[QGIS Commit] r12087 - in trunk/qgis/src: app app/composer ui
svn_qgis at osgeo.org
Wed Nov 11 12:05:17 EST 2009
Author: mhugent
Date: 2009-11-11 12:05:16 -0500 (Wed, 11 Nov 2009)
New Revision: 12087
Added:
trunk/qgis/src/app/composer/qgscomposermanager.cpp
trunk/qgis/src/app/composer/qgscomposermanager.h
trunk/qgis/src/ui/qgscomposermanagerbase.ui
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/app/composer/qgscomposer.h
trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgisappinterface.cpp
trunk/qgis/src/ui/qgscomposerbase.ui
[FEATURE?] Close composers instead of deleting them. Added composer manager dialog to manage the existing composer instances
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/CMakeLists.txt 2009-11-11 17:05:16 UTC (rev 12087)
@@ -77,6 +77,7 @@
composer/qgscomposeritemwidget.cpp
composer/qgscomposerlabelwidget.cpp
composer/qgscomposerpicturewidget.cpp
+ composer/qgscomposermanager.cpp
composer/qgscomposerscalebarwidget.cpp
composer/qgscomposerlegenditemdialog.cpp
@@ -174,6 +175,7 @@
composer/qgscomposeritemwidget.h
composer/qgscomposerlabelwidget.h
composer/qgscomposerlegendwidget.h
+ composer/qgscomposermanager.h
composer/qgscomposermapwidget.h
composer/qgscomposerpicturewidget.h
composer/qgscomposerscalebarwidget.h
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2009-11-11 17:05:16 UTC (rev 12087)
@@ -65,11 +65,12 @@
#include <QSizeGrip>
#include "qgslogger.h"
-QgsComposer::QgsComposer( QgisApp *qgis, const QString& id ): QMainWindow(), mId( id )
+QgsComposer::QgsComposer( QgisApp *qgis, const QString& title ): QMainWindow(), mTitle( title )
setupUi( this );
- setAttribute( Qt::WA_DeleteOnClose );
+ setWindowTitle( mTitle );
setupTheme();
+ QObject::connect( mButtonBox, SIGNAL( rejected() ), this, SLOT( close() ) );
QToolButton* orderingToolButton = new QToolButton( this );
orderingToolButton->setPopupMode( QToolButton::InstantPopup );
@@ -107,8 +108,6 @@
toggleActionGroup->addAction( mActionSelectMoveItem );
toggleActionGroup->setExclusive( true );
- setWindowTitle( mId );
mActionAddNewMap->setCheckable( true );
mActionAddNewLabel->setCheckable( true );
mActionAddNewLegend->setCheckable( true );
@@ -185,6 +184,7 @@
connectSlots();
mComposition = new QgsComposition( mQgis->mapCanvas()->mapRenderer() );
+ mComposition->setParent(mView);
mView->setComposition( mComposition );
QgsCompositionWidget* compositionWidget = new QgsCompositionWidget( mCompositionOptionsFrame, mComposition );
@@ -297,31 +297,12 @@
void QgsComposer::activate()
+ show();
raise();
setWindowState( windowState() & ~Qt::WindowMinimized );
activateWindow();
-void QgsComposer::closeEvent( QCloseEvent *event )
- if ( QMessageBox::warning( 0, tr( "Remove composer?" ), tr( "Do you really want to remove the composer instance '%1'?" ).arg( mId ), QMessageBox::Ok | QMessageBox::Cancel, QMessageBox::Cancel ) == QMessageBox::Ok )
- mQgis->checkOutComposer( this );
- event->accept();
- else
- event->ignore();
-#if 0
- QMainWindow::closeEvent( event );
- if ( event->isAccepted() )
- QgisApp::instance()->removeWindow( mWindowAction );
-#endif //0
#ifdef Q_WS_MAC
void QgsComposer::changeEvent( QEvent* event )
@@ -351,6 +332,12 @@
#endif
+void QgsComposer::setTitle( const QString& title )
+ mTitle = title;
void QgsComposer::showCompositionOptions( QWidget *w )
QWidget* currentWidget = mItemStackedWidget->currentWidget();
@@ -1024,7 +1011,7 @@
void QgsComposer::writeXML( QDomNode& parentNode, QDomDocument& doc )
QDomElement composerElem = doc.createElement( "Composer" );
- composerElem.setAttribute( "id", mId );
+ composerElem.setAttribute( "title", mTitle );
parentNode.appendChild( composerElem );
//store composer items:
@@ -1055,14 +1042,16 @@
void QgsComposer::readXML( const QDomElement& composerElem, const QDomDocument& doc )
- mId = composerElem.attribute( "id", "" );
// Create action to select this window
delete mWindowAction;
mWindowAction = new QAction( windowTitle(), this );
connect( mWindowAction, SIGNAL( triggered() ), this, SLOT( activate() ) );
+ if ( composerElem.hasAttribute( "title" ) )
+ setTitle( composerElem.attribute( "title", tr( "Composer" ) ) );
//delete composer view and composition
delete mView;
mView = 0;
@@ -1187,148 +1176,6 @@
setSelectionTool();
-#if 0
-void QgsComposer::readXML( const QDomDocument& doc )
- //look for Composer element
- QDomNodeList nl = doc.elementsByTagName( "Composer" );
- if ( nl.size() < 1 )
- return; //nothing to do...
- QDomElement composerElem = nl.at( 0 ).toElement();
- //look for Composition element
- QDomNodeList cnl = composerElem.elementsByTagName( "Composition" );
- if ( cnl.size() < 1 )
- //delete composer view and composition
- delete mView;
- mView = 0;
- //delete every child of mViewFrame
- QObjectList viewFrameChildren = mViewFrame->children();
- QObjectList::iterator it = viewFrameChildren.begin();
- for ( ; it != viewFrameChildren.end(); ++it )
- delete( *it );
- //delete composition widget
- QgsCompositionWidget* oldCompositionWidget = qobject_cast<QgsCompositionWidget *>( mCompositionOptionsFrame->children().at( 0 ) );
- delete oldCompositionWidget;
- delete mCompositionOptionsLayout;
- mCompositionOptionsLayout = 0;
- QDomElement compositionElem = cnl.at( 0 ).toElement();
- //todo: move in function because duplicated code with constructor
- mView = new QgsComposerView( mViewFrame );
- connectSlots();
- mComposition = new QgsComposition( mQgis->mapCanvas()->mapRenderer() );
- mComposition->readXML( compositionElem, doc );
- QGridLayout *l = new QGridLayout( mViewFrame );
- l->setMargin( 0 );
- l->addWidget( mView, 0, 0 );
- //create compositionwidget
- QgsCompositionWidget* compositionWidget = new QgsCompositionWidget( mCompositionOptionsFrame, mComposition );
- QObject::connect( mComposition, SIGNAL( paperSizeChanged() ), compositionWidget, SLOT( displayCompositionWidthHeight() ) );
- compositionWidget->show();
- mCompositionOptionsLayout = new QGridLayout( mCompositionOptionsFrame );
- mCompositionOptionsLayout->setMargin( 0 );
- mCompositionOptionsLayout->addWidget( compositionWidget );
- //read and restore all the items
- //composer labels
- QDomNodeList composerLabelList = composerElem.elementsByTagName( "ComposerLabel" );
- for ( int i = 0; i < composerLabelList.size(); ++i )
- QDomElement currentComposerLabelElem = composerLabelList.at( i ).toElement();
- QgsComposerLabel* newLabel = new QgsComposerLabel( mComposition );
- newLabel->readXML( currentComposerLabelElem, doc );
- addComposerLabel( newLabel );
- mComposition->addItem( newLabel );
- mComposition->update();
- mComposition->clearSelection();
- newLabel->setSelected( true );
- showItemOptions( newLabel );
- //composer maps
- QDomNodeList composerMapList = composerElem.elementsByTagName( "ComposerMap" );
- for ( int i = 0; i < composerMapList.size(); ++i )
- QDomElement currentComposerMapElem = composerMapList.at( i ).toElement();
- QgsComposerMap* newMap = new QgsComposerMap( mComposition );
- newMap->readXML( currentComposerMapElem, doc );
- addComposerMap( newMap );
- mComposition->addItem( newMap );
- newMap->setSelected( true );
- showItemOptions( newMap );
- //composer scalebars
- QDomNodeList composerScaleBarList = composerElem.elementsByTagName( "ComposerScaleBar" );
- for ( int i = 0; i < composerScaleBarList.size(); ++i )
- QDomElement currentScaleBarElem = composerScaleBarList.at( i ).toElement();
- QgsComposerScaleBar* newScaleBar = new QgsComposerScaleBar( mComposition );
- newScaleBar->readXML( currentScaleBarElem, doc );
- addComposerScaleBar( newScaleBar );
- mComposition->addItem( newScaleBar );
- newScaleBar->setSelected( true );
- showItemOptions( newScaleBar );
- //composer legends
- QDomNodeList composerLegendList = composerElem.elementsByTagName( "ComposerLegend" );
- for ( int i = 0; i < composerLegendList.size(); ++i )
- QDomElement currentLegendElem = composerLegendList.at( i ).toElement();
- QgsComposerLegend* newLegend = new QgsComposerLegend( mComposition );
- newLegend->readXML( currentLegendElem, doc );
- addComposerLegend( newLegend );
- mComposition->addItem( newLegend );
- newLegend->setSelected( true );
- showItemOptions( newLegend );
- //composer pictures
- QDomNodeList composerPictureList = composerElem.elementsByTagName( "ComposerPicture" );
- for ( int i = 0; i < composerPictureList.size(); ++i )
- QDomElement currentPictureElem = composerPictureList.at( i ).toElement();
- QgsComposerPicture* newPicture = new QgsComposerPicture( mComposition );
- newPicture->readXML( currentPictureElem, doc );
- addComposerPicture( newPicture );
- mComposition->addItem( newPicture );
- newPicture->setSelected( true );
- showItemOptions( newPicture );
- mComposition->sortZList();
- mView->setComposition( mComposition );
- setSelectionTool();
-#endif //0
void QgsComposer::addComposerMap( QgsComposerMap* map )
if ( !map )
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2009-11-11 17:05:16 UTC (rev 12087)
@@ -46,7 +46,7 @@
Q_OBJECT
public:
- QgsComposer( QgisApp *qgis, const QString& id );
+ QgsComposer( QgisApp *qgis, const QString& title );
~QgsComposer();
//! Set the pixmap / icons on the toolbar buttons
@@ -75,7 +75,8 @@
QAction* windowAction() {return mWindowAction;}
- QString id() const {return mId;}
+ const QString& title() const {return mTitle;}
+ void setTitle( const QString& title );
protected:
//! Move event
@@ -84,9 +85,6 @@
//! Resize event
virtual void resizeEvent( QResizeEvent * );
- //! Close event (remove window from menu)
- virtual void closeEvent( QCloseEvent * );
#ifdef Q_WS_MAC
//! Change event (update window menu on ActivationChange)
virtual void changeEvent( QEvent * );
@@ -225,8 +223,6 @@
void setSelectionTool();
- private slots:
//! Raise, unminimize and activate this window
void activate();
@@ -250,8 +246,8 @@
//! Writes state under DOM element
void writeXML( QDomNode& parentNode, QDomDocument& doc );
- /**Identification string*/
- QString mId;
+ /**Composer title*/
+ QString mTitle;
//! Pointer to composer view
QgsComposerView *mView;
Added: trunk/qgis/src/app/composer/qgscomposermanager.cpp
--- trunk/qgis/src/app/composer/qgscomposermanager.cpp (rev 0)
+++ trunk/qgis/src/app/composer/qgscomposermanager.cpp 2009-11-11 17:05:16 UTC (rev 12087)
@@ -0,0 +1,159 @@
+ qgscomposermanager.cpp
+ begin : September 11 2009
+ copyright : (C) 2009 by Marco Hugentobler
+ email : marco at hugis dot net
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include "qgscomposermanager.h"
+#include "qgisapp.h"
+#include "qgscomposer.h"
+#include <QInputDialog>
+#include <QListWidgetItem>
+#include <QMessageBox>
+QgsComposerManager::QgsComposerManager(QgisApp* app, QWidget * parent, Qt::WindowFlags f): QDialog(parent, f), mQgisApp(app)
+ setupUi(this);
+ connect(mButtonBox, SIGNAL(rejected()), this, SLOT(close()));
+ initialize();
+QgsComposerManager::~QgsComposerManager()
+void QgsComposerManager::initialize()
+ if(!mQgisApp)
+ return;
+ QSet<QgsComposer*> composers = mQgisApp->printComposers();
+ QSet<QgsComposer*>::const_iterator it = composers.constBegin();
+ for(; it != composers.constEnd(); ++it)
+ QListWidgetItem* item = new QListWidgetItem((*it)->title(), mComposerListWidget);
+ item->setFlags(Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable);
+ mItemComposerMap.insert(item, *it);
+void QgsComposerManager::on_mAddButton_clicked()
+ if(!mQgisApp)
+ return;
+ QgsComposer* newComposer = mQgisApp->createNewComposer();
+ if(!newComposer)
+ return;
+ QListWidgetItem* item = new QListWidgetItem(newComposer->title(), mComposerListWidget);
+ mItemComposerMap.insert(item, newComposer);
+void QgsComposerManager::on_mRemoveButton_clicked()
+ if(!mQgisApp)
+ return;
+ QListWidgetItem* item = mComposerListWidget->currentItem();
+ if(!item)
+ return;
+ //ask for confirmation
+ if(QMessageBox::warning(0, tr("Remove composer"), tr("Do you really want to remove the map composer '%1'?").arg(item->text()), QMessageBox::Ok | QMessageBox::Cancel) != QMessageBox::Ok)
+ return;
+ //delete composer
+ QMap<QListWidgetItem*, QgsComposer*>::iterator it = mItemComposerMap.find(item);
+ if(it != mItemComposerMap.end())
+ mQgisApp->deleteComposer(it.value());
+ mItemComposerMap.remove(item);
+ mComposerListWidget->removeItemWidget(item);
+ //and remove the list widget row
+ delete (mComposerListWidget->takeItem(mComposerListWidget->row(item)));
+void QgsComposerManager::on_mShowPushButton_clicked()
+ if(!mQgisApp)
+ return;
+ if(!item)
+ return;
+ //delete composer
+ it.value()->show();
+ it.value()->activate();
+ it.value()->stackUnder(this);
+void QgsComposerManager::on_mRenamePushButton_clicked()
+ if(!item)
+ return;
+ QString currentTitle;
+ QgsComposer* currentComposer = 0;
+ currentComposer = it.value();
+ currentTitle = it.value()->title();
+ else
+ return;
+ QString newTitle = QInputDialog::getText(0, tr("Change title"), tr("Title"), QLineEdit::Normal, currentTitle );
+ if(newTitle.isNull())
+ return;
+ currentComposer->setTitle(newTitle);
+ item->setText(newTitle);
+void QgsComposerManager::on_mComposerListWidget_itemChanged( QListWidgetItem * item )
+ it.value()->setTitle(item->text());
Added: trunk/qgis/src/app/composer/qgscomposermanager.h
--- trunk/qgis/src/app/composer/qgscomposermanager.h (rev 0)
+++ trunk/qgis/src/app/composer/qgscomposermanager.h 2009-11-11 17:05:16 UTC (rev 12087)
@@ -0,0 +1,51 @@
+ qgscomposermanager.h
+#ifndef QGSCOMPOSERMANAGER_H
+#define QGSCOMPOSERMANAGER_H
+#include "ui_qgscomposermanagerbase.h"
+class QgisApp;
+class QListWidgetItem;
+class QgsComposer;
+/**A dialog that shows the existing composer instances. Lets the user add new \
+instances and change title of existing ones*/
+class QgsComposerManager: public QDialog, private Ui::QgsComposerManagerBase
+ Q_OBJECT
+ public:
+ QgsComposerManager(QgisApp* app, QWidget * parent = 0, Qt::WindowFlags f = 0);
+ ~QgsComposerManager();
+ private:
+ QgisApp* mQgisApp;
+ /**Stores the relation between items and composer pointers */
+ QMap<QListWidgetItem*, QgsComposer*> mItemComposerMap;
+ /**Enters the composer instances and created the item-composer map*/
+ void initialize();
+ private slots:
+ void on_mAddButton_clicked();
+ void on_mRemoveButton_clicked();
+ void on_mShowPushButton_clicked();
+ void on_mRenamePushButton_clicked();
+ void on_mComposerListWidget_itemChanged( QListWidgetItem * item );
+#endif // QGSCOMPOSERMANAGER_H
Modified: trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposermapwidget.cpp 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/composer/qgscomposermapwidget.cpp 2009-11-11 17:05:16 UTC (rev 12087)
@@ -55,15 +55,13 @@
mAnnotationDirectionComboBox->insertItem( 1, tr( "Vertical" ) );
mAnnotationDirectionComboBox->insertItem( 2, tr( "Horizontal and Vertical" ) );
mAnnotationDirectionComboBox->insertItem( 2, tr( "Boundary direction" ) );
- blockAllSignals( false );
if ( composerMap )
connect( composerMap, SIGNAL( extentChanged() ), this, SLOT( updateSettingsNoSignals() ) );
updateGuiElements();
+ blockAllSignals( false );
QgsComposerMapWidget::~QgsComposerMapWidget()
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-11-11 17:05:16 UTC (rev 12087)
@@ -94,6 +94,7 @@
#include "qgsbookmarks.h"
#include "qgsclipboard.h"
#include "qgsconfigureshortcutsdialog.h"
#include "qgscoordinatetransform.h"
#include "qgscursors.h"
@@ -592,11 +593,15 @@
mActionSaveMapAsImage->setStatusTip( tr( "Save map as image" ) );
connect( mActionSaveMapAsImage, SIGNAL( triggered() ), this, SLOT( saveMapAsImage() ) );
- mActionNewPrintComposer = new QAction( getThemeIcon( "mActionFilePrint.png" ), tr( "&New Print Composer" ), this );
+ mActionNewPrintComposer = new QAction( getThemeIcon( "mActionNewComposer.png" ), tr( "&New Print Composer" ), this );
shortcuts->registerAction( mActionNewPrintComposer, tr( "Ctrl+P", "New Print Composer" ) );
mActionNewPrintComposer->setStatusTip( tr( "New Print Composer" ) );
connect( mActionNewPrintComposer, SIGNAL( triggered() ), this, SLOT( newPrintComposer() ) );
+ mActionShowComposerManager = new QAction( getThemeIcon( "mActionFilePrint.png" ), tr( "Composer manager..." ), this );
+ mActionShowComposerManager->setStatusTip( tr( "Composer manager" ) );
+ connect( mActionShowComposerManager, SIGNAL( triggered() ), this, SLOT( showComposerManager() ) );
mActionExit = new QAction( getThemeIcon( "mActionFileExit.png" ), tr( "Exit" ), this );
shortcuts->registerAction( mActionExit, tr( "Ctrl+Q", "Exit QGIS" ) );
mActionExit->setStatusTip( tr( "Exit QGIS" ) );
@@ -1174,6 +1179,7 @@
mFileMenu->addAction( mActionNewPrintComposer );
+ mFileMenu->addAction( mActionShowComposerManager );
mPrintComposersMenu = mFileMenu->addMenu( tr( "Print Composers" ) );
mActionFileSeparator4 = mFileMenu->addSeparator();
@@ -1374,6 +1380,7 @@
mFileToolBar->addAction( mActionSaveProject );
mFileToolBar->addAction( mActionSaveProjectAs );
mFileToolBar->addAction( mActionNewPrintComposer );
+ mFileToolBar->addAction( mActionShowComposerManager );
mToolbarMenu->addAction( mFileToolBar->toggleViewAction() );
// Layer Toolbar
@@ -1641,6 +1648,7 @@
mActionSaveProject->setIcon( getThemeIcon( "/mActionFileSave.png" ) );
mActionSaveProjectAs->setIcon( getThemeIcon( "/mActionFileSaveAs.png" ) );
mActionNewPrintComposer->setIcon( getThemeIcon( "/mActionNewComposer.png" ) );
+ mActionShowComposerManager->setIcon( getThemeIcon( "/mActionFilePrint.png" ) );
mActionSaveMapAsImage->setIcon( getThemeIcon( "/mActionSaveMapAsImage.png" ) );
mActionExit->setIcon( getThemeIcon( "/mActionFileExit.png" ) );
mActionAddOgrLayer->setIcon( getThemeIcon( "/mActionAddOgrLayer.png" ) );
@@ -1709,10 +1717,10 @@
mActionAddToOverview->setIcon( getThemeIcon( "/mActionInOverview.png" ) );
//change themes of all composers
- QMap<QString, QgsComposer*>::iterator composerIt = mPrintComposers.begin();
+ QSet<QgsComposer*>::iterator composerIt = mPrintComposers.begin();
for ( ; composerIt != mPrintComposers.end(); ++composerIt )
- composerIt.value()->setupTheme();
+ ( *composerIt )->setupTheme();
emit currentThemeChanged( theThemeName );
@@ -3701,18 +3709,15 @@
return;
- //ask user about name
- mLastComposerId++;
- QString composerId = QString( tr("Map Composer %1").arg( mLastComposerId ) );
- //create new composer object
- QgsComposer* newComposerObject = new QgsComposer( this, composerId );
- //add it to the map of existing print composers
- mPrintComposers.insert( composerId, newComposerObject );
- //and place action into print composers menu
- mPrintComposersMenu->addAction( newComposerObject->windowAction() );
- newComposerObject->open();
+ createNewComposer();
+void QgisApp::showComposerManager()
+ QgsComposerManager m( this, 0, Qt::WindowStaysOnTopHint );
+ m.exec();
void QgisApp::saveMapAsImage()
//create a map to hold the QImageIO names and the filter names
@@ -4191,25 +4196,25 @@
return unionGeom;
-QList<QgsComposer*> QgisApp::printComposers()
+QgsComposer* QgisApp::createNewComposer()
- QList<QgsComposer*> composerList;
- QMap<QString, QgsComposer*>::iterator it = mPrintComposers.begin();
- for ( ; it != mPrintComposers.end(); ++it )
- composerList.push_back( it.value() );
- return composerList;
+ //ask user about name
+ mLastComposerId++;
+ //create new composer object
+ QgsComposer* newComposerObject = new QgsComposer( this, tr( "Composer %1" ).arg( mLastComposerId ) );
+ //add it to the map of existing print composers
+ mPrintComposers.insert( newComposerObject );
+ //and place action into print composers menu
+ mPrintComposersMenu->addAction( newComposerObject->windowAction() );
+ newComposerObject->open();
+ return newComposerObject;
-void QgisApp::checkOutComposer( QgsComposer* c )
+void QgisApp::deleteComposer( QgsComposer* c )
- if ( !c )
- return;
- mPrintComposers.remove( c->id() );
+ mPrintComposers.remove( c );
mPrintComposersMenu->removeAction( c->windowAction() );
+ delete c;
bool QgisApp::loadComposersFromProject( const QString& projectFilePath )
@@ -4231,24 +4236,23 @@
QDomNodeList composerNodes = projectDom.elementsByTagName( "Composer" );
for ( int i = 0; i < composerNodes.size(); ++i )
- QgsComposer* composer = new QgsComposer( this, "" );
+ ++mLastComposerId;
+ QgsComposer* composer = new QgsComposer( this, tr( "Composer %1" ).arg( mLastComposerId ) );
composer->readXML( composerNodes.at( i ).toElement(), projectDom );
- mPrintComposers.insert( composer->id(), composer );
+ mPrintComposers.insert( composer );
mPrintComposersMenu->addAction( composer->windowAction() );
composer->showMinimized();
composer->zoomFull();
- mLastComposerId = composerNodes.size();
return true;
void QgisApp::deletePrintComposers()
+ QSet<QgsComposer*>::iterator it = mPrintComposers.begin();
- delete it.value();
+ delete( *it );
mPrintComposers.clear();
mLastComposerId = 0;
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/qgisapp.h 2009-11-11 17:05:16 UTC (rev 12087)
@@ -195,11 +195,13 @@
void removeWindow( QAction *action );
/**Returns the print composers*/
- QList<QgsComposer*> printComposers();
- /**Unregisters a composer instance but does _not_ delete it. This method is usually called from within QgsComposer::closeEvent before
- the composer deletes itself using the Qt::WA_DeleteOnClose flag*/
- void checkOutComposer( QgsComposer* c );
+ QSet<QgsComposer*> printComposers() const {return mPrintComposers;}
+ /**Creates a new composer and returns a pointer to it*/
+ QgsComposer* createNewComposer();
+ /**Deletes a composer and removes entry from Set*/
+ void deleteComposer( QgsComposer* c );
//! Actions to be inserted in menus and toolbars
QAction *actionNewProject() { return mActionNewProject; }
QAction *actionOpenProject() { return mActionOpenProject; }
@@ -450,6 +452,7 @@
void newVectorLayer();
//! Print the current map view frame
void newPrintComposer();
+ void showComposerManager();
//! Add all loaded layers into the overview - overides qgisappbase method
void addAllToOverview();
//! Remove all loaded layers from the overview - overides qgisappbase method
@@ -727,6 +730,7 @@
QAction *mActionProjectProperties;
QAction *mActionFileSeparator3;
QAction *mActionNewPrintComposer;
+ QAction *mActionShowComposerManager;
QAction *mActionFileSeparator4;
QAction *mActionExit;
@@ -947,7 +951,7 @@
//! list of recently opened/saved project files
QStringList mRecentProjectPaths;
//! Print composers of this project, accessible by id string
- QMap<QString, QgsComposer*> mPrintComposers;
+ QSet<QgsComposer*> mPrintComposers;
//! How to determine the number of decimal places used to
//! display the mouse position
bool mMousePrecisionAutomatic;
Modified: trunk/qgis/src/app/qgisappinterface.cpp
--- trunk/qgis/src/app/qgisappinterface.cpp 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/app/qgisappinterface.cpp 2009-11-11 17:05:16 UTC (rev 12087)
@@ -152,9 +152,9 @@
QList<QgsComposerView*> composerViewList;
if ( qgis )
- QList<QgsComposer*> composerList = qgis->printComposers();
- QList<QgsComposer*>::iterator it = composerList.begin();
- for ( ; it != composerList.end(); ++it )
+ const QSet<QgsComposer*> composerList = qgis->printComposers();
+ QSet<QgsComposer*>::const_iterator it = composerList.constBegin();
+ for ( ; it != composerList.constEnd(); ++it )
if ( *it )
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2009-11-11 10:38:40 UTC (rev 12086)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2009-11-11 17:05:16 UTC (rev 12087)
@@ -20,8 +20,8 @@
<property name="mouseTracking">
<bool>true</bool>
</property>
- <layout class="QGridLayout">
- <item row="1" column="0">
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
<widget class="QSplitter" name="mSplitter">
<bool>true</bool>
@@ -133,6 +133,13 @@
</widget>
</widget>
</item>
+ <item row="1" column="0">
+ <widget class="QDialogButtonBox" name="mButtonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Close</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
<widget class="QToolBar" name="toolBar">
Added: trunk/qgis/src/ui/qgscomposermanagerbase.ui
--- trunk/qgis/src/ui/qgscomposermanagerbase.ui (rev 0)
+++ trunk/qgis/src/ui/qgscomposermanagerbase.ui 2009-11-11 17:05:16 UTC (rev 12087)
@@ -0,0 +1,108 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsComposerManagerBase</class>
+ <widget class="QDialog" name="QgsComposerManagerBase">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>333</width>
+ <height>198</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Composer manager</string>
+ </property>
+ <item row="0" column="0" rowspan="5">
+ <widget class="QListWidget" name="mComposerListWidget"/>
+ </item>
+ <item row="0" column="1">
+ <widget class="QPushButton" name="mAddButton">
+ <property name="text">
+ <string>Add</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QPushButton" name="mRemoveButton">
+ <string>Remove</string>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QPushButton" name="mRenamePushButton">
+ <string>Rename</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
+ <widget class="QPushButton" name="mShowPushButton">
+ <string>Show</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1">
+ <spacer name="verticalSpacer">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>50</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="5" column="0" colspan="2">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>mButtonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsComposerManagerBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>251</x>
+ <y>193</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>251</x>
+ <y>193</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
