[QGIS Commit] r12168 - trunk/qgis/doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Nov 17 23:09:51 EST 2009
Author: kyngchaos
Date: 2009-11-17 23:09:49 -0500 (Tue, 17 Nov 2009)
New Revision: 12168
   trunk/qgis/doc/INSTALL.t2t
more OSX install updates
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2009-11-17 23:30:16 UTC (rev 12167)
+++ trunk/qgis/doc/INSTALL.t2t	2009-11-18 04:09:49 UTC (rev 12168)
@@ -415,30 +415,10 @@
 Once downloaded open the dmg and run the installer. Note you need admin
 privileges to install.
-After installing you need to make two small changes:
-First edit ``/Library/Frameworks/QtCore.framework/Headers/qconfig.h`` and
-change
-/!\ Note: this isn't needed since version 4.2.3
-``QT_EDITION_Unknown`` to ``QT_EDITION_OPENSOURCE``
-Second change the default mkspec symlink so that it points to macx-g++:
-cd /usr/local/Qt4.3/mkspecs/
-sudo rm default
-sudo ln -sf macx-g++ default
-/!\ Note: this doesn't seem to be needed since version 4.4.
 == Install development frameworks for QGIS dependencies ==
-Download William Kyngesburye's excellent all in one framework that includes
-proj, gdal, sqlite3, etc.
+Download William Kyngesburye's excellent all in GDAL Complete framework that includes proj, gdal, sqlite3, etc.
 http://www.kyngchaos.com/wiki/software:frameworks
@@ -458,6 +438,7 @@
 http://www.kyngchaos.com/wiki/software:grass
 === Additional Dependencies : General compatibility note ===
 There are some additional dependencies that, at the time of writing, are not
@@ -465,7 +446,7 @@
 If you are wanting to build Qgis as a 64-bit application, you will need to
 provide the appropriate build commands to produce 64-bit support in dependencies.
 Likewise, for 32-bit support on Snow Leopard, you will need to override the
-default system architecture, which is 64-bit according to instructions for
+default system architecture, which is 64-bit, according to instructions for
 individual dependency packages.
 === Additional Dependencies : GSL ===
@@ -477,7 +458,7 @@
 Then extract it and build it to a prefix of /usr/local.  Double-click the source
-tarball to unpack it, then cd to the source folder and:
+tarball to unpack it, then, in Terminal.app, cd to the source folder and:
 ./configure
@@ -485,20 +466,14 @@
 sudo make install
-__Snow Leopard note:__ For explicit 32-bit support in gsl, substitute the standard
-configure line with:
+__Snow Leopard note:__ Snow Leopard compiles 64bit by default.
+For explicit 32-bit support in gsl, substitute the standard configure line with:
-./configure --build=i386
+./configure CFLAGS="-Os -arch i386"
-And for 64-bit gsl:
-./configure --build=x86_64
 === Additional Dependencies : Expat ===
 __Snow Leopard note:__ Snow Leopard includes a usable expat, so this step is
@@ -510,7 +485,7 @@
 http://sourceforge.net/project/showfiles.php?group_id=10127
-Double-click the source tarball to unpack, then cd to the source folder and:
+Double-click the source tarball to unpack, then, in Terminal.app, cd to the source folder and:
 ./configure
@@ -518,13 +493,19 @@
 sudo make install
+__Leopard note:__ To compile for 64bit, substitute the standard configure line with:
+./configure CFLAGS="-Os -arch x86_64"
 === Additional Dependencies : SIP ===
 __Leopard and Snow Leopard note:__ Leopard and Snow Leopard include a usable Python
 2.5 or 2.6, respectively.  You can install Python from python.org if preferred.
-Make sure you have the latest Python 2.5 from
+Make sure you have at least the latest Python 2.5 from
 http://www.python.org/download/mac/
@@ -536,7 +517,7 @@
 http://www.riverbankcomputing.com/software/sip/download
-Double-click the source tarball to unpack it, then cd to the source folder
+Double-click the source tarball to unpack it, then, in Terminal.app, cd to the source folder
 and (this installs by default into the Python framework):
@@ -552,42 +533,36 @@
 basic configure above:
-python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip
+python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin \
+-e /usr/local/include -v /usr/local/share/sip
 __Snow Leopard notes__
-If building on Snow Leopard, you need to use one of the following configure lines
-based on your installed version of Qt. If you are using 32-bit Qt (Qt Carbon):
+Similar to Leopard, you should install outside the system Python path.  Also, you need to specify the architecture you want (requires at least SIP 4.9). If you are using 32-bit Qt (Qt Carbon):
-python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip --arch i386
+python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin \
+-e /usr/local/include -v /usr/local/share/sip --arch=i386
 For 64-bit Qt (Qt Cocoa), use this configure line:
-python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip --arch x86_64
+-e /usr/local/include -v /usr/local/share/sip --arch=x86_64
 === Additional Dependencies : PyQt ===
-If you encounter problems compiling PyQt using the instructions
-below you can also try adding python from your frameworks dir
-explicitly to your path e.g.
-export PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:$PATH
 Retrieve the python bindings toolkit for Qt from
 http://www.riverbankcomputing.com/software/pyqt/download
@@ -600,7 +575,9 @@
 __Leopard notes__
-If building on Leopard, using Leopard's bundled Python, PyQt wants to install in the system path -- this is not a good idea.  Use this configure command instead of the basic configure above:
+If building on Leopard, using Leopard's bundled Python, PyQt wants to install
+in the system path -- this is not a good idea.  Use this configure command
+instead of the basic configure above:
@@ -612,7 +589,9 @@
-If building on Snow Leopard, you need to use one of the following configure lines based on your installed version of Qt. If you are using 32-bit Qt (Qt Carbon):
+Also, you need to specify the architecture you want (requires at least PyQt 4.6).
+If you are using 32-bit Qt (Qt Carbon):
 python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
@@ -627,7 +606,7 @@
 === Additional Dependencies : Bison ===
-__Leopard and Snow Leopard note:__ Leopard and Snow Leopard includes Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
+__Leopard and Snow Leopard note:__ Leopard and Snow Leopard include Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
 The version of bison available by default on Mac OS X 10.4 and older is too old so you need to
 get a more recent one on your system. Download at least version 2.3 from:
@@ -666,9 +645,9 @@
 == Install subversion for OSX ==
-__Leopard and Snow Leopard note:__ Leopard and Snow Leopard include SVN, so this step can be skipped on these Operating Systems.
+__Leopard and Snow Leopard note:__ Leopard and Snow Leopard include SVN, so this step can be skipped on Leopard and Snow Leopard.
-The [http://sourceforge.net/projects/macsvn/ MacSVN] project has a downloadable
+The [http://sourceforge.net/projects/macsvn/MacSVN] project has a downloadable
 build of svn. If you are a GUI inclined person you may want to grab their gui
 client too. Get the command line client here:
@@ -711,7 +690,7 @@
 == Check out QGIS from SVN ==
 Now we are going to check out the sources for QGIS. First we will create a
-directory for working in:
+directory for working in (or some folder of your choice):
 mkdir -p ~/dev/cpp cd ~/dev/cpp
@@ -756,40 +735,27 @@
 === Configure the Cmake build ===
 CMake supports out of source build so we will create a 'build' dir for the
-build process. By convention I build my software into a dir called 'apps' in
-my home directory. If you have the correct permissions you may want to build
+build process. OS X uses ${HOME}/Applications as a standard user app folder (it gives it the system app folder icon).
+If you have the correct permissions you may want to build
 straight into your /Applications folder. The instructions below assume you are
-building into a pre-existing ${HOME}/apps directory ...
+building into a pre-existing ${HOME}/Applications directory ...
 cd qgis
 mkdir build
 cd build
-cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ -D CMAKE_BUILD_TYPE=Release ..
+cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release ..
-__Leopard note:__ To find the custom install of SIP on Leopard, add ""-
-D SIP_BINARY_PATH=/usr/local/bin/sip"" to the cmake command above,
-before the "".."" at the end, ie:
-cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ \
-	  -D CMAKE_BUILD_TYPE=Release \
-	  -D SIP_BINARY_PATH=/usr/local/bin/sip \
 To use the application build of GRASS on OSX, you can optionally use the
 following cmake invocation (minimum GRASS 6.3 required, substitute the GRASS
 version as required):
-cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
-      -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/
-      include \
-      -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
+cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
+-D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include \
+-D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
 Or, to use a Unix-style build of GRASS, use the following cmake invocation
@@ -797,51 +763,54 @@
 path and version as required):
-  -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
-  -D GRASS_PREFIX=/user/local/grass-6.4.0 \
+-D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
+-D GRASS_PREFIX=/user/local/grass-6.4.0 \
+__Leopard note:__ To find the custom install of SIP on Leopard, add
+'-D SIP_BINARY_PATH=/usr/local/bin/sip' to the cmake commands above,
+before the '..' at the end, ie:
+-D SIP_BINARY_PATH=/usr/local/bin/sip \
 __Snow Leopard note:__ To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed.
-For 32-bit Qt (Carbon) with GRASS-6.4:
+For 32-bit Qt (Carbon) with GRASS-6.4, add '-D CMAKE_CXX_FLAGS="-arch i386" -D CMAKE_OSX_ARCHITECTURES=i386':
-	  -D CMAKE_C_FLAGS=-m32 \
-	  -D CMAKE_CXX_FLAGS=-m32
-	  -D CMAKE_OSX_ARCHITECTURES=i386
-	  -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include\
+-D CMAKE_CXX_FLAGS="-arch i386" -D CMAKE_OSX_ARCHITECTURES=i386 \
 For 64-bit Qt (Cocoa) with GRASS-6.4:
-	  -D CMAKE_C_FLAGS=-m64 \
-	  -D CMAKE_CXX_FLAGS=-m64
-	  -D CMAKE_OSX_ARCHITECTURES=x86_64
+-D CMAKE_CXX_FLAGS="-arch x86_64" -D CMAKE_OSX_ARCHITECTURES=x86_64 \
 === Configure the Xcode build ===
 In the mac/xcode folder in the source, duplicate the 'qgis_user-template.xcconfig'
 file and name it 'qgis_user.xcconfig'. A default build will use the KyngChaos
-frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 and extra dependencies
+frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 (for Tiger)
+or the system Python (for Leopard and Snow Leopard) and extra dependencies
 as described above, and compile for the current OSX architecture and version, so no
-extra configuration is necessary. If building on Leopard or newer, you may want to
-use the system Python, which requires editing qgis_user.xcconfig.
+extra configuration is necessary.
 See the mac/xcode/readme.rtf for details, if you need to customize the build.
 The default build will also bundle the Qt frameworks, Postgres library, and
@@ -876,21 +845,12 @@
 there have been compilation problems reported, so it is suggested that you disable
 ccache support.
 Alternatively, from within the mac/xcode directory, build with the command:
 xcodebuild
-__Snow Leopard note:__ You can also build Qgis using the new llvm compilers supplied
-with Xcode 3.2.x. To do this, you first need to export the proper compiler settings:
-export CC=/Developer/usr/bin/llvm-gcc
-export CXX=/Developer/usr/bin/llvm-g++
-xcodebuild
 The Qgis application will be found in the 'build/$SYSTEM/Release' folder in the xcode folder.
 Copy this to whereever you like.
More information about the QGIS-commit mailing list
