[QGIS Commit] r12200 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Thu Nov 19 15:26:45 EST 2009
Author: timlinux
Date: 2009-11-19 15:26:42 -0500 (Thu, 19 Nov 2009)
New Revision: 12200
trunk/qgis/src/ui/qgsoptionsbase.ui
Layout fixes for options dialog
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-11-19 20:13:43 UTC (rev 12199)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-11-19 20:26:42 UTC (rev 12200)
@@ -6,7 +6,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>833</width>
+ <width>813</width>
<height>532</height>
</rect>
</property>
@@ -66,7 +66,7 @@
</item>
<item row="0" column="1">
<widget class="QStackedWidget" name="stackedWidget">
- <widget class="QWidget" name="stackedWidgetPage1" native="true">
+ <widget class="QWidget" name="stackedWidgetPage1">
<layout class="QGridLayout">
<property name="margin">
<number>0</number>
@@ -266,7 +266,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage2" native="true">
+ <widget class="QWidget" name="stackedWidgetPage2">
<number>0</number>
@@ -414,7 +414,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage3" native="true">
+ <widget class="QWidget" name="stackedWidgetPage3">
<number>0</number>
@@ -635,7 +635,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage4" native="true">
+ <widget class="QWidget" name="stackedWidgetPage4">
<number>0</number>
@@ -687,7 +687,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage5" native="true">
+ <widget class="QWidget" name="stackedWidgetPage5">
<number>0</number>
@@ -984,7 +984,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage6" native="true">
+ <widget class="QWidget" name="stackedWidgetPage6">
<number>0</number>
@@ -1015,13 +1015,23 @@
<item row="0" column="0">
<widget class="QGroupBox" name="grpProjectionBehaviour">
<property name="title">
- <string>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</string>
+ <string>Default Coordinate Reference System</string>
</property>
<layout class="QVBoxLayout">
<number>11</number>
</property>
<item>
+ <widget class="QLabel" name="label_8">
+ <property name="text">
+ <string>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</string>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QRadioButton" name="radPromptForProjection">
<string>Prompt for CRS</string>
@@ -1047,7 +1057,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage7" native="true">
+ <widget class="QWidget" name="stackedWidgetPage7">
<number>0</number>
@@ -1115,7 +1125,7 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="stackedWidgetPage8" native="true">
+ <widget class="QWidget" name="stackedWidgetPage8">
<layout class="QGridLayout" name="gridLayout_2">
<number>0</number>
