[QGIS Commit] r12074 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Tue Nov 10 11:43:51 EST 2009
Author: macho
Date: 2009-11-10 11:43:50 -0500 (Tue, 10 Nov 2009)
New Revision: 12074
trunk/qgis/src/ui/qgsmessageviewer.ui
small ui update in messageviewer -> buttonbox
Modified: trunk/qgis/src/ui/qgsmessageviewer.ui
--- trunk/qgis/src/ui/qgsmessageviewer.ui 2009-11-10 16:16:38 UTC (rev 12073)
+++ trunk/qgis/src/ui/qgsmessageviewer.ui 2009-11-10 16:43:50 UTC (rev 12074)
@@ -44,9 +44,9 @@
</widget>
</item>
<item row="2" column="1">
- <widget class="QPushButton" name="btnClose">
- <property name="text">
- <string>Close</string>
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Close</set>
</property>
</widget>
</item>
@@ -72,23 +72,22 @@
<tabstops>
<tabstop>txtMessage</tabstop>
<tabstop>checkBox</tabstop>
- <tabstop>btnClose</tabstop>
</tabstops>
<resources/>
<connections>
<connection>
- <sender>btnClose</sender>
- <signal>clicked()</signal>
+ <sender>buttonBox</sender>
+ <signal>rejected()</signal>
<receiver>QgsMessageViewer</receiver>
<slot>reject()</slot>
<hints>
<hint type="sourcelabel">
- <x>483</x>
- <y>271</y>
+ <x>450</x>
+ <y>257</y>
</hint>
<hint type="destinationlabel">
- <x>249</x>
- <y>141</y>
+ <x>495</x>
+ <y>188</y>
</hint>
</hints>
</connection>
