[QGIS Commit] r12040 - in trunk/qgis: python/analysis src/analysis src/analysis/vector
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 8 18:10:49 EST 2009
Author: cfarmer
Date: 2009-11-08 18:10:48 -0500 (Sun, 08 Nov 2009)
New Revision: 12040
Added:
   trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.cpp
   trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.h
   trunk/qgis/python/analysis/analysis.sip
   trunk/qgis/src/analysis/CMakeLists.txt
   trunk/qgis/src/analysis/vector/qgsgeometryanalyzer.cpp
Fix crashes due to geometry pointers in QgsGeometryAnalyzer; Add QgsOverlayAnalyzer to analysis library (currently only supports intersections)
Modified: trunk/qgis/python/analysis/analysis.sip
--- trunk/qgis/python/analysis/analysis.sip	2009-11-08 23:06:42 UTC (rev 12039)
+++ trunk/qgis/python/analysis/analysis.sip	2009-11-08 23:10:48 UTC (rev 12040)
@@ -8,4 +8,5 @@
 %Import core/core.sip
 %Include qgsgeometryanalyzer.sip
+%Include qgsoverlayanalyzer.sip
Modified: trunk/qgis/src/analysis/CMakeLists.txt
--- trunk/qgis/src/analysis/CMakeLists.txt	2009-11-08 23:06:42 UTC (rev 12039)
+++ trunk/qgis/src/analysis/CMakeLists.txt	2009-11-08 23:10:48 UTC (rev 12040)
@@ -31,6 +31,7 @@
   raster/qgstotalcurvaturefilter.cpp
   vector/qgszonalstatistics.cpp
+  vector/qgsoverlayanalyzer.cpp
 SET(QGIS_ANALYSIS_MOC_HDRS
@@ -43,6 +44,7 @@
   ${CMAKE_CURRENT_SOURCE_DIR}
   ${CMAKE_CURRENT_SOURCE_DIR}/../core/
   ${CMAKE_CURRENT_SOURCE_DIR}/../core/renderer
+  ${CMAKE_CURRENT_SOURCE_DIR}/../core/spatialindex
   interpolation
   ${PROJ_INCLUDE_DIR}
   ${GEOS_INCLUDE_DIR}
@@ -99,7 +101,7 @@
 # Added by Tim to install headers
-SET(QGIS_ANALYSIS_HDRS vector/qgsgeometryanalyzer.h vector/qgszonalstatistics.h
+SET(QGIS_ANALYSIS_HDRS vector/qgsgeometryanalyzer.h vector/qgszonalstatistics.h vector/qgsgeometryanalyzer.h
 INSTALL(CODE "MESSAGE(\"Installing ANALYSIS headers...\")")
Modified: trunk/qgis/src/analysis/vector/qgsgeometryanalyzer.cpp
--- trunk/qgis/src/analysis/vector/qgsgeometryanalyzer.cpp	2009-11-08 23:06:42 UTC (rev 12039)
+++ trunk/qgis/src/analysis/vector/qgsgeometryanalyzer.cpp	2009-11-08 23:10:48 UTC (rev 12040)
@@ -329,6 +329,7 @@
 QList<double> QgsGeometryAnalyzer::simpleMeasure( QgsGeometry* mpGeometry )
   QList<double> list;
+  double perim;
   if ( mpGeometry->wkbType() == QGis::WKBPoint )
     QgsPoint pt = mpGeometry->asPoint();
@@ -341,11 +342,11 @@
     list.append( measure.measure( mpGeometry ) );
     if ( mpGeometry->type() == QGis::Polygon )
-      list.append( perimeterMeasure( mpGeometry, measure ) );
+      perim = perimeterMeasure( mpGeometry, measure );
+      list.append( perim );
   return list;
 double QgsGeometryAnalyzer::perimeterMeasure( QgsGeometry* geometry, QgsDistanceArea& measure )
@@ -383,37 +384,76 @@
     return false;
   QgsVectorDataProvider* dp = layer->dataProvider();
   if ( !dp )
     return false;
+  bool useField = false;
+  if ( uniqueIdField == -1 )
+    uniqueIdField = 0;
+  else
+    useField = true;
+  QgsFieldMap fields;
+  fields.insert( 0 , QgsField( QString( "UID" ), QVariant::String ) );
+  fields.insert( 1 , QgsField( QString( "AREA" ), QVariant::Double ) );
+  fields.insert( 2 , QgsField( QString( "PERIM" ), QVariant::Double ) );
   QGis::WkbType outputType = QGis::WKBPolygon;
   const QgsCoordinateReferenceSystem crs = layer->srs();
-  QgsVectorFileWriter vWriter( shapefileName, dp->encoding(), dp->fields(), outputType, &crs );
+  QgsVectorFileWriter vWriter( shapefileName, dp->encoding(), fields, outputType, &crs );
   QgsFeature currentFeature;
   QgsGeometry* dissolveGeometry; //dissolve geometry
   QMultiMap<QString, int> map;
-  bool useField = false;
-  if ( uniqueIdField == -1 )
+  if ( onlySelectedFeatures )
-    uniqueIdField = 0;
+    //use QgsVectorLayer::featureAtId
+    const QgsFeatureIds selection = layer->selectedFeaturesIds();
+    QgsFeatureIds::const_iterator it = selection.constBegin();
+    for ( ; it != selection.constEnd(); ++it )
+//      if ( p )
+//        p->setValue( processedFeatures );
+//      if ( p && p->wasCanceled() )
+//        // break; // it may be better to do something else here?
+//        return false;
+      if ( !layer->featureAtId( *it, currentFeature, true, true ) )
+        continue;
+      map.insert( currentFeature.attributeMap()[ uniqueIdField ].toString(), currentFeature.id() );
   else
-    useField = true;
     layer->select( layer->pendingAllAttributesList(), QgsRectangle(), true, false );
     while ( layer->nextFeature( currentFeature ) )
-      map.insert( currentFeature.attributeMap()[uniqueIdField].toString(), currentFeature.id() );
+  //    if ( p )
+  //      p->setValue( processedFeatures );
+  //    if ( p && p->wasCanceled() )
+  //      // break; // it may be better to do something else here?
+  //      return false;
-  QMultiMap<QString, int>::const_iterator jt;
-  for (jt = map.constBegin(); jt != map.constEnd(); ++jt)
+  QMultiMap<QString, int>::const_iterator jt = map.constBegin();
+  while ( jt != map.constEnd() )
     QString currentKey = jt.key();
     int processedFeatures = 0;
@@ -421,13 +461,13 @@
-        const QgsFeatureIds selection = layer->selectedFeaturesIds();
         if ( p )
-            p->setMaximum( selection.size() );
+          p->setMaximum( selection.size() );
-        while ( jt != map.end() && ( jt.key() == currentKey || !useField ) )
+        while ( jt != map.constEnd() && ( jt.key() == currentKey || !useField ) )
@@ -437,18 +477,26 @@
             if ( p )
-                p->setValue( processedFeatures );
+              p->setValue( processedFeatures );
             if ( !layer->featureAtId( jt.value(), currentFeature, true, true ) )
-                continue;
+              continue;
             convexFeature( currentFeature, processedFeatures, &dissolveGeometry );
             ++processedFeatures;
           ++jt;
+        QList<double> values;
+        dissolveGeometry = dissolveGeometry->convexHull();
+        values = simpleMeasure( dissolveGeometry );
+        QgsAttributeMap attributeMap;
+        attributeMap.insert( 0 , QVariant( currentKey ) );
+        attributeMap.insert( 1 , values[ 0 ] );
+        attributeMap.insert( 2 , values[ 1 ] );
         QgsFeature dissolveFeature;
+        dissolveFeature.setAttributeMap( attributeMap );
         dissolveFeature.setGeometry( dissolveGeometry );
         vWriter.addFeature( dissolveFeature );
@@ -461,7 +509,7 @@
         p->setMaximum( featureCount );
         if ( p )
@@ -480,9 +528,19 @@
         ++jt;
-      QgsFeature dissolveFeature;
-      dissolveFeature.setGeometry( dissolveGeometry );
-      vWriter.addFeature( dissolveFeature );
+        // QgsGeometry* tmpGeometry = 0;
+        // values = simpleMeasure( tmpGeometry );
+        attributeMap.insert( 1 , QVariant( values[ 0 ] ) );
+        attributeMap.insert( 2 , QVariant( values[ 1 ] ) );
+        QgsFeature dissolveFeature;
+        dissolveFeature.setGeometry( dissolveGeometry );
+        vWriter.addFeature( dissolveFeature );
   return true;
@@ -522,51 +580,69 @@
     return false;
   if ( !dp )
     return false;
+  else
+    useField = true;
   QGis::WkbType outputType = dp->geometryType();
-  QgsGeometry* dissolveGeometry; //dissolve geometry
+        continue;
   else
-    useField = true;
+  QgsGeometry* dissolveGeometry; //dissolve geometry
+  QgsFeature outputFeature;
+    bool first = true;
     //take only selection
         if ( p )
-        processedFeatures = 0;
@@ -576,20 +652,22 @@
             if ( p )
-                continue;
+              continue;
+            if ( first )
+              outputFeature.setAttributeMap( currentFeature.attributeMap() );
+              first = false;
             dissolveFeature( currentFeature, processedFeatures, &dissolveGeometry );
           ++jt;
     //take all features
     else
@@ -599,8 +677,7 @@
         if ( p )
@@ -615,14 +692,17 @@
           continue;
+          first = false;
         ++jt;
+    outputFeature.setGeometry( dissolveGeometry );
+    vWriter.addFeature( outputFeature );
   return true;
@@ -630,7 +710,6 @@
 void QgsGeometryAnalyzer::dissolveFeature( QgsFeature& f, int nProcessedFeatures, QgsGeometry** dissolveGeometry )
   QgsGeometry* featureGeometry = f.geometry();
-  QgsGeometry* tmpGeometry = 0;
   if ( !featureGeometry )
@@ -639,13 +718,15 @@
   if ( nProcessedFeatures == 0 )
-    *dissolveGeometry = featureGeometry;
+    int geomSize = featureGeometry->wkbSize();
+    *dissolveGeometry = new QgsGeometry();
+    unsigned char* wkb = new unsigned char[geomSize];
+    memcpy(wkb, featureGeometry->asWkb(), geomSize);
+    (*dissolveGeometry)->fromWkb(wkb, geomSize);
   else
-    tmpGeometry = *dissolveGeometry;
     *dissolveGeometry = ( *dissolveGeometry )->combine( featureGeometry );
-    delete tmpGeometry;
Added: trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.cpp
--- trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.cpp	                        (rev 0)
+++ trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.cpp	2009-11-08 23:10:48 UTC (rev 12040)
@@ -0,0 +1,204 @@
+    qgsoverlayanalyzer.cpp - QGIS Tools for vector geometry analysis
+    begin                : 8 Nov 2009
+    copyright            : (C) Carson J. Q. Farmer
+    email                : carson.farmer at gmail.com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/* $Id: qgis.h 9774 2008-12-12 05:41:24Z timlinux $ */
+#include "qgsoverlayanalyzer.h"
+#include "qgsapplication.h"
+#include "qgsfield.h"
+#include "qgsfeature.h"
+#include "qgslogger.h"
+#include "qgscoordinatereferencesystem.h"
+#include "qgsvectorfilewriter.h"
+#include "qgsvectordataprovider.h"
+#include "qgsdistancearea.h"
+#include <QProgressDialog>
+bool QgsOverlayAnalyzer::intersection( QgsVectorLayer* layerA, QgsVectorLayer* layerB,
+                                        const QString& shapefileName, bool onlySelectedFeatures,
+                                        QProgressDialog* p )
+  if ( !layerA && !layerB )
+    return false;
+  QgsVectorDataProvider* dpA = layerA->dataProvider();
+  QgsVectorDataProvider* dpB = layerB->dataProvider();
+  if ( !dpA && !dpB )
+    return false;
+  QGis::WkbType outputType = dpA->geometryType();
+  const QgsCoordinateReferenceSystem crs = layerA->srs();
+  //fields = combineFieldLists( dpA->fields(), dpB->fields() );
+  QgsVectorFileWriter vWriter( shapefileName, dpA->encoding(), fields, outputType, &crs );
+  QgsFeature currentFeature;
+  QgsGeometry* dissolveGeometry; //dissolve geometry (if dissolve enabled)
+  QgsSpatialIndex index;
+  //take only selection
+    const QgsFeatureIds selectionB = layerB->selectedFeaturesIds();
+    QgsFeatureIds::const_iterator it = selectionB.constBegin();
+    for ( ; it != selectionB.constEnd(); ++it )
+      if ( !layerB->featureAtId( *it, currentFeature, true, true ) )
+        continue;
+      index.insertFeature( currentFeature );
+    const QgsFeatureIds selectionA = layerA->selectedFeaturesIds();
+    if ( p )
+      p->setMaximum( selectionA.size() );
+    int processedFeatures = 0;
+    it = selectionA.constBegin();
+    for ( ; it != selectionA.constEnd(); ++it )
+      if ( p )
+      if ( p && p->wasCanceled() )
+        break;
+      if ( !layerA->featureAtId( *it, currentFeature, true, true ) )
+        continue;
+      intersectFeature( currentFeature, &vWriter, layerB, &index );
+      ++processedFeatures;
+    if ( p )
+      p->setValue( selectionA.size() );
+  //take all features
+  else
+    layerB->select( layerB->pendingAllAttributesList(), QgsRectangle(), true, false );
+    while ( dpB->nextFeature( currentFeature ) )
+    layerA->select( layerA->pendingAllAttributesList(), QgsRectangle(), true, false );
+    int featureCount = layerA->featureCount();
+    if ( p )
+      p->setMaximum( featureCount );
+    while ( layerA->nextFeature( currentFeature ) )
+      if ( p )
+        break;
+    if ( p )
+      p->setValue( featureCount );
+  return true;
+void QgsOverlayAnalyzer::intersectFeature( QgsFeature& f, QgsVectorFileWriter* vfw,
+                                            QgsVectorLayer* vl, QgsSpatialIndex* index )
+  QgsGeometry* featureGeometry = f.geometry();
+  QgsGeometry* intersectGeometry = 0;
+  if ( !featureGeometry )
+    return;
+  QList<int> intersects;
+  intersects = index->intersects( featureGeometry->boundingBox() );
+  QList<int>::const_iterator it = intersects.constBegin();
+  for ( ; it != intersects.constEnd(); ++it )
+    if ( !vl->featureAtId( *it, currentFeature, true, true ) )
+      continue;
+    if ( featureGeometry->intersects( currentFeature.geometry() ) )
+      intersectGeometry = featureGeometry->intersection( currentFeature.geometry() );
+      QgsFeature outFeature;
+      outFeature.setGeometry( intersectGeometry );
+      outFeature.setAttributeMap( f.attributeMap() );
+      //add it to vector file writer
+      if ( vfw )
+        vfw->addFeature( outFeature );
+void QgsOverlayAnalyzer::combineFieldLists( QgsFieldMap fieldListA, QgsFieldMap fieldListB )
+  QMap<int, QgsField>::const_iterator i = fieldListB.constBegin();
+  int count = 0;
+  while ( i != fieldListB.constEnd() )
+    if ( !fieldListA.contains( i.key() ) )
+      fieldListA.insert( fieldListA.size()-1, i.value() );
+      count = 0;
+    else
+      QgsField field;
+      field = i.value();
+      QString name = field.name();
+      name.append( "_" ).append( QString( count ) );
+      fieldListA.insert( fieldListA.size()-1 , QgsField( name, field.type() ) );
+      ++count;
+      continue;
+    ++i;
Added: trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.h
--- trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.h	                        (rev 0)
+++ trunk/qgis/src/analysis/vector/qgsoverlayanalyzer.h	2009-11-08 23:10:48 UTC (rev 12040)
@@ -0,0 +1,105 @@
+    qgsoverlayanalyzer.h - QGIS Tools for vector geometry analysis
+    begin                : 19 March 2009
+    copyright            : (C) Carson Farmer
+#ifndef QGSOVERLAYANALYZERH
+#define QGSOVERLAYANALYZERH
+#include "qgsvectorlayer.h"
+#include "qgsspatialindex.h"
+#include "qgsgeometry.h"
+class QgsVectorFileWriter;
+class QProgressDialog;
+/** \ingroup analysis
+ * The QGis class provides vector overlay analysis functions
+class ANALYSIS_EXPORT QgsOverlayAnalyzer
+  public:
+    /**Perform an intersection on two input vector layers and write output to a new shape file
+      @param layerA input vector layer
+      @param layerB input vector layer
+      @param shapefileName path to the output shp
+      @param onlySelectedFeatures if true, only selected features are considered, else all the features
+      @param p progress dialog (or 0 if no progress dialog is to be shown)
+      @note: added in version 1.4*/
+    bool intersection( QgsVectorLayer* layerA, QgsVectorLayer* layerB, \
+                       const QString& shapefileName, bool onlySelectedFeatures = false, \
+                       QProgressDialog* p = 0 );
+//    /**Perform a union of two input vector layers and write output to a new shape file
+//      @param layerA input vector layer
+//      @param layerB input vector layer
+//      @param shapefileName path to the output shp
+//      @param onlySelectedFeatures if true, only selected features are considered, else all the features
+//      @param p progress dialog (or 0 if no progress dialog is to be shown)
+//      @note: added in version 1.4*/
+//    bool combine( QgsVectorLayer* layerA, QgsVectorLayer* layerB,
+//                       const QString& shapefileName, bool onlySelectedFeatures = false,
+//                       QProgressDialog* p = 0 );
+//    /**Clip a vector layer based on the boundary of another vector layer and
+//       write output to a new shape file
+//    bool clip( QgsVectorLayer* layerA, QgsVectorLayer* layerB,
+//    /**Difference a vector layer based on the geometries of another vector layer
+//       and write the output to a new shape file
+//    bool difference( QgsVectorLayer* layerA, QgsVectorLayer* layerB,
+//    /**Intersect two vector layers and write the geometries of each layer that
+//       do not intersect with the other layer to a new shape file (Symmetrical difference)
+//    bool symDifference( QgsVectorLayer* layerA, QgsVectorLayer* layerB,
+  private:
+    void combineFieldLists( QgsFieldMap fieldListA, QgsFieldMap fieldListB );
+    void intersectFeature( QgsFeature& f, QgsVectorFileWriter* vfw, QgsVectorLayer* dp, QgsSpatialIndex* index );
+#endif //QGSVECTORANALYZER
More information about the QGIS-commit mailing list
