[QGIS Commit] r12133 - trunk/qgis/python/plugins/mapserver_export
svn_qgis at osgeo.org
Sun Nov 15 17:29:33 EST 2009
Author: rduivenvoorde
Date: 2009-11-15 17:29:32 -0500 (Sun, 15 Nov 2009)
New Revision: 12133
trunk/qgis/python/plugins/mapserver_export/__init__.py
trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
trunk/qgis/python/plugins/mapserver_export/ms_export.py
trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui
Using QSettings to remember mapserverexport settings
Modified: trunk/qgis/python/plugins/mapserver_export/__init__.py
--- trunk/qgis/python/plugins/mapserver_export/__init__.py 2009-11-15 21:38:32 UTC (rev 12132)
+++ trunk/qgis/python/plugins/mapserver_export/__init__.py 2009-11-15 22:29:32 UTC (rev 12133)
@@ -24,7 +24,7 @@
def description():
return "Export a saved QGIS project file to a MapServer map file"
def version():
- return "Version 0.4.1"
+ return "Version 0.4.2"
def qgisMinimumVersion():
return "1.0"
def authorName():
Modified: trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
--- trunk/qgis/python/plugins/mapserver_export/mapserverexport.py 2009-11-15 21:38:32 UTC (rev 12132)
+++ trunk/qgis/python/plugins/mapserver_export/mapserverexport.py 2009-11-15 22:29:32 UTC (rev 12133)
@@ -80,68 +80,8 @@
# create and show the MapServerExport dialog
self.dlg = MapServerExportDialog()
- # TODO: should come from settings
- self.dlg.ui.txtMapFilePath.setText('/usr/lib/cgi-bin/kaas.map')
- # project defaults to current instance
- project = QgsProject.instance()
- # question: save project on loading export dialog?
- if project.isDirty():
- shouldSave = QMessageBox.question(self.dlg,
- "Save?",
- "Save project to \"" + project.fileName() + "\" before exporting? Only the last saved version of your project will be exported.",
- QMessageBox.Yes,
- QMessageBox.No,
- QMessageBox.Cancel
- if shouldSave == QMessageBox.Yes:
- if project.fileName().size() == 0:
- # project has not yet been saved:
- saveAsFileName = QFileDialog.getSaveFileName(self.dlg,
- "Save QGIS Project file as...",
- "QGIS Project Files (*.qgs)",
- "Filter list for selecting files from a dialog box")
- # Check that a file was selected
- if saveAsFileName.size() == 0:
- QMessageBox.warning(self.dlg, "Not saved!", "QGis project file not saved because no file name was given.")
- # fall back to using current project if available
- self.dlg.ui.txtQgisFilePath.setText(project.fileName())
- else:
- project.setFileName(saveAsFileName)
- project.write()
- else:
- project.write()
- elif shouldSave == QMessageBox.Cancel:
- return # do not show the export dialog
- # set title, or set default one if none available
- title = project.title()
- if title == "":
- title = "QGisGeneratedMapfile"
- self.dlg.ui.txtMapName.setText(project.title())
- if self.dlg.ui.txtMapFilePath.text().size() == 0:
- btnOk = self.dlg.ui.buttonBox.button(QDialogButtonBox.Ok)
- btnOk.setEnabled(False)
- # TODO: fetch unit used from QSettings
- # TODO: fetch width/height guess from QSettings:
- # fetch the last used values from settings and intialize the
- # dialog with them
- #settings = QSettings("MicroResources", "ZoomToPoint")
- #xValue = settings.value("coordinate/x")
- #self.dlg.ui.xCoord.setText(str(xValue.toString()))
- #yValue = settings.value("coordinate/y")
- #self.dlg.ui.yCoord.setText(str(yValue.toString()))
- #scale = settings.value("zoom/scale", QVariant(4))
- #self.dlg.ui.spinBoxScale.setValue(scale.toInt()[0])
- QObject.connect(self.dlg.ui.btnChooseFile, SIGNAL("clicked()"), self.setSaveFile)
+ # attach events to inputs and buttons
+ QObject.connect(self.dlg.ui.btnChooseFile, SIGNAL("clicked()"), self.setMapFile)
QObject.connect(self.dlg.ui.txtMapFilePath, SIGNAL("textChanged(QString)"), self.mapfileChanged)
QObject.connect(self.dlg.ui.btnChooseProjectFile, SIGNAL("clicked()"), self.setProjectFile)
QObject.connect(self.dlg.ui.chkExpLayersOnly, SIGNAL("clicked(bool)"), self.toggleLayersOnly)
@@ -150,40 +90,51 @@
QObject.connect(self.dlg.ui.btnChooseHeaderFile, SIGNAL("clicked()"), self.setHeaderFile)
QObject.connect(self.dlg.ui.btnChooseTemplateFile, SIGNAL("clicked()"), self.setTemplateFile)
QObject.connect(self.dlg.ui.buttonBox, SIGNAL("accepted()"), self.ok_clicked)
+ # qgs-project
+ # defaults to current instance
+ project = QgsProject.instance()
+ self.dlg.ui.txtQgisFilePath.setText(project.fileName())
+ # get some settings from former successfull exports
+ # defaults are defined in ms_export.py and set in mapserverexportdialog.py
+ settings = QSettings()
+ # map-file name and force mapfileChanged to enable/disable ok button
+ self.dlg.ui.txtMapFilePath.setText(settings.value("/MapserverExport/mapfileName", QVariant("")).toString ())
+ self.mapfileChanged(self.dlg.ui.txtMapFilePath.text())
+ # map width and height
+ if settings.contains("/MapserverExport/mapWidth"):
+ self.dlg.ui.txtMapWidth.setText(settings.value("/MapserverExport/mapWidth").toString ())
+ if settings.contains("/MapserverExport/mapHeight"):
+ self.dlg.ui.txtMapHeight.setText(settings.value("/MapserverExport/mapHeight").toString ())
+ # MapServer IMAGETYPE's [gif|png|jpeg|wbmp|gtiff|swf|userdefined]
+ self.dlg.ui.cmbMapImageType.addItems(QStringList(["png","gif","jpeg","wbmp","gtiff","swf","userdefined"]))
+ if settings.contains("/MapserverExport/imageType"):
+ idx = self.dlg.ui.cmbMapImageType.findText(settings.value("/MapserverExport/imageType").toString ())
+ self.dlg.ui.cmbMapImageType.setCurrentIndex(idx)
+ # MapServer URL (default value already set by dialog defaults)
+ if settings.contains("/MapserverExport/mapserverUrl"):
+ self.dlg.ui.txtMapServerUrl.setText(settings.value("/MapserverExport/mapserverUrl").toString())
+ # set title or default to one if none available
+ title = project.title()
+ if title == "":
+ title = "QGIS-MAP"
+ self.dlg.ui.txtMapName.setText(title)
+ # TODO: fetch units used from current project
+ # QGIS: Meters, Feet, Degrees, UnknownUnit since 1.4 also: DecimalDegrees, DegreesMinutesSeconds, DegreesDecimalMinutes
+ # Mapserver: UNITS [feet|inches|kilometers|meters|miles|dd]
self.dlg.show()
def ok_clicked(self):
- # Check if map file name is provided
- "Please choose to save map file as...",
- "Map files (*.map)",
- QMessageBox.warning(self.dlg, "Not saved!", "Map file not saved because no file name was given")
- return
- else:
- self.dlg.ui.txtMapFilePath.setText(saveAsFileName)
- self.saveMapFile()
- # Check if map file exists and we should overwrite it
- elif QFile(self.dlg.ui.txtMapFilePath.text()).exists():
- shouldOverwrite = QMessageBox.question(self.dlg,
- "Overwrite?",
- "Map file \"" + self.dlg.ui.txtMapFilePath.text() + "\" already exists. \nShould we overwrite it?",
- QMessageBox.Yes,
- if shouldOverwrite == QMessageBox.Yes:
- elif shouldOverwrite == QMessageBox.Cancel:
- return
- else:
+ if self.checkMapFile():
self.saveMapFile()
+ else:
+ print "Failed for Map file check, try again..."
+ pass
def toggleUseCurrentProject(self, boolUseCurrent):
self.dlg.ui.txtQgisFilePath.setEnabled(not boolUseCurrent)
@@ -248,7 +199,18 @@
except Exception, err:
QMessageBox.information(self.dlg, "MapServer Export Error", str(err))
return
+ # ok succesfull: write some setting for a next session
+ # mapfile name
+ settings.setValue("/MapserverExport/mapfileName", QVariant(self.dlg.ui.txtMapFilePath.text()))
+ # map width and heigth
+ settings.setValue("/MapserverExport/mapWidth", QVariant(self.dlg.ui.txtMapWidth.text()))
+ settings.setValue("/MapserverExport/mapHeight", QVariant(self.dlg.ui.txtMapHeight.text()))
+ # mapserver url
+ settings.setValue("/MapserverExport/mapserverUrl", QVariant(self.dlg.ui.txtMapServerUrl.text()))
+ # map ImageType
+ settings.setValue("/MapserverExport/imageType", QVariant(self.dlg.ui.cmbMapImageType.currentText()))
+ # show results
QMessageBox.information(self.dlg, "MapServer Export Results", result)
def mapfileChanged(self, text):
@@ -259,11 +221,30 @@
else:
- def setSaveFile(self):
- mapFile = QFileDialog.getSaveFileName(self.dlg, "Name for the map file", \
- ".", "MapServer map files (*.map);;All files (*.*)","Filter list for selecting files from a dialog box")
- self.dlg.ui.txtMapFilePath.setText(mapFile)
+ def checkMapFile(self):
+ # Check if map file name is provided
+ mapFileName = self.dlg.ui.txtMapFilePath.text()
+ if mapFileName.size() == 0:
+ QMessageBox.warning(self.dlg, "Not saved!", "Map file not saved because no file name was given")
+ return False
+ # Check/fix for .map extension (mapserver fails to read otherwise)
+ if not mapFileName.trimmed().endsWith('.map'):
+ mapFileName += '.map'
+ self.dlg.ui.txtMapFilePath.setText(mapFileName)
+ # Check if map file exists and we should overwrite it
+ if QFile(mapFileName).exists():
+ if QMessageBox.Cancel == QMessageBox.question(self.dlg, "Overwrite?",
+ "Map file \"" + mapFileName + "\" already exists. \nShould we overwrite it?",
+ QMessageBox.Yes, QMessageBox.Cancel):
+ return False
+ # mapfile ok, extension ok, ok to overwrite
+ return True
+ def setMapFile(self):
+ mapFileName = QFileDialog.getSaveFileName(self.dlg, "Name for the map file", \
+ self.dlg.ui.txtMapFilePath.text(), "MapServer map files (*.map);;All files (*.*)","Filter list for selecting files from a dialog box")
def setProjectFile(self):
qgisProjectFile = QFileDialog.getOpenFileName(self.dlg, "Choose a QGIS Project file", \
".", "QGIS Project Files (*.qgs);;All files (*.*)", "Filter list for selecting files from a dialog box")
Modified: trunk/qgis/python/plugins/mapserver_export/ms_export.py
--- trunk/qgis/python/plugins/mapserver_export/ms_export.py 2009-11-15 21:38:32 UTC (rev 12132)
+++ trunk/qgis/python/plugins/mapserver_export/ms_export.py 2009-11-15 22:29:32 UTC (rev 12133)
@@ -235,7 +235,7 @@
logmsg += "Map file completed for " + self.projectFileName + "\n"
logmsg += "Map file saved as " + self.mapFile + "\n"
if self.exportLayersOnly:
- logmsg += "\n> We only saved the LAYER portion of the map file. Merge this into an excisting mapfile to see it working\n"
+ logmsg += "\n> We only saved the LAYER portion of the map file. \nMerge this into an excisting map file to see it working\n"
else:
logmsg += "\n> If this mapfile is accessible by your mapserver, you\nshould be able to see the capabilities by firing this url:\n" + self.mapServerUrl + "?MAP="+self.mapFile+"&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities\n"
logmsg += "\n> if this mapfile is accessible by your mapserver, you\nshould be able to see a map by firing this url:\n" + self.mapServerUrl + "?MAP="+self.mapFile+"&SERVICE=WMS&LAYERS=ALL&MODE=MAP\n"
@@ -243,7 +243,6 @@
# Write the general parts of the map section
def writeMapSection(self):
- print "writeMapSection, projNaam = %s en type = %s" % (self.projectFileName, type(self.projectFileName))
self.outFile.write("# Map file created from QGIS project file " + str(self.projectFileName).encode('utf-8') + "\n")
self.outFile.write("# Edit this file to customize for your map interface\n")
self.outFile.write("# (Created with PyQgis MapServer Export plugin)\n")
@@ -299,7 +298,6 @@
self.outFile.write(" MIMETYPE 'image/" + lower(self.imageType) + "'\n")
if self.imageType.lower() != "gif":
self.outFile.write(" IMAGEMODE RGBA\n")
- #self.outFile.write(" #IMAGEMODE PC256\n")
self.outFile.write(" EXTENSION '" + lower(self.imageType) + "'\n")
self.outFile.write(" END\n")
Modified: trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui
--- trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui 2009-11-15 21:38:32 UTC (rev 12132)
+++ trunk/qgis/python/plugins/mapserver_export/qgsmapserverexportbase.ui 2009-11-15 22:29:32 UTC (rev 12133)
@@ -131,43 +131,7 @@
</widget>
</item>
<item row="0" column="3">
- <widget class="QComboBox" name="cmbMapImageType">
- <item>
- <property name="text">
- <string>png</string>
- </property>
- </item>
- <item>
- <string>gif</string>
- </property>
- </item>
- <item>
- <string>gtiff</string>
- </property>
- </item>
- <item>
- <string>jpeg</string>
- </property>
- </item>
- <item>
- <string>swf</string>
- </property>
- </item>
- <item>
- <string>userdefined</string>
- </property>
- </item>
- <item>
- <string>wbmp</string>
- </property>
- </item>
- </widget>
+ <widget class="QComboBox" name="cmbMapImageType"/>
</item>
<item row="0" column="4">
<widget class="QLabel" name="label">
