[QGIS Commit] r12193 - trunk/qgis/src/core/symbology-ng
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Nov 19 09:43:44 EST 2009
Author: wonder
Date: 2009-11-19 09:43:43 -0500 (Thu, 19 Nov 2009)
New Revision: 12193
   trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp
Do transformation of coordinates in symbology-ng if on-the-fly projections are turned on
Modified: trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp	2009-11-19 14:42:26 UTC (rev 12192)
+++ trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp	2009-11-19 14:43:43 UTC (rev 12193)
@@ -18,37 +18,47 @@
-static unsigned char* _getPoint(QPointF& pt, const QgsMapToPixel& mapToPixel, unsigned char* wkb)
+static unsigned char* _getPoint( QPointF& pt, QgsRenderContext& context, unsigned char* wkb )
   wkb++; // jump over endian info
   unsigned int wkbType = *(( int* ) wkb );
-  wkb += sizeof(unsigned int);
-  double x = *(( double * ) wkb ); wkb += sizeof(double);
-  double y = *(( double * ) wkb ); wkb += sizeof(double);
+  wkb += sizeof( unsigned int );
+  double x = *(( double * ) wkb ); wkb += sizeof( double );
+  double y = *(( double * ) wkb ); wkb += sizeof( double );
   if ( wkbType == QGis::WKBPolygon25D )
-    wkb += sizeof(double);
-  mapToPixel.transformInPlace(x,y);
-  // TODO: coordinate transform
-  pt = QPointF(x,y);
+    wkb += sizeof( double );
+  if ( context.coordinateTransform() )
+    double z = 0; // dummy variable for coordiante transform
+    context.coordinateTransform()->transformInPlace( x, y, z );
+  context.mapToPixel().transformInPlace( x, y );
+  pt = QPointF( x, y );
   return wkb;
-static unsigned char* _getLineString(QPolygonF& pts, const QgsMapToPixel& mapToPixel, unsigned char* wkb)
+static unsigned char* _getLineString( QPolygonF& pts, QgsRenderContext& context, unsigned char* wkb )
   unsigned int nPoints = *(( int* ) wkb );
   bool hasZValue = ( wkbType == QGis::WKBLineString25D );
-  double x,y;
+  double x, y;
-  pts.resize(nPoints);
+  pts.resize( nPoints );
+  const QgsCoordinateTransform* ct = context.coordinateTransform();
+  const QgsMapToPixel& mtp = context.mapToPixel();
   for ( unsigned int i = 0; i < nPoints; ++i )
@@ -58,195 +68,203 @@
     if ( hasZValue ) // ignore Z value
-    pts[i] = QPointF(x,y);
+    // TODO: maybe to the transform at once (faster?)
+    if ( ct )
+      ct->transformInPlace( x, y, z );
+    mtp.transformInPlace( x, y );
+    pts[i] = QPointF( x, y );
   return wkb;
-static unsigned char* _getPolygon(QPolygonF& pts, QList<QPolygonF>& holes, const QgsMapToPixel& mapToPixel, unsigned char* wkb)
+static unsigned char* _getPolygon( QPolygonF& pts, QList<QPolygonF>& holes, QgsRenderContext& context, unsigned char* wkb )
-  wkb += sizeof(unsigned int); // jump over wkb type
+  wkb += sizeof( unsigned int ); // jump over wkb type
   unsigned int numRings = *(( int* ) wkb );
   if ( numRings == 0 )  // sanity check for zero rings in polygon
     return wkb;
   bool hasZValue = ( wkbType == QGis::WKBPolygon25D );
-  double x,y;
+  double x, y;
   holes.clear();
   for ( unsigned int idx = 0; idx < numRings; idx++ )
     unsigned int nPoints = *(( int* )wkb );
-    QPolygonF poly(nPoints);
+    QPolygonF poly( nPoints );
     // Extract the points from the WKB and store in a pair of vectors.
     for ( unsigned int jdx = 0; jdx < nPoints; jdx++ )
-      poly[jdx] = QPointF(x,y);
+      if ( ct )
+      poly[jdx] = QPointF( x, y );
       if ( hasZValue )
     if ( nPoints < 1 )
       continue;
-    if (idx == 0)
+    if ( idx == 0 )
       pts = poly;
     else
-      holes.append(poly);
+      holes.append( poly );
   return wkb;
-QgsFeatureRendererV2::QgsFeatureRendererV2(QString type)
-  : mType(type), mUsingSymbolLevels(false)
+QgsFeatureRendererV2::QgsFeatureRendererV2( QString type )
+    : mType( type ), mUsingSymbolLevels( false )
-QgsFeatureRendererV2* QgsFeatureRendererV2::defaultRenderer(QGis::GeometryType geomType)
+QgsFeatureRendererV2* QgsFeatureRendererV2::defaultRenderer( QGis::GeometryType geomType )
-  return new QgsSingleSymbolRendererV2( QgsSymbolV2::defaultSymbol(geomType) );
+  return new QgsSingleSymbolRendererV2( QgsSymbolV2::defaultSymbol( geomType ) );
-void QgsFeatureRendererV2::renderFeature(QgsFeature& feature, QgsRenderContext& context, int layer)
+void QgsFeatureRendererV2::renderFeature( QgsFeature& feature, QgsRenderContext& context, int layer )
-  QgsSymbolV2* symbol = symbolForFeature(feature);
-  if (symbol == NULL)
+  QgsSymbolV2* symbol = symbolForFeature( feature );
+  if ( symbol == NULL )
     return;
   QgsSymbolV2::SymbolType symbolType = symbol->type();
   QgsGeometry* geom = feature.geometry();
-  switch (geom->wkbType())
+  switch ( geom->wkbType() )
     case QGis::WKBPoint:
+      if ( symbolType != QgsSymbolV2::Marker )
-        if (symbolType != QgsSymbolV2::Marker)
-          QgsDebugMsg("point can be drawn only with marker symbol!");
-          break;
-        QPointF pt;
-        _getPoint(pt, context.mapToPixel(), geom->asWkb());
-        ((QgsMarkerSymbolV2*)symbol)->renderPoint(pt, context, layer);
+        QgsDebugMsg( "point can be drawn only with marker symbol!" );
+        break;
-      break;
+      QPointF pt;
+      _getPoint( pt, context, geom->asWkb() );
+      (( QgsMarkerSymbolV2* )symbol )->renderPoint( pt, context, layer );
+    break;
     case QGis::WKBLineString:
+      if ( symbolType != QgsSymbolV2::Line )
-        if (symbolType != QgsSymbolV2::Line)
-          QgsDebugMsg("linestring can be drawn only with line symbol!");
-          break;
-        QPolygonF pts;
-        _getLineString(pts, context.mapToPixel(), geom->asWkb());
-        ((QgsLineSymbolV2*)symbol)->renderPolyline(pts, context, layer);
+        QgsDebugMsg( "linestring can be drawn only with line symbol!" );
+        break;
-      break;
+      QPolygonF pts;
+      _getLineString( pts, context, geom->asWkb() );
+      (( QgsLineSymbolV2* )symbol )->renderPolyline( pts, context, layer );
+    break;
     case QGis::WKBPolygon:
+      if ( symbolType != QgsSymbolV2::Fill )
-        if (symbolType != QgsSymbolV2::Fill)
-          QgsDebugMsg("polygon can be drawn only with fill symbol!");
-          break;
-        QPolygonF pts;
-        QList<QPolygonF> holes;
-        _getPolygon(pts, holes, context.mapToPixel(), geom->asWkb());
-        ((QgsFillSymbolV2*)symbol)->renderPolygon(pts, (holes.count() ? &holes : NULL), context, layer);
+        QgsDebugMsg( "polygon can be drawn only with fill symbol!" );
+        break;
-      break;
+      QPolygonF pts;
+      QList<QPolygonF> holes;
+      _getPolygon( pts, holes, context, geom->asWkb() );
+      (( QgsFillSymbolV2* )symbol )->renderPolygon( pts, ( holes.count() ? &holes : NULL ), context, layer );
+    break;
     case QGis::WKBMultiPoint:
-          QgsDebugMsg("multi-point can be drawn only with marker symbol!");
-          break;
-        unsigned char* wkb = geom->asWkb();
-        unsigned int num = *(( int* )(wkb + 5) );
-        unsigned char* ptr = wkb + 9;
-        QPointF pt;
-        for (unsigned int i = 0; i < num; ++i)
-          ptr = _getPoint(pt, context.mapToPixel(), ptr);
+        QgsDebugMsg( "multi-point can be drawn only with marker symbol!" );
+        break;
-      break;
+      unsigned char* wkb = geom->asWkb();
+      unsigned int num = *(( int* )( wkb + 5 ) );
+      unsigned char* ptr = wkb + 9;
+      QPointF pt;
+      for ( unsigned int i = 0; i < num; ++i )
+        ptr = _getPoint( pt, context, ptr );
+    break;
     case QGis::WKBMultiLineString:
-          QgsDebugMsg("multi-linestring can be drawn only with line symbol!");
-          break;
-        QPolygonF pts;
-          ptr = _getLineString(pts, context.mapToPixel(), ptr);
+        QgsDebugMsg( "multi-linestring can be drawn only with line symbol!" );
+        break;
-      break;
+      QPolygonF pts;
+        ptr = _getLineString( pts, context, ptr );
+    break;
     case QGis::WKBMultiPolygon:
-          QgsDebugMsg("multi-polygon can be drawn only with fill symbol!");
-          break;
-        QPolygonF pts;
-          ptr = _getPolygon(pts, holes, context.mapToPixel(), ptr);
+        QgsDebugMsg( "multi-polygon can be drawn only with fill symbol!" );
+        break;
-      break;
+      QPolygonF pts;
+        ptr = _getPolygon( pts, holes, context, ptr );
+    break;
     default:
-      QgsDebugMsg("unsupported wkb type for rendering");
+      QgsDebugMsg( "unsupported wkb type for rendering" );
@@ -256,32 +274,32 @@
-QgsFeatureRendererV2* QgsFeatureRendererV2::load(QDomElement& element)
+QgsFeatureRendererV2* QgsFeatureRendererV2::load( QDomElement& element )
   // <renderer-v2 type=""> ... </renderer-v2>
-  if (element.isNull())
+  if ( element.isNull() )
     return NULL;
   // load renderer
-  QString rendererType = element.attribute("type");
+  QString rendererType = element.attribute( "type" );
-  QgsRendererV2CreateFunc pfCreate = QgsRendererV2Registry::instance()->rendererMetadata(rendererType).createFunction();
+  QgsRendererV2CreateFunc pfCreate = QgsRendererV2Registry::instance()->rendererMetadata( rendererType ).createFunction();
   // unknown renderer type?
-  if (pfCreate == NULL)
+  if ( pfCreate == NULL )
     return NULL;
-  return pfCreate(element);
+  return pfCreate( element );
-QDomElement QgsFeatureRendererV2::save(QDomDocument& doc)
+QDomElement QgsFeatureRendererV2::save( QDomDocument& doc )
   // create empty renderer element
-  return doc.createElement(RENDERER_TAG_NAME);
+  return doc.createElement( RENDERER_TAG_NAME );
-QgsLegendSymbologyList QgsFeatureRendererV2::legendSymbologyItems(QSize iconSize)
+QgsLegendSymbologyList QgsFeatureRendererV2::legendSymbologyItems( QSize iconSize )
   // empty list by default
   return QgsLegendSymbologyList();
More information about the QGIS-commit mailing list
