
- QgsLegendLayerFile* llf;
Qt::CheckState cstate; //check state for legend layers and legend groups
QTreeWidgetItem* currentItem = firstItem();
@@ -951,14 +804,7 @@
legendnode = tmplegendnode;
legendgroupnode = document.createElement( "legendgroup" );
- if ( isItemExpanded( item ) )
- legendgroupnode.setAttribute( "open", "true" );
- else
- legendgroupnode.setAttribute( "open", "false" );
+ legendgroupnode.setAttribute( "open", isItemExpanded( item ) ? "true" : "false" );
legendgroupnode.setAttribute( "name", item->text( 0 ) );
cstate = item->checkState( 0 );
if ( cstate == Qt::Checked )
@@ -985,14 +831,7 @@
legendlayernode = document.createElement( "legendlayer" );
- legendlayernode.setAttribute( "open", "true" );
- else
- legendlayernode.setAttribute( "open", "false" );
+ legendlayernode.setAttribute( "open", isItemExpanded( item ) ? "true" : "false" );
@@ -1008,76 +847,45 @@
legendlayernode.setAttribute( "name", item->text( 0 ) );
legendnode.appendChild( legendlayernode );
- break;
- case QgsLegendItem::LEGEND_PROPERTY_GROUP:
- legendpropertynode = document.createElement( "propertygroup" );
+ // save the information about layer
+ // emulate a legend layer file group and a legend layer file
+ // to keep it compatible with older projects
- legendpropertynode.setAttribute( "open", "true" );
- else
- legendpropertynode.setAttribute( "open", "false" );
- legendlayernode.appendChild( legendpropertynode );
- break;
+ QgsLegendLayer *ll = dynamic_cast<QgsLegendLayer *>( item );
+ QgsMapLayer* layer = ll->layer();
- case QgsLegendItem::LEGEND_SYMBOL_GROUP:
- legendsymbolnode = document.createElement( "symbolgroup" );
- legendsymbolnode.setAttribute( "open", "true" );
- else
- legendsymbolnode.setAttribute( "open", "false" );
- legendlayernode.appendChild( legendsymbolnode );
- break;
+ layerfilegroupnode = document.createElement( "filegroup" );
+ layerfilegroupnode.setAttribute( "open", isItemExpanded( item ) ? "true" : "false" );
+ layerfilegroupnode.setAttribute( "hidden", isItemHidden( item ) ? "true" : "false" );
+ legendlayernode.appendChild( layerfilegroupnode );
+ legendlayerfilenode = document.createElement( "legendlayerfile" );
- case QgsLegendItem::LEGEND_LAYER_FILE_GROUP:
- layerfilegroupnode = document.createElement( "filegroup" );
- layerfilegroupnode.setAttribute( "open", "true" );
- else
- layerfilegroupnode.setAttribute( "open", "false" );
- if ( isItemHidden( item ) )
- layerfilegroupnode.setAttribute( "hidden", "true" );
- else
- layerfilegroupnode.setAttribute( "hidden", "false" );
- legendlayernode.appendChild( layerfilegroupnode );
- break;
- case QgsLegendItem::LEGEND_LAYER_FILE:
- legendlayerfilenode = document.createElement( "legendlayerfile" );
- llf = qobject_cast<QgsLegendLayerFile *>( item );
- if ( llf )
- QgsMapLayer* layer = llf->layer();
// layer id
legendlayerfilenode.setAttribute( "layerid", layer->getLayerID() );
layerfilegroupnode.appendChild( legendlayerfilenode );
// visible flag
- legendlayerfilenode.setAttribute( "visible", llf->isVisible() );
+ legendlayerfilenode.setAttribute( "visible", ll->isVisible() );
// show in overview flag
- legendlayerfilenode.setAttribute( "isInOverview", llf->isInOverview() );
+ legendlayerfilenode.setAttribute( "isInOverview", ll->isInOverview() );
break;
+ case QgsLegendItem::LEGEND_PROPERTY_GROUP:
+ legendpropertynode = document.createElement( "propertygroup" );
+ legendpropertynode.setAttribute( "open", isItemExpanded( item ) ? "true" : "false" );
+ legendlayernode.appendChild( legendpropertynode );
+ break;
+ case QgsLegendItem::LEGEND_SYMBOL_GROUP:
+ legendsymbolnode = document.createElement( "symbolgroup" );
+ legendsymbolnode.setAttribute( "open", isItemExpanded( item ) ? "true" : "false" );
+ legendlayernode.appendChild( legendsymbolnode );
+ break;
default: //do nothing for the leaf nodes
break;
@@ -1093,7 +901,6 @@
QDomNode child;
QgsLegendGroup* lastGroup = 0; //pointer to the last inserted group
QgsLegendLayer* lastLayer = 0; //pointer to the last inserted legendlayer
- QgsLegendLayerFileGroup* lastLayerFileGroup = 0; //pointer to the last inserted layerfilegroup
child = legendnode.firstChild();
@@ -1142,103 +949,37 @@
else if ( childelem.tagName() == "legendlayer" )
- //add the legendlayer to the legend (but no legendlayerfile yet, follows later)
- //if childelem is in a legendgroup element, add the layer to the group
- QgsLegendLayer* theLayer;
- if ( child.parentNode().toElement().tagName() == "legendgroup" )
- theLayer = new QgsLegendLayer( lastGroup, name );
- else
- theLayer = new QgsLegendLayer( this, name );
- lastGroup = 0;
- childelem.attribute( "open" ) == "true" ? expanded.push_back( theLayer ) : collapsed.push_back( theLayer );
+ bool isOpen; // to recieve info whether the item is open or closed
+ lastLayer = readLayerFromXML(childelem, isOpen);
- //set the checkbox of the legend layer to the right state
- blockSignals( true );
- QString checked = childelem.attribute( "checked", "Qt::Checked" ); // Default is to show
- if ( checked == "Qt::Checked" )
+ if (lastLayer)
- theLayer->setCheckState( 0, Qt::Checked );
- mStateOfCheckBoxes.insert( std::make_pair( theLayer, Qt::Checked ) );
- else if ( checked == "Qt::Unchecked" )
- theLayer->setCheckState( 0, Qt::Unchecked );
- mStateOfCheckBoxes.insert( std::make_pair( theLayer, Qt::Unchecked ) );
- else if ( checked == "Qt::PartiallyChecked" )
- theLayer->setCheckState( 0, Qt::PartiallyChecked );
- mStateOfCheckBoxes.insert( std::make_pair( theLayer, Qt::PartiallyChecked ) );
- blockSignals( false );
- lastLayer = theLayer;
- else if ( childelem.tagName() == "legendlayerfile" )
- //find out the legendlayer
- QgsMapLayer* theMapLayer = QgsMapLayerRegistry::instance()->mapLayer( childelem.attribute( "layerid" ) );
- if ( theMapLayer == NULL ) //the layer cannot be found (e.g. the file has been moved)
- // remove the whole legendlayer if this is the only legendlayerfile
- if ( childelem.previousSibling().isNull() && childelem.nextSibling().isNull() )
+ // add to tree - either as a top-level node or a child of a group
+ if ( child.parentNode().toElement().tagName() == "legendgroup" )
- collapsed.removeAll( lastLayer );
- expanded.removeAll( lastLayer );
- delete lastLayer;
- lastLayer = 0;
+ lastGroup->addChild( lastLayer );
- else if ( lastLayerFileGroup )
- QgsLegendLayerFile* theLegendLayerFile = new QgsLegendLayerFile( lastLayerFileGroup, QgsLegendLayerFile::nameFromLayer( theMapLayer ), theMapLayer );
- // load layer's visibility and 'show in overview' flag
- theLegendLayerFile->setVisible( atoi( childelem.attribute( "visible", "1" ).toUtf8() ) ); //Default is visible
- theLegendLayerFile->setInOverview( atoi( childelem.attribute( "isInOverview" ).toUtf8() ) );
- // set the check state
- if ( theLegendLayerFile->isVisible() )
- mStateOfCheckBoxes.insert( std::make_pair( theLegendLayerFile, Qt::Checked ) );
- theLegendLayerFile->setCheckState( 0, Qt::Checked );
else
- mStateOfCheckBoxes.insert( std::make_pair( theLegendLayerFile, Qt::Unchecked ) );
- theLegendLayerFile->setCheckState( 0, Qt::Unchecked );
+ addTopLevelItem(lastLayer);
+ lastGroup = 0;
- //set the layer type icon if this legendlayerfile is the last in the file group
- if ( child.nextSibling().isNull() )
- static_cast<QgsLegendLayer*>( theLegendLayerFile->parent()->parent() )->updateIcon();
+ // expanded or collapsed
+ isOpen ? expanded.push_back( lastLayer ) : collapsed.push_back( lastLayer );
- theLegendLayerFile->updateLegendItem();
- refreshLayerSymbology( theMapLayer->getLayerID() );
- // setup connections that will update the layer icons
- if ( qobject_cast<QgsVectorLayer *>( theMapLayer ) )
- QgsDebugMsg( "Connecting signals for updating icons, layer " + theMapLayer->name() );
- connect( theMapLayer, SIGNAL( editingStarted() ), lastLayer, SLOT( updateIcon() ) );
- connect( theMapLayer, SIGNAL( editingStopped() ), lastLayer, SLOT( updateIcon() ) );
+ // load symbology
+ refreshLayerSymbology( lastLayer->layer()->getLayerID() );
+ else if ( childelem.tagName() == "legendlayerfile" )
+ // do nothing, this has been handled in readLayerFromXML()
else if ( childelem.tagName() == "filegroup" )
- QgsLegendLayerFileGroup* theFileGroup = new QgsLegendLayerFileGroup( lastLayer, "Files" );
- childelem.attribute( "open" ) == "true" ? expandItem( theFileGroup ) : collapseItem( theFileGroup );
- childelem.attribute( "hidden" ) == "true" ? theFileGroup->setHidden( true ) : theFileGroup->setHidden( false );
- lastLayerFileGroup = theFileGroup;
else if ( childelem.tagName() == "propertygroup" )
@@ -1259,6 +1000,64 @@
return true;
+QgsLegendLayer* QgsLegend::readLayerFromXML(QDomElement& childelem, bool& isOpen)
+ QDomElement fileGroupElem = childelem.firstChildElement("filegroup");
+ if (fileGroupElem.isNull())
+ return NULL; // we need a file group!
+ QDomElement fileElem = fileGroupElem.firstChildElement("legendlayerfile");
+ if (fileElem.isNull()) // we need a file element!
+ return NULL;
+ QgsMapLayer* theMapLayer = QgsMapLayerRegistry::instance()->mapLayer( fileElem.attribute( "layerid" ) );
+ if ( theMapLayer == NULL ) //the layer cannot be found (e.g. the file has been moved)
+ return NULL;
+ // create the item
+ QgsLegendLayer* ll = new QgsLegendLayer( theMapLayer );
+ // load layer's visibility and 'show in overview' flag
+ ll->setInOverview( atoi( fileElem.attribute( "isInOverview" ).toUtf8() ) );
+ //set the layer type icon
+ ll->updateIcon();
+ // setup connections that will update the layer icons
+ if ( qobject_cast<QgsVectorLayer *>( theMapLayer ) )
+ QgsDebugMsg( "Connecting signals for updating icons, layer " + theMapLayer->name() );
+ connect( theMapLayer, SIGNAL( editingStarted() ), ll, SLOT( updateIcon() ) );
+ connect( theMapLayer, SIGNAL( editingStopped() ), ll, SLOT( updateIcon() ) );
+ isOpen = (childelem.attribute( "open" ) == "true");
+ //set the checkbox of the legend layer to the right state
+ blockSignals( true );
+ QString checked = childelem.attribute( "checked", "Qt::Checked" ); // Default is to show
+ if ( checked == "Qt::Checked" )
+ ll->setVisible(true);
+ ll->setCheckState( 0, Qt::Checked );
+ mStateOfCheckBoxes.insert( std::make_pair( ll, Qt::Checked ) );
+ else if ( checked == "Qt::Unchecked" )
+ ll->setVisible(false);
+ ll->setCheckState( 0, Qt::Unchecked );
+ mStateOfCheckBoxes.insert( std::make_pair( ll, Qt::Unchecked ) );
+ blockSignals( false );
+ return ll;
void QgsLegend::storeInitialPosition( QTreeWidgetItem* li )
if ( li == firstItem() ) //the item is the first item in the list view
@@ -1325,20 +1124,15 @@
QgsLegendLayer* QgsLegend::findLegendLayer( const QString& layerKey )
QgsLegendLayer* theLegendLayer = 0;
- std::list<QgsMapLayer*> theMapLayers;
do
theLegendLayer = dynamic_cast<QgsLegendLayer *>( theItem );
if ( theLegendLayer ) //item is a legend layer
- theMapLayers = theLegendLayer->mapLayers();
- for ( std::list<QgsMapLayer*>::iterator it = theMapLayers.begin(); it != theMapLayers.end(); ++it )
+ if (theLegendLayer->layer()->getLayerID() == layerKey)
- if (( *it )->getLayerID() == layerKey )
- return theLegendLayer;
+ return theLegendLayer;
@@ -1556,10 +1350,10 @@
while ( theItem )
- if ( llf )
+ if ( ll )
- QgsMapCanvasLayer& lyr = llf->canvasLayer();
+ QgsMapCanvasLayer& lyr = ll->canvasLayer();
layers.append( lyr );
@@ -1579,10 +1373,10 @@
while ( theItem )
- QgsLegendLayerFile* llf = dynamic_cast<QgsLegendLayerFile *>( theItem );
- if ( llf )
+ QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( theItem );
+ if ( ll )
- llf->setInOverview( isInOverview );
+ ll->setInOverview( isInOverview );
@@ -1597,10 +1391,10 @@
while ( theItem )
- if ( llf )
+ if ( ll )
- QgsMapLayer *lyr = llf->layer();
+ QgsMapLayer *lyr = ll->layer();
layers.push_front( lyr->getLayerID() );
@@ -1677,22 +1471,7 @@
//todo: adapt the icon size if height is the largest value and the size of the next element is higher than the minimum
-void QgsLegend::setName( QgsLegendLayerFile* legendLayerFile,
- QString layerName )
- if ( legendLayerFile )
- QTreeWidgetItem* p = legendLayerFile->parent();
- if ( p )
- p = p->parent();
- if ( p )
- p->setText( 0, layerName );
void QgsLegend::handleItemChange( QTreeWidgetItem* item, int row )
if ( !item )
@@ -1700,15 +1479,14 @@
return;
+ bool renderFlagState = mMapCanvas->renderFlag();
//if the text of a QgsLegendLayer has changed, change the display names of all its maplayers
+ // TODO: is this still necessary?
QgsLegendLayer* theLegendLayer = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
- std::list<QgsMapLayer*> theMapLayers = theLegendLayer->mapLayers();
- ( *it )->setLayerName( theLegendLayer->text( 0 ) );
+ theLegendLayer->layer()->setLayerName( theLegendLayer->text( 0 ) );
std::map<QTreeWidgetItem*, Qt::CheckState>::iterator it = mStateOfCheckBoxes.find( item );
@@ -1719,46 +1497,14 @@
if ( it->second == item->checkState( 0 ) )
return;
- QgsLegendLayerFile* llf = dynamic_cast<QgsLegendLayerFile *>( item ); //item is a layer file
- if ( llf )
- llf->setVisible( item->checkState( 0 ) == Qt::Checked );
- //update check state of the legend layer
- QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( item->parent()->parent() );
- if ( ll )
- ll->updateCheckState();
- mStateOfCheckBoxes[ll] = ll->checkState( 0 );
- //update check state of the legend group (if any)
- if ( item->parent()->parent()->parent() )
- QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item->parent()->parent()->parent() );
- if ( lg )
- lg->updateCheckState();
- mStateOfCheckBoxes[lg] = lg->checkState( 0 );
- mStateOfCheckBoxes[item] = item->checkState( 0 );
- // Setting the renderFlag to true will trigger a render,
- // so only do this if the flag is alread set to true.
- if ( mMapCanvas->renderFlag() )
- mMapCanvas->setRenderFlag( true );
- std::list<QgsLegendLayerFile*> subfiles;
QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item ); //item is a legend group
if ( lg )
//set all the child layer files to the new check state
- subfiles = lg->legendLayerFiles();
+ std::list<QgsLegendLayer*> subfiles = lg->legendLayers();
mMapCanvas->setRenderFlag( false );
- for ( std::list<QgsLegendLayerFile*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
+ for ( std::list<QgsLegendLayer*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
#ifdef QGISDEBUG
if ( item->checkState( 0 ) == Qt::Checked )
@@ -1784,12 +1530,6 @@
- //update the check states of all child legend layers
- for ( int i = 0; i < lg->childCount(); ++i )
- static_cast<QgsLegendLayer*>( lg->child( i ) )->updateCheckState();
- mStateOfCheckBoxes[lg->child( i )] = lg->child( i )->checkState( 0 );
// If it was on, turn it back on, otherwise leave it
// off, as turning it on causes a refresh.
if ( renderFlagState )
@@ -1800,22 +1540,15 @@
QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
if ( ll )
- //set all the child layer files to the new check state
- subfiles = ll->legendLayerFiles();
- bool renderFlagState = mMapCanvas->renderFlag();
- mMapCanvas->freeze( true );
- mMapCanvas->setRenderFlag( false );
+ ll->setCheckState( 0, item->checkState( 0 ) );
+ mStateOfCheckBoxes[ll] = item->checkState( 0 );
+ if (ll->layer() )
- ( *iter )->setCheckState( 0, item->checkState( 0 ) );
- mStateOfCheckBoxes[( *iter )] = item->checkState( 0 );
- if (( *iter )->layer() )
- ( *iter )->setVisible( item->checkState( 0 ) == Qt::Checked );
+ ll->setVisible( item->checkState( 0 ) == Qt::Checked );
if ( ll->parent() )
static_cast<QgsLegendGroup*>( ll->parent() )->updateCheckState();
@@ -1857,84 +1590,17 @@
-void QgsLegend::showLegendLayerFileGroups()
- // Toggle the boolean associated with the checkbox
- mShowLegendLayerFiles = !mShowLegendLayerFiles;
- QgsLegendLayerFileGroup* theFileGroup = 0;
- QTreeWidgetItem* theItem = firstItem();
- if ( !theItem )
- return;
- do
- // This call seems to fix a bug in Qt4.2 (qgis trac #405) whereby the
- // setHidden() call in the if statement below doesn't result in
- // correct drawing of the visible file group part of the tree,
- // but doing this setHidden() call does result in correct drawing.
- theItem->setHidden( false );
- theFileGroup = dynamic_cast<QgsLegendLayerFileGroup *>( theItem );
- if ( theFileGroup )
- theFileGroup->setHidden( !mShowLegendLayerFiles );
- while (( theItem = nextItem( theItem ) ) );
void QgsLegend::legendLayerZoom()
- std::list<QgsLegendLayerFile*> layerFiles;
//find current Layer
QgsLegendLayer* currentLayer = dynamic_cast<QgsLegendLayer *>( currentItem() );
- if ( currentLayer )
- layerFiles = currentLayer->legendLayerFiles();
- else
- if ( llf )
- // user selected legend layer file - use just that one
- layerFiles.push_back( llf );
- if ( layerFiles.size() == 0 )
+ if ( !currentLayer )
return;
- QgsMapLayer* theLayer;
- bool first( true );
- QgsRectangle extent;
+ QgsMapLayer* theLayer = currentLayer->layer();
+ QgsRectangle extent = theLayer->extent();
- for ( std::list<QgsLegendLayerFile*>::iterator it = layerFiles.begin(); it != layerFiles.end(); ++it )
- theLayer = ( *it )->layer();
- if ( !theLayer )
- continue;
- QgsRectangle lyrExtent = mMapCanvas->mapRenderer()->layerExtentToOutputExtent( theLayer, theLayer->extent() );
- if ( !lyrExtent.isFinite() )
- lyrExtent = theLayer->extent();
- if ( first )
- extent = lyrExtent;
- first = false;
- else
- extent.combineExtentWith( &lyrExtent );
// Increase bounding box with 5%, so that layer is a bit inside the borders
extent.scale( 1.05 );
@@ -1948,17 +1614,12 @@
void QgsLegend::legendLayerZoomNative()
- QgsLegendItem* citem = dynamic_cast<QgsLegendItem *>( currentItem() );
- if ( !citem )
+ //find current Layer
+ QgsLegendLayer* currentLayer = dynamic_cast<QgsLegendLayer *>( currentItem() );
return;
- QgsLegendLayer* ll = qobject_cast<QgsLegendLayer *>( citem );
- if ( !ll )
- return;
- QgsRasterLayer *layer = qobject_cast<QgsRasterLayer *>( ll->firstMapLayer() );
+ QgsRasterLayer *layer = qobject_cast<QgsRasterLayer *>( currentLayer->layer() );
if ( layer )
QgsDebugMsg( "Raster units per pixel : " + QString::number( layer->rasterUnitsPerPixel() ) );
@@ -1985,34 +1646,22 @@
// try whether it's a legend layer
- if ( ll )
+ if ( !ll )
- vlayer = qobject_cast<QgsVectorLayer *>( ll->firstMapLayer() );
+ // nothing selected
+ QMessageBox::information( this,
+ tr( "No Layer Selected" ),
+ tr( "To open an attribute table, you must select a vector layer in the legend" ) );
+ return;
- if ( !vlayer )
- // try whether it's a legend layer file
- if ( llf )
- vlayer = qobject_cast<QgsVectorLayer *>( llf->layer() );
+ vlayer = qobject_cast<QgsVectorLayer *>( ll->layer() );
if ( vlayer )
QgsAttributeTableDialog *mDialog = new QgsAttributeTableDialog( vlayer );
mDialog->show();
// the dialog will be deleted by itself on close
- else
- // nothing selected
- QMessageBox::information( this,
- tr( "No Layer Selected" ),
- tr( "To open an attribute table, you must select a vector layer in the legend" ) );
void QgsLegend::readProject( const QDomDocument & doc )
Modified: trunk/qgis/src/app/legend/qgslegend.h
--- trunk/qgis/src/app/legend/qgslegend.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegend.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -26,11 +26,11 @@
#include <QTreeWidget>
class QgsLegendLayer;
-class QgsLegendLayerFile;
class QgsLegendItem;
class QgsMapLayer;
class QgsMapCanvas;
class QDomDocument;
+class QDomElement;
class QDomNode;
class QMouseEvent;
class QTreeWidgetItem;
@@ -69,12 +69,6 @@
<li>QgsLegendPropertyItem - A list of properties related to the layer. Double clicking
a property item will invoke a dialog that will let you change
the property settings. Can only exist inside a property group</li>
- <li>QgsLegendLayerFileGroup - each QgsLegendLayer can have one or more files associated
- with it. This is the container group for these files. Can
- only exist inside of a QgsLegendLayer.</li>
- <li>QgsLegendLayerFile - A file node that relates to a file on disk. Assigning multiple
- file nodes in a file group allows you treat them as if they are
- one entity.</li>
</ul>
@note Additional group types may be defined in the future to accommodate WMS, PostGIS etc layers.
@author Gary E.Sherman, Tim Sutton, Marco Hugentobler and Jens Oberender
@@ -101,10 +95,10 @@
//! Destructor
~QgsLegend();
- /** Returns QgsLegendLayerFile associated with current layer */
- QgsLegendLayerFile* currentLayerFile();
+ /** Returns QgsLegendLayer associated with current layer */
+ QgsLegendLayer* currentLegendLayer();
- /*!Returns the current layer if the current item is a QgsLegendLayerFile.
+ /*!Returns the current layer if the current item is a QgsLegendLayer.
If the current item is a QgsLegendLayer, its first maplayer is returned.
Else, 0 is returned.*/
QgsMapLayer* currentLayer();
@@ -168,10 +162,6 @@
/**Removes an entry from mPixmapHeightValues*/
void removePixmapHeightValue( int height );
- /** Sets the name of the QgsLegendLayer that is the parent of
- the given QgsLegendLayerFile */
- void setName( QgsLegendLayerFile* w, QString layerName );
/**Sets the toggle editing action. Usually called from QgisApp*/
void setToggleEditingAction( QAction* editingAction ) {mToggleEditingAction = editingAction;}
@@ -219,7 +209,7 @@
/** called to write legend settings to project */
void writeProject( QDomDocument & );
- /**Removes the current LegendLayer and all its LegendLayerFiles*/
+ /**Removes the current LegendLayer*/
void legendLayerRemove();
/**Removes a layer. If the layer is editable, a dialog is shown where user can select 'save', 'discard' and optionally 'cancel'. Cancel
@@ -332,6 +322,9 @@
/** Returns the last visible item in the tree widget */
QTreeWidgetItem *lastVisibleItem();
+ /** read layer settings from XML element and add item */
+ QgsLegendLayer* readLayerFromXML(QDomElement& childelem, bool& isOpen);
private slots:
/**Calls 'handleRightClickEvent' on the item*/
@@ -350,8 +343,6 @@
void openEditor();
/**Removes the current item and inserts it as a toplevel item at the end of the legend*/
void makeToTopLevelItem();
- /**Show/ Hide the legend layer file groups*/
- void showLegendLayerFileGroups();
private:
@@ -396,8 +387,6 @@
HIERARCHY_POSITION_TYPE mRestoreInformation;
QTreeWidgetItem* mRestoreItem;
- bool mShowLegendLayerFiles;
/**Stores the layer ordering before a mouse Move. After the move, this is used to
decide if the mapcanvas really has to be refreshed*/
std::deque<QString> mLayersPriorToMove;
Modified: trunk/qgis/src/app/legend/qgslegendgroup.cpp
--- trunk/qgis/src/app/legend/qgslegendgroup.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendgroup.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -21,7 +21,6 @@
#include "qgisapp.h"
#include "qgslegendgroup.h"
#include <QCoreApplication>
#include <QIcon>
@@ -96,7 +95,7 @@
return NO_ACTION;
-bool QgsLegendGroup::insert( QgsLegendItem* theItem )
+/*bool QgsLegendGroup::insert( QgsLegendItem* theItem )
if ( theItem->type() == LEGEND_LAYER )
@@ -106,18 +105,17 @@
// XXX - mloskot - I don't know what to return
// but this function must return a value
return true;
-std::list<QgsLegendLayerFile*> QgsLegendGroup::legendLayerFiles()
+std::list<QgsLegendLayer*> QgsLegendGroup::legendLayers()
- std::list<QgsLegendLayerFile*> result;
+ std::list<QgsLegendLayer*> result;
for ( int i = 0; i < childCount(); ++i )
QgsLegendLayer* childItem = dynamic_cast<QgsLegendLayer *>( child( i ) );
if ( childItem )
- std::list<QgsLegendLayerFile*> childList = childItem->legendLayerFiles();
- result.splice( result.end(), childList );
+ result.push_back(childItem);
return result;
@@ -125,15 +123,15 @@
void QgsLegendGroup::updateCheckState()
- std::list<QgsLegendLayerFile*> llfiles = legendLayerFiles();
- if ( llfiles.size() < 1 )
+ std::list<QgsLegendLayer*> llayers = legendLayers();
+ if ( llayers.size() == 0 )
return;
- std::list<QgsLegendLayerFile*>::iterator iter = llfiles.begin();
+ std::list<QgsLegendLayer*>::iterator iter = llayers.begin();
Qt::CheckState theState = ( *iter )->checkState( 0 );
- for ( ; iter != llfiles.end(); ++iter )
+ for ( ; iter != llayers.end(); ++iter )
if ( theState != ( *iter )->checkState( 0 ) )
Modified: trunk/qgis/src/app/legend/qgslegendgroup.h
--- trunk/qgis/src/app/legend/qgslegendgroup.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendgroup.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -23,7 +23,6 @@
#include <list>
#include <qgslegenditem.h>
This is a specialised version of QLegendItem that specifies that the items below this point will be treated as a group. For example hiding this node will hide all layers below that are members of the group.
@@ -41,10 +40,10 @@
QgsLegendItem::DRAG_ACTION accept( LEGEND_ITEM_TYPE type );
QgsLegendItem::DRAG_ACTION accept( const QgsLegendItem* li ) const;
bool isLeafNode();
- bool insert( QgsLegendItem* theItem );
- /**Returns all legend layer files under this group*/
- std::list<QgsLegendLayerFile*> legendLayerFiles();
- /**Goes through all the legendlayerfiles and sets check state to checked/partially checked/unchecked*/
+ //bool insert( QgsLegendItem* theItem );
+ /**Returns all legend layers under this group*/
+ std::list<QgsLegendLayer*> legendLayers();
+ /**Goes through all the legendlayers and sets check state to checked/partially checked/unchecked*/
void updateCheckState();
Modified: trunk/qgis/src/app/legend/qgslegenditem.h
--- trunk/qgis/src/app/legend/qgslegenditem.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegenditem.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -66,7 +66,6 @@
virtual bool isLeafNode() = 0;
virtual LEGEND_ITEM_TYPE type() const {return mType;}
- virtual void addItem( QgsLegendItem* ) {}
/**Returns the type of action that will be done if a drag, originating at a certain
item type, will be released at this item*/
virtual DRAG_ACTION accept( LEGEND_ITEM_TYPE type ) = 0;
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -22,8 +22,6 @@
#include "qgslegend.h"
#include "qgslogger.h"
@@ -35,6 +33,10 @@
#include "qgssymbol.h"
#include "qgsvectorlayer.h"
#include "qgsvectordataprovider.h"
+#include "qgsvectorfilewriter.h"
+#include "qgsgenericprojectionselector.h"
+#include "qgsattributetabledialog.h"
+#include "qgsencodingfiledialog.h"
#include <iostream>
#include <QAction>
@@ -45,32 +47,39 @@
#include <QPainter>
#include <QSettings>
-QgsLegendLayer::QgsLegendLayer( QTreeWidgetItem* parent, QString name )
- : QgsLegendItem( parent, name )
- mType = LEGEND_LAYER;
- setFlags( Qt::ItemIsEditable | Qt::ItemIsUserCheckable | Qt::ItemIsEnabled | Qt::ItemIsSelectable );
- setCheckState( 0, Qt::Checked );
- setText( 0, name );
- setupFont();
-QgsLegendLayer::QgsLegendLayer( QTreeWidget* parent, QString name ): QgsLegendItem( parent, name )
+QgsLegendLayer::QgsLegendLayer( QgsMapLayer* layer )
+ : QgsLegendItem( ),
+ mLyr( layer )
+ setText( 0, layer->name() );
setupFont();
-QgsLegendLayer::QgsLegendLayer( QString name ): QgsLegendItem()
- setupFont();
+ // Set the initial visibility flag for layers
+ // This user option allows the user to turn off initial drawing of
+ // layers when they are added to the map. This is useful when adding
+ // many layers and the user wants to adjusty symbology, etc prior to
+ // actually viewing the layer.
+ QSettings settings;
+ bool visible = settings.value( "/qgis/new_layers_visible", true ).toBool();
+ mLyr.setVisible( visible );
+ // not in overview by default
+ mLyr.setInOverview( FALSE );
+ // Add check if vector layer when connecting to selectionChanged slot
+ // Ticket #811 - racicot
+ QgsMapLayer *currentLayer = mLyr.layer();
+ QgsVectorLayer *isVectLyr = qobject_cast<QgsVectorLayer *>( currentLayer );
+ if ( isVectLyr )
+ connect( mLyr.layer(), SIGNAL( editingStarted() ), this, SLOT( updateLegendItem() ) );
+ connect( mLyr.layer(), SIGNAL( editingStopped() ), this, SLOT( updateLegendItem() ) );
+ connect( mLyr.layer(), SIGNAL( layerNameChanged() ), this, SLOT( layerNameChanged() ) );
QgsLegendLayer::~QgsLegendLayer()
@@ -126,135 +135,12 @@
return NO_ACTION;
-QgsLegendLayerFile* QgsLegendLayer::firstLayerFile() const
- //first find the legend layer file group
- QgsLegendLayerFileGroup* llfg = 0;
- for ( int i = 0; i < childCount(); ++i )
- llfg = dynamic_cast<QgsLegendLayerFileGroup *>( child( i ) );
- if ( llfg )
- break;
- if ( !llfg )
- return 0;
- QTreeWidgetItem* llf = llfg->child( 0 );
- if ( !llf )
- return 0;
- QgsLegendLayerFile* legendlayerfile = dynamic_cast<QgsLegendLayerFile *>( llf );
- return legendlayerfile;
-QgsMapLayer* QgsLegendLayer::firstMapLayer() const
+QgsMapLayer* QgsLegendLayer::layer()
- QgsLegendLayerFile* llf = firstLayerFile();
- if ( llf )
- else
- return 0;
+ return mLyr.layer();
-std::list<QgsMapLayer*> QgsLegendLayer::mapLayers()
- std::list<QgsMapLayer*> list;
- std::list<QgsLegendLayerFile*> llist = legendLayerFiles();
- for ( std::list<QgsLegendLayerFile*>::iterator it = llist.begin(); it != llist.end(); ++it )
- list.push_back(( *it )->layer() );
- return list;
-std::list<QgsLegendLayerFile*> QgsLegendLayer::legendLayerFiles()
- std::list<QgsLegendLayerFile*> list;
- //find the layer file group
- QgsLegendLayerFileGroup* theLayerGroup = 0;
- theLayerGroup = dynamic_cast<QgsLegendLayerFileGroup *>( child( i ) );
- if ( theLayerGroup )
- break;
- //add all the legend layer files in the group
- QgsLegendLayerFile* theFile = 0;
- for ( int i = 0; i < theLayerGroup->childCount(); ++i )
- theFile = dynamic_cast<QgsLegendLayerFile *>( theLayerGroup->child( i ) );
- if ( theFile )
- list.push_back( theFile );
- return list;
-void QgsLegendLayer::updateLayerSymbologySettings( const QgsMapLayer* mapLayer )
- if ( mapLayer )
- //find all layers
- std::list<QgsMapLayer*> theMapLayers = mapLayers();
- if (( *it ) != mapLayer )
- ( *it )->copySymbologySettings( *mapLayer );
- // source might have changed - e.g. other subset
- setToolTip( 0, mapLayer->publicSource() );
-void QgsLegendLayer::updateCheckState()
- return;
- Qt::CheckState theState = ( *iter )->checkState( 0 );
- if ( theState != ( *iter )->checkState( 0 ) )
- theState = Qt::PartiallyChecked;
- break;
- if ( theState != checkState( 0 ) )
- treeWidget()->blockSignals( true );
- setCheckState( 0, theState );
- //notify the legend that the check state has changed
- legend()->updateCheckStates( this, theState );
- treeWidget()->blockSignals( false );
void QgsLegendLayer::refreshSymbology( const QString& key, double widthScale )
QgsMapLayer* theMapLayer = QgsMapLayerRegistry::instance()->mapLayer( key );
@@ -307,9 +193,6 @@
++childposition;
- //copy the legend settings for the other layer files in the same legend layer
- updateLayerSymbologySettings( theMapLayer );
@@ -401,48 +284,48 @@
QPixmap newIcon( getOriginalPixmap() );
- QgsMapLayer* theLayer = firstMapLayer();
+ QgsMapLayer* theLayer = layer();
- if ( mapLayers().size() == 1 )
+ //overview
+ // FIXME: overview icon is missing
+ if ( theFile->isInOverview() )
- //overview
- // FIXME: overview icon is missing
- if ( theFile->isInOverview() )
- // Overlay the overview icon on the default icon
- QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconOverview.png" );
- QPainter p( &newIcon );
- p.drawPixmap( 0, 0, myPixmap );
- p.end();
+ // Overlay the overview icon on the default icon
+ QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconOverview.png" );
+ QPainter p( &newIcon );
+ p.drawPixmap( 0, 0, myPixmap );
+ p.end();
- //editable
- if ( theLayer->isEditable() )
- QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconEditable.png" );
- // use editable icon instead of the layer's type icon
- newIcon = myPixmap;
+ //editable
+ if ( theLayer->isEditable() )
+ QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconEditable.png" );
+ // use editable icon instead of the layer's type icon
+ newIcon = myPixmap;
- // Overlay the editable icon on the default icon
- /*QPainter p( &newIcon );
- p.end();*/
+ // Overlay the editable icon on the default icon
+ /*QPainter p( &newIcon );
+ p.end();*/
+ // TODO: projection error icon?
QIcon theIcon( newIcon );
setIcon( 0, theIcon );
-QPixmap QgsLegendLayer::getOriginalPixmap() const
+QPixmap QgsLegendLayer::getOriginalPixmap()
- QgsMapLayer* firstLayer = firstMapLayer();
- if ( firstLayer )
+ if ( theLayer )
- if ( firstLayer->type() == QgsMapLayer::VectorLayer )
+ if ( theLayer->type() == QgsMapLayer::VectorLayer )
- QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( firstLayer );
+ QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( theLayer );
switch ( vlayer->geometryType() )
case QGis::Point:
@@ -458,9 +341,9 @@
return QgisApp::getThemePixmap( "/mIconLayer.png" );
- else if ( firstLayer->type() == QgsMapLayer::RasterLayer )
+ else if ( theLayer->type() == QgsMapLayer::RasterLayer )
- QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>( firstLayer );
+ QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>( theLayer );
QPixmap myPixmap( 32, 32 );
rlayer->thumbnailAsPixmap( &myPixmap );
return myPixmap;
@@ -473,25 +356,23 @@
void QgsLegendLayer::addToPopupMenu( QMenu& theMenu, QAction* toggleEditingAction )
- std::list<QgsLegendLayerFile*> files = legendLayerFiles();
- QgsMapLayer* firstLayer = NULL;
- if ( files.size() > 0 )
- firstLayer = files.front()->layer();
+ QgsMapLayer* lyr = layer();
// zoom to layer extent
theMenu.addAction( QgisApp::getThemeIcon( "/mActionZoomToLayer.png" ),
tr( "&Zoom to layer extent" ), legend(), SLOT( legendLayerZoom() ) );
- if ( firstLayer && firstLayer->type() == QgsMapLayer::RasterLayer )
+ if ( lyr->type() == QgsMapLayer::RasterLayer )
theMenu.addAction( tr( "&Zoom to best scale (100%)" ), legend(), SLOT( legendLayerZoomNative() ) );
// show in overview
QAction* showInOverviewAction = theMenu.addAction( tr( "&Show in overview" ), this, SLOT( showInOverview() ) );
- showInOverviewAction->setCheckable( true ); // doesn't support tristate
- showInOverviewAction->setChecked( isInOverview() );
+ showInOverviewAction->setCheckable( true );
+ showInOverviewAction->blockSignals( true );
+ showInOverviewAction->setChecked( mLyr.isInOverview() );
+ showInOverviewAction->blockSignals( false );
// remove from canvas
theMenu.addAction( QgisApp::getThemeIcon( "/mActionRemove.png" ),
@@ -499,42 +380,30 @@
theMenu.addSeparator();
- if ( firstLayer && firstLayer->type() == QgsMapLayer::VectorLayer )
+ if ( lyr->type() == QgsMapLayer::VectorLayer )
+ QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( lyr );
// attribute table
QAction* tableAction = theMenu.addAction( tr( "&Open attribute table" ), this, SLOT( table() ) );
- if ( files.size() != 1 )
- tableAction->setEnabled( false );
// allow editing
- if ( toggleEditingAction )
+ int cap = vlayer->dataProvider()->capabilities();
+ if ( cap & QgsVectorDataProvider::EditingCapabilities )
- theMenu.addAction( toggleEditingAction );
+ if ( toggleEditingAction )
+ theMenu.addAction( toggleEditingAction );
+ toggleEditingAction->setChecked( vlayer->isEditable() );
- QgsVectorLayer* mypVectorLayer = qobject_cast<QgsVectorLayer *>( firstLayer );
- toggleEditingAction->setEnabled( false );
- if ( mypVectorLayer )
- toggleEditingAction->setChecked( mypVectorLayer->isEditable() );
// save as shapefile
QAction* saveShpAction = theMenu.addAction( tr( "Save as shapefile..." ), this, SLOT( saveAsShapefile() ) );
- saveShpAction->setEnabled( false );
// save selection as shapefile
QAction* saveSelectionAction = theMenu.addAction( tr( "Save selection as shapefile..." ), this, SLOT( saveSelectionAsShapefile() ) );
- if ( files.size() != 1 || mypVectorLayer->selectedFeatureCount() == 0 )
+ if ( vlayer->selectedFeatureCount() == 0 )
saveSelectionAction->setEnabled( false );
@@ -542,79 +411,212 @@
+ // properties goes on bottom of menu for consistency with normal ui standards
+ // e.g. kde stuff
+ theMenu.addAction( tr( "&Properties" ), legend(), SLOT( legendLayerShowProperties() ) );
- QAction* propertiesAction = theMenu.addAction( tr( "&Properties" ), legend(), SLOT( legendLayerShowProperties() ) );
- propertiesAction->setEnabled( false );
+void QgsLegendLayer::table()
+ QgsVectorLayer * myLayer = qobject_cast<QgsVectorLayer *>( mLyr.layer() );
+ QgsAttributeTableDialog *mDialog = new QgsAttributeTableDialog( myLayer );
+ mDialog->show();
+ // the dialog will be deleted by itself on close
-bool QgsLegendLayer::isInOverview()
+void QgsLegendLayer::saveAsShapefile()
- // QAction doesn't support tristate checkboxes
- // returns true if just some are in overview
- bool hasVisible = false;
+ saveAsShapefileGeneral( FALSE );
- // find out whether we're showing or hiding them
- std::list<QgsLegendLayerFile*> maplayers = legendLayerFiles();
- for ( std::list<QgsLegendLayerFile*>::iterator it = maplayers.begin(); it != maplayers.end(); ++it )
- if ( *it && ( *it )->isInOverview() )
- hasVisible = true;
- break;
+void QgsLegendLayer::saveSelectionAsShapefile()
+ saveAsShapefileGeneral( TRUE );
- return hasVisible;
+void QgsLegendLayer::setVisible( bool visible )
+bool QgsLegendLayer::isVisible()
+ return mLyr.isVisible();
+void QgsLegendLayer::setInOverview( bool isInOverview )
+ mLyr.setInOverview( isInOverview );
+bool QgsLegendLayer::isInOverview()
+ return mLyr.isInOverview();
void QgsLegendLayer::showInOverview()
- bool showLayers = ( ! isInOverview() );
+ // toggle current status
+ setInOverview( ! isInOverview() );
- // set overview visibility
- if ( *it )
- ( *it )->setInOverview( showLayers );
legend()->updateMapCanvasLayerSet();
legend()->updateOverview();
-void QgsLegendLayer::table()
+void QgsLegendLayer::saveAsShapefileGeneral( bool saveOnlySelection )
- if ( maplayers.size() > 1 )
+ QgsCoordinateReferenceSystem destCRS;
+ if ( mLyr.layer()->type() != QgsMapLayer::VectorLayer )
+ return;
+ QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( mLyr.layer() );
+ // get a name for the shapefile
+ // Get a file to process, starting at the current directory
+ QString filter = QString( "Shapefiles (*.shp)" );
+ QString dirName = settings.value( "/UI/lastShapefileDir", "." ).toString();
+ QgsEncodingFileDialog* openFileDialog = new QgsEncodingFileDialog( 0,
+ tr( "Save layer as..." ),
+ dirName,
+ filter,
+ QString( "" ) );
+ openFileDialog->setAcceptMode( QFileDialog::AcceptSave );
+ // allow for selection of more than one file
+ //openFileDialog->setMode(QFileDialog::AnyFile);
+ if ( openFileDialog->exec() != QDialog::Accepted )
+ return;
+ QString encoding = openFileDialog->encoding();
+ QString shapefileName = openFileDialog->selectedFiles().first();
+ settings.setValue( "/UI/lastShapefileDir", QFileInfo( shapefileName ).absolutePath() );
+ if ( shapefileName.isNull() )
+ return;
+ // add the extension if not present
+ if ( shapefileName.indexOf( ".shp" ) == -1 )
- QMessageBox::information( 0, tr( "Multiple layers" ),
- tr( "This item contains multiple layers. Displaying multiple layers in the table is not supported." ) );
+ shapefileName += ".shp";
- else if ( maplayers.size() == 1 )
+ destCRS = vlayer->srs();
+ // Find out if we have projections enabled or not
+ if ( QgisApp::instance()->mapCanvas()->mapRenderer()->hasCrsTransformEnabled() )
- maplayers.front()->table();
+ destCRS = QgisApp::instance()->mapCanvas()->mapRenderer()->destinationSrs();
-void QgsLegendLayer::saveAsShapefile()
- if ( maplayers.size() == 1 )
+ QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector();
+ mySelector->setSelectedCrsId( destCRS.srsid() );
+ mySelector->setMessage( tr( "Select the coordinate reference system for the saved shapefile. "
+ "The data points will be transformed from the layer coordinate reference system." ) );
+ if ( mySelector->exec() )
- maplayers.front()->saveAsShapefile();
+ QgsCoordinateReferenceSystem srs( mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId );
+ destCRS = srs;
+ // destCRS->createFromId(mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId)
+ else
+ // Aborted CS selection, don't save.
+ delete mySelector;
+ return;
+ // overwrite the file - user will already have been prompted
+ // to verify they want to overwrite by the file dialog above
+ if ( QFile::exists( shapefileName ) )
+ if ( !QgsVectorFileWriter::deleteShapeFile( shapefileName ) )
+ return;
+ // ok if the file existed it should be deleted now so we can continue...
+ QApplication::setOverrideCursor( Qt::WaitCursor );
+ QgsVectorFileWriter::WriterError error;
+ error = QgsVectorFileWriter::writeAsShapefile( vlayer, shapefileName, encoding, &destCRS, saveOnlySelection );
+ QApplication::restoreOverrideCursor();
+ switch ( error )
+ case QgsVectorFileWriter::NoError:
+ QMessageBox::information( 0, tr( "Saving done" ), tr( "Export to Shapefile has been completed" ) );
+ break;
+ case QgsVectorFileWriter::ErrDriverNotFound:
+ QMessageBox::warning( 0, tr( "Driver not found" ), tr( "ESRI Shapefile driver is not available" ) );
+ break;
+ case QgsVectorFileWriter::ErrCreateDataSource:
+ QMessageBox::warning( 0, tr( "Error creating shapefile" ),
+ tr( "The shapefile could not be created (%1)" ).arg( shapefileName ) );
+ break;
+ case QgsVectorFileWriter::ErrCreateLayer:
+ QMessageBox::warning( 0, tr( "Error" ), tr( "Layer creation failed" ) );
+ break;
+ case QgsVectorFileWriter::ErrAttributeTypeUnsupported:
+ tr( "Layer attribute table contains unsupported datatype(s)" ) );
+ break;
+ case QgsVectorFileWriter::ErrAttributeCreationFailed:
+ tr( "Creation of an attribute failed" ) );
+ break;
-void QgsLegendLayer::saveSelectionAsShapefile()
+QString QgsLegendLayer::nameFromLayer( QgsMapLayer* layer )
+ QString sourcename = layer->publicSource(); //todo: move this duplicated code into a new function
+ if ( sourcename.startsWith( "host", Qt::CaseInsensitive ) )
- maplayers.front()->saveSelectionAsShapefile();
+ //this layer is a database layer
+ //modify source string such that password is not visible
+ sourcename = layer->name();
+ else
+ //modify source name such that only the file is visible
+ sourcename = layer->publicSource().section( '/', -1, -1 );
+ return sourcename;
+QgsMapCanvasLayer& QgsLegendLayer::canvasLayer()
+ return mLyr;
+void QgsLegendLayer::layerNameChanged()
+ QString name = mLyr.layer()->name();
+ setText( 0, name );
Modified: trunk/qgis/src/app/legend/qgslegendlayer.h
--- trunk/qgis/src/app/legend/qgslegendlayer.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayer.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -20,12 +20,12 @@
#ifndef QGSLEGENDLAYER_H
#define QGSLEGENDLAYER_H
-//#include <qobject.h>
#include <QFileInfo>
+#include "qgsmapcanvas.h"
class QgsLegendPropertyGroup;
class QgsMapLayer;
class QgsRasterLayer;
@@ -45,25 +45,17 @@
Q_OBJECT
public:
- QgsLegendLayer( QTreeWidgetItem *, QString );
- QgsLegendLayer( QTreeWidget*, QString );
- QgsLegendLayer( QString name );
+ QgsLegendLayer( QgsMapLayer* layer );
~QgsLegendLayer();
bool isLeafNode();
- /**Returns the map layer associated with the first QgsLegendLayerFile or 0 if
- there is no QgsLegendLayerFile*/
- QgsMapLayer* firstMapLayer() const;
- /**Returns first map layer's file or 0 if there's no QgsLegendLayerFile */
- QgsLegendLayerFile* firstLayerFile() const;
- /**Returns the map layers associated with the QgsLegendLayerFiles*/
- std::list<QgsMapLayer*> mapLayers();
- /**Returns the legend layer file items associated with this legend layer*/
+ /**Returns the map layer associated the item*/
+ QgsMapLayer* layer();
+ QgsMapCanvasLayer& canvasLayer();
- void updateCheckState();
+ //void updateCheckState();
/**Updates symbology of the layer and copies symbology to other layer files in the group*/
void refreshSymbology( const QString& key, double widthScale = 1.0 );
@@ -71,9 +63,19 @@
/** called to add appropriate menu items to legend's popup menu */
void addToPopupMenu( QMenu& theMenu, QAction* toggleEditingAction );
+ /** Set layer to be visible in canvas */
+ void setVisible( bool visible = TRUE );
+ /** Find out whether the layer is visible */
+ bool isVisible();
+ void setInOverview( bool isInOverview = TRUE );
/**Determines whether there are layers in overview*/
bool isInOverview();
+ /**Returns a label for a layer. Is static such that
+ the name can be passed to the constructor of QgsLegendLayer*/
+ static QString nameFromLayer( QgsMapLayer* layer );
public slots:
/**Toggle show in overview*/
@@ -85,10 +87,12 @@
void saveAsShapefile();
void saveSelectionAsShapefile();
- /**Goes through all the legendlayerfiles and adds editing/overview pixmaps to the icon. If not all layer files
- have the same editing/overview state, a tristate is applied*/
+ /**update the layer's icon to show whether is in editing mode or in overview */
void updateIcon();
+ /**Layer name has changed - set it also in legend*/
+ void layerNameChanged();
protected:
/** Prepare and change symbology for vector layer */
@@ -97,19 +101,13 @@
/** Prepare and change symbology for raster layer */
void rasterLayerSymbology( QgsRasterLayer* mapLayer );
- /** Removes the symbology items of a layer and adds new ones.
- * If other files are in the same legend layer, the new symbology settings are copied.
- * Note: the QIcon* are deleted and therefore need to be allocated by calling
- * functions using operator new
+ /** Removes the symbology items of a layer and adds new ones. */
void changeSymbologySettings( const QgsMapLayer* mapLayer, const SymbologyList& newSymbologyItems );
- /** Copies the symbology settings of the layer to all maplayers in the QgsLegendLayerFileGroup.
- * This method should be called whenever a layer in this group changes it symbology settings
- void updateLayerSymbologySettings( const QgsMapLayer* mapLayer );
+ QPixmap getOriginalPixmap();
- QPixmap getOriginalPixmap() const;
+ /**Save as shapefile (called from saveAsShapefile and saveSelectionAsShapefile)*/
+ void saveAsShapefileGeneral( bool saveOnlySelection );
private:
/** Helper method to make the font bold from all ctors.
@@ -117,6 +115,11 @@
* from the QTreeWidgetItem base class.
void setupFont();
+ protected:
+ /** layer identified by its layer id */
+ QgsMapCanvasLayer mLyr;
#endif
Deleted: trunk/qgis/src/app/legend/qgslegendlayerfile.cpp
--- trunk/qgis/src/app/legend/qgslegendlayerfile.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayerfile.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -1,424 +0,0 @@
- * Copyright (C) 2005 by Tim Sutton *
- * aps02ts at macbuntu *
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
- * This program is distributed in the hope that it will be useful, *
- * but WITHOUT ANY WARRANTY; without even the implied warranty of *
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
- * GNU General Public License for more details. *
- * You should have received a copy of the GNU General Public License *
- * along with this program; if not, write to the *
- * Free Software Foundation, Inc., *
- * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
-#include "qgsapplication.h"
-#include "qgisapp.h"
-#include "qgslegend.h"
-#include "qgslegendlayer.h"
-#include "qgsmaplayer.h"
-#include "qgsmaprenderer.h"
-#include "qgsrasterlayer.h"
-#include "qgsvectorfilewriter.h"
-#include "qgsvectorlayer.h"
-#include "qgsvectordataprovider.h"
-#include "qgsgenericprojectionselector.h"
-// attribute table
-#include "qgsattributetabledialog.h"
-#include "qgsencodingfiledialog.h"
-#include <QApplication>
-#include <QMenu>
-#include <QMessageBox>
-#include <QPainter>
-#include <QSettings>
-QgsLegendLayerFile::QgsLegendLayerFile( QTreeWidgetItem * theLegendItem, QString theString, QgsMapLayer* theLayer )
- : QgsLegendItem( theLegendItem, theString ), mLyr( theLayer )
- // Set the initial visibility flag for layers
- // This user option allows the user to turn off initial drawing of
- // layers when they are added to the map. This is useful when adding
- // many layers and the user wants to adjusty symbology, etc prior to
- // actually viewing the layer.
- QSettings settings;
- bool visible = settings.value( "/qgis/new_layers_visible", true ).toBool();
- mLyr.setVisible( visible );
- // not in overview by default
- mLyr.setInOverview( FALSE );
- mType = LEGEND_LAYER_FILE;
- setFlags( Qt::ItemIsUserCheckable | Qt::ItemIsEnabled | Qt::ItemIsSelectable );
- setText( 0, theString );
- // Add check if vector layer when connecting to selectionChanged slot
- // Ticket #811 - racicot
- QgsMapLayer *currentLayer = mLyr.layer();
- QgsVectorLayer *isVectLyr = qobject_cast<QgsVectorLayer *>( currentLayer );
- if ( isVectLyr )
- connect( mLyr.layer(), SIGNAL( editingStarted() ), this, SLOT( updateLegendItem() ) );
- connect( mLyr.layer(), SIGNAL( editingStopped() ), this, SLOT( updateLegendItem() ) );
- connect( mLyr.layer(), SIGNAL( layerNameChanged() ), this, SLOT( layerNameChanged() ) );
-QgsLegendItem::DRAG_ACTION QgsLegendLayerFile::accept( LEGEND_ITEM_TYPE type )
- return NO_ACTION;
-QgsLegendItem::DRAG_ACTION QgsLegendLayerFile::accept( const QgsLegendItem* li ) const
- if ( li->parent() == this->parent() )
- return REORDER;
- return NO_ACTION;
-QPixmap QgsLegendLayerFile::getOriginalPixmap() const
- QPixmap myPixmap = QgisApp::getThemePixmap( "mActionFileSmall.png" );
- return myPixmap;
-void QgsLegendLayerFile::updateLegendItem()
- QPixmap pix = legend()->pixmaps().mOriginalPixmap;
- if ( mLyr.isInOverview() )
- //add overview glasses to the pixmap
- QPainter p( &pix );
- p.drawPixmap( 0, 0, legend()->pixmaps().mInOverviewPixmap );
- if ( mLyr.layer()->isEditable() )
- //add editing icon to the pixmap
- p.drawPixmap( 30, 0, legend()->pixmaps().mEditablePixmap );
- // TODO:
- if(mLyr.layer()->hasProjectionError())
- QPainter p(&pix);
- p.drawPixmap(60,0, legend()->pixmaps().mProjectionErrorPixmap);
- QIcon theIcon( pix );
- setIcon( 0, theIcon );
-void QgsLegendLayerFile::setIconAppearance( bool isInOverview,
- bool editable )
- QPixmap newIcon( getOriginalPixmap() );
- if ( isInOverview )
- QPixmap myPixmap = QgisApp::getThemePixmap( "mIconOverview.png" );
- p.end();
- if ( editable )
- QPixmap myPixmap = QgisApp::getThemePixmap( "mIconEditable.png" );
- p.end();
- QIcon theIcon( newIcon );
- //also update the icon of the legend layer
- (( QgsLegendLayer* )( parent()->parent() ) )->updateIcon();
-QString QgsLegendLayerFile::nameFromLayer( QgsMapLayer* layer )
- QString sourcename = layer->publicSource(); //todo: move this duplicated code into a new function
- if ( sourcename.startsWith( "host", Qt::CaseInsensitive ) )
- //this layer is a database layer
- //modify source string such that password is not visible
- sourcename = layer->name();
- else
- //modify source name such that only the file is visible
- sourcename = layer->publicSource().section( '/', -1, -1 );
- return sourcename;
-void QgsLegendLayerFile::setVisible( bool visible )
-bool QgsLegendLayerFile::isVisible()
- return mLyr.isVisible();
-void QgsLegendLayerFile::setInOverview( bool isInOverview )
- mLyr.setInOverview( isInOverview );
-bool QgsLegendLayerFile::isInOverview()
- return mLyr.isInOverview();
-void QgsLegendLayerFile::showInOverview()
- // toggle current status
- setInOverview( ! isInOverview() );
- legend()->updateMapCanvasLayerSet();
- legend()->updateOverview();
-void QgsLegendLayerFile::saveAsShapefile()
- saveAsShapefileGeneral( FALSE );
-void QgsLegendLayerFile::table()
- QgsVectorLayer * myLayer = qobject_cast<QgsVectorLayer *>( mLyr.layer() );
- QgsAttributeTableDialog *mDialog = new QgsAttributeTableDialog( myLayer );
- mDialog->show();
- // the dialog will be deleted by itself on close
-void QgsLegendLayerFile::saveSelectionAsShapefile()
- saveAsShapefileGeneral( TRUE );
-void QgsLegendLayerFile::saveAsShapefileGeneral( bool saveOnlySelection )
- QgsCoordinateReferenceSystem destCRS;
- if ( mLyr.layer()->type() != QgsMapLayer::VectorLayer )
- return;
- QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( mLyr.layer() );
- // get a name for the shapefile
- // Get a file to process, starting at the current directory
- QString filter = QString( "Shapefiles (*.shp)" );
- QString dirName = settings.value( "/UI/lastShapefileDir", "." ).toString();
- QgsEncodingFileDialog* openFileDialog = new QgsEncodingFileDialog( 0,
- tr( "Save layer as..." ),
- dirName,
- filter,
- QString( "" ) );
- openFileDialog->setAcceptMode( QFileDialog::AcceptSave );
- // allow for selection of more than one file
- //openFileDialog->setMode(QFileDialog::AnyFile);
- if ( openFileDialog->exec() != QDialog::Accepted )
- return;
- QString encoding = openFileDialog->encoding();
- QString shapefileName = openFileDialog->selectedFiles().first();
- settings.setValue( "/UI/lastShapefileDir", QFileInfo( shapefileName ).absolutePath() );
- if ( shapefileName.isNull() )
- return;
- // add the extension if not present
- if ( shapefileName.indexOf( ".shp" ) == -1 )
- shapefileName += ".shp";
- destCRS = vlayer->srs();
- // Find out if we have projections enabled or not
- if ( QgisApp::instance()->mapCanvas()->mapRenderer()->hasCrsTransformEnabled() )
- destCRS = QgisApp::instance()->mapCanvas()->mapRenderer()->destinationSrs();
- QgsGenericProjectionSelector * mySelector = new QgsGenericProjectionSelector();
- mySelector->setSelectedCrsId( destCRS.srsid() );
- mySelector->setMessage( tr( "Select the coordinate reference system for the saved shapefile. "
- "The data points will be transformed from the layer coordinate reference system." ) );
- if ( mySelector->exec() )
- QgsCoordinateReferenceSystem srs( mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId );
- destCRS = srs;
- // destCRS->createFromId(mySelector->selectedCrsId(), QgsCoordinateReferenceSystem::InternalCrsId)
- else
- // Aborted CS selection, don't save.
- delete mySelector;
- return;
- // overwrite the file - user will already have been prompted
- // to verify they want to overwrite by the file dialog above
- if ( QFile::exists( shapefileName ) )
- if ( !QgsVectorFileWriter::deleteShapeFile( shapefileName ) )
- return;
- // ok if the file existed it should be deleted now so we can continue...
- QApplication::setOverrideCursor( Qt::WaitCursor );
- QgsVectorFileWriter::WriterError error;
- error = QgsVectorFileWriter::writeAsShapefile( vlayer, shapefileName, encoding, &destCRS, saveOnlySelection );
- QApplication::restoreOverrideCursor();
- switch ( error )
- case QgsVectorFileWriter::NoError:
- QMessageBox::information( 0, tr( "Saving done" ), tr( "Export to Shapefile has been completed" ) );
- break;
- case QgsVectorFileWriter::ErrDriverNotFound:
- QMessageBox::warning( 0, tr( "Driver not found" ), tr( "ESRI Shapefile driver is not available" ) );
- break;
- case QgsVectorFileWriter::ErrCreateDataSource:
- QMessageBox::warning( 0, tr( "Error creating shapefile" ),
- tr( "The shapefile could not be created (%1)" ).arg( shapefileName ) );
- break;
- case QgsVectorFileWriter::ErrCreateLayer:
- QMessageBox::warning( 0, tr( "Error" ), tr( "Layer creation failed" ) );
- break;
- case QgsVectorFileWriter::ErrAttributeTypeUnsupported:
- tr( "Layer attribute table contains unsupported datatype(s)" ) );
- break;
- case QgsVectorFileWriter::ErrAttributeCreationFailed:
- tr( "Creation of an attribute failed" ) );
- break;
-bool QgsLegendLayerFile::isEditing()
- return vlayer && vlayer->isEditable();
-void QgsLegendLayerFile::layerNameChanged()
- QString name = mLyr.layer()->name();
- // set also parent's name
- legend()->setName( this, name );
-void QgsLegendLayerFile::addToPopupMenu( QMenu& theMenu, QAction* toggleEditingAction )
- QgsMapLayer* lyr = layer();
- // zoom to layer extent
- theMenu.addAction( QgisApp::getThemeIcon( "/mActionZoomToLayer.png" ),
- tr( "&Zoom to layer extent" ), legend(), SLOT( legendLayerZoom() ) );
- // show in overview
- QAction* showInOverviewAction = theMenu.addAction( tr( "&Show in overview" ), this, SLOT( showInOverview() ) );
- showInOverviewAction->blockSignals( true );
- showInOverviewAction->setChecked( mLyr.isInOverview() );
- showInOverviewAction->blockSignals( false );
- // remove from canvas
- theMenu.addAction( QgisApp::getThemeIcon( "/mActionRemove.png" ),
- tr( "&Remove" ), legend(), SLOT( legendLayerRemove() ) );
- theMenu.addSeparator();
- if ( lyr->type() == QgsMapLayer::VectorLayer )
- QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( lyr );
- // attribute table
- theMenu.addAction( tr( "&Open attribute table" ), this, SLOT( table() ) );
- // editing
- int cap = vlayer->dataProvider()->capabilities();
- if ( cap & QgsVectorDataProvider::EditingCapabilities )
- // save as shapefile
- theMenu.addAction( tr( "Save as shapefile..." ), this, SLOT( saveAsShapefile() ) );
- QAction* saveSelectionAction = theMenu.addAction( tr( "Save selection as shapefile..." ), this, SLOT( saveSelectionAsShapefile() ) );
- if ( vlayer->selectedFeatureCount() == 0 )
- saveSelectionAction->setEnabled( false );
- else if ( lyr->type() == QgsMapLayer::RasterLayer )
- // TODO: what was this for?
- //QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>(lyr);
- //theMenu.addAction(tr("&Convert to..."), rlayer, SLOT(convertTo()));
- // properties goes on bottom of menu for consistency with normal ui standards
- // e.g. kde stuff
- theMenu.addAction( tr( "&Properties" ), legend(), SLOT( legendLayerShowProperties() ) );
Deleted: trunk/qgis/src/app/legend/qgslegendlayerfile.h
--- trunk/qgis/src/app/legend/qgslegendlayerfile.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayerfile.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -1,95 +0,0 @@
-#ifndef QGSLEGENDLAYERFILE_H
-#define QGSLEGENDLAYERFILE_H
-#include <QPixmap>
-#include "qgslegenditem.h"
-#include "qgsmapcanvas.h"
-class QgsMapLayer;
- at author Tim Sutton
-class QgsLegendLayerFile : public QgsLegendItem
- Q_OBJECT
- public:
- QgsLegendLayerFile( QTreeWidgetItem * theLegendItem, QString theString, QgsMapLayer* theLayer );
- bool isLeafNode() {return true;}
- DRAG_ACTION accept( LEGEND_ITEM_TYPE type );
- QgsLegendItem::DRAG_ACTION accept( const QgsLegendItem* li ) const;
- QgsMapLayer* layer() { return mLyr.layer(); }
- const QgsMapLayer* layer() const { return mLyr.layer(); }
- QgsMapCanvasLayer& canvasLayer() { return mLyr; }
- void setIconAppearance( bool isInOverview, bool editable );
- /**Returns a label for a layer. Is static such that
- the name can be passed to the constructor of QgsLegendLayerFile*/
- static QString nameFromLayer( QgsMapLayer* layer );
- void setVisible( bool visible = TRUE );
- bool isVisible();
- void setInOverview( bool isInOverview = TRUE );
- bool isInOverview();
- /** called to add appropriate menu items to legend's popup menu */
- void addToPopupMenu( QMenu& theMenu, QAction* toggleEditingAction );
- public slots:
- /** updates item to the current state of the layer */
- void updateLegendItem();
- /**Open attribute table*/
- void table();
- /**Save as shapefile*/
- void saveAsShapefile();
- /**Save selection as shapefile*/
- void saveSelectionAsShapefile();
- /**Return editing status for layer*/
- bool isEditing();
- /**Toggle show in overview*/
- void showInOverview();
- /**Layer name has changed - set it also in legend*/
- void layerNameChanged();
- protected:
- /**Save as shapefile (called from saveAsShapefile and saveSelectionAsShapefile)*/
- void saveAsShapefileGeneral( bool saveOnlySelection );
- /** layer identified by its layer id */
- QgsMapCanvasLayer mLyr;
-#endif
Deleted: trunk/qgis/src/app/legend/qgslegendlayerfilegroup.cpp
--- trunk/qgis/src/app/legend/qgslegendlayerfilegroup.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayerfilegroup.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -1,158 +0,0 @@
- qgslegendlayerfilegroup.cpp - description
- begin : Juli 2005
- copyright : (C) 2005 by Marco Hugentobler
- email : marco.hugentobler at autoform.ch
-#include "qgslegendlayerfilegroup.h"
-#include "qgslegendlayerfile.h"
-#include "qgslegendsymbologygroup.h"
-#include "qgslogger.h"
-QgsLegendLayerFileGroup::QgsLegendLayerFileGroup( QTreeWidgetItem* theItem, QString theString ): QgsLegendItem( theItem, theString )
- mType = LEGEND_LAYER_FILE_GROUP;
-QgsLegendItem::DRAG_ACTION QgsLegendLayerFileGroup::accept( LEGEND_ITEM_TYPE type )
- if ( type == LEGEND_LAYER_FILE )
- return INSERT; //there should be a way to already test, if the layers are symbology compatible
- else
- return NO_ACTION;
-QgsLegendItem::DRAG_ACTION QgsLegendLayerFileGroup::accept( const QgsLegendItem* li ) const
- QgsDebugMsg( "entered." );
- if ( li )
- LEGEND_ITEM_TYPE type = li->type();
- if ( type == LEGEND_LAYER_FILE /*&& this != li->parent()*/ )
- if ( child( 0 ) == 0 )
- return INSERT;
- else
- QgsLegendLayerFile* llf = dynamic_cast<QgsLegendLayerFile *>( child( 0 ) );
- if ( llf )
- QgsMapLayer* childlayer = llf->layer();
- const QgsMapLayer* newlayer = qobject_cast<const QgsLegendLayerFile *>( li )->layer();
- if ( newlayer->hasCompatibleSymbology( *childlayer ) )
- return INSERT;
- return NO_ACTION;
-bool QgsLegendLayerFileGroup::insert( QgsLegendItem* newItem )
- if ( newItem->type() == LEGEND_LAYER_FILE )
- QgsLegendItem* oldItem = firstChild();
- if ( !oldItem )//this item is the first child
- insertChild( 0, newItem );
- return true;
- //there are already legend layer files
- //find the lowest sibling
- while ( oldItem->nextSibling() != 0 )
- oldItem = oldItem->nextSibling();
- QgsLegendLayerFile* thefile = qobject_cast<QgsLegendLayerFile *>( oldItem );
- if ( !thefile )
- return false;
- QgsMapLayer* thelayer = thefile->layer();
- if ( !thelayer )
- return false;
- QgsMapLayer* newLayer = qobject_cast<QgsLegendLayerFile *>( newItem )->layer();
- if ( newLayer->hasCompatibleSymbology( *thelayer ) )
- insertChild( childCount(), newItem );
- return true;
- else
- return false;
- else
- return false;
-bool QgsLegendLayerFileGroup::containsLegendLayerFile( const QgsLegendLayerFile* llf ) const
- bool result = false;
- if ( llf == child( i ) )
- result = true;
- break;
- return result;
-void QgsLegendLayerFileGroup::receive( QgsLegendItem* newChild )
- if ( newChild->type() == LEGEND_LAYER_FILE )
- QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( parent() );
- if ( ll )
- ll->updateIcon();
-void QgsLegendLayerFileGroup::release( QgsLegendItem* formerChild )
- if ( formerChild->type() == LEGEND_LAYER_FILE )
- if ( ll )
- ll->updateIcon();
Deleted: trunk/qgis/src/app/legend/qgslegendlayerfilegroup.h
--- trunk/qgis/src/app/legend/qgslegendlayerfilegroup.h 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendlayerfilegroup.h 2009-11-08 21:44:47 UTC (rev 12035)
@@ -1,38 +0,0 @@
- qgslegendlayerfilegroup.h - description
- begin : Juli 2005
-class QgsLegendLayerFileGroup: public QgsLegendItem
- public:
- QgsLegendLayerFileGroup( QTreeWidgetItem* theItem, QString theString );
- bool isLeafNode() {return false;}
- /**Returns true if llf is a childelement*/
- bool containsLegendLayerFile( const QgsLegendLayerFile* llf ) const;
- /**Makes the parent QgsLegendLayer update the checkState and the icon after a new
- QgsLegendLayerFile was inserted*/
- void receive( QgsLegendItem* newChild );
- /**Cleanups when after a child QgsLegendLayerFile item has left. Tells the parent QgsLegendLayer to
- refresh the checkState and the icon*/
- void release( QgsLegendItem* formerChild );
Modified: trunk/qgis/src/app/legend/qgslegendsymbologygroup.cpp
--- trunk/qgis/src/app/legend/qgslegendsymbologygroup.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/legend/qgslegendsymbologygroup.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -19,8 +19,6 @@
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-11-08 21:41:00 UTC (rev 12034)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-11-08 21:44:47 UTC (rev 12035)
@@ -106,7 +106,6 @@
#include "qgshelpviewer.h"
@@ -4050,12 +4049,12 @@
void QgisApp::saveAsShapefile()
- mMapLegend->currentLayerFile()->saveAsShapefile();
+ mMapLegend->currentLegendLayer()->saveAsShapefile();
void QgisApp::saveSelectionAsShapefile()
- mMapLegend->currentLayerFile()->saveSelectionAsShapefile();
+ mMapLegend->currentLegendLayer()->saveSelectionAsShapefile();
void QgisApp::layerProperties()
@@ -4576,8 +4575,8 @@
if ( mMapCanvas && mMapCanvas->isDrawing() )
return;
- QgsLegendLayerFile* currentLayerFile = mMapLegend->currentLayerFile();
- if ( currentLayerFile )
+ QgsLegendLayer* currentLayer = mMapLegend->currentLegendLayer();
+ if ( currentLayer )
toggleEditing( mMapLegend->currentLayer() );
