[QGIS Commit] r12178 - in trunk/qgis/src: app core core/symbology
core/symbology-ng gui/symbology-ng plugins/labeling
svn_qgis at osgeo.org
Wed Nov 18 15:58:11 EST 2009
Author: jef
Date: 2009-11-18 15:58:09 -0500 (Wed, 18 Nov 2009)
New Revision: 12178
trunk/qgis/src/app/qgsmeasuredialog.cpp
trunk/qgis/src/core/qgsmaplayer.h
trunk/qgis/src/core/qgsmaprenderer.cpp
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/core/qgsrendercontext.cpp
trunk/qgis/src/core/qgsrendercontext.h
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgsstylev2.cpp
trunk/qgis/src/core/symbology/qgssymbol.cpp
trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgspenstylecombobox.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp
trunk/qgis/src/plugins/labeling/pallabeling.cpp
automatic indentation update (r12139-r12177)
Modified: trunk/qgis/src/app/qgsmeasuredialog.cpp
--- trunk/qgis/src/app/qgsmeasuredialog.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/app/qgsmeasuredialog.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -35,7 +35,7 @@
: QDialog( tool->canvas()->topLevelWidget(), f ), mTool( tool )
setupUi( this );
QPushButton *nb = new QPushButton( tr( "&New" ) );
buttonBox->addButton( nb, QDialogButtonBox::ActionRole );
connect( nb, SIGNAL( clicked() ), this, SLOT( restart() ) );
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/qgsmaplayer.h 2009-11-18 20:58:09 UTC (rev 12178)
@@ -78,10 +78,10 @@
QString const & name() const;
- /** This is the method that does the actual work of
+ /** This is the method that does the actual work of
* drawing the layer onto a paint device.
- * @param QgsRenderContext - describes the extents,
- * resolution etc. that should be used when rendering the
+ * @param QgsRenderContext - describes the extents,
+ * resolution etc. that should be used when rendering the
* layer.
virtual bool draw( QgsRenderContext& rendererContext );
@@ -291,9 +291,9 @@
/** Get the QImage used for caching render operations
* @note This method was added in QGIS 1.4 **/
QImage * cacheImage() { return mpCacheImage; }
- /** Set the QImage used for caching render operations
+ /** Set the QImage used for caching render operations
- void setCacheImage( QImage * thepImage );
+ void setCacheImage( QImage * thepImage );
public slots:
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -212,7 +212,7 @@
void QgsMapRenderer::render( QPainter* painter )
- //flag to see if the render context has changed
+ //flag to see if the render context has changed
//since the last time we rendered. If it hasnt changed we can
//take some shortcuts with rendering
bool mySameAsLastFlag = true;
@@ -285,20 +285,20 @@
mySameAsLastFlag = false;
- mRenderContext.setLabelingEngine(mLabelingEngine);
+ mRenderContext.setLabelingEngine( mLabelingEngine );
if ( mLabelingEngine )
mLabelingEngine->init();
- // know we know if this render is just a repeat of the last time, we
+ // know we know if this render is just a repeat of the last time, we
// can clear caches if it has changed
if ( !mySameAsLastFlag )
- //clear the cache pixmap if we changed resolution / extent
- QSettings mySettings;
- if ( mySettings.value ( "/qgis/enable_render_caching", false ).toBool() )
- QgsMapLayerRegistry::instance()->clearAllLayerCaches();
+ //clear the cache pixmap if we changed resolution / extent
+ QSettings mySettings;
+ if ( mySettings.value( "/qgis/enable_render_caching", false ).toBool() )
+ QgsMapLayerRegistry::instance()->clearAllLayerCaches();
bool placeOverlays = false;
@@ -322,7 +322,7 @@
break;
- // Store the painter in case we need to swap it out for the
+ // Store the painter in case we need to swap it out for the
// cache painter
QPainter * mypContextPainter = mRenderContext.painter();
@@ -422,17 +422,17 @@
ml->setCacheImage( 0 );
if ( ! split )//render caching does not yet cater for split extents
- if ( !mySameAsLastFlag || ml->cacheImage() == 0 )
+ if ( !mySameAsLastFlag || ml->cacheImage() == 0 )
QgsDebugMsg( "\n\n\nCaching enabled but layer redraw forced by extent change or empty cache\n\n\n" );
- QImage * mypImage = new QImage( mRenderContext.painter()->device()->width(),
- mRenderContext.painter()->device()->height(), QImage::Format_ARGB32 );
+ QImage * mypImage = new QImage( mRenderContext.painter()->device()->width(),
+ mRenderContext.painter()->device()->height(), QImage::Format_ARGB32 );
mypImage->fill( 0 );
ml->setCacheImage( mypImage ); //no need to delete the old one, maplayer does it for you
QPainter * mypPainter = new QPainter( ml->cacheImage() );
@@ -440,13 +440,13 @@
mypPainter->setRenderHint( QPainter::Antialiasing );
- mRenderContext.setPainter( mypPainter );
+ mRenderContext.setPainter( mypPainter );
else if ( mySameAsLastFlag )
//draw from cached image
QgsDebugMsg( "\n\n\nCaching enabled --- drawing layer from cached image\n\n\n" );
- mypContextPainter->drawImage( 0,0, *(ml->cacheImage()) );
+ mypContextPainter->drawImage( 0, 0, *( ml->cacheImage() ) );
disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
//short circuit as there is nothing else to do...
continue;
@@ -472,7 +472,7 @@
else
- QgsDebugMsg( "\n\n\nLayer rendered without issues\n\n\n" );
+ QgsDebugMsg( "\n\n\nLayer rendered without issues\n\n\n" );
if ( split )
@@ -489,16 +489,16 @@
mRenderContext.painter()->restore();
if ( !split )
// composite the cached image into our view and then clean up from caching
// by reinstating the painter as it was swapped out for caching renders
delete mRenderContext.painter();
- mRenderContext.setPainter( mypContextPainter );
+ mRenderContext.setPainter( mypContextPainter );
//draw from cached image that we created further up
@@ -506,7 +506,7 @@
else // layer not visible due to scale
QgsDebugMsg( "Layer not rendered because it is not within the defined "
- "visibility scale range" );
+ "visibility scale range" );
} // while (li.hasPrevious())
@@ -1055,9 +1055,9 @@
return true;
-void QgsMapRenderer::setLabelingEngine(QgsLabelingEngineInterface* iface)
+void QgsMapRenderer::setLabelingEngine( QgsLabelingEngineInterface* iface )
- if (mLabelingEngine)
+ if ( mLabelingEngine )
delete mLabelingEngine;
mLabelingEngine = iface;
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2009-11-18 20:58:09 UTC (rev 12178)
@@ -42,19 +42,19 @@
class QgsLabelingEngineInterface
-public:
- virtual ~QgsLabelingEngineInterface() {}
+ public:
+ virtual ~QgsLabelingEngineInterface() {}
- //! called when we're going to start with rendering
- virtual void init() = 0;
- //! called when starting rendering of a layer
- virtual int prepareLayer(QgsVectorLayer* layer, int& attrIndex) = 0;
- //! called for every feature
- virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat ) = 0;
- //! called when the map is drawn and labels should be placed
- virtual void drawLabeling( QgsRenderContext& context ) = 0;
- //! called when we're done with rendering
- virtual void exit() = 0;
+ //! called when we're going to start with rendering
+ virtual void init() = 0;
+ //! called when starting rendering of a layer
+ virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex ) = 0;
+ //! called for every feature
+ virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat ) = 0;
+ //! called when the map is drawn and labels should be placed
+ virtual void drawLabeling( QgsRenderContext& context ) = 0;
+ //! called when we're done with rendering
+ virtual void exit() = 0;
@@ -178,7 +178,7 @@
//! Set labeling engine. Previous engine (if any) is deleted.
//! Takes ownership of the engine.
//! Added in QGIS v1.4
- void setLabelingEngine(QgsLabelingEngineInterface* iface);
+ void setLabelingEngine( QgsLabelingEngineInterface* iface );
signals:
@@ -234,7 +234,7 @@
//! current extent to be drawn
QgsRectangle mExtent;
- /** Last extent to we drew so we know if we can
+ /** Last extent to we drew so we know if we can
used layer render caching or not. Note there are no
accessors for this as it is intended to internal
use only.
Modified: trunk/qgis/src/core/qgsrendercontext.cpp
--- trunk/qgis/src/core/qgsrendercontext.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/qgsrendercontext.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -19,7 +19,7 @@
#include "qgsrendercontext.h"
QgsRenderContext::QgsRenderContext()
- : mPainter( 0 ),
+ : mPainter( 0 ),
mCoordTransform( 0 ),
mDrawEditingInformation( false ),
mForceVectorOutput( true ),
Modified: trunk/qgis/src/core/qgsrendercontext.h
--- trunk/qgis/src/core/qgsrendercontext.h 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/qgsrendercontext.h 2009-11-18 20:58:09 UTC (rev 12178)
@@ -76,7 +76,7 @@
void setRendererScale( double scale ) {mRendererScale = scale;}
void setPainter( QPainter* p ) {mPainter = p;}
- void setLabelingEngine(QgsLabelingEngineInterface* iface) { mLabelingEngine = iface; }
+ void setLabelingEngine( QgsLabelingEngineInterface* iface ) { mLabelingEngine = iface; }
private:
Modified: trunk/qgis/src/core/symbology/qgssymbol.cpp
--- trunk/qgis/src/core/symbology/qgssymbol.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/symbology/qgssymbol.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -218,9 +218,9 @@
QgsDebugMsg( "Name: " + name );
//see if we can resolve the problem...
QStringList svgPaths = QgsApplication::svgPaths();
- for( int i=0; i<svgPaths.size(); i++)
+ for ( int i = 0; i < svgPaths.size(); i++ )
QgsDebugMsg( "SvgPath: " + svgPaths[i] );
QFileInfo myInfo( myTempName );
@@ -515,14 +515,14 @@
- for(int i=0; i<svgPaths.size(); i++)
QString dir = QFileInfo( svgPaths[i] ).canonicalFilePath();
if ( !dir.isEmpty() && name.startsWith( dir ) )
name = name.mid( dir.size() );
- break;
+ break;
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -6,14 +6,14 @@
#include <QPainter>
-QgsSimpleFillSymbolLayerV2::QgsSimpleFillSymbolLayerV2(QColor color, Qt::BrushStyle style, QColor borderColor, Qt::PenStyle borderStyle, double borderWidth)
- : mBrushStyle(style), mBorderColor(borderColor), mBorderStyle(borderStyle), mBorderWidth(borderWidth)
+QgsSimpleFillSymbolLayerV2::QgsSimpleFillSymbolLayerV2( QColor color, Qt::BrushStyle style, QColor borderColor, Qt::PenStyle borderStyle, double borderWidth )
+ : mBrushStyle( style ), mBorderColor( borderColor ), mBorderStyle( borderStyle ), mBorderWidth( borderWidth )
mColor = color;
-QgsSymbolLayerV2* QgsSimpleFillSymbolLayerV2::create(const QgsStringMap& props)
+QgsSymbolLayerV2* QgsSimpleFillSymbolLayerV2::create( const QgsStringMap& props )
QColor color = DEFAULT_SIMPLEFILL_COLOR;
Qt::BrushStyle style = DEFAULT_SIMPLEFILL_STYLE;
@@ -21,18 +21,18 @@
Qt::PenStyle borderStyle = DEFAULT_SIMPLEFILL_BORDERSTYLE;
double borderWidth = DEFAULT_SIMPLEFILL_BORDERWIDTH;
- if (props.contains("color"))
- color = QgsSymbolLayerV2Utils::decodeColor(props["color"]);
- if (props.contains("style"))
- style = QgsSymbolLayerV2Utils::decodeBrushStyle(props["style"]);
- if (props.contains("color_border"))
- borderColor = QgsSymbolLayerV2Utils::decodeColor(props["color_border"]);
- if (props.contains("style_border"))
- borderStyle = QgsSymbolLayerV2Utils::decodePenStyle(props["style_border"]);
- if (props.contains("width_border"))
+ if ( props.contains( "color" ) )
+ color = QgsSymbolLayerV2Utils::decodeColor( props["color"] );
+ if ( props.contains( "style" ) )
+ style = QgsSymbolLayerV2Utils::decodeBrushStyle( props["style"] );
+ if ( props.contains( "color_border" ) )
+ borderColor = QgsSymbolLayerV2Utils::decodeColor( props["color_border"] );
+ if ( props.contains( "style_border" ) )
+ borderStyle = QgsSymbolLayerV2Utils::decodePenStyle( props["style_border"] );
+ if ( props.contains( "width_border" ) )
borderWidth = props["width_border"].toDouble();
- return new QgsSimpleFillSymbolLayerV2(color, style, borderColor, borderStyle, borderWidth);
+ return new QgsSimpleFillSymbolLayerV2( color, style, borderColor, borderStyle, borderWidth );
@@ -41,54 +41,54 @@
return "SimpleFill";
-void QgsSimpleFillSymbolLayerV2::startRender(QgsRenderContext& context)
+void QgsSimpleFillSymbolLayerV2::startRender( QgsRenderContext& context )
- mBrush = QBrush(mColor, mBrushStyle);
- mPen = QPen(mBorderColor);
- mPen.setStyle(mBorderStyle);
- mPen.setWidthF(mBorderWidth);
+ mBrush = QBrush( mColor, mBrushStyle );
+ mPen = QPen( mBorderColor );
+ mPen.setStyle( mBorderStyle );
+ mPen.setWidthF( mBorderWidth );
-void QgsSimpleFillSymbolLayerV2::stopRender(QgsRenderContext& context)
+void QgsSimpleFillSymbolLayerV2::stopRender( QgsRenderContext& context )
-void QgsSimpleFillSymbolLayerV2::renderPolygon(const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context)
+void QgsSimpleFillSymbolLayerV2::renderPolygon( const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context )
QPainter* p = context.painter();
- p->setBrush(mBrush);
- p->setPen(mPen);
- if (rings == NULL)
+ p->setBrush( mBrush );
+ p->setPen( mPen );
+ if ( rings == NULL )
// simple polygon without holes
- p->drawPolygon(points);
+ p->drawPolygon( points );
else
// polygon with holes must be drawn using painter path
QPainterPath path;
- path.addPolygon(points);
+ path.addPolygon( points );
QList<QPolygonF>::iterator it;
- for (it = rings->begin(); it != rings->end(); ++it)
- path.addPolygon(*it);
- p->drawPath(path);
+ for ( it = rings->begin(); it != rings->end(); ++it )
+ path.addPolygon( *it );
+ p->drawPath( path );
QgsStringMap QgsSimpleFillSymbolLayerV2::properties() const
QgsStringMap map;
- map["color"] = QgsSymbolLayerV2Utils::encodeColor(mColor);
- map["style"] = QgsSymbolLayerV2Utils::encodeBrushStyle(mBrushStyle);
- map["color_border"] = QgsSymbolLayerV2Utils::encodeColor(mBorderColor);
- map["style_border"] = QgsSymbolLayerV2Utils::encodePenStyle(mBorderStyle);
- map["width_border"] = QString::number(mBorderWidth);
+ map["color"] = QgsSymbolLayerV2Utils::encodeColor( mColor );
+ map["style"] = QgsSymbolLayerV2Utils::encodeBrushStyle( mBrushStyle );
+ map["color_border"] = QgsSymbolLayerV2Utils::encodeColor( mBorderColor );
+ map["style_border"] = QgsSymbolLayerV2Utils::encodePenStyle( mBorderStyle );
+ map["width_border"] = QString::number( mBorderWidth );
return map;
QgsSymbolLayerV2* QgsSimpleFillSymbolLayerV2::clone() const
- return new QgsSimpleFillSymbolLayerV2(mColor, mBrushStyle, mBorderColor, mBorderStyle, mBorderWidth);
+ return new QgsSimpleFillSymbolLayerV2( mColor, mBrushStyle, mBorderColor, mBorderStyle, mBorderWidth );
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2009-11-18 20:58:09 UTC (rev 12178)
@@ -21,7 +21,7 @@
QColor borderColor = DEFAULT_SIMPLEFILL_BORDERCOLOR,
Qt::PenStyle borderStyle = DEFAULT_SIMPLEFILL_BORDERSTYLE,
double borderWidth = DEFAULT_SIMPLEFILL_BORDERWIDTH );
// static stuff
static QgsSymbolLayerV2* create( const QgsStringMap& properties = QgsStringMap() );
Modified: trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/symbology-ng/qgslinesymbollayerv2.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -101,7 +101,7 @@
class MyLine
public:
- MyLine( QPointF p1, QPointF p2 ) : mVertical(false), mIncreasing(false), mT(0.0), mLength(0.0)
+ MyLine( QPointF p1, QPointF p2 ) : mVertical( false ), mIncreasing( false ), mT( 0.0 ), mLength( 0.0 )
if ( p1 == p2 )
return; // invalid
@@ -356,7 +356,7 @@
// return angle (in radians) between two points
if ( x1 == x2 )
- return M_PI * ( y2 >= y1 ? 1 / 2 : 3 / 2 ); // angle is 90 or 270
+ return M_PI *( y2 >= y1 ? 1 / 2 : 3 / 2 ); // angle is 90 or 270
double t = ( y2 - y1 ) / ( x2 - x1 );
if ( t >= 0 )
Modified: trunk/qgis/src/core/symbology-ng/qgsstylev2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsstylev2.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/core/symbology-ng/qgsstylev2.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -30,7 +30,7 @@
QgsStyleV2* QgsStyleV2::defaultStyle() // static
- if (mDefaultStyle == NULL)
+ if ( mDefaultStyle == NULL )
QString styleFilename = QgsApplication::userStyleV2Path();
@@ -49,48 +49,48 @@
void QgsStyleV2::clear()
- for (QMap<QString, QgsSymbolV2*>::iterator its = mSymbols.begin(); its != mSymbols.end(); ++its)
+ for ( QMap<QString, QgsSymbolV2*>::iterator its = mSymbols.begin(); its != mSymbols.end(); ++its )
delete its.value();
- for (QMap<QString, QgsVectorColorRampV2*>::iterator itr = mColorRamps.begin(); itr != mColorRamps.end(); ++itr)
+ for ( QMap<QString, QgsVectorColorRampV2*>::iterator itr = mColorRamps.begin(); itr != mColorRamps.end(); ++itr )
delete itr.value();
mSymbols.clear();
mColorRamps.clear();
-bool QgsStyleV2::addSymbol(QString name, QgsSymbolV2* symbol)
+bool QgsStyleV2::addSymbol( QString name, QgsSymbolV2* symbol )
- if (!symbol || name.count() == 0)
+ if ( !symbol || name.count() == 0 )
return false;
// delete previous symbol (if any)
- if (mSymbols.contains(name))
- delete mSymbols.value(name);
- mSymbols.insert(name, symbol);
+ if ( mSymbols.contains( name ) )
+ delete mSymbols.value( name );
+ mSymbols.insert( name, symbol );
return true;
-bool QgsStyleV2::removeSymbol(QString name)
+bool QgsStyleV2::removeSymbol( QString name )
- if (!mSymbols.contains(name))
+ if ( !mSymbols.contains( name ) )
return false;
// remove from map and delete
- delete mSymbols.take(name);
+ delete mSymbols.take( name );
return true;
-QgsSymbolV2* QgsStyleV2::symbol(QString name)
+QgsSymbolV2* QgsStyleV2::symbol( QString name )
return NULL;
return mSymbols[name]->clone();
-const QgsSymbolV2* QgsStyleV2::symbolRef(QString name) const
+const QgsSymbolV2* QgsStyleV2::symbolRef( QString name ) const
return NULL;
return mSymbols[name];
@@ -106,39 +106,39 @@
-bool QgsStyleV2::addColorRamp(QString name, QgsVectorColorRampV2* colorRamp)
+bool QgsStyleV2::addColorRamp( QString name, QgsVectorColorRampV2* colorRamp )
- if (!colorRamp || name.count() == 0)
+ if ( !colorRamp || name.count() == 0 )
return false;
- if (mColorRamps.contains(name))
- delete mColorRamps.value(name);
- mColorRamps.insert(name, colorRamp);
+ if ( mColorRamps.contains( name ) )
+ delete mColorRamps.value( name );
+ mColorRamps.insert( name, colorRamp );
return true;
-bool QgsStyleV2::removeColorRamp(QString name)
+bool QgsStyleV2::removeColorRamp( QString name )
- if (!mColorRamps.contains(name))
+ if ( !mColorRamps.contains( name ) )
return false;
- delete mColorRamps.take(name);
+ delete mColorRamps.take( name );
return true;
-QgsVectorColorRampV2* QgsStyleV2::colorRamp(QString name)
+QgsVectorColorRampV2* QgsStyleV2::colorRamp( QString name )
return NULL;
return mColorRamps[name]->clone();
-const QgsVectorColorRampV2* QgsStyleV2::colorRampRef(QString name) const
+const QgsVectorColorRampV2* QgsStyleV2::colorRampRef( QString name ) const
return NULL;
return mColorRamps[name];
@@ -147,71 +147,71 @@
return mColorRamps.count();
QStringList QgsStyleV2::colorRampNames()
return mColorRamps.keys();
-bool QgsStyleV2::load(QString filename)
+bool QgsStyleV2::load( QString filename )
mErrorString = QString();
// import xml file
- QDomDocument doc("style");
- QFile f(filename);
- if (!f.open(QFile::ReadOnly))
+ QDomDocument doc( "style" );
+ QFile f( filename );
+ if ( !f.open( QFile::ReadOnly ) )
mErrorString = "Couldn't open the style file: " + filename;
return false;
// parse the document
- if (!doc.setContent(&f))
+ if ( !doc.setContent( &f ) )
mErrorString = "Couldn't parse the style file: " + filename;
f.close();
return false;
f.close();
QDomElement docElem = doc.documentElement();
- if (docElem.tagName() != "qgis_style")
+ if ( docElem.tagName() != "qgis_style" )
mErrorString = "Incorrect root tag in style: " + docElem.tagName();
return false;
// check for style version
- QString version = docElem.attribute("version");
- if (version != STYLE_CURRENT_VERSION)
+ QString version = docElem.attribute( "version" );
+ if ( version != STYLE_CURRENT_VERSION )
mErrorString = "Unknown style file version: " + version;
return false;
// load symbols
- QDomElement symbolsElement = docElem.firstChildElement("symbols");
- if (!symbolsElement.isNull())
+ QDomElement symbolsElement = docElem.firstChildElement( "symbols" );
+ if ( !symbolsElement.isNull() )
- mSymbols = QgsSymbolLayerV2Utils::loadSymbols(symbolsElement);
+ mSymbols = QgsSymbolLayerV2Utils::loadSymbols( symbolsElement );
// load color ramps
- QDomElement rampsElement = docElem.firstChildElement("colorramps");
+ QDomElement rampsElement = docElem.firstChildElement( "colorramps" );
QDomElement e = rampsElement.firstChildElement();
- while (!e.isNull())
+ while ( !e.isNull() )
- if (e.tagName() == "colorramp")
+ if ( e.tagName() == "colorramp" )
- QgsVectorColorRampV2* ramp = QgsSymbolLayerV2Utils::loadColorRamp(e);
- if (ramp != NULL)
- addColorRamp(e.attribute("name"), ramp);
+ QgsVectorColorRampV2* ramp = QgsSymbolLayerV2Utils::loadColorRamp( e );
+ if ( ramp != NULL )
+ addColorRamp( e.attribute( "name" ), ramp );
else
- QgsDebugMsg("unknown tag: " + e.tagName());
+ QgsDebugMsg( "unknown tag: " + e.tagName() );
e = e.nextSiblingElement();
@@ -222,42 +222,42 @@
-bool QgsStyleV2::save(QString filename)
+bool QgsStyleV2::save( QString filename )
- if (filename.isEmpty())
+ if ( filename.isEmpty() )
filename = mFileName;
- QDomDocument doc("qgis_style");
- QDomElement root = doc.createElement("qgis_style");
- root.setAttribute("version", STYLE_CURRENT_VERSION);
- doc.appendChild(root);
- QDomElement symbolsElem = QgsSymbolLayerV2Utils::saveSymbols(mSymbols, "symbols", doc);
+ QDomDocument doc( "qgis_style" );
+ QDomElement root = doc.createElement( "qgis_style" );
+ root.setAttribute( "version", STYLE_CURRENT_VERSION );
+ doc.appendChild( root );
- QDomElement rampsElem = doc.createElement("colorramps");
+ QDomElement symbolsElem = QgsSymbolLayerV2Utils::saveSymbols( mSymbols, "symbols", doc );
+ QDomElement rampsElem = doc.createElement( "colorramps" );
// save color ramps
- QDomElement rampEl = QgsSymbolLayerV2Utils::saveColorRamp(itr.key(), itr.value(), doc);
- rampsElem.appendChild(rampEl);
+ QDomElement rampEl = QgsSymbolLayerV2Utils::saveColorRamp( itr.key(), itr.value(), doc );
+ rampsElem.appendChild( rampEl );
- root.appendChild(symbolsElem);
- root.appendChild(rampsElem);
+ root.appendChild( symbolsElem );
+ root.appendChild( rampsElem );
// save
- if (!f.open(QFile::WriteOnly))
+ if ( !f.open( QFile::WriteOnly ) )
- mErrorString = "Couldn't open file for writing: "+filename;
+ mErrorString = "Couldn't open file for writing: " + filename;
return false;
- QTextStream ts(&f);
- doc.save(ts, 2);
+ QTextStream ts( &f );
+ doc.save( ts, 2 );
f.close();
mFileName = filename;
return true;
Modified: trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -260,9 +260,9 @@
if ( ramp == NULL )
if ( cboCategorizedColorRamp->count() == 0 )
- QMessageBox::critical( this, tr("Error"), tr("There are no available color ramps. You can add them in Style Manager.") );
+ QMessageBox::critical( this, tr( "Error" ), tr( "There are no available color ramps. You can add them in Style Manager." ) );
else
- QMessageBox::critical( this, tr("Error"), tr("The selected color ramp is not available.") );
+ QMessageBox::critical( this, tr( "Error" ), tr( "The selected color ramp is not available." ) );
return;
Modified: trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -16,46 +16,46 @@
#include <QStandardItem>
-QgsRendererV2Widget* QgsGraduatedSymbolRendererV2Widget::create(QgsVectorLayer* layer, QgsStyleV2* style, QgsFeatureRendererV2* renderer)
+QgsRendererV2Widget* QgsGraduatedSymbolRendererV2Widget::create( QgsVectorLayer* layer, QgsStyleV2* style, QgsFeatureRendererV2* renderer )
- return new QgsGraduatedSymbolRendererV2Widget(layer, style, renderer);
+ return new QgsGraduatedSymbolRendererV2Widget( layer, style, renderer );
-QgsGraduatedSymbolRendererV2Widget::QgsGraduatedSymbolRendererV2Widget(QgsVectorLayer* layer, QgsStyleV2* style, QgsFeatureRendererV2* renderer)
- : QgsRendererV2Widget(layer, style)
+QgsGraduatedSymbolRendererV2Widget::QgsGraduatedSymbolRendererV2Widget( QgsVectorLayer* layer, QgsStyleV2* style, QgsFeatureRendererV2* renderer )
+ : QgsRendererV2Widget( layer, style )
// try to recognize the previous renderer
// (null renderer means "no previous renderer")
- if (!renderer || renderer->type() != "graduatedSymbol")
+ if ( !renderer || renderer->type() != "graduatedSymbol" )
// we're not going to use it - so let's delete the renderer
delete renderer;
- mRenderer = new QgsGraduatedSymbolRendererV2("", QgsRangeList());
+ mRenderer = new QgsGraduatedSymbolRendererV2( "", QgsRangeList() );
else
- mRenderer = static_cast<QgsGraduatedSymbolRendererV2*>(renderer);
+ mRenderer = static_cast<QgsGraduatedSymbolRendererV2*>( renderer );
// setup user interface
- setupUi(this);
+ setupUi( this );
populateColumns();
populateColorRamps();
- QStandardItemModel* mg = new QStandardItemModel(this);
+ QStandardItemModel* mg = new QStandardItemModel( this );
QStringList labels;
labels << "Range" << "Label";
- mg->setHorizontalHeaderLabels(labels);
- viewGraduated->setModel(mg);
+ mg->setHorizontalHeaderLabels( labels );
+ viewGraduated->setModel( mg );
- mGraduatedSymbol = QgsSymbolV2::defaultSymbol(mLayer->geometryType());
+ mGraduatedSymbol = QgsSymbolV2::defaultSymbol( mLayer->geometryType() );
- connect(viewGraduated, SIGNAL(doubleClicked(const QModelIndex &)), this, SLOT(rangesDoubleClicked(const QModelIndex &)));
+ connect( viewGraduated, SIGNAL( doubleClicked( const QModelIndex & ) ), this, SLOT( rangesDoubleClicked( const QModelIndex & ) ) );
- connect(btnGraduatedClassify, SIGNAL(clicked()), this, SLOT(classifyGraduated()));
- connect(btnChangeGraduatedSymbol, SIGNAL(clicked()), this, SLOT(changeGraduatedSymbol()));
+ connect( btnGraduatedClassify, SIGNAL( clicked() ), this, SLOT( classifyGraduated() ) );
+ connect( btnChangeGraduatedSymbol, SIGNAL( clicked() ), this, SLOT( changeGraduatedSymbol() ) );
// initialize from previously set renderer
updateUiFromRenderer();
@@ -79,20 +79,20 @@
populateRanges();
// update UI from the graduated renderer (update combo boxes, view)
- if (mRenderer->mode() < cboGraduatedMode->count())
+ if ( mRenderer->mode() < cboGraduatedMode->count() )
cboGraduatedMode->setCurrentIndex( mRenderer->mode() );
- if (mRenderer->ranges().count())
+ if ( mRenderer->ranges().count() )
spinGraduatedClasses->setValue( mRenderer->ranges().count() );
// set column
//disconnect(cboGraduatedColumn, SIGNAL(currentIndexChanged(int)), this, SLOT(graduatedColumnChanged()));
QString attrName = mRenderer->classAttribute();
- int idx = cboGraduatedColumn->findText(attrName, Qt::MatchExactly);
- cboGraduatedColumn->setCurrentIndex(idx >= 0 ? idx : 0);
+ int idx = cboGraduatedColumn->findText( attrName, Qt::MatchExactly );
+ cboGraduatedColumn->setCurrentIndex( idx >= 0 ? idx : 0 );
//connect(cboGraduatedColumn, SIGNAL(currentIndexChanged(int)), this, SLOT(graduatedColumnChanged()));
// set source symbol
- if (mRenderer->sourceSymbol())
+ if ( mRenderer->sourceSymbol() )
delete mGraduatedSymbol;
mGraduatedSymbol = mRenderer->sourceSymbol()->clone();
@@ -100,15 +100,15 @@
// set source color ramp
- if (mRenderer->sourceColorRamp())
+ if ( mRenderer->sourceColorRamp() )
- QSize rampIconSize(50,16);
- QIcon icon = QgsSymbolLayerV2Utils::colorRampPreviewIcon(mRenderer->sourceColorRamp(), rampIconSize);
- if (cboGraduatedColorRamp->itemText(0) == "[source]")
- cboGraduatedColorRamp->setItemIcon(0, icon);
+ QSize rampIconSize( 50, 16 );
+ QIcon icon = QgsSymbolLayerV2Utils::colorRampPreviewIcon( mRenderer->sourceColorRamp(), rampIconSize );
+ if ( cboGraduatedColorRamp->itemText( 0 ) == "[source]" )
+ cboGraduatedColorRamp->setItemIcon( 0, icon );
else
- cboGraduatedColorRamp->insertItem(0, icon, "[source]");
- cboGraduatedColorRamp->setCurrentIndex(0);
+ cboGraduatedColorRamp->insertItem( 0, icon, "[source]" );
+ cboGraduatedColorRamp->setCurrentIndex( 0 );
@@ -120,25 +120,25 @@
cboGraduatedColumn->clear();
const QgsFieldMap& flds = mLayer->pendingFields();
QgsFieldMap::ConstIterator it = flds.begin();
- for ( ; it != flds.end(); ++it)
+ for ( ; it != flds.end(); ++it )
- if (it->type() == QVariant::Double || it->type() == QVariant::Int)
- cboGraduatedColumn->addItem(it->name());
+ if ( it->type() == QVariant::Double || it->type() == QVariant::Int )
+ cboGraduatedColumn->addItem( it->name() );
void QgsGraduatedSymbolRendererV2Widget::populateColorRamps()
- cboGraduatedColorRamp->setIconSize(rampIconSize);
+ cboGraduatedColorRamp->setIconSize( rampIconSize );
QStringList rampNames = mStyle->colorRampNames();
- for (QStringList::iterator it = rampNames.begin(); it != rampNames.end(); ++it)
+ for ( QStringList::iterator it = rampNames.begin(); it != rampNames.end(); ++it )
- QgsVectorColorRampV2* ramp = mStyle->colorRamp(*it);
- QIcon icon = QgsSymbolLayerV2Utils::colorRampPreviewIcon(ramp, rampIconSize);
- cboGraduatedColorRamp->addItem(icon, *it);
+ QgsVectorColorRampV2* ramp = mStyle->colorRamp( *it );
+ QIcon icon = QgsSymbolLayerV2Utils::colorRampPreviewIcon( ramp, rampIconSize );
+ cboGraduatedColorRamp->addItem( icon, *it );
delete ramp;
@@ -153,7 +153,7 @@
QgsVectorColorRampV2* ramp = NULL;
QString rampName = cboGraduatedColorRamp->currentText();
- if (rampName == "[source]")
+ if ( rampName == "[source]" )
ramp = mRenderer->sourceColorRamp()->clone();
else
ramp = mStyle->colorRamp( rampName );
@@ -161,14 +161,14 @@
if ( ramp == NULL )
if ( cboGraduatedColorRamp->count() == 0 )
else
return;
QgsGraduatedSymbolRendererV2::Mode mode;
- if (cboGraduatedMode->currentIndex() == 0)
+ if ( cboGraduatedMode->currentIndex() == 0 )
mode = QgsGraduatedSymbolRendererV2::EqualInterval;
else
mode = QgsGraduatedSymbolRendererV2::Quantile;
@@ -176,15 +176,15 @@
// create and set new renderer
delete mRenderer;
mRenderer = QgsGraduatedSymbolRendererV2::createRenderer(
- mLayer, attrName, classes, mode, mGraduatedSymbol, ramp);
+ mLayer, attrName, classes, mode, mGraduatedSymbol, ramp );
populateRanges();
void QgsGraduatedSymbolRendererV2Widget::changeGraduatedSymbol()
- QgsSymbolV2SelectorDialog dlg(mGraduatedSymbol, mStyle, this);
- if (!dlg.exec())
+ QgsSymbolV2SelectorDialog dlg( mGraduatedSymbol, mStyle, this );
+ if ( !dlg.exec() )
return;
updateGraduatedSymbolIcon();
@@ -192,42 +192,42 @@
void QgsGraduatedSymbolRendererV2Widget::updateGraduatedSymbolIcon()
- QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon(mGraduatedSymbol, btnChangeGraduatedSymbol->iconSize());
- btnChangeGraduatedSymbol->setIcon(icon);
+ QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon( mGraduatedSymbol, btnChangeGraduatedSymbol->iconSize() );
+ btnChangeGraduatedSymbol->setIcon( icon );
void QgsGraduatedSymbolRendererV2Widget::populateRanges()
- QStandardItemModel* m = qobject_cast<QStandardItemModel*>(viewGraduated->model());
+ QStandardItemModel* m = qobject_cast<QStandardItemModel*>( viewGraduated->model() );
m->clear();
QStringList labels;
- m->setHorizontalHeaderLabels(labels);
+ m->setHorizontalHeaderLabels( labels );
- QSize iconSize(16,16);
+ QSize iconSize( 16, 16 );
int i, count = mRenderer->ranges().count();
- for (i = 0; i < count; i++)
+ for ( i = 0; i < count; i++ )
const QgsRendererRangeV2& range = mRenderer->ranges()[i];
- QString rangeStr = QString::number(range.lowerValue(),'f',4) + " - " + QString::number(range.upperValue(),'f',4);
+ QString rangeStr = QString::number( range.lowerValue(), 'f', 4 ) + " - " + QString::number( range.upperValue(), 'f', 4 );
- QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon(range.symbol(), iconSize);
- QStandardItem* item = new QStandardItem(icon, rangeStr);
+ QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon( range.symbol(), iconSize );
+ QStandardItem* item = new QStandardItem( icon, rangeStr );
//item->setData(k); // set attribute value as user role
- item->setFlags(Qt::ItemIsSelectable | Qt::ItemIsEnabled);
+ item->setFlags( Qt::ItemIsSelectable | Qt::ItemIsEnabled );
QList<QStandardItem *> list;
- list << item << new QStandardItem(range.label());
+ list << item << new QStandardItem( range.label() );
m->appendRow( list );
// make sure that the "range" column has visible context
- viewGraduated->resizeColumnToContents(0);
+ viewGraduated->resizeColumnToContents( 0 );
@@ -241,25 +241,25 @@
-void QgsGraduatedSymbolRendererV2Widget::rangesDoubleClicked(const QModelIndex & idx)
+void QgsGraduatedSymbolRendererV2Widget::rangesDoubleClicked( const QModelIndex & idx )
- if (idx.isValid() && idx.column() == 0)
- changeRangeSymbol(idx.row());
+ if ( idx.isValid() && idx.column() == 0 )
+ changeRangeSymbol( idx.row() );
-void QgsGraduatedSymbolRendererV2Widget::changeRangeSymbol(int rangeIdx)
+void QgsGraduatedSymbolRendererV2Widget::changeRangeSymbol( int rangeIdx )
QgsSymbolV2* newSymbol = mRenderer->ranges()[rangeIdx].symbol()->clone();
- QgsSymbolV2SelectorDialog dlg(newSymbol, mStyle, this);
- if (!dlg.exec())
+ QgsSymbolV2SelectorDialog dlg( newSymbol, mStyle, this );
delete newSymbol;
return;
- mRenderer->updateRangeSymbol(rangeIdx, newSymbol);
+ mRenderer->updateRangeSymbol( rangeIdx, newSymbol );
populateRanges();
Modified: trunk/qgis/src/gui/symbology-ng/qgspenstylecombobox.cpp
--- trunk/qgis/src/gui/symbology-ng/qgspenstylecombobox.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/gui/symbology-ng/qgspenstylecombobox.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -9,76 +9,76 @@
#include <QPainter>
#include <QPen>
-QgsPenStyleComboBox::QgsPenStyleComboBox(QWidget* parent)
- : QComboBox(parent)
+QgsPenStyleComboBox::QgsPenStyleComboBox( QWidget* parent )
+ : QComboBox( parent )
QList < QPair<Qt::PenStyle, QString> > styles;
- styles << qMakePair(Qt::SolidLine, QString("Solid Line"))
- << qMakePair(Qt::DashLine, QString("Dash Line"))
- << qMakePair(Qt::DotLine, QString("Dot Line"))
- << qMakePair(Qt::DashDotLine, QString("Dash Dot Line"))
- << qMakePair(Qt::DashDotDotLine, QString("Dash Dot Dot Line"))
- << qMakePair(Qt::NoPen, QString("No Pen"));
- setIconSize(QSize(32,12));
- for (int i = 0; i < styles.count(); i++)
+ styles << qMakePair( Qt::SolidLine, QString( "Solid Line" ) )
+ << qMakePair( Qt::DashLine, QString( "Dash Line" ) )
+ << qMakePair( Qt::DotLine, QString( "Dot Line" ) )
+ << qMakePair( Qt::DashDotLine, QString( "Dash Dot Line" ) )
+ << qMakePair( Qt::DashDotDotLine, QString( "Dash Dot Dot Line" ) )
+ << qMakePair( Qt::NoPen, QString( "No Pen" ) );
+ setIconSize( QSize( 32, 12 ) );
+ for ( int i = 0; i < styles.count(); i++ )
- Qt::PenStyle style = styles.at(i).first;
- QString name = styles.at(i).second;
- addItem(iconForPen(style), name, QVariant(style));
+ Qt::PenStyle style = styles.at( i ).first;
+ QString name = styles.at( i ).second;
+ addItem( iconForPen( style ), name, QVariant( style ) );
Qt::PenStyle QgsPenStyleComboBox::penStyle() const
- return (Qt::PenStyle) itemData(currentIndex()).toInt();
+ return ( Qt::PenStyle ) itemData( currentIndex() ).toInt();
-void QgsPenStyleComboBox::setPenStyle(Qt::PenStyle style)
+void QgsPenStyleComboBox::setPenStyle( Qt::PenStyle style )
- int idx = findData(QVariant(style));
+ int idx = findData( QVariant( style ) );
setCurrentIndex( idx == -1 ? 0 : idx );
-QIcon QgsPenStyleComboBox::iconForPen(Qt::PenStyle style)
+QIcon QgsPenStyleComboBox::iconForPen( Qt::PenStyle style )
- QPixmap pix(iconSize());
+ QPixmap pix( iconSize() );
QPainter p;
- pix.fill(Qt::transparent);
- p.begin(&pix);
- QPen pen(style);
- pen.setWidth(2);
- p.setPen(pen);
+ pix.fill( Qt::transparent );
+ p.begin( &pix );
+ QPen pen( style );
+ pen.setWidth( 2 );
+ p.setPen( pen );
double mid = iconSize().height() / 2.0;
- p.drawLine(0,mid,iconSize().width(),mid);
+ p.drawLine( 0, mid, iconSize().width(), mid );
p.end();
- return QIcon(pix);
+ return QIcon( pix );
// join
-QgsPenJoinStyleComboBox::QgsPenJoinStyleComboBox(QWidget* parent)
+QgsPenJoinStyleComboBox::QgsPenJoinStyleComboBox( QWidget* parent )
QString path = QgsApplication::defaultThemePath();
- addItem(QIcon(path + "/join_bevel.png"), tr("Bevel"), QVariant(Qt::BevelJoin));
- addItem(QIcon(path + "/join_miter.png"), tr("Miter"), QVariant(Qt::MiterJoin));
- addItem(QIcon(path + "/join_round.png"), tr("Round"), QVariant(Qt::RoundJoin));
+ addItem( QIcon( path + "/join_bevel.png" ), tr( "Bevel" ), QVariant( Qt::BevelJoin ) );
+ addItem( QIcon( path + "/join_miter.png" ), tr( "Miter" ), QVariant( Qt::MiterJoin ) );
+ addItem( QIcon( path + "/join_round.png" ), tr( "Round" ), QVariant( Qt::RoundJoin ) );
Qt::PenJoinStyle QgsPenJoinStyleComboBox::penJoinStyle() const
- return (Qt::PenJoinStyle) itemData(currentIndex()).toInt();
+ return ( Qt::PenJoinStyle ) itemData( currentIndex() ).toInt();
-void QgsPenJoinStyleComboBox::setPenJoinStyle(Qt::PenJoinStyle style)
+void QgsPenJoinStyleComboBox::setPenJoinStyle( Qt::PenJoinStyle style )
@@ -86,22 +86,22 @@
// cap
-QgsPenCapStyleComboBox::QgsPenCapStyleComboBox(QWidget* parent)
+QgsPenCapStyleComboBox::QgsPenCapStyleComboBox( QWidget* parent )
- addItem(QIcon(path + "/cap_square.png"), tr("Square"), QVariant(Qt::SquareCap));
- addItem(QIcon(path + "/cap_flat.png"), tr("Flat"), QVariant(Qt::FlatCap));
- addItem(QIcon(path + "/cap_round.png"), tr("Round"), QVariant(Qt::RoundCap));
+ addItem( QIcon( path + "/cap_square.png" ), tr( "Square" ), QVariant( Qt::SquareCap ) );
+ addItem( QIcon( path + "/cap_flat.png" ), tr( "Flat" ), QVariant( Qt::FlatCap ) );
+ addItem( QIcon( path + "/cap_round.png" ), tr( "Round" ), QVariant( Qt::RoundCap ) );
Qt::PenCapStyle QgsPenCapStyleComboBox::penCapStyle() const
- return (Qt::PenCapStyle) itemData(currentIndex()).toInt();
+ return ( Qt::PenCapStyle ) itemData( currentIndex() ).toInt();
-void QgsPenCapStyleComboBox::setPenCapStyle(Qt::PenCapStyle style)
+void QgsPenCapStyleComboBox::setPenCapStyle( Qt::PenCapStyle style )
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -18,37 +18,37 @@
-QgsSimpleLineSymbolLayerV2Widget::QgsSimpleLineSymbolLayerV2Widget(QWidget* parent)
- : QgsSymbolLayerV2Widget(parent)
+QgsSimpleLineSymbolLayerV2Widget::QgsSimpleLineSymbolLayerV2Widget( QWidget* parent )
+ : QgsSymbolLayerV2Widget( parent )
mLayer = NULL;
- setupUi(this);
- connect(spinWidth, SIGNAL(valueChanged(double)), this, SLOT(penWidthChanged()));
- connect(btnChangeColor, SIGNAL(clicked()), this, SLOT(colorChanged()));
- connect(cboPenStyle, SIGNAL(currentIndexChanged(int)), this, SLOT(penStyleChanged()));
- connect(spinOffset, SIGNAL(valueChanged(double)), this, SLOT(offsetChanged()));
- connect(cboCapStyle, SIGNAL(currentIndexChanged(int)), this, SLOT(penStyleChanged()));
- connect(cboJoinStyle, SIGNAL(currentIndexChanged(int)), this, SLOT(penStyleChanged()));
+ setupUi( this );
+ connect( spinWidth, SIGNAL( valueChanged( double ) ), this, SLOT( penWidthChanged() ) );
+ connect( btnChangeColor, SIGNAL( clicked() ), this, SLOT( colorChanged() ) );
+ connect( cboPenStyle, SIGNAL( currentIndexChanged( int ) ), this, SLOT( penStyleChanged() ) );
+ connect( spinOffset, SIGNAL( valueChanged( double ) ), this, SLOT( offsetChanged() ) );
+ connect( cboCapStyle, SIGNAL( currentIndexChanged( int ) ), this, SLOT( penStyleChanged() ) );
+ connect( cboJoinStyle, SIGNAL( currentIndexChanged( int ) ), this, SLOT( penStyleChanged() ) );
-void QgsSimpleLineSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsSimpleLineSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "SimpleLine")
+ if ( layer->layerType() != "SimpleLine" )
return;
// layer type is correct, we can do the cast
- mLayer = static_cast<QgsSimpleLineSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsSimpleLineSymbolLayerV2*>( layer );
// set values
- spinWidth->setValue(mLayer->width());
- btnChangeColor->setColor(mLayer->color());
- cboPenStyle->setPenStyle(mLayer->penStyle());
- spinOffset->setValue(mLayer->offset());
- cboJoinStyle->setPenJoinStyle(mLayer->penJoinStyle());
- cboCapStyle->setPenCapStyle(mLayer->penCapStyle());
+ spinWidth->setValue( mLayer->width() );
+ btnChangeColor->setColor( mLayer->color() );
+ cboPenStyle->setPenStyle( mLayer->penStyle() );
+ spinOffset->setValue( mLayer->offset() );
+ cboJoinStyle->setPenJoinStyle( mLayer->penJoinStyle() );
+ cboCapStyle->setPenCapStyle( mLayer->penCapStyle() );
QgsSymbolLayerV2* QgsSimpleLineSymbolLayerV2Widget::symbolLayer()
@@ -58,31 +58,31 @@
void QgsSimpleLineSymbolLayerV2Widget::penWidthChanged()
- mLayer->setWidth(spinWidth->value());
+ mLayer->setWidth( spinWidth->value() );
emit changed();
void QgsSimpleLineSymbolLayerV2Widget::colorChanged()
- QColor color = QColorDialog::getColor(mLayer->color(), this);
- if (!color.isValid())
+ QColor color = QColorDialog::getColor( mLayer->color(), this );
+ if ( !color.isValid() )
return;
- mLayer->setColor(color);
+ mLayer->setColor( color );
emit changed();
void QgsSimpleLineSymbolLayerV2Widget::penStyleChanged()
- mLayer->setPenStyle(cboPenStyle->penStyle());
- mLayer->setPenJoinStyle(cboJoinStyle->penJoinStyle());
- mLayer->setPenCapStyle(cboCapStyle->penCapStyle());
+ mLayer->setPenStyle( cboPenStyle->penStyle() );
+ mLayer->setPenJoinStyle( cboJoinStyle->penJoinStyle() );
+ mLayer->setPenCapStyle( cboCapStyle->penCapStyle() );
emit changed();
void QgsSimpleLineSymbolLayerV2Widget::offsetChanged()
- mLayer->setOffset(spinOffset->value());
+ mLayer->setOffset( spinOffset->value() );
emit changed();
@@ -90,66 +90,66 @@
-QgsSimpleMarkerSymbolLayerV2Widget::QgsSimpleMarkerSymbolLayerV2Widget(QWidget* parent)
+QgsSimpleMarkerSymbolLayerV2Widget::QgsSimpleMarkerSymbolLayerV2Widget( QWidget* parent )
mLayer = NULL;
- setupUi(this);
+ setupUi( this );
QSize size = lstNames->iconSize();
QStringList names;
names << "circle" << "rectangle" << "diamond" << "pentagon" << "cross" << "cross2" << "triangle"
- << "equilateral_triangle" << "star" << "regular_star" << "arrow";
- double markerSize = size.width()-1; // keep some space around
- for (int i = 0; i < names.count(); ++i)
+ << "equilateral_triangle" << "star" << "regular_star" << "arrow";
+ double markerSize = size.width() - 1; // keep some space around
+ for ( int i = 0; i < names.count(); ++i )
- QgsSimpleMarkerSymbolLayerV2* lyr = new QgsSimpleMarkerSymbolLayerV2(names[i], QColor(200,200,200), QColor(0,0,0), markerSize);
- QIcon icon = QgsSymbolLayerV2Utils::symbolLayerPreviewIcon(lyr, size);
- QListWidgetItem* item = new QListWidgetItem(icon, QString(), lstNames);
- item->setData(Qt::UserRole, names[i]);
+ QgsSimpleMarkerSymbolLayerV2* lyr = new QgsSimpleMarkerSymbolLayerV2( names[i], QColor( 200, 200, 200 ), QColor( 0, 0, 0 ), markerSize );
+ QIcon icon = QgsSymbolLayerV2Utils::symbolLayerPreviewIcon( lyr, size );
+ QListWidgetItem* item = new QListWidgetItem( icon, QString(), lstNames );
+ item->setData( Qt::UserRole, names[i] );
delete lyr;
- connect(lstNames, SIGNAL(currentRowChanged(int)), this, SLOT(setName()));
- connect(btnChangeColorBorder, SIGNAL(clicked()), this, SLOT(setColorBorder()));
- connect(btnChangeColorFill, SIGNAL(clicked()), this, SLOT(setColorFill()));
- connect(spinSize, SIGNAL(valueChanged(double)), this, SLOT(setSize()));
- connect(spinAngle, SIGNAL(valueChanged(double)), this, SLOT(setAngle()));
- connect(spinOffsetX, SIGNAL(valueChanged(double)), this, SLOT(setOffset()));
- connect(spinOffsetY, SIGNAL(valueChanged(double)), this, SLOT(setOffset()));
+ connect( lstNames, SIGNAL( currentRowChanged( int ) ), this, SLOT( setName() ) );
+ connect( btnChangeColorBorder, SIGNAL( clicked() ), this, SLOT( setColorBorder() ) );
+ connect( btnChangeColorFill, SIGNAL( clicked() ), this, SLOT( setColorFill() ) );
+ connect( spinSize, SIGNAL( valueChanged( double ) ), this, SLOT( setSize() ) );
+ connect( spinAngle, SIGNAL( valueChanged( double ) ), this, SLOT( setAngle() ) );
+ connect( spinOffsetX, SIGNAL( valueChanged( double ) ), this, SLOT( setOffset() ) );
+ connect( spinOffsetY, SIGNAL( valueChanged( double ) ), this, SLOT( setOffset() ) );
-void QgsSimpleMarkerSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsSimpleMarkerSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "SimpleMarker")
+ if ( layer->layerType() != "SimpleMarker" )
return;
- mLayer = static_cast<QgsSimpleMarkerSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsSimpleMarkerSymbolLayerV2*>( layer );
// set values
QString name = mLayer->name();
- for (int i = 0; i < lstNames->count(); ++i)
+ for ( int i = 0; i < lstNames->count(); ++i )
- if (lstNames->item(i)->data(Qt::UserRole).toString() == name)
+ if ( lstNames->item( i )->data( Qt::UserRole ).toString() == name )
- lstNames->setCurrentRow(i);
+ lstNames->setCurrentRow( i );
break;
- btnChangeColorBorder->setColor(mLayer->borderColor());
- btnChangeColorFill->setColor(mLayer->color());
- spinSize->setValue(mLayer->size());
- spinAngle->setValue(mLayer->angle());
+ btnChangeColorBorder->setColor( mLayer->borderColor() );
+ btnChangeColorFill->setColor( mLayer->color() );
+ spinSize->setValue( mLayer->size() );
+ spinAngle->setValue( mLayer->angle() );
// without blocking signals the value gets changed because of slot setOffset()
- spinOffsetX->blockSignals(true);
- spinOffsetX->setValue(mLayer->offset().x());
- spinOffsetX->blockSignals(false);
- spinOffsetY->blockSignals(true);
- spinOffsetY->setValue(mLayer->offset().y());
- spinOffsetY->blockSignals(false);
+ spinOffsetX->blockSignals( true );
+ spinOffsetX->setValue( mLayer->offset().x() );
+ spinOffsetX->blockSignals( false );
+ spinOffsetY->blockSignals( true );
+ spinOffsetY->setValue( mLayer->offset().y() );
+ spinOffsetY->blockSignals( false );
QgsSymbolLayerV2* QgsSimpleMarkerSymbolLayerV2Widget::symbolLayer()
@@ -159,39 +159,39 @@
void QgsSimpleMarkerSymbolLayerV2Widget::setName()
- mLayer->setName(lstNames->currentItem()->data(Qt::UserRole).toString());
+ mLayer->setName( lstNames->currentItem()->data( Qt::UserRole ).toString() );
emit changed();
void QgsSimpleMarkerSymbolLayerV2Widget::setColorBorder()
- QColor borderColor = QColorDialog::getColor(mLayer->borderColor(), this);
- if (!borderColor.isValid())
+ QColor borderColor = QColorDialog::getColor( mLayer->borderColor(), this );
+ if ( !borderColor.isValid() )
return;
- mLayer->setBorderColor(borderColor);
+ mLayer->setBorderColor( borderColor );
emit changed();
void QgsSimpleMarkerSymbolLayerV2Widget::setColorFill()
return;
emit changed();
void QgsSimpleMarkerSymbolLayerV2Widget::setSize()
- mLayer->setSize(spinSize->value());
+ mLayer->setSize( spinSize->value() );
emit changed();
void QgsSimpleMarkerSymbolLayerV2Widget::setAngle()
- mLayer->setAngle(spinAngle->value());
+ mLayer->setAngle( spinAngle->value() );
emit changed();
@@ -204,34 +204,34 @@
-QgsSimpleFillSymbolLayerV2Widget::QgsSimpleFillSymbolLayerV2Widget(QWidget* parent)
+QgsSimpleFillSymbolLayerV2Widget::QgsSimpleFillSymbolLayerV2Widget( QWidget* parent )
mLayer = NULL;
- setupUi(this);
- connect(btnChangeColor, SIGNAL(clicked()), this, SLOT(setColor()));
- connect(cboFillStyle, SIGNAL(currentIndexChanged(int)), this, SLOT(setBrushStyle()));
- connect(btnChangeBorderColor, SIGNAL(clicked()), this, SLOT(setBorderColor()));
- connect(spinBorderWidth, SIGNAL(valueChanged(double)), this, SLOT(borderWidthChanged()));
- connect(cboBorderStyle, SIGNAL(currentIndexChanged(int)), this, SLOT(borderStyleChanged()));
+ setupUi( this );
+ connect( btnChangeColor, SIGNAL( clicked() ), this, SLOT( setColor() ) );
+ connect( cboFillStyle, SIGNAL( currentIndexChanged( int ) ), this, SLOT( setBrushStyle() ) );
+ connect( btnChangeBorderColor, SIGNAL( clicked() ), this, SLOT( setBorderColor() ) );
+ connect( spinBorderWidth, SIGNAL( valueChanged( double ) ), this, SLOT( borderWidthChanged() ) );
+ connect( cboBorderStyle, SIGNAL( currentIndexChanged( int ) ), this, SLOT( borderStyleChanged() ) );
-void QgsSimpleFillSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsSimpleFillSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "SimpleFill")
+ if ( layer->layerType() != "SimpleFill" )
return;
- mLayer = static_cast<QgsSimpleFillSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsSimpleFillSymbolLayerV2*>( layer );
// set values
- cboFillStyle->setBrushStyle(mLayer->brushStyle());
- btnChangeBorderColor->setColor(mLayer->borderColor());
- cboBorderStyle->setPenStyle(mLayer->borderStyle());
- spinBorderWidth->setValue(mLayer->borderWidth());
+ cboFillStyle->setBrushStyle( mLayer->brushStyle() );
+ btnChangeBorderColor->setColor( mLayer->borderColor() );
+ cboBorderStyle->setPenStyle( mLayer->borderStyle() );
+ spinBorderWidth->setValue( mLayer->borderWidth() );
QgsSymbolLayerV2* QgsSimpleFillSymbolLayerV2Widget::symbolLayer()
@@ -241,69 +241,69 @@
void QgsSimpleFillSymbolLayerV2Widget::setColor()
return;
emit changed();
void QgsSimpleFillSymbolLayerV2Widget::setBorderColor()
- QColor color = QColorDialog::getColor(mLayer->borderColor(), this);
+ QColor color = QColorDialog::getColor( mLayer->borderColor(), this );
return;
- mLayer->setBorderColor(color);
+ mLayer->setBorderColor( color );
emit changed();
void QgsSimpleFillSymbolLayerV2Widget::setBrushStyle()
- mLayer->setBrushStyle(cboFillStyle->brushStyle());
+ mLayer->setBrushStyle( cboFillStyle->brushStyle() );
emit changed();
void QgsSimpleFillSymbolLayerV2Widget::borderWidthChanged()
- mLayer->setBorderWidth(spinBorderWidth->value());
+ mLayer->setBorderWidth( spinBorderWidth->value() );
emit changed();
void QgsSimpleFillSymbolLayerV2Widget::borderStyleChanged()
- mLayer->setBorderStyle(cboBorderStyle->penStyle());
+ mLayer->setBorderStyle( cboBorderStyle->penStyle() );
emit changed();
-QgsMarkerLineSymbolLayerV2Widget::QgsMarkerLineSymbolLayerV2Widget(QWidget* parent)
+QgsMarkerLineSymbolLayerV2Widget::QgsMarkerLineSymbolLayerV2Widget( QWidget* parent )
mLayer = NULL;
- setupUi(this);
- connect(spinInterval, SIGNAL(valueChanged(double)), this, SLOT(setInterval(double)));
- connect(btnChangeMarker, SIGNAL(clicked()), this, SLOT(setMarker()));
- connect(chkRotateMarker, SIGNAL(clicked()), this, SLOT(setRotate()));
- connect(spinOffset, SIGNAL(valueChanged(double)), this, SLOT(setOffset()));
+ setupUi( this );
+ connect( spinInterval, SIGNAL( valueChanged( double ) ), this, SLOT( setInterval( double ) ) );
+ connect( btnChangeMarker, SIGNAL( clicked() ), this, SLOT( setMarker() ) );
+ connect( chkRotateMarker, SIGNAL( clicked() ), this, SLOT( setRotate() ) );
+ connect( spinOffset, SIGNAL( valueChanged( double ) ), this, SLOT( setOffset() ) );
-void QgsMarkerLineSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsMarkerLineSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "MarkerLine")
+ if ( layer->layerType() != "MarkerLine" )
return;
- mLayer = static_cast<QgsMarkerLineSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsMarkerLineSymbolLayerV2*>( layer );
// set values
- spinInterval->setValue( (int) mLayer->interval());
- chkRotateMarker->setChecked(mLayer->rotateMarker());
+ spinInterval->setValue(( int ) mLayer->interval() );
+ chkRotateMarker->setChecked( mLayer->rotateMarker() );
updateMarker();
@@ -312,16 +312,16 @@
return mLayer;
-void QgsMarkerLineSymbolLayerV2Widget::setInterval(double val)
+void QgsMarkerLineSymbolLayerV2Widget::setInterval( double val )
- mLayer->setInterval(val);
+ mLayer->setInterval( val );
emit changed();
void QgsMarkerLineSymbolLayerV2Widget::setMarker()
- QgsSymbolV2PropertiesDialog dlg(mLayer->subSymbol(), this);
- if (dlg.exec() == 0)
+ QgsSymbolV2PropertiesDialog dlg( mLayer->subSymbol(), this );
+ if ( dlg.exec() == 0 )
return;
updateMarker();
@@ -330,52 +330,52 @@
void QgsMarkerLineSymbolLayerV2Widget::setRotate()
- mLayer->setRotateMarker(chkRotateMarker->isChecked());
+ mLayer->setRotateMarker( chkRotateMarker->isChecked() );
emit changed();
void QgsMarkerLineSymbolLayerV2Widget::setOffset()
emit changed();
void QgsMarkerLineSymbolLayerV2Widget::updateMarker()
- QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon(mLayer->subSymbol(), btnChangeMarker->iconSize());
- btnChangeMarker->setIcon(icon);
+ QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon( mLayer->subSymbol(), btnChangeMarker->iconSize() );
+ btnChangeMarker->setIcon( icon );
-QgsSvgMarkerSymbolLayerV2Widget::QgsSvgMarkerSymbolLayerV2Widget(QWidget* parent)
+QgsSvgMarkerSymbolLayerV2Widget::QgsSvgMarkerSymbolLayerV2Widget( QWidget* parent )
mLayer = NULL;
- setupUi(this);
+ setupUi( this );
populateList();
- connect(viewImages->selectionModel(), SIGNAL(currentChanged(const QModelIndex&, const QModelIndex&)), this, SLOT(setName(const QModelIndex&)));
+ connect( viewImages->selectionModel(), SIGNAL( currentChanged( const QModelIndex&, const QModelIndex& ) ), this, SLOT( setName( const QModelIndex& ) ) );
void QgsSvgMarkerSymbolLayerV2Widget::populateList()
- QStandardItemModel* m = new QStandardItemModel(viewImages);
- viewImages->setModel(m);
+ QStandardItemModel* m = new QStandardItemModel( viewImages );
+ viewImages->setModel( m );
QString svgPath = QgsApplication::svgPath();
QSvgRenderer renderer;
QPainter painter;
QDir dir( svgPath );
QStringList dl = dir.entryList( QDir::Dirs );
@@ -392,51 +392,51 @@
// TODO test if it is correct SVG
QString entry = *it2;
// render SVG file
renderer.load( dir2.filePath( *it2 ) );
- QPixmap pixmap(renderer.defaultSize());
+ QPixmap pixmap( renderer.defaultSize() );
pixmap.fill();
- painter.begin(&pixmap);
- renderer.render(&painter);
+ painter.begin( &pixmap );
+ renderer.render( &painter );
painter.end();
// add item
- QStandardItem* item = new QStandardItem(QIcon(pixmap), *it + "/" + entry);
- m->appendRow(item);
+ QStandardItem* item = new QStandardItem( QIcon( pixmap ), *it + "/" + entry );
+ m->appendRow( item );
-void QgsSvgMarkerSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsSvgMarkerSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "SvgMarker")
+ if ( layer->layerType() != "SvgMarker" )
return;
- mLayer = static_cast<QgsSvgMarkerSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsSvgMarkerSymbolLayerV2*>( layer );
// set values
- QStandardItemModel* m = static_cast<QStandardItemModel*>(viewImages->model());
- QList<QStandardItem*> items = m->findItems(mLayer->name());
- if (items.count() > 0)
+ QStandardItemModel* m = static_cast<QStandardItemModel*>( viewImages->model() );
+ QList<QStandardItem*> items = m->findItems( mLayer->name() );
+ if ( items.count() > 0 )
QModelIndex idx = items[0]->index();
- viewImages->selectionModel()->select(idx, QItemSelectionModel::SelectCurrent);
+ viewImages->selectionModel()->select( idx, QItemSelectionModel::SelectCurrent );
QgsSymbolLayerV2* QgsSvgMarkerSymbolLayerV2Widget::symbolLayer()
@@ -444,9 +444,9 @@
return mLayer;
-void QgsSvgMarkerSymbolLayerV2Widget::setName(const QModelIndex& idx)
+void QgsSvgMarkerSymbolLayerV2Widget::setName( const QModelIndex& idx )
- mLayer->setName(idx.data().toString());
+ mLayer->setName( idx.data().toString() );
//mLayer->setName(lstNames->currentItem()->data(Qt::UserRole).toString());
emit changed();
@@ -454,13 +454,13 @@
void QgsSvgMarkerSymbolLayerV2Widget::setSize()
emit changed();
void QgsSvgMarkerSymbolLayerV2Widget::setAngle()
emit changed();
@@ -472,26 +472,26 @@
-QgsLineDecorationSymbolLayerV2Widget::QgsLineDecorationSymbolLayerV2Widget(QWidget* parent)
+QgsLineDecorationSymbolLayerV2Widget::QgsLineDecorationSymbolLayerV2Widget( QWidget* parent )
mLayer = NULL;
- setupUi(this);
+ setupUi( this );
-void QgsLineDecorationSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
+void QgsLineDecorationSymbolLayerV2Widget::setSymbolLayer( QgsSymbolLayerV2* layer )
- if (layer->layerType() != "LineDecoration")
+ if ( layer->layerType() != "LineDecoration" )
return;
- mLayer = static_cast<QgsLineDecorationSymbolLayerV2*>(layer);
+ mLayer = static_cast<QgsLineDecorationSymbolLayerV2*>( layer );
// set values
QgsSymbolLayerV2* QgsLineDecorationSymbolLayerV2Widget::symbolLayer()
@@ -501,10 +501,10 @@
void QgsLineDecorationSymbolLayerV2Widget::colorChanged()
return;
emit changed();
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbolv2selectordialog.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -15,96 +15,96 @@
#include <QInputDialog>
#include <QKeyEvent>
-QgsSymbolV2SelectorDialog::QgsSymbolV2SelectorDialog(QgsSymbolV2* symbol, QgsStyleV2* style, QWidget* parent, bool embedded)
- : QDialog(parent)
+QgsSymbolV2SelectorDialog::QgsSymbolV2SelectorDialog( QgsSymbolV2* symbol, QgsStyleV2* style, QWidget* parent, bool embedded )
+ : QDialog( parent )
mStyle = style;
mSymbol = symbol;
- setupUi(this);
+ setupUi( this );
// can be embedded in renderer properties dialog
- if (embedded)
+ if ( embedded )
buttonBox->hide();
- layout()->setContentsMargins(0,0,0,0);
+ layout()->setContentsMargins( 0, 0, 0, 0 );
- connect(btnSymbolProperties, SIGNAL(clicked()), this, SLOT(changeSymbolProperties()));
+ connect( btnSymbolProperties, SIGNAL( clicked() ), this, SLOT( changeSymbolProperties() ) );
- QStandardItemModel* model = new QStandardItemModel(viewSymbols);
- viewSymbols->setModel(model);
- connect(viewSymbols, SIGNAL(clicked(const QModelIndex &)), this, SLOT(setSymbolFromStyle(const QModelIndex &)));
+ QStandardItemModel* model = new QStandardItemModel( viewSymbols );
+ viewSymbols->setModel( model );
+ connect( viewSymbols, SIGNAL( clicked( const QModelIndex & ) ), this, SLOT( setSymbolFromStyle( const QModelIndex & ) ) );
populateSymbolView();
updateSymbolPreview();
updateSymbolInfo();
// select correct page in stacked widget
// there's a correspondence between symbol type number and page numbering => exploit it!
- stackedWidget->setCurrentIndex(symbol->type());
- connect(btnColorMarker, SIGNAL(clicked()), this, SLOT(setSymbolColor()));
- connect(btnColorLine, SIGNAL(clicked()), this, SLOT(setSymbolColor()));
- connect(btnColorFill, SIGNAL(clicked()), this, SLOT(setSymbolColor()));
- connect(spinAngle, SIGNAL(valueChanged(double)), this, SLOT(setMarkerAngle(double)));
- connect(spinSize, SIGNAL(valueChanged(double)), this, SLOT(setMarkerSize(double)));
- connect(spinWidth, SIGNAL(valueChanged(double)), this, SLOT(setLineWidth(double)));
+ stackedWidget->setCurrentIndex( symbol->type() );
- connect(btnAddToStyle, SIGNAL(clicked()), this, SLOT(addSymbolToStyle()));
+ connect( btnColorMarker, SIGNAL( clicked() ), this, SLOT( setSymbolColor() ) );
+ connect( btnColorLine, SIGNAL( clicked() ), this, SLOT( setSymbolColor() ) );
+ connect( btnColorFill, SIGNAL( clicked() ), this, SLOT( setSymbolColor() ) );
+ connect( spinAngle, SIGNAL( valueChanged( double ) ), this, SLOT( setMarkerAngle( double ) ) );
+ connect( spinSize, SIGNAL( valueChanged( double ) ), this, SLOT( setMarkerSize( double ) ) );
+ connect( spinWidth, SIGNAL( valueChanged( double ) ), this, SLOT( setLineWidth( double ) ) );
+ connect( btnAddToStyle, SIGNAL( clicked() ), this, SLOT( addSymbolToStyle() ) );
btnSymbolProperties->setIcon( QIcon( QgsApplication::defaultThemePath() + "mActionOptions.png" ) );
btnAddToStyle->setIcon( QIcon( QgsApplication::defaultThemePath() + "symbologyAdd.png" ) );
void QgsSymbolV2SelectorDialog::populateSymbolView()
QSize previewSize = viewSymbols->iconSize();
- QPixmap p(previewSize);
+ QPixmap p( previewSize );
QPainter painter;
- QStandardItemModel* model = qobject_cast<QStandardItemModel*>(viewSymbols->model());
- if (!model)
+ QStandardItemModel* model = qobject_cast<QStandardItemModel*>( viewSymbols->model() );
+ if ( !model )
return;
model->clear();
QStringList names = mStyle->symbolNames();
- for (int i = 0; i < names.count(); i++)
+ for ( int i = 0; i < names.count(); i++ )
- QgsSymbolV2* s = mStyle->symbol(names[i]);
- if (s->type() != mSymbol->type())
+ QgsSymbolV2* s = mStyle->symbol( names[i] );
+ if ( s->type() != mSymbol->type() )
delete s;
continue;
- QStandardItem* item = new QStandardItem(names[i]);
- item->setFlags(Qt::ItemIsEnabled | Qt::ItemIsSelectable);
+ QStandardItem* item = new QStandardItem( names[i] );
+ item->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
// create preview icon
- QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon(s, previewSize);
- item->setIcon(icon);
+ QIcon icon = QgsSymbolLayerV2Utils::symbolPreviewIcon( s, previewSize );
+ item->setIcon( icon );
// add to model
- model->appendRow(item);
+ model->appendRow( item );
delete s;
-void QgsSymbolV2SelectorDialog::setSymbolFromStyle(const QModelIndex & index)
+void QgsSymbolV2SelectorDialog::setSymbolFromStyle( const QModelIndex & index )
QString symbolName = index.data().toString();
// get new instance of symbol from style
- QgsSymbolV2* s = mStyle->symbol(symbolName);
+ QgsSymbolV2* s = mStyle->symbol( symbolName );
// remove all symbol layers from original symbol
- while (mSymbol->symbolLayerCount())
- mSymbol->deleteSymbolLayer(0);
+ while ( mSymbol->symbolLayerCount() )
+ mSymbol->deleteSymbolLayer( 0 );
// move all symbol layers to our symbol
- while (s->symbolLayerCount())
+ while ( s->symbolLayerCount() )
- QgsSymbolLayerV2* sl = s->takeSymbolLayer(0);
- mSymbol->appendSymbolLayer(sl);
+ QgsSymbolLayerV2* sl = s->takeSymbolLayer( 0 );
+ mSymbol->appendSymbolLayer( sl );
// delete the temporary symbol
delete s;
updateSymbolInfo();
emit symbolModified();
@@ -113,40 +113,40 @@
void QgsSymbolV2SelectorDialog::updateSymbolPreview()
QImage preview = mSymbol->bigSymbolPreviewImage();
- lblPreview->setPixmap(QPixmap::fromImage(preview));
+ lblPreview->setPixmap( QPixmap::fromImage( preview ) );
void QgsSymbolV2SelectorDialog::updateSymbolColor()
QColor c = mSymbol->color();
- btnColorMarker->setColor(c);
- btnColorLine->setColor(c);
- btnColorFill->setColor(c);
+ btnColorMarker->setColor( c );
+ btnColorLine->setColor( c );
+ btnColorFill->setColor( c );
void QgsSymbolV2SelectorDialog::updateSymbolInfo()
updateSymbolColor();
- if (mSymbol->type() == QgsSymbolV2::Marker)
+ if ( mSymbol->type() == QgsSymbolV2::Marker )
- QgsMarkerSymbolV2* markerSymbol = static_cast<QgsMarkerSymbolV2*>(mSymbol);
- spinSize->setValue(markerSymbol->size());
- spinAngle->setValue(markerSymbol->angle());
+ QgsMarkerSymbolV2* markerSymbol = static_cast<QgsMarkerSymbolV2*>( mSymbol );
+ spinSize->setValue( markerSymbol->size() );
+ spinAngle->setValue( markerSymbol->angle() );
- else if (mSymbol->type() == QgsSymbolV2::Line)
+ else if ( mSymbol->type() == QgsSymbolV2::Line )
- QgsLineSymbolV2* lineSymbol = static_cast<QgsLineSymbolV2*>(mSymbol);
- spinWidth->setValue(lineSymbol->width());
+ QgsLineSymbolV2* lineSymbol = static_cast<QgsLineSymbolV2*>( mSymbol );
+ spinWidth->setValue( lineSymbol->width() );
void QgsSymbolV2SelectorDialog::changeSymbolProperties()
- QgsSymbolV2PropertiesDialog dlg(mSymbol, this);
- if (!dlg.exec())
+ QgsSymbolV2PropertiesDialog dlg( mSymbol, this );
return;
updateSymbolInfo();
@@ -155,42 +155,42 @@
void QgsSymbolV2SelectorDialog::setSymbolColor()
- QColor color = QColorDialog::getColor(mSymbol->color(), this);
+ QColor color = QColorDialog::getColor( mSymbol->color(), this );
return;
- mSymbol->setColor(color);
+ mSymbol->setColor( color );
-void QgsSymbolV2SelectorDialog::setMarkerAngle(double angle)
+void QgsSymbolV2SelectorDialog::setMarkerAngle( double angle )
- if (markerSymbol->angle() == angle)
+ if ( markerSymbol->angle() == angle )
return;
- markerSymbol->setAngle(angle);
+ markerSymbol->setAngle( angle );
-void QgsSymbolV2SelectorDialog::setMarkerSize(double size)
+void QgsSymbolV2SelectorDialog::setMarkerSize( double size )
- if (markerSymbol->size() == size)
+ if ( markerSymbol->size() == size )
return;
- markerSymbol->setSize(size);
+ markerSymbol->setSize( size );
-void QgsSymbolV2SelectorDialog::setLineWidth(double width)
+void QgsSymbolV2SelectorDialog::setLineWidth( double width )
- if (lineSymbol->width() == width)
+ if ( lineSymbol->width() == width )
return;
- lineSymbol->setWidth(width);
+ lineSymbol->setWidth( width );
@@ -198,13 +198,13 @@
void QgsSymbolV2SelectorDialog::addSymbolToStyle()
bool ok;
- QString name = QInputDialog::getText(this, "Symbol name",
- "Please enter name for the symbol:", QLineEdit::Normal, "New symbol", &ok);
- if (!ok || name.isEmpty())
+ QString name = QInputDialog::getText( this, "Symbol name",
+ "Please enter name for the symbol:", QLineEdit::Normal, "New symbol", &ok );
+ if ( !ok || name.isEmpty() )
return;
// add new symbol to style and re-populate the list
- mStyle->addSymbol(name, mSymbol->clone());
+ mStyle->addSymbol( name, mSymbol->clone() );
// make sure the symbol is stored
mStyle->save();
@@ -221,6 +221,6 @@
else
- QDialog::keyPressEvent(e);
+ QDialog::keyPressEvent( e );
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-11-18 20:51:28 UTC (rev 12177)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-11-18 20:58:09 UTC (rev 12178)
@@ -308,7 +308,7 @@
case LayerSettings::Curved: arrangement = P_CURVED; break;
case LayerSettings::Horizontal: arrangement = P_HORIZ; break;
case LayerSettings::Free: arrangement = P_FREE; break;
- default: Q_ASSERT( "unsupported placement" && 0 ); return 0; break;
+ default: Q_ASSERT( "unsupported placement" && 0 ); return 0; break;
// create the pal layer
@@ -367,7 +367,7 @@
SearchMethod s;
switch ( mSearch )
- default:
+ default:
case Chain: s = CHAIN; break;
case Popmusic_Tabu: s = POPMUSIC_TABU; break;
case Popmusic_Chain: s = POPMUSIC_CHAIN; break;
