[QGIS Commit] r12212 - trunk/qgis/src/plugins/oracle_raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 20 15:35:28 EST 2009
Author: timlinux
Date: 2009-11-20 15:35:26 -0500 (Fri, 20 Nov 2009)
New Revision: 12212
   trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui
Dont use form layout use grid layout (for  #2121)
Modified: trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui
--- trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui	2009-11-20 20:32:11 UTC (rev 12211)
+++ trunk/qgis/src/plugins/oracle_raster/qgsoracleconnectbase.ui	2009-11-20 20:35:26 UTC (rev 12212)
@@ -7,7 +7,7 @@
     <x>0</x>
     <y>0</y>
     <width>318</width>
-    <height>177</height>
+    <height>213</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -18,7 +18,7 @@
     <normaloff/>
    </iconset>
   </property>
-  <layout class="QFormLayout" name="formLayout">
+  <layout class="QGridLayout" name="gridLayout">
    <item row="0" column="0">
     <widget class="QLabel" name="TextLabel1_2">
      <property name="text">
@@ -79,13 +79,6 @@
      </property>
     </widget>
    </item>
-   <item row="6" column="0" colspan="2">
-    <widget class="QDialogButtonBox" name="buttonBox">
-     <property name="standardButtons">
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
    <item row="4" column="1">
     <widget class="QCheckBox" name="chkStorePassword">
@@ -93,6 +86,13 @@
      </property>
     </widget>
    </item>
+   <item row="5" column="0" colspan="2">
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
More information about the QGIS-commit mailing list
