[QGIS Commit] r12124 - in trunk/qgis: python/core
src/app/attributetable src/core
svn_qgis at osgeo.org
Sun Nov 15 12:13:22 EST 2009
Author: jef
Date: 2009-11-15 12:13:20 -0500 (Sun, 15 Nov 2009)
New Revision: 12124
trunk/qgis/python/core/qgsattributeaction.sip
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/core/qgsattributeaction.cpp
trunk/qgis/src/core/qgsattributeaction.h
fix build errors on windows
Modified: trunk/qgis/python/core/qgsattributeaction.sip
--- trunk/qgis/python/core/qgsattributeaction.sip 2009-11-15 15:19:43 UTC (rev 12123)
+++ trunk/qgis/python/core/qgsattributeaction.sip 2009-11-15 17:13:20 UTC (rev 12124)
@@ -71,7 +71,7 @@
//! Reads the actions in in XML format
bool readXML( const QDomNode& layer_node );
- //! interface to inherited methods from QList<QgsAction>
- const QgsAction &at( int idx );
- const int size();
+ int size() const;
+ QgsAction &at( int idx );
+ QgsAction &operator[]( int idx );
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-11-15 15:19:43 UTC (rev 12123)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-11-15 17:13:20 UTC (rev 12124)
@@ -388,8 +388,8 @@
// new selection should be created
if ( clickType == 0 ) // Single click
- if ( mSelectedFeatures.size() == 1 and wasSelected ) // One item selected
- return // Click over a selected item doesn't do anything
+ if ( mSelectedFeatures.size() == 1 && wasSelected ) // One item selected
+ return; // Click over a selected item doesn't do anything
mView->setCurrentIndex( mFilterModel->index( first, 0 ) );
mView->selectRow( first );
Modified: trunk/qgis/src/core/qgsattributeaction.cpp
--- trunk/qgis/src/core/qgsattributeaction.cpp 2009-11-15 15:19:43 UTC (rev 12123)
+++ trunk/qgis/src/core/qgsattributeaction.cpp 2009-11-15 17:13:20 UTC (rev 12124)
@@ -35,7 +35,7 @@
void QgsAttributeAction::addAction( QgsAction::ActionType type, QString name, QString action, bool capture )
- *this << QgsAction( type, name, action, capture );
+ mActions << QgsAction( type, name, action, capture );
void QgsAttributeAction::doAction( int index, const QList< QPair<QString, QString> > &values,
@@ -116,13 +116,13 @@
QDomElement aActions = doc.createElement( "attributeactions" );
- for ( int i = 0; i < size(); i++ )
+ for ( int i = 0; i < mActions.size(); i++ )
QDomElement actionSetting = doc.createElement( "actionsetting" );
- actionSetting.setAttribute( "type", at( i ).type() );
- actionSetting.setAttribute( "name", at( i ).name() );
- actionSetting.setAttribute( "action", at( i ).action() );
- actionSetting.setAttribute( "capture", at( i ).capture() );
+ actionSetting.setAttribute( "type", mActions[i].type() );
+ actionSetting.setAttribute( "name", mActions[i].name() );
+ actionSetting.setAttribute( "action", mActions[i].action() );
+ actionSetting.setAttribute( "capture", mActions[i].capture() );
aActions.appendChild( actionSetting );
layer_node.appendChild( aActions );
@@ -132,7 +132,7 @@
bool QgsAttributeAction::readXML( const QDomNode& layer_node )
- clear();
+ mActions.clear();
QDomNode aaNode = layer_node.namedItem( "attributeactions" );
Modified: trunk/qgis/src/core/qgsattributeaction.h
--- trunk/qgis/src/core/qgsattributeaction.h 2009-11-15 15:19:43 UTC (rev 12123)
+++ trunk/qgis/src/core/qgsattributeaction.h 2009-11-15 17:13:20 UTC (rev 12124)
@@ -63,7 +63,7 @@
//! Whether to capture output for display when this action is run
bool capture() const { return mCaptureOutput; }
+ //! Wheter the action is runable on the current platform
bool runable() const
return mType == Generic ||
@@ -90,14 +90,14 @@
* attributes.
-class CORE_EXPORT QgsAttributeAction : public QList<QgsAction>
+class CORE_EXPORT QgsAttributeAction
public:
//! Constructor
- QgsAttributeAction() {};
+ QgsAttributeAction() {}
//! Destructor
- virtual ~QgsAttributeAction() {};
+ virtual ~QgsAttributeAction() {}
//! Add an action with the given name and action details.
// Will happily have duplicate names and actions. If
@@ -113,7 +113,7 @@
int defaultValueIndex = 0, void ( *executePython )( const QString & ) = 0 );
//! Removes all actions
- void clearActions() { clear(); }
+ void clearActions() { mActions.clear(); }
//! Expands the given action, replacing all %'s with the value as
// given.
@@ -125,6 +125,13 @@
+ int size() const { return mActions.size(); }
+ QgsAction &at( int idx ) { return mActions[idx]; }
+ QgsAction &operator[]( int idx ) { return mActions[idx]; }
+ private:
+ QList<QgsAction> mActions;
#endif
