[QGIS Commit] r12267 - trunk/qgis/src/core
svn_qgis at osgeo.org
Fri Nov 27 04:25:46 EST 2009
Author: mhugent
Date: 2009-11-27 04:25:44 -0500 (Fri, 27 Nov 2009)
New Revision: 12267
trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
better test for 0 objects when using pal diagram placement
Modified: trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
--- trunk/qgis/src/core/qgspalobjectpositionmanager.cpp 2009-11-27 07:56:15 UTC (rev 12266)
+++ trunk/qgis/src/core/qgspalobjectpositionmanager.cpp 2009-11-27 09:25:44 UTC (rev 12267)
@@ -142,11 +142,22 @@
//pal geometry that the current label object refers to
QgsPALGeometry* referredGeometry = 0;
QgsOverlayObject* referredOverlayObject = 0;
+ pal::FeaturePart* referredPart = 0;
std::list<pal::LabelPosition*>::iterator labelIt = resultLabelList->begin();
for ( ; labelIt != resultLabelList->end(); ++labelIt )
- referredGeometry = dynamic_cast<QgsPALGeometry*>(( *labelIt )->getFeaturePart()->getUserGeometry() );
+ if ( !*labelIt )
+ continue;
+ referredPart = ( *labelIt )->getFeaturePart();
+ if ( !referredPart )
+ continue;
+ referredGeometry = dynamic_cast<QgsPALGeometry*>( referredPart->getUserGeometry() );
if ( !referredGeometry )
continue;
@@ -160,8 +171,8 @@
pal::LabelPosition* lp = *labelIt;
//QGIS takes the coordinates of the middle points
- double x = (lp->getX( 0 ) + lp->getX( 1 ) + lp->getX( 2 ) + lp->getX( 3 ) ) / 4;
- double y = (lp->getY( 0 ) + lp->getY( 1 ) + lp->getY( 2 ) + lp->getY( 3 ) ) / 4;
+ double x = ( lp->getX( 0 ) + lp->getX( 1 ) + lp->getX( 2 ) + lp->getX( 3 ) ) / 4;
+ double y = ( lp->getY( 0 ) + lp->getY( 1 ) + lp->getY( 2 ) + lp->getY( 3 ) ) / 4;
referredOverlayObject->addPosition( QgsPoint( x, y ) );
