[QGIS Commit] r12089 - trunk/qgis/src/helpviewer
svn_qgis at osgeo.org
Wed Nov 11 12:12:18 EST 2009
Author: macho
Date: 2009-11-11 12:12:17 -0500 (Wed, 11 Nov 2009)
New Revision: 12089
trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
ui cleanup -> buttonbox to helpviewert:x
Modified: trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
--- trunk/qgis/src/helpviewer/qgshelpviewerbase.ui 2009-11-11 17:12:17 UTC (rev 12088)
+++ trunk/qgis/src/helpviewer/qgshelpviewerbase.ui 2009-11-11 17:12:17 UTC (rev 12089)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsHelpViewerBase</class>
- <widget class="QDialog" name="QgsHelpViewerBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsHelpViewerBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
@@ -9,88 +10,56 @@
<height>417</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>QGIS Help</string>
</property>
- <property name="windowIcon" >
+ <property name="windowIcon">
<iconset>
<normaloff/>
</iconset>
</property>
- <property name="sizeGripEnabled" >
+ <property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <layout class="QGridLayout" >
- <property name="margin" >
+ <layout class="QGridLayout">
+ <property name="margin">
<number>9</number>
</property>
- <property name="spacing" >
+ <property name="spacing">
<number>6</number>
</property>
- <item row="0" column="0" >
- <widget class="QTextBrowser" name="txtBrowser" >
- <property name="acceptDrops" >
+ <item row="0" column="0">
+ <widget class="QTextBrowser" name="txtBrowser">
+ <property name="acceptDrops">
<bool>false</bool>
</property>
</widget>
</item>
- <item row="1" column="0" >
- <layout class="QHBoxLayout" >
- <number>0</number>
+ <item row="1" column="0">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Close</set>
</property>
- <number>6</number>
- </property>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>390</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="buttonCancel" >
- <property name="text" >
- <string>&Close</string>
- </property>
- <property name="shortcut" >
- <string>Alt+C</string>
- </property>
- <property name="autoDefault" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- </layout>
+ </widget>
</item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
<resources/>
<connections>
<connection>
- <sender>buttonCancel</sender>
- <signal>clicked()</signal>
+ <sender>buttonBox</sender>
+ <signal>rejected()</signal>
<receiver>QgsHelpViewerBase</receiver>
<slot>reject()</slot>
<hints>
- <hint type="sourcelabel" >
- <x>455</x>
- <y>393</y>
+ <hint type="sourcelabel">
+ <x>482</x>
+ <y>390</y>
</hint>
- <hint type="destinationlabel" >
- <x>256</x>
- <y>208</y>
+ <hint type="destinationlabel">
+ <x>508</x>
+ <y>288</y>
</hint>
</hints>
</connection>
