[QGIS Commit] r12223 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sun Nov 22 16:26:15 EST 2009
Author: macho
Date: 2009-11-22 16:26:12 -0500 (Sun, 22 Nov 2009)
New Revision: 12223
trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui
fixed not working close button in sqlite ui
Modified: trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui
--- trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui 2009-11-22 16:12:39 UTC (rev 12222)
+++ trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui 2009-11-22 21:26:12 UTC (rev 12223)
@@ -107,6 +107,9 @@
<property name="text">
<string>Search:</string>
</property>
+ <property name="buddy">
+ <cstring>mSearchTableEdit</cstring>
+ </property>
</widget>
</item>
<item row="2" column="0" colspan="2">
@@ -114,6 +117,9 @@
<string>Search mode:</string>
</property>
+ <cstring>mSearchModeComboBox</cstring>
+ </property>
</widget>
</item>
<item row="2" column="2">
@@ -124,6 +130,9 @@
<string>Search in columns:</string>
</property>
+ <cstring>mSearchColumnComboBox</cstring>
+ </property>
</widget>
</item>
<item row="1" column="2">
@@ -157,7 +166,30 @@
<tabstop>btnConnect</tabstop>
<tabstop>btnNew</tabstop>
<tabstop>btnDelete</tabstop>
+ <tabstop>mTablesTreeView</tabstop>
+ <tabstop>mSearchOptionsButton</tabstop>
+ <tabstop>mSearchTableEdit</tabstop>
+ <tabstop>mSearchColumnComboBox</tabstop>
+ <tabstop>mSearchModeComboBox</tabstop>
+ <tabstop>buttonBox</tabstop>
</tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>rejected()</signal>
+ <receiver>QgsSpatiaLiteSourceSelectBase</receiver>
+ <slot>reject()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>630</x>
+ <y>663</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>666</x>
+ <y>562</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
