[QGIS Commit] r12103 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 14 06:21:34 EST 2009
Author: timlinux
Date: 2009-11-14 06:21:34 -0500 (Sat, 14 Nov 2009)
New Revision: 12103
   trunk/qgis/src/ui/qgslabeldialogbase.ui
Fix for missing label field combo
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui	2009-11-13 20:05:18 UTC (rev 12102)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui	2009-11-14 11:21:34 UTC (rev 12103)
@@ -6,7 +6,7 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>668</width>
+    <width>642</width>
     <height>516</height>
    </rect>
   </property>
@@ -23,63 +23,7 @@
    <property name="margin">
     <number>0</number>
    </property>
-   <item row="0" column="0" rowspan="2" colspan="2">
-    <layout class="QHBoxLayout">
-     <item>
-      <widget class="QLabel" name="textLabel5">
-       <property name="text">
-        <string>Field containing label</string>
-       </property>
-       <property name="buddy">
-        <cstring>cboLabelField</cstring>
-       </property>
-      </widget>
-     </item>
-     <item>
-      <widget class="QComboBox" name="cboLabelField">
-       <property name="sizePolicy">
-        <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
-         <horstretch>1</horstretch>
-         <verstretch>0</verstretch>
-        </sizepolicy>
-       </property>
-       <property name="minimumSize">
-        <size>
-         <width>0</width>
-         <height>20</height>
-        </size>
-       </property>
-      </widget>
-     </item>
-     <item>
-      <widget class="QLabel" name="textLabel1">
-        <string>Default label</string>
-       </property>
-        <cstring>leDefaultLabel</cstring>
-       </property>
-      </widget>
-     </item>
-     <item>
-      <widget class="QLineEdit" name="leDefaultLabel">
-         <horstretch>2</horstretch>
-        </sizepolicy>
-       </property>
-        <size>
-         <width>0</width>
-        </size>
-       </property>
-      </widget>
-     </item>
-    </layout>
-   </item>
-   <item row="1" column="1">
+   <item row="0" column="0">
     <widget class="QScrollArea" name="scrollArea">
      <property name="widgetResizable">
       <bool>true</bool>
@@ -88,104 +32,163 @@
       <property name="geometry">
        <rect>
         <x>0</x>
-        <y>0</y>
-        <width>639</width>
-        <height>1455</height>
+        <y>-990</y>
+        <width>619</width>
+        <height>1440</height>
        </rect>
       </property>
       <layout class="QGridLayout" name="gridLayout">
-       <item row="0" column="0" colspan="2">
         <layout class="QGridLayout">
-          <widget class="QPushButton" name="btnDefaultFont">
-            </sizepolicy>
+          <widget class="QGroupBox" name="groupBox_8">
+           <property name="title">
+            <string>Basic label options</string>
            </property>
-            <string>Font</string>
-           </property>
+           <layout class="QGridLayout" name="gridLayout_8">
+             <widget class="QLabel" name="textLabel5">
+              <property name="text">
+               <string>Field containing label</string>
+              </property>
+              <property name="buddy">
+               <cstring>cboLabelField</cstring>
+              </property>
+             </widget>
+            </item>
+            <item row="0" column="2">
+             <widget class="QComboBox" name="cboLabelField">
+              <property name="sizePolicy">
+               <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+                <horstretch>1</horstretch>
+                <verstretch>0</verstretch>
+               </sizepolicy>
+              </property>
+             </widget>
+            </item>
+            <item row="1" column="0">
+             <widget class="QLabel" name="textLabel1">
+               <string>Default label</string>
+              </property>
+               <cstring>leDefaultLabel</cstring>
+              </property>
+             </widget>
+            </item>
+            <item row="1" column="2">
+             <widget class="QLineEdit" name="leDefaultLabel">
+                <horstretch>2</horstretch>
+               </sizepolicy>
+              </property>
+             </widget>
+            </item>
+            <item row="2" column="0">
+             <widget class="QPushButton" name="btnDefaultFont">
+               <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+               </sizepolicy>
+              </property>
+               <string>Font</string>
+              </property>
+             </widget>
+            </item>
+            <item row="2" column="1">
+             <widget class="QLabel" name="textLabel5_2_2_3_2">
+               <string>Font size</string>
+              </property>
+              <property name="alignment">
+               <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
+              </property>
+               <cstring>spinFontSize</cstring>
+              </property>
+             </widget>
+            </item>
+            <item row="2" column="2">
+             <widget class="QDoubleSpinBox" name="spinFontSize">
+                <horstretch>0</horstretch>
+               </sizepolicy>
+              </property>
+              <property name="minimumSize">
+               <size>
+                <width>50</width>
+                <height>0</height>
+               </size>
+              </property>
+              <property name="decimals">
+               <number>6</number>
+              </property>
+              <property name="maximum">
+               <double>1000000.000000000000000</double>
+              </property>
+              <property name="value">
+               <double>0.000000000000000</double>
+              </property>
+             </widget>
+            </item>
+            <item row="3" column="0">
+             <widget class="QPushButton" name="pbnDefaultFontColor">
+               </sizepolicy>
+              </property>
+               <string>Color</string>
+              </property>
+             </widget>
+            </item>
+            <item row="3" column="1">
+             <widget class="QLabel" name="textLabel1_2_2_2_2_2">
+               <string>Angle (deg)</string>
+              </property>
+               <cstring>spinAngle</cstring>
+              </property>
+             </widget>
+            </item>
+            <item row="3" column="2">
+             <widget class="QSpinBox" name="spinAngle">
+              <property name="suffix">
+               <string>°</string>
+              </property>
+               <number>360</number>
+              </property>
+               <number>0</number>
+              </property>
+             </widget>
+            </item>
+            <item row="4" column="0">
+             <widget class="QCheckBox" name="chkUseMultiline">
+               <string>Multiline labels?</string>
+              </property>
+              <property name="checked">
+               <bool>true</bool>
+              </property>
+             </widget>
+            </item>
+           </layout>
           </widget>
          </item>
-         <item row="0" column="1">
-          <widget class="QLabel" name="textLabel5_2_2_3_2">
-            <string>Font size</string>
-           </property>
-           <property name="alignment">
-            <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
-           </property>
-            <cstring>spinFontSize</cstring>
-           </property>
-          </widget>
-         </item>
-         <item row="0" column="2">
-          <widget class="QDoubleSpinBox" name="spinFontSize">
-             <horstretch>0</horstretch>
-            </sizepolicy>
-           </property>
-            <size>
-             <width>50</width>
-             <height>0</height>
-            </size>
-           </property>
-           <property name="decimals">
-            <number>6</number>
-           </property>
-           <property name="maximum">
-            <double>1000000.000000000000000</double>
-           </property>
-           <property name="value">
-            <double>0.000000000000000</double>
-           </property>
-          </widget>
-         </item>
-         <item row="1" column="0">
-          <widget class="QPushButton" name="pbnDefaultFontColor">
-            </sizepolicy>
-           </property>
-            <string>Color</string>
-           </property>
-          </widget>
-         </item>
-          <widget class="QLabel" name="textLabel1_2_2_2_2_2">
-            <string>Angle (deg)</string>
-           </property>
-            <cstring>spinAngle</cstring>
-           </property>
-          </widget>
-         </item>
-         <item row="1" column="2">
-          <widget class="QSpinBox" name="spinAngle">
-           <property name="suffix">
-            <string>°</string>
-           </property>
-            <number>360</number>
-           </property>
-            <number>0</number>
-           </property>
-          </widget>
-         </item>
         </layout>
        </item>
-       <item row="1" column="0" colspan="2">
         <widget class="QGroupBox" name="groupBox_2">
           <string>Placement</string>
@@ -263,7 +266,7 @@
          </layout>
         </widget>
        </item>
-       <item row="2" column="0" colspan="2">
         <widget class="QGroupBox" name="groupBox_3">
           <string>Font size units</string>
@@ -286,7 +289,7 @@
          </layout>
         </widget>
        </item>
-       <item row="3" column="0" colspan="2">
         <widget class="QGroupBox" name="chkUseScaleDependentRendering">
           <string>Use scale dependent rendering</string>
@@ -347,155 +350,145 @@
          </layout>
         </widget>
        </item>
-       <item row="4" column="0" colspan="2">
-        <widget class="QCheckBox" name="chkUseMultiline">
-          <string>Multiline labels?</string>
-         </property>
-         <property name="checked">
-          <bool>true</bool>
-         </property>
-        </widget>
-       </item>
-       <item row="5" column="0">
-        <widget class="QCheckBox" name="chkUseBuffer">
-          <string>Buffer labels?</string>
-         </property>
-          <bool>true</bool>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="0">
-        <widget class="QLabel" name="textLabel4_3_2_2">
-          <string>Buffer size</string>
-         </property>
-        </widget>
-       </item>
-       <item row="6" column="1">
-        <widget class="QDoubleSpinBox" name="spinBufferSize"/>
-       </item>
-       <item row="7" column="0">
-        <widget class="QLabel" name="textLabel5_2_2_3">
-         <property name="enabled">
-          <bool>false</bool>
-         </property>
-          <string>Transparency</string>
-         </property>
-         </property>
-        </widget>
-       </item>
-       <item row="7" column="1">
-        <widget class="QSpinBox" name="spinBufferTransparency">
-         </property>
-          </sizepolicy>
-         </property>
-          <size>
-           <width>50</width>
-          </size>
-         </property>
-          <string>%</string>
-         </property>
-          <number>100</number>
-         </property>
-         </property>
-        </widget>
-       </item>
-       <item row="8" column="0" colspan="2">
-        <widget class="QPushButton" name="pbnDefaultBufferColor_2">
-         </property>
-        </widget>
-       </item>
-       <item row="9" column="0" colspan="2">
+       <item row="10" column="0">
         <widget class="QGroupBox" name="groupBox_4">
           <string>Buffer size units</string>
          </property>
-         <layout class="QGridLayout">
-          <item row="0" column="0">
+         <layout class="QGridLayout" name="gridLayout_9">
+           <widget class="QLabel" name="textLabel4_3_2_2">
+             <string>Buffer size</string>
+            </property>
+           </widget>
+          </item>
+          <item row="1" column="1">
+           <widget class="QDoubleSpinBox" name="spinBufferSize"/>
+          </item>
            <widget class="QRadioButton" name="radioBufferUnitsPoints">
              <string>Size is in points</string>
             </property>
            </widget>
           </item>
            <widget class="QRadioButton" name="radioBufferUnitsMap">
              <string>Size is in map units</string>
             </property>
            </widget>
           </item>
+           <widget class="QLabel" name="textLabel5_2_2_3">
+            <property name="enabled">
+             <bool>false</bool>
+            </property>
+             <string>Transparency</string>
+            </property>
+            </property>
+           </widget>
+          </item>
+           <widget class="QSpinBox" name="spinBufferTransparency">
+            </property>
+             </sizepolicy>
+            </property>
+             <size>
+              <width>50</width>
+             </size>
+            </property>
+             <string>%</string>
+            </property>
+             <number>100</number>
+            </property>
+            </property>
+           </widget>
+          </item>
+           <widget class="QCheckBox" name="chkUseBuffer">
+             <string>Buffer labels?</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+          <item row="0" column="1">
+           <widget class="QPushButton" name="pbnDefaultBufferColor_2">
+            </property>
+           </widget>
+          </item>
          </layout>
         </widget>
        </item>
-       <item row="10" column="0">
+       <item row="11" column="0">
         <widget class="QGroupBox" name="buttonGroup10">
           <string>Offset units</string>
          </property>
          <layout class="QGridLayout" name="gridLayout_2">
-           <widget class="QDoubleSpinBox" name="spinXOffset">
-            <property name="minimum">
-             <double>-99.000000000000000</double>
+           <widget class="QLabel" name="textLabel1_2_2_2_3">
+             <string>Y Offset (pts)</string>
             </property>
            </widget>
           </item>
-          <item row="3" column="0">
            <widget class="QLabel" name="textLabel1_2_3_2">
              <string>X Offset (pts)</string>
             </property>
            </widget>
           </item>
-          <item row="4" column="0">
+           <widget class="QDoubleSpinBox" name="spinXOffset">
+            <property name="minimum">
+             <double>-99.000000000000000</double>
+            </property>
+           </widget>
+          </item>
            <widget class="QDoubleSpinBox" name="spinYOffset">
             </property>
            </widget>
           </item>
            <widget class="QRadioButton" name="radioOffsetUnitsPoints">
              <string>Points</string>
             </property>
            </widget>
           </item>
-          <item row="5" column="1">
            <widget class="QRadioButton" name="radioOffsetUnitsMap">
              <string>Map units</string>
             </property>
            </widget>
           </item>
-           <widget class="QLabel" name="textLabel1_2_2_2_3">
-             <string>Y Offset (pts)</string>
-            </property>
-           </widget>
-          </item>
          </layout>
         </widget>
        </item>
@@ -540,46 +533,33 @@
          </layout>
         </widget>
        </item>
-       <item row="14" column="0">
-        <widget class="QGroupBox" name="groupBox_6">
+       <item row="13" column="0">
+        <widget class="QGroupBox" name="groupBox">
-          <string>Data defined buffer</string>
+          <string>Data defined properties</string>
          </property>
-         <layout class="QGridLayout" name="gridLayout_5">
+         <layout class="QGridLayout" name="gridLayout_3">
-           <widget class="QLabel" name="textLabel1_3_2_2_2">
-            </property>
+           <widget class="QLabel" name="lblFont">
              </sizepolicy>
             </property>
-             <size>
-              <width>70</width>
-             </size>
-            </property>
-             <string>Transparency:</string>
+             <string>&amp;Font family</string>
             </property>
-             <cstring>cboBufferTransparencyField</cstring>
+             <cstring>cboFontField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboBufferTransparencyField">
-            </property>
-           </widget>
+           <widget class="QComboBox" name="cboFontField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_3_2_2_2">
+           <widget class="QLabel" name="textLabel4">
@@ -587,27 +567,18 @@
              </sizepolicy>
             </property>
-             <string>Size:</string>
+             <string>&amp;Bold</string>
             </property>
-             <cstring>cboBufferSizeField</cstring>
+             <cstring>cboBoldField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboBufferSizeField"/>
+           <widget class="QComboBox" name="cboBoldField"/>
           </item>
-         </layout>
-        </widget>
-       </item>
-       <item row="15" column="0">
-        <widget class="QGroupBox" name="groupBox_7">
-         <property name="title">
-          <string>Data defined position</string>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_6">
-           <widget class="QLabel" name="textLabel1_2">
+           <widget class="QLabel" name="textLabel4_2_4">
@@ -615,15 +586,18 @@
              </sizepolicy>
             </property>
-             <string>X Coordinate</string>
+             <string>&amp;Italic</string>
             </property>
+             <cstring>cboItalicField</cstring>
+            </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboXCoordinateField"/>
+           <widget class="QComboBox" name="cboItalicField"/>
           </item>
-           <widget class="QLabel" name="textLabel1_2_2">
+           <widget class="QLabel" name="textLabel4_3">
@@ -631,15 +605,18 @@
              </sizepolicy>
             </property>
-             <string>Y Coordinate</string>
+             <string>&amp;Underline</string>
             </property>
+             <cstring>cboUnderlineField</cstring>
+            </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboYCoordinateField"/>
+           <widget class="QComboBox" name="cboUnderlineField"/>
           </item>
-          <item row="2" column="0">
-           <widget class="QLabel" name="textLabel1_2_3">
+           <widget class="QLabel" name="textLabel4_3_2">
@@ -647,15 +624,18 @@
              </sizepolicy>
             </property>
-             <string>X Offset (pts)</string>
+             <string>&amp;Size</string>
             </property>
+             <cstring>cboFontSizeField</cstring>
+            </property>
            </widget>
           </item>
-          <item row="2" column="1">
-           <widget class="QComboBox" name="cboXOffsetField"/>
+          <item row="4" column="1">
+           <widget class="QComboBox" name="cboFontSizeField"/>
           </item>
-           <widget class="QLabel" name="textLabel1_2_2_2">
+          <item row="5" column="0">
+           <widget class="QLabel" name="textLabel4_3_2_4">
@@ -663,24 +643,21 @@
              </sizepolicy>
             </property>
+             <string>Size units</string>
             </property>
+             <cstring>cboFontSizeTypeField</cstring>
+            </property>
            </widget>
           </item>
-          <item row="3" column="1">
-           <widget class="QComboBox" name="cboYOffsetField"/>
+          <item row="5" column="1">
+           <widget class="QComboBox" name="cboFontSizeTypeField"/>
           </item>
-         </layout>
-        </widget>
-       </item>
-       <item row="13" column="0">
-        <widget class="QGroupBox" name="groupBox">
-          <string>Data defined properties</string>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_3">
-           <widget class="QLabel" name="lblFont">
+          <item row="6" column="0">
+           <widget class="QLabel" name="textLabel4_3_2_3">
+            </property>
@@ -688,18 +665,22 @@
              </sizepolicy>
             </property>
-             <string>&amp;Font family</string>
             </property>
-             <cstring>cboFontField</cstring>
+             <cstring>cboFontTransparencyField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboFontField"/>
+          <item row="6" column="1">
+           <widget class="QComboBox" name="cboFontTransparencyField">
+            </property>
+           </widget>
           </item>
-           <widget class="QLabel" name="textLabel4">
+          <item row="7" column="0">
+           <widget class="QLabel" name="textLabel4_3_2_5">
@@ -707,37 +688,59 @@
              </sizepolicy>
             </property>
-             <string>&amp;Bold</string>
+             <string>&amp;Color</string>
             </property>
-             <cstring>cboBoldField</cstring>
+             <cstring>cboFontColorField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboBoldField"/>
+          <item row="7" column="1">
+           <widget class="QComboBox" name="cboFontColorField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_2_4">
+         </layout>
+        </widget>
+       </item>
+       <item row="14" column="0">
+        <widget class="QGroupBox" name="groupBox_6">
+          <string>Data defined buffer</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_5">
+           <widget class="QLabel" name="textLabel1_3_2_2_2">
+            </property>
              </sizepolicy>
             </property>
+             <size>
+              <width>70</width>
+             </size>
+            </property>
-             <string>&amp;Italic</string>
+             <string>Transparency:</string>
             </property>
-             <cstring>cboItalicField</cstring>
+             <cstring>cboBufferTransparencyField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboItalicField"/>
+           <widget class="QComboBox" name="cboBufferTransparencyField">
+            </property>
+           </widget>
           </item>
-           <widget class="QLabel" name="textLabel4_3">
+           <widget class="QLabel" name="textLabel4_3_2_2_2">
@@ -745,18 +748,27 @@
              </sizepolicy>
             </property>
-             <string>&amp;Underline</string>
+             <string>Size:</string>
             </property>
-             <cstring>cboUnderlineField</cstring>
+             <cstring>cboBufferSizeField</cstring>
             </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboUnderlineField"/>
+           <widget class="QComboBox" name="cboBufferSizeField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_3_2">
+         </layout>
+        </widget>
+       </item>
+       <item row="15" column="0">
+        <widget class="QGroupBox" name="groupBox_7">
+          <string>Data defined position</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_6">
+           <widget class="QLabel" name="textLabel1_2">
@@ -764,18 +776,15 @@
              </sizepolicy>
             </property>
-             <string>&amp;Size</string>
+             <string>X Coordinate</string>
             </property>
-             <cstring>cboFontSizeField</cstring>
-            </property>
            </widget>
           </item>
-          <item row="4" column="1">
-           <widget class="QComboBox" name="cboFontSizeField"/>
+           <widget class="QComboBox" name="cboXCoordinateField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_3_2_4">
+           <widget class="QLabel" name="textLabel1_2_2">
@@ -783,21 +792,15 @@
              </sizepolicy>
             </property>
-             <string>Size units</string>
+             <string>Y Coordinate</string>
             </property>
-             <cstring>cboFontSizeTypeField</cstring>
-            </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboFontSizeTypeField"/>
+           <widget class="QComboBox" name="cboYCoordinateField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_3_2_3">
-            </property>
+           <widget class="QLabel" name="textLabel1_2_3">
@@ -805,22 +808,15 @@
              </sizepolicy>
             </property>
+             <string>X Offset (pts)</string>
             </property>
-             <cstring>cboFontTransparencyField</cstring>
-            </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboFontTransparencyField">
-            </property>
-           </widget>
+           <widget class="QComboBox" name="cboXOffsetField"/>
           </item>
-           <widget class="QLabel" name="textLabel4_3_2_5">
+           <widget class="QLabel" name="textLabel1_2_2_2">
@@ -828,15 +824,12 @@
              </sizepolicy>
             </property>
-             <string>&amp;Color</string>
             </property>
-             <cstring>cboFontColorField</cstring>
-            </property>
            </widget>
           </item>
-           <widget class="QComboBox" name="cboFontColorField"/>
+           <widget class="QComboBox" name="cboYOffsetField"/>
           </item>
          </layout>
         </widget>
@@ -845,7 +838,7 @@
      </widget>
     </widget>
    </item>
     <widget class="QGroupBox" name="groupBox5">
@@ -880,12 +873,14 @@
  </widget>
  <layoutdefault spacing="6" margin="11"/>
  <tabstops>
+  <tabstop>scrollArea</tabstop>
   <tabstop>cboLabelField</tabstop>
   <tabstop>leDefaultLabel</tabstop>
   <tabstop>btnDefaultFont</tabstop>
   <tabstop>spinFontSize</tabstop>
   <tabstop>pbnDefaultFontColor</tabstop>
   <tabstop>spinAngle</tabstop>
+  <tabstop>chkUseMultiline</tabstop>
   <tabstop>radioAboveLeft</tabstop>
   <tabstop>radioAbove</tabstop>
   <tabstop>radioAboveRight</tabstop>
@@ -897,12 +892,35 @@
   <tabstop>radioBelowRight</tabstop>
   <tabstop>radioFontSizeUnitsPoints</tabstop>
   <tabstop>radioFontSizeUnitsMap</tabstop>
+  <tabstop>chkUseScaleDependentRendering</tabstop>
   <tabstop>spinMinimumScale</tabstop>
   <tabstop>spinMaximumScale</tabstop>
+  <tabstop>chkUseBuffer</tabstop>
+  <tabstop>pbnDefaultBufferColor_2</tabstop>
+  <tabstop>spinBufferSize</tabstop>
+  <tabstop>radioBufferUnitsPoints</tabstop>
+  <tabstop>radioBufferUnitsMap</tabstop>
+  <tabstop>spinBufferTransparency</tabstop>
+  <tabstop>spinXOffset</tabstop>
+  <tabstop>spinYOffset</tabstop>
   <tabstop>radioOffsetUnitsPoints</tabstop>
   <tabstop>radioOffsetUnitsMap</tabstop>
-  <tabstop>radioBufferUnitsPoints</tabstop>
-  <tabstop>radioBufferUnitsMap</tabstop>
+  <tabstop>cboAlignmentField</tabstop>
+  <tabstop>cboAngleField</tabstop>
+  <tabstop>cboFontField</tabstop>
+  <tabstop>cboBoldField</tabstop>
+  <tabstop>cboItalicField</tabstop>
+  <tabstop>cboUnderlineField</tabstop>
+  <tabstop>cboFontSizeField</tabstop>
+  <tabstop>cboFontSizeTypeField</tabstop>
+  <tabstop>cboFontTransparencyField</tabstop>
+  <tabstop>cboFontColorField</tabstop>
+  <tabstop>cboBufferTransparencyField</tabstop>
+  <tabstop>cboBufferSizeField</tabstop>
+  <tabstop>cboXCoordinateField</tabstop>
+  <tabstop>cboYCoordinateField</tabstop>
+  <tabstop>cboXOffsetField</tabstop>
+  <tabstop>cboYOffsetField</tabstop>
  </tabstops>
  <resources/>
  <connections>
More information about the QGIS-commit mailing list
