[QGIS Commit] r12294 - in trunk/qgis: resources/context_help
src/core src/helpviewer
svn_qgis at osgeo.org
Sun Nov 29 17:16:57 EST 2009
Author: timlinux
Date: 2009-11-29 17:16:56 -0500 (Sun, 29 Nov 2009)
New Revision: 12294
trunk/qgis/resources/context_help/QgsOpenVectorLayerDialog-en_US
trunk/qgis/src/core/qgsapplication.cpp
trunk/qgis/src/helpviewer/CMakeLists.txt
trunk/qgis/src/helpviewer/qgshelpviewer.cpp
trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
Switch to using QWebView to allow rich html in help viewer
Modified: trunk/qgis/resources/context_help/QgsOpenVectorLayerDialog-en_US
--- trunk/qgis/resources/context_help/QgsOpenVectorLayerDialog-en_US 2009-11-29 21:59:36 UTC (rev 12293)
+++ trunk/qgis/resources/context_help/QgsOpenVectorLayerDialog-en_US 2009-11-29 22:16:56 UTC (rev 12294)
@@ -1 +1,6 @@
<h3>Open Vector Layer Dialog</h3>
+<p class="overview">
+The open vector layer dialog is used to add vector data to the QGIS map view. Vector data are spatial data described using geometries of points, lines and polygons (enclosed areas).</p>
+<img src=":/themes/default/mActionDelete.png">
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2009-11-29 21:59:36 UTC (rev 12293)
+++ trunk/qgis/src/core/qgsapplication.cpp 2009-11-29 22:16:56 UTC (rev 12294)
@@ -385,6 +385,7 @@
"padding-bottom: 8px;"
"border: 1px solid #6c6c6c;"
+ ".overview{ font: 1.82em; font-weight: bold;}"
"h1 {font-size : 22pt; }"
"h2 {font-size : 18pt; }"
"h3 {font-size : 14pt; }";
Modified: trunk/qgis/src/helpviewer/CMakeLists.txt
--- trunk/qgis/src/helpviewer/CMakeLists.txt 2009-11-29 21:59:36 UTC (rev 12293)
+++ trunk/qgis/src/helpviewer/CMakeLists.txt 2009-11-29 22:16:56 UTC (rev 12294)
@@ -59,6 +59,7 @@
${QT_QTNETWORK_LIBRARY}
${QT_QTSVG_LIBRARY}
${QT_QTXML_LIBRARY}
+ ${QT_QTWEBKIT_LIBRARY}
ENDIF (${QTVERSION} STRLESS "4.3.0")
Modified: trunk/qgis/src/helpviewer/qgshelpviewer.cpp
--- trunk/qgis/src/helpviewer/qgshelpviewer.cpp 2009-11-29 21:59:36 UTC (rev 12293)
+++ trunk/qgis/src/helpviewer/qgshelpviewer.cpp 2009-11-29 22:16:56 UTC (rev 12294)
@@ -151,7 +151,9 @@
file.close();
// Set the browser text to the help contents
- txtBrowser->setHtml( helpContents );
+ QString myStyle = QgsApplication::reportStyleSheet();
+ helpContents = "<head><style>" + myStyle + "</style></head><body>" + helpContents + "</body>";
+ webView->setHtml( helpContents );
setWindowTitle( tr( "Quantum GIS Help" ) );
@@ -179,7 +181,7 @@
// there should only be one row returned
// Set the browser text to the record from the database
- txtBrowser->setText(( char* )sqlite3_column_text( ppStmt, 0 ) );
+ webView->setHtml(( char* )sqlite3_column_text( ppStmt, 0 ) );
setWindowTitle( tr( "Quantum GIS Help - %1" ).arg(( char* )sqlite3_column_text( ppStmt, 1 ) ) );
Modified: trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
--- trunk/qgis/src/helpviewer/qgshelpviewerbase.ui 2009-11-29 21:59:36 UTC (rev 12293)
+++ trunk/qgis/src/helpviewer/qgshelpviewerbase.ui 2009-11-29 22:16:56 UTC (rev 12294)
@@ -21,17 +21,13 @@
<property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <layout class="QGridLayout">
- <property name="margin">
- <number>9</number>
- </property>
- <property name="spacing">
- <number>6</number>
- </property>
+ <layout class="QGridLayout" name="gridLayout">
<item row="0" column="0">
- <widget class="QTextBrowser" name="txtBrowser">
- <property name="acceptDrops">
- <bool>false</bool>
+ <widget class="QWebView" name="webView">
+ <property name="url">
+ <url>
+ <string>about:blank</string>
+ </url>
</property>
</widget>
</item>
@@ -45,6 +41,13 @@
</layout>
</widget>
<layoutdefault spacing="6" margin="11"/>
+ <customwidgets>
+ <customwidget>
+ <class>QWebView</class>
+ <extends>QWidget</extends>
+ <header>QtWebKit/QWebView</header>
+ </customwidget>
+ </customwidgets>
<resources/>
<connections>
<connection>
