[QGIS Commit] r12038 - trunk/qgis/resources/context_help
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 8 17:35:45 EST 2009
Author: macho
Date: 2009-11-08 17:35:44 -0500 (Sun, 08 Nov 2009)
New Revision: 12038
Added:
   trunk/qgis/resources/context_help/1033030847_ru_RU
   trunk/qgis/resources/context_help/151694916_ru_RU
   trunk/qgis/resources/context_help/165149618_ru_RU
   trunk/qgis/resources/context_help/308026563_ru_RU
   trunk/qgis/resources/context_help/32338213_ru_RU
   trunk/qgis/resources/context_help/348772824_ru_RU
   trunk/qgis/resources/context_help/361087368_ru_RU
   trunk/qgis/resources/context_help/63428984_ru_RU
   trunk/qgis/resources/context_help/687883780_ru_RU
   trunk/qgis/resources/context_help/689216579_ru_RU
   trunk/qgis/resources/context_help/710979116_ru_RU
   trunk/qgis/resources/context_help/831088384_ru_RU
   trunk/qgis/resources/context_help/863656587_ru_RU
   trunk/qgis/resources/context_help/929865718_ru_RU
   trunk/qgis/resources/context_help/939347163_ru_RU
   trunk/qgis/resources/context_help/94000531_ru_RU
   trunk/qgis/resources/context_help/985715179_ru_RU
   trunk/qgis/resources/context_help/995980174_ru_RU
Added: trunk/qgis/resources/context_help/1033030847_ru_RU
--- trunk/qgis/resources/context_help/1033030847_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/1033030847_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Текст с разделителями</h3>
Property changes on: trunk/qgis/resources/context_help/1033030847_ru_RU
___________________________________________________________________
Added: svn:executable
Added: trunk/qgis/resources/context_help/151694916_ru_RU
--- trunk/qgis/resources/context_help/151694916_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/151694916_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,21 @@
+<h3>Пространственные закладки</h3>
+Пространственные закладки позволяют «запомнить» положение в пространстве и вернуться к нему позже.
+<h4>Создание закладки</h4>
+Для создания закладки:
+<ol>
+<li>Перейдите к интересующей области
+<li>Нажмите <i>Новая закладка</i> или воспользуйтесь горячими клавишами Ctrl-B
+<li>Введите имя новой закладки (до 255 символов)
+<li>Нажмите <i>OK</i> для создания закладки или <i>Cancel</i> для выхода без сохранения изменений
+</ol>
+Вы можете создать несколько закладок с одним и тем же именем.
+<h4>Работа с закладками</h4>
+Доступ к управлению закладками можно получить нажав кнопку <i>Показать закладки</i> или выбрав <i>Показать закладки</i> в меню <i>Вид</i>. Появившийся диалог позволит переходить к закладкам и удалять их. Изменение имени закладки или координат не доступно.
+<h5>Переход по закладкам</h5>
+Откройте окно Закладки, выделите нужную закладку, после чего нажмите кнопку <i>Увеличить до</i>.
+<p>
+Переходить по закладкам можно и при помощи двойного клика по имени закладки.
+<h5>Удаление закладки</h5>
+Для удаления закладки из списка, выделите ее, затем нажмите кнопку <i>Удалить</i>. Подтвердите свой выбор нажав <i>OK</i> или отмените удаление, нажав <i>Отменить</i>.
Property changes on: trunk/qgis/resources/context_help/151694916_ru_RU
Added: trunk/qgis/resources/context_help/165149618_ru_RU
--- trunk/qgis/resources/context_help/165149618_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/165149618_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,2 @@
+<h3>Создать новый векторный слой</h3>
Property changes on: trunk/qgis/resources/context_help/165149618_ru_RU
Added: trunk/qgis/resources/context_help/308026563_ru_RU
(Binary files differ)
Property changes on: trunk/qgis/resources/context_help/308026563_ru_RU
Added: svn:mime-type
   + application/octet-stream
Added: trunk/qgis/resources/context_help/32338213_ru_RU
--- trunk/qgis/resources/context_help/32338213_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/32338213_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Знак авторского права</h3>
Property changes on: trunk/qgis/resources/context_help/32338213_ru_RU
Added: trunk/qgis/resources/context_help/348772824_ru_RU
--- trunk/qgis/resources/context_help/348772824_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/348772824_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Добавить векторный слой</h3>
Property changes on: trunk/qgis/resources/context_help/348772824_ru_RU
Added: trunk/qgis/resources/context_help/361087368_ru_RU
--- trunk/qgis/resources/context_help/361087368_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/361087368_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,25 @@
+<h3>Свойства проекта</h3>
+Диалог предназначен для установки свойств <i>Проекта</i>. Проект - это сохраненный набор слоев и их настроек, а также остальная информация, необходимая для восстановления проекта из файла на диске.<p>
+<h4>Общие</h4>
+<table border=1>
+<tr>
+<td>Заглавие проекта</td><td>Описательное заглавие проекта. Этот текст будет отображаться в сроке заголовка главного окна QGIS</td>
+</tr>
+<tr>
+<td>Единицы слоя</td><td>Задаются единицы координат, используемые в проекте</td>
+</tr>
+<tr>
+<td>Точность</td><td>Используется для установки точности отображения в строке состояния. Во время движения мыши над картой, координаты в строке состояния будут отображаться с заданой вами точностью. По умолчанию используется точность, зависящая от единиц карты.</td>
+</tr>
+<tr>
+<td>Оцифровка</td><td>Позволяет установить порог прилипания в пикселях, толщину и цвет линии, используемой при редактировании.</td>
+</tr>
+<tr><td>Цвет выделения</td><td>Выбранные объекты будут оторажаться заданным здесь цветом.</td>
+</tr>
+</table>
+<a anchor="projections"></a><h4>Вкладка Система координат</h4>
+Вклдака Система координат позволяет задать систему координат активного проекта и включить перепроецирование на лету. Активация перепроецирования на лету не требует сохранения проекта.<p>
+Для использования перепроецирования на лету необходимо включить переключатель <i>Включить преобразование кординат «на лету»</i>. Затем выбрать систему координат проекта (карты) из списка географических или прямугольных систем координат.
+<p>
+Найти нужную систему координат можно введя PostGIS SRID, код EPSG или QGIS SRSRID и нажав кнопку <i>Найти</i>.
Property changes on: trunk/qgis/resources/context_help/361087368_ru_RU
Added: trunk/qgis/resources/context_help/63428984_ru_RU
--- trunk/qgis/resources/context_help/63428984_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/63428984_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Новое OGR-соединение с базой данных</h3>
Property changes on: trunk/qgis/resources/context_help/63428984_ru_RU
Added: trunk/qgis/resources/context_help/687883780_ru_RU
Property changes on: trunk/qgis/resources/context_help/687883780_ru_RU
Added: trunk/qgis/resources/context_help/689216579_ru_RU
Property changes on: trunk/qgis/resources/context_help/689216579_ru_RU
Added: trunk/qgis/resources/context_help/710979116_ru_RU
--- trunk/qgis/resources/context_help/710979116_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/710979116_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Справка WMS</h3>
Property changes on: trunk/qgis/resources/context_help/710979116_ru_RU
Added: trunk/qgis/resources/context_help/831088384_ru_RU
Property changes on: trunk/qgis/resources/context_help/831088384_ru_RU
Added: trunk/qgis/resources/context_help/863656587_ru_RU
--- trunk/qgis/resources/context_help/863656587_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/863656587_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,40 @@
+<h3>Экспорт  проекта  QGIS в файл MapServer</h3>
+<p> Инструмент предназначен
+для  экспорта  сохраненного проекта QGIS в файл MapServer. Этот инструмент
+установлен  в каталог исполнимых файлов QGIS и может использоаться независимо от QGIS. Необходимо  заполнить  только  два поля: <b>Map файл</b> и <b>Файл проекта QGIS</b>.
+</p>
+<h4>Параметры</h4>
+<dl>
+ <dt>Файл карты</dt>
+ <dd>Введите имя  map-файла.  Используя кнопку справа от поля ввода, можно указать каталог для сохранения map-файла.
+ <dt>Файл проекта QGIS</dt>
+ <dd>Введите полный путь к файлу проекта  QGIS  (.qgs),  который  необходимо  экспортировать.  Для более удобного
+поиска  проекта  можно  воспользоваться кнопкой справа от поля ввода.</dd>
+</dl>
+<h4>Карта</h4>
+Эти значения определяют такие настроки, как размер результирующего изображения, единицы измерения и тип файла.
+<dl>
+  <dt>Имя</dt>
+  <dd>Имя MAP-файла. Имена сгенерированых изображений будут начинаться с этого имени.</dd>
+  <dt>Ширина</dt>
+  <dd>Ширина результирующего изображения в пикселях.</dd>
+  <dt>Высота</dt>
+  <dd>Высота результирующего изображения в пикселях.</dd>
+  <dt>Единицы</dt>
+  <dd>Единицы измерения, испоьзуемые при экспорте.</dd>
+  <dt>Формат изображения</dt>
+  <dd>Формат изображений, генерируемых MapServer</dd>
+</dl>
+<h4>Определение  Web-интерфейса</h4>
+<dl>
+ <dt>Шаблон</dt>
+ <dd>Полный путь к шаблону MapServer, который будет использоваться  при
+экспорте.</dd>
+ <dt>Верхний  колонтитул</dt>
+ <dd>Полный путь к файлу верхнего колонтитула  MapServer.</dd>
+ <dt>Нижний колонтитул</dt>
+ <dd>Полный путь к файлу нижнего колонтитула MapServer.</dd>
Property changes on: trunk/qgis/resources/context_help/863656587_ru_RU
Added: trunk/qgis/resources/context_help/929865718_ru_RU
--- trunk/qgis/resources/context_help/929865718_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/929865718_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,18 @@
+Для создания нового PostGIS-соединения, необходимо знать узел, порт, а также имя пользователя и пароль для доступа к серверу баз данных.
+<h4>Необходимые параметры</h4>
+<ul>
+<li>Имя - имя этого соединения
+<li>Узел - имя узла сервера баз данных (например, madison.qgis.org)
+<li>База данных - название базы данных,  к  которой  необходимо  подключиться
+<li>Порт - порт, обслуживаемый PostgreSQL. По умолчанию это 5432. Если возникают сомнения, свяжитесь со своим системным администратором.
+<li>Пользователь - имя пользователя базы данных
+<li>Пароль - пароль для доступа к БД
+</ul>
+<h4>Настройки</h4>
+<ol>
+<li><i>Сохранить пароль</i> - сохраняет введеный пароль, вам не придется вводить его каждый раз. Пароль хранится в виде обычного текста вместе со всеми остальными настройками QGIS.
+<li><i>Искать только в таблице geometry_columns</i> - обычно QGIS проверят каждую таблицу базы данных на наличие в ней поля геометрии, и если оно найдено - добавляет ее в список слоев. Установка этого переключателя заставит QGIS отображать только «зарегистрированные» и имеющие запись в таблице geometry_columns слои.
+<li><i>Искать только в схеме 'public'</i> - поиск слоев производится только в схеме public
+</ol>
+<h4>Проверка соединения</h4>
+Нажатие на кнопку <i>Проверить соединение</i> инициирует попытку подключения к базе данных, используя указанные ранее параметры. Это хороший способ проверить параметры соединения перед тем как сохранить его.
\ No newline at end of file
Property changes on: trunk/qgis/resources/context_help/929865718_ru_RU
Added: trunk/qgis/resources/context_help/939347163_ru_RU
--- trunk/qgis/resources/context_help/939347163_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/939347163_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,20 @@
+<h3>Добавить слой PostGIS</h3>
+Этот дилог позволяет добавить на карту слои PostGIS (таблицы, содержащие поле с геметрией).
+<h4>Подключения</h4>
+<ul>
+<li>Выберите необходимое подключение из выпадающего списка и нажмите <i>Подключить</i>
+<li>Если подключение отсутствует, создать его можно нажав на кнопку <i>Новое</i>
+<li>Для изменения параметров подключения нажмите кнопку <i>Правка</i>
+</ul>
+<h4>Добавление слоёв</h4>
+Для добавления слоя:
+<ol>
+<li>Выберите необходимое соединение из выпадающего списка
+<li>Нажмите <i>Подключить</i>
+<li>Найдите в списке нужый слой и выделите его
+<li>Можно выделять несколько слоев одновременно при нажатой клавише Ctrl
+<li>Нажмите <i>Добавить</i> для добавления слоя(ёв) на карту
+</ol>
+<h4>Фильтрация</h4>
+Для применения к слою фильтра дважды щелкните по его имени. Откроется Конструктор запросов, при помощи которого формируется SQL-выражение для отбора нужных записей.
Property changes on: trunk/qgis/resources/context_help/939347163_ru_RU
Added: trunk/qgis/resources/context_help/94000531_ru_RU
--- trunk/qgis/resources/context_help/94000531_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/94000531_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1,26 @@
+<h3>Свойства векторного слоя</h3>
+Диалог позволяет просматривать настройки и свойства векторного слоя. В окне пять вкладок:
+<ol>
+<li><a href="#symbology">Символика</a></li>
+<li><a href="#general">Общие</a></li>
+<li><a href="#metadata">Метаданные</a></li>
+<li><a href="#labels">Подписи</a></li>
+<li><a href="#actions">Действия</a></li>
+</ol>
+<a name="symbology">
+<h4>Символика</h4>
+</a>
+<a name="general">
+<h4>Общие</h4>
+</a>
+<a name="metadata">
+<h4>Метаданные</h4>
+</a>
+<a name="labels">
+<h4>Подписи</h4>
+</a>
+<a name="actions">
+<h4>Действия</h4>
+</a>
Property changes on: trunk/qgis/resources/context_help/94000531_ru_RU
Added: trunk/qgis/resources/context_help/985715179_ru_RU
Property changes on: trunk/qgis/resources/context_help/985715179_ru_RU
Added: trunk/qgis/resources/context_help/995980174_ru_RU
--- trunk/qgis/resources/context_help/995980174_ru_RU	                        (rev 0)
+++ trunk/qgis/resources/context_help/995980174_ru_RU	2009-11-08 22:35:44 UTC (rev 12038)
@@ -0,0 +1 @@
+<h3>Инструменты GPS</h3>
Property changes on: trunk/qgis/resources/context_help/995980174_ru_RU
More information about the QGIS-commit mailing list
