[QGIS Commit] r11747 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Oct 3 17:47:14 EDT 2009
Author: timlinux
Date: 2009-10-03 17:47:14 -0400 (Sat, 03 Oct 2009)
New Revision: 11747
   trunk/qgis/src/ui/qgscomposerbase.ui
   trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui
   trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui
   trunk/qgis/src/ui/qgscomposerlegenditemdialogbase.ui
   trunk/qgis/src/ui/qgscomposerlegendwidgetbase.ui
   trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
   trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
   trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
HIG compliance for composer and it's dialogs
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -19,23 +19,8 @@
    <property name="mouseTracking" >
     <bool>true</bool>
    </property>
-   <layout class="QVBoxLayout" >
-    <property name="spacing" >
-     <number>6</number>
-    </property>
-    <property name="leftMargin" >
-     <number>9</number>
-    </property>
-    <property name="topMargin" >
-    </property>
-    <property name="rightMargin" >
-    </property>
-    <property name="bottomMargin" >
-    </property>
-    <item>
+   <layout class="QGridLayout" >
+    <item row="0" column="0" >
      <widget class="QSplitter" name="mSplitter" >
        <bool>true</bool>
@@ -171,51 +156,12 @@
       </widget>
      </widget>
     </item>
-    <item>
-     <layout class="QHBoxLayout" >
+    <item row="1" column="0" >
+     <widget class="QDialogButtonBox" name="buttonBox" >
+      <property name="standardButtons" >
+       <set>QDialogButtonBox::Close|QDialogButtonBox::Help|QDialogButtonBox::NoButton</set>
       </property>
-       <number>0</number>
-      </property>
-      </property>
-      </property>
-      </property>
-      <item>
-       <widget class="QPushButton" name="helpPButton" >
-        <property name="text" >
-         <string>Help</string>
-        </property>
-       </widget>
-      </item>
-      <item>
-       <spacer>
-        <property name="orientation" >
-         <enum>Qt::Horizontal</enum>
-        </property>
-        <property name="sizeHint" >
-         <size>
-          <width>40</width>
-          <height>20</height>
-         </size>
-        </property>
-       </spacer>
-      </item>
-      <item>
-       <widget class="QPushButton" name="closePButton" >
-         <string>Close</string>
-        </property>
-       </widget>
-      </item>
-     </layout>
+     </widget>
     </item>
    </layout>
   </widget>
@@ -502,5 +448,22 @@
   <tabstop>mSplitter</tabstop>
  </tabstops>
  <resources/>
- <connections/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>rejected()</signal>
+   <receiver>QgsComposerBase</receiver>
+   <slot>close()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>612</x>
+     <y>583</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>735</x>
+     <y>567</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
 </ui>
Modified: trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -22,8 +22,11 @@
        <widget class="QLabel" name="mColorLabel" >
-         <string>Color:</string>
+         <string>Color</string>
         </property>
+        <property name="buddy" >
+         <cstring>mFrameColorButton</cstring>
+        </property>
        </widget>
       </item>
       <item row="0" column="1" colspan="2" >
@@ -43,8 +46,11 @@
       <item row="1" column="0" colspan="2" >
        <widget class="QLabel" name="mOpacityLabel" >
-         <string>Opacity:</string>
+         <string>Opacity</string>
         </property>
+         <cstring>mOpacitySlider</cstring>
+        </property>
        </widget>
       </item>
       <item row="1" column="2" colspan="2" >
@@ -60,8 +66,11 @@
       <item row="2" column="0" colspan="2" >
        <widget class="QLabel" name="mOutlineWidthLabel" >
-         <string>Outline width: </string>
+         <string>Outline width</string>
         </property>
+         <cstring>mOutlineWidthSpinBox</cstring>
+        </property>
        </widget>
       </item>
       <item row="2" column="2" colspan="2" >
Modified: trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -42,8 +42,11 @@
    <item row="2" column="0" >
     <widget class="QLabel" name="mMarginTextLabel" >
-      <string>Margin (mm):</string>
+      <string>Margin (mm)</string>
      </property>
+      <cstring>mMarginDoubleSpinBox</cstring>
+     </property>
     </widget>
    </item>
    <item row="2" column="1" >
@@ -53,7 +56,9 @@
  </widget>
  <layoutdefault spacing="6" margin="11" />
  <tabstops>
+  <tabstop>mTextEdit</tabstop>
   <tabstop>mFontButton</tabstop>
+  <tabstop>mMarginDoubleSpinBox</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgscomposerlegenditemdialogbase.ui
--- trunk/qgis/src/ui/qgscomposerlegenditemdialogbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerlegenditemdialogbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -16,8 +16,11 @@
     <widget class="QLabel" name="mItemTextLabel" >
-      <string>Item text:</string>
+      <string>Item text</string>
      </property>
+      <cstring>mItemTextLineEdit</cstring>
+     </property>
     </widget>
    </item>
    <item row="0" column="1" >
@@ -44,8 +47,8 @@
    <slot>accept()</slot>
    <hints>
-     <x>248</x>
-     <y>254</y>
+     <x>257</x>
+     <y>76</y>
     </hint>
      <x>157</x>
@@ -60,8 +63,8 @@
    <slot>reject()</slot>
    <hints>
-     <x>316</x>
-     <y>260</y>
+     <x>325</x>
+     <y>76</y>
     </hint>
      <x>286</x>
Modified: trunk/qgis/src/ui/qgscomposerlegendwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerlegendwidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerlegendwidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -5,8 +5,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>560</width>
-    <height>537</height>
+    <width>520</width>
+    <height>498</height>
    </rect>
   </property>
   <property name="sizePolicy" >
@@ -26,125 +26,130 @@
      </property>
-        <item>
-         <widget class="QLabel" name="mTitleLabel" >
-           <string>Title:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="mTitleLineEdit" />
-        </item>
-       </layout>
+       <widget class="QLabel" name="mTitleLabel" >
+        <property name="text" >
+         <string>Title</string>
+        </property>
+         <cstring>mTitleLineEdit</cstring>
+        </property>
+       </widget>
       </item>
-      <item row="1" column="0" >
-        <item>
-         <widget class="QLabel" name="mFontLabel" >
-           <string>Font:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QPushButton" name="mTitleFontButton" >
-          <property name="sizePolicy" >
-           <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
-            <horstretch>0</horstretch>
-            <verstretch>0</verstretch>
-           </sizepolicy>
-          </property>
-           <string>Title...</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QPushButton" name="mLayerFontButton" >
-           <string>Layer...</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QPushButton" name="mItemFontButton" >
-           <string>Item...</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+      <item row="0" column="1" colspan="8" >
+       <widget class="QLineEdit" name="mTitleLineEdit" />
       </item>
-      <item row="2" column="0" >
-       <layout class="QGridLayout" >
-        <item row="0" column="0" colspan="2" >
-         <widget class="QLabel" name="mSymbolWidthLabel" >
-           <string>Symbol width: </string>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="2" >
-         <widget class="QDoubleSpinBox" name="mSymbolWidthSpinBox" />
-        </item>
-        <item row="0" column="3" colspan="2" >
-         <widget class="QLabel" name="mSymbolHeightLabel" >
-           <string>Symbol height:</string>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="5" >
-         <widget class="QDoubleSpinBox" name="mSymbolHeightSpinBox" />
-        </item>
-         <widget class="QLabel" name="mLayerSpaceLabel" >
-           <string>Layer space: </string>
-          </property>
-         </widget>
-        </item>
-        <item row="1" column="1" colspan="2" >
-         <widget class="QDoubleSpinBox" name="mLayerSpaceSpinBox" />
-        </item>
-        <item row="1" column="3" >
-         <widget class="QLabel" name="mSymbolSpaceLabel" >
-           <string>Symbol space:</string>
-          </property>
-         </widget>
-        </item>
-        <item row="1" column="4" colspan="2" >
-         <widget class="QDoubleSpinBox" name="mSymbolSpaceSpinBox" />
-        </item>
-       </layout>
+      <item row="1" column="0" colspan="3" >
+       <widget class="QLabel" name="mFontLabel" >
+         <string>Font</string>
+        </property>
+       </widget>
       </item>
-      <item row="3" column="0" >
-        <item>
-         <widget class="QLabel" name="mIconLabelSpaceLabel" >
-           <string>Icon label space:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QDoubleSpinBox" name="mIconLabelSpaceSpinBox" />
-        </item>
-        <item>
-         <widget class="QLabel" name="mBoxSpaceLabel" >
-           <string>Box space:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QDoubleSpinBox" name="mBoxSpaceSpinBox" />
-        </item>
-       </layout>
+      <item row="1" column="3" colspan="2" >
+       <widget class="QPushButton" name="mTitleFontButton" >
+        <property name="sizePolicy" >
+         <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+         <string>Title...</string>
+        </property>
+       </widget>
       </item>
+      <item row="1" column="5" colspan="2" >
+       <widget class="QPushButton" name="mLayerFontButton" >
+         <string>Layer...</string>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="7" colspan="2" >
+       <widget class="QPushButton" name="mItemFontButton" >
+         <string>Item...</string>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="0" colspan="4" >
+       <widget class="QLabel" name="mSymbolWidthLabel" >
+         <string>Symbol width</string>
+        </property>
+         <cstring>mSymbolWidthSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="4" >
+       <widget class="QDoubleSpinBox" name="mSymbolWidthSpinBox" />
+      </item>
+      <item row="2" column="5" colspan="3" >
+       <widget class="QLabel" name="mSymbolHeightLabel" >
+         <string>Symbol height</string>
+        </property>
+         <cstring>mSymbolHeightSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="8" >
+       <widget class="QDoubleSpinBox" name="mSymbolHeightSpinBox" />
+      </item>
+      <item row="3" column="0" colspan="2" >
+       <widget class="QLabel" name="mLayerSpaceLabel" >
+         <string>Layer space</string>
+        </property>
+         <cstring>mLayerSpaceSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2" colspan="3" >
+       <widget class="QDoubleSpinBox" name="mLayerSpaceSpinBox" />
+      </item>
+      <item row="3" column="5" >
+       <widget class="QLabel" name="mSymbolSpaceLabel" >
+         <string>Symbol space</string>
+        </property>
+         <cstring>mSymbolSpaceSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="6" colspan="3" >
+       <widget class="QDoubleSpinBox" name="mSymbolSpaceSpinBox" />
+      </item>
+      <item row="4" column="0" colspan="3" >
+       <widget class="QLabel" name="mIconLabelSpaceLabel" >
+         <string>Icon label space</string>
+        </property>
+         <cstring>mIconLabelSpaceSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="4" column="3" colspan="2" >
+       <widget class="QDoubleSpinBox" name="mIconLabelSpaceSpinBox" />
+      </item>
+      <item row="4" column="5" colspan="2" >
+       <widget class="QLabel" name="mBoxSpaceLabel" >
+         <string>Box space</string>
+        </property>
+         <cstring>mBoxSpaceSpinBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="4" column="7" colspan="2" >
+       <widget class="QDoubleSpinBox" name="mBoxSpaceSpinBox" />
+      </item>
      </layout>
     </widget>
    </item>
@@ -154,55 +159,55 @@
       <string>Legend items</string>
      </property>
-      <item row="0" column="0" >
+      <item row="0" column="0" colspan="6" >
+       <widget class="QTreeView" name="mItemTreeView" >
+        <property name="headerHidden" stdset="0" >
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
        <widget class="QPushButton" name="mMoveDownPushButton" >
-         <string>down</string>
+         <string>Down</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="1" >
+      <item row="1" column="1" >
        <widget class="QPushButton" name="mMoveUpPushButton" >
-         <string>up</string>
+         <string>Up</string>
         </property>
        </widget>
       </item>
+      <item row="1" column="2" >
        <widget class="QPushButton" name="mRemovePushButton" >
-         <string>remove</string>
+         <string>Remove</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="3" >
+      <item row="1" column="3" >
        <widget class="QPushButton" name="mEditPushButton" >
-         <string>edit...</string>
+         <string>Edit...</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="4" >
+      <item row="1" column="4" >
        <widget class="QPushButton" name="mUpdatePushButton" >
-         <string>update</string>
+         <string>Update</string>
         </property>
        </widget>
       </item>
+      <item row="1" column="5" >
        <widget class="QPushButton" name="mUpdateAllPushButton" >
-         <string>update all</string>
+         <string>Update all</string>
         </property>
        </widget>
       </item>
-      <item row="1" column="0" colspan="6" >
-       <widget class="QTreeView" name="mItemTreeView" >
-        <property name="headerHidden" stdset="0" >
-         <bool>true</bool>
-        </property>
-       </widget>
-      </item>
      </layout>
     </widget>
    </item>
@@ -210,7 +215,23 @@
  </widget>
  <tabstops>
+  <tabstop>mTitleLineEdit</tabstop>
   <tabstop>mTitleFontButton</tabstop>
+  <tabstop>mLayerFontButton</tabstop>
+  <tabstop>mItemFontButton</tabstop>
+  <tabstop>mSymbolWidthSpinBox</tabstop>
+  <tabstop>mSymbolHeightSpinBox</tabstop>
+  <tabstop>mLayerSpaceSpinBox</tabstop>
+  <tabstop>mSymbolSpaceSpinBox</tabstop>
+  <tabstop>mIconLabelSpaceSpinBox</tabstop>
+  <tabstop>mBoxSpaceSpinBox</tabstop>
+  <tabstop>mItemTreeView</tabstop>
+  <tabstop>mMoveDownPushButton</tabstop>
+  <tabstop>mMoveUpPushButton</tabstop>
+  <tabstop>mRemovePushButton</tabstop>
+  <tabstop>mEditPushButton</tabstop>
+  <tabstop>mUpdatePushButton</tabstop>
+  <tabstop>mUpdateAllPushButton</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposermapwidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposermapwidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -1,8 +1,7 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
+<ui version="4.0" >
  <class>QgsComposerMapWidgetBase</class>
- <widget class="QWidget" name="QgsComposerMapWidgetBase">
-  <property name="geometry">
+ <widget class="QWidget" name="QgsComposerMapWidgetBase" >
+  <property name="geometry" >
    <rect>
     <x>0</x>
     <y>0</y>
@@ -10,175 +9,157 @@
     <height>374</height>
    </rect>
   </property>
-  <property name="sizePolicy">
-   <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+   <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
    </sizepolicy>
   </property>
-  <property name="windowTitle">
+  <property name="windowTitle" >
    <string>Map options</string>
   </property>
-  <layout class="QGridLayout" name="gridLayout">
-   <item row="0" column="0">
-    <widget class="QLabel" name="mNameLabel">
-     <property name="text">
-      <string>&lt;b&gt;Map&lt;/b&gt;</string>
+   <item row="0" column="0" colspan="3" >
+    <widget class="QGroupBox" name="groupBox" >
+     <property name="title" >
+      <string>Map</string>
      </property>
+       <widget class="QLabel" name="textLabel1" >
+         <string>Width</string>
+        </property>
+        <property name="wordWrap" >
+         <bool>true</bool>
+        </property>
+         <cstring>mWidthLineEdit</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="2" >
+       <widget class="QLineEdit" name="mWidthLineEdit" />
+      </item>
+       <widget class="QLabel" name="textLabel2" >
+         <string>Height</string>
+        </property>
+         <bool>true</bool>
+        </property>
+         <cstring>mHeightLineEdit</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="mHeightLineEdit" />
+      </item>
+      <item row="2" column="0" >
+       <widget class="QLabel" name="label_2" >
+         <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+         </sizepolicy>
+        </property>
+         <string>Scale</string>
+        </property>
+         <bool>true</bool>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" >
+       <widget class="QLabel" name="label" >
+         <string>1:</string>
+        </property>
+        <property name="alignment" >
+         <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="2" >
+       <widget class="QLineEdit" name="mScaleLineEdit" >
+        <property name="inputMask" >
+         <string/>
+        </property>
+       </widget>
+      </item>
+     </layout>
     </widget>
    </item>
-   <item row="1" column="0" colspan="5">
-    <widget class="Line" name="line1">
-     <property name="frameShape">
-      <enum>QFrame::HLine</enum>
-     </property>
-     <property name="frameShadow">
-      <enum>QFrame::Sunken</enum>
-     </property>
-     <property name="orientation">
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="0">
-    <widget class="QLabel" name="textLabel1">
-      <string>Width</string>
-     </property>
-     <property name="wordWrap">
-      <bool>true</bool>
-     </property>
-     <property name="buddy">
-      <cstring>mWidthLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="3">
-    <widget class="QLineEdit" name="mWidthLineEdit"/>
-   </item>
-   <item row="3" column="0">
-    <widget class="QLabel" name="textLabel2">
-      <string>Height</string>
-     </property>
-      <bool>true</bool>
-     </property>
-      <cstring>mHeightLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="3" column="3">
-    <widget class="QLineEdit" name="mHeightLineEdit"/>
-   </item>
-   <item row="4" column="0">
-    <widget class="QLabel" name="label_2">
-      <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
-      </sizepolicy>
-     </property>
-      <string>Scale:</string>
-     </property>
-      <bool>true</bool>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="1" colspan="2">
-    <widget class="QLabel" name="label">
-      <string>1:</string>
-     </property>
-     <property name="alignment">
-      <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="3">
-    <widget class="QLineEdit" name="mScaleLineEdit"/>
-   </item>
-   <item row="5" column="0" colspan="5">
-    <widget class="QGroupBox" name="mMapExtentGroupBox">
-     <property name="title">
+    <widget class="QGroupBox" name="mMapExtentGroupBox" >
       <string>Map extent</string>
      </property>
-     <layout class="QGridLayout">
-       <layout class="QVBoxLayout">
-        <item>
-         <widget class="QLabel" name="mXMinLabel">
-          <property name="enabled">
-           <bool>true</bool>
-          </property>
-           <string>X min:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLabel" name="mYMinLabel">
-           <string>Y min:</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+       <widget class="QLabel" name="mXMinLabel" >
+        <property name="enabled" >
+         <bool>true</bool>
+        </property>
+         <string>X min</string>
+        </property>
+         <cstring>mXMinLineEdit</cstring>
+        </property>
+       </widget>
       </item>
-      <item row="0" column="1" colspan="2">
-        <item>
-         <widget class="QLineEdit" name="mXMinLineEdit"/>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="mYMinLineEdit"/>
-        </item>
-       </layout>
+      <item row="0" column="1" >
+       <widget class="QLineEdit" name="mXMinLineEdit" />
       </item>
-      <item row="0" column="3">
-        <item>
-         <widget class="QLabel" name="mXMaxLabel">
-           <string>X max:</string>
-          </property>
-         </widget>
-        </item>
-        <item>
-         <widget class="QLabel" name="mYMaxLabel">
-           <string>Y max:</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
+       <widget class="QLabel" name="mXMaxLabel" >
+         <string>X max</string>
+        </property>
+         <cstring>mXMaxLineEdit</cstring>
+        </property>
+       </widget>
       </item>
-      <item row="0" column="4">
-        <item>
-         <widget class="QLineEdit" name="mXMaxLineEdit"/>
-        </item>
-        <item>
-         <widget class="QLineEdit" name="mYMaxLineEdit"/>
-        </item>
-       </layout>
+      <item row="0" column="3" colspan="2" >
+       <widget class="QLineEdit" name="mXMaxLineEdit" />
       </item>
-      <item row="1" column="0" colspan="2">
-       <widget class="QPushButton" name="mSetToMapCanvasExtentButton">
-         <string>set to map canvas extent</string>
+       <widget class="QLabel" name="mYMinLabel" >
+         <string>Y min</string>
         </property>
+         <cstring>mYMinLineEdit</cstring>
+        </property>
        </widget>
       </item>
-      <item row="1" column="2" colspan="3">
+       <widget class="QLineEdit" name="mYMinLineEdit" />
+      </item>
+       <widget class="QLabel" name="mYMaxLabel" >
+         <string>Y max</string>
+        </property>
+         <cstring>mYMaxLineEdit</cstring>
+        </property>
+       </widget>
+      </item>
+       <widget class="QLineEdit" name="mYMaxLineEdit" />
+      </item>
        <spacer>
+        <property name="orientation" >
         </property>
-        <property name="sizeHint" stdset="0">
+        <property name="sizeHint" >
          <size>
           <width>311</width>
           <height>20</height>
@@ -186,52 +167,59 @@
         </property>
        </spacer>
       </item>
+       <widget class="QPushButton" name="mSetToMapCanvasExtentButton" >
+         <string>Set to map canvas extent</string>
+        </property>
+       </widget>
+      </item>
      </layout>
     </widget>
    </item>
-   <item row="6" column="0" colspan="2">
-    <widget class="QLabel" name="mPreviewModeLabel">
+    <widget class="QLabel" name="mPreviewModeLabel" >
       <string>Preview</string>
      </property>
       <bool>true</bool>
      </property>
       <cstring>mPreviewModeComboBox</cstring>
      </property>
     </widget>
    </item>
-   <item row="6" column="3">
-    <widget class="QComboBox" name="mPreviewModeComboBox">
-      <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+    <widget class="QComboBox" name="mPreviewModeComboBox" >
+      <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
       </sizepolicy>
      </property>
     </widget>
    </item>
-   <item row="6" column="4">
-    <widget class="QPushButton" name="mUpdatePreviewButton">
+    <widget class="QPushButton" name="mUpdatePreviewButton" >
       <string>Update preview</string>
      </property>
     </widget>
    </item>
-   <item row="7" column="0" colspan="4">
-    <widget class="QCheckBox" name="mKeepLayerListCheckBox">
+    <widget class="QCheckBox" name="mKeepLayerListCheckBox" >
       <string>Keep layer list</string>
      </property>
     </widget>
    </item>
-   <item row="8" column="2" colspan="3">
+   <item row="4" column="1" colspan="2" >
     <spacer>
       <enum>Qt::Vertical</enum>
      </property>
       <size>
        <width>458</width>
        <height>31</height>
@@ -241,11 +229,19 @@
    </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11"/>
+ <layoutdefault spacing="6" margin="11" />
  <tabstops>
   <tabstop>mWidthLineEdit</tabstop>
   <tabstop>mHeightLineEdit</tabstop>
+  <tabstop>mScaleLineEdit</tabstop>
+  <tabstop>mXMinLineEdit</tabstop>
+  <tabstop>mXMaxLineEdit</tabstop>
+  <tabstop>mYMinLineEdit</tabstop>
+  <tabstop>mYMaxLineEdit</tabstop>
+  <tabstop>mSetToMapCanvasExtentButton</tabstop>
   <tabstop>mPreviewModeComboBox</tabstop>
+  <tabstop>mUpdatePreviewButton</tabstop>
+  <tabstop>mKeepLayerListCheckBox</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -19,7 +19,7 @@
    <string>Picture Options</string>
   </property>
+   <item row="0" column="0" colspan="4" >
     <widget class="QGroupBox" name="mSearchDirectoriesGroupBox" >
@@ -31,12 +31,22 @@
       <string>Search directories</string>
      </property>
+       <widget class="QComboBox" name="mSearchDirectoriesComboBox" >
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
        <spacer>
         </property>
-        <property name="sizeHint" stdset="0" >
          <size>
           <width>101</width>
           <height>20</height>
@@ -44,34 +54,24 @@
         </property>
        </spacer>
       </item>
        <widget class="QPushButton" name="mAddDirectoryButton" >
          <string>Add...</string>
         </property>
        </widget>
       </item>
        <widget class="QPushButton" name="mRemoveDirectoryButton" >
         </property>
        </widget>
       </item>
-      <item row="1" column="0" colspan="3" >
-       <widget class="QComboBox" name="mSearchDirectoriesComboBox" >
-         <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
      </layout>
     </widget>
    </item>
+   <item row="1" column="0" colspan="4" >
     <widget class="QGroupBox" name="mPreviewGroupBox" >
@@ -89,7 +89,7 @@
          <bool>false</bool>
         </property>
         <property name="dragDropMode" >
-         <enum>QAbstractItemView::NoDragDrop</enum>
+         <enum>QAbstractItemView::DragDrop</enum>
         </property>
         <property name="movement" >
          <enum>QListView::Free</enum>
@@ -118,104 +118,116 @@
     </widget>
    </item>
+      <string>Load</string>
      </property>
-     <property name="margin" >
+      <cstring>mPictureLineEdit</cstring>
      </property>
-     <item>
-      <widget class="QLineEdit" name="mPictureLineEdit" />
-     </item>
-     <item>
-      <widget class="QPushButton" name="mPictureBrowseButton" >
-        </sizepolicy>
-       </property>
-       <property name="maximumSize" >
-        <size>
-         <width>150</width>
-         <height>32767</height>
-        </size>
-       </property>
-        <string>Browse...</string>
-       </property>
-      </widget>
-     </item>
-    </layout>
+    </widget>
    </item>
+   <item row="2" column="1" colspan="2" >
+    <widget class="QLineEdit" name="mPictureLineEdit" />
+   </item>
+   <item row="2" column="3" >
+    <widget class="QPushButton" name="mPictureBrowseButton" >
+      </sizepolicy>
+     </property>
+     <property name="maximumSize" >
+      <size>
+       <width>150</width>
+       <height>32767</height>
+      </size>
+     </property>
+      <string>...</string>
+     </property>
+    </widget>
+   </item>
-      <widget class="QLabel" name="textLabel3" >
-        <sizepolicy vsizetype="Preferred" hsizetype="Minimum" >
-        </sizepolicy>
-       </property>
-        <string>Width:</string>
-       </property>
-       <property name="wordWrap" >
-        <bool>true</bool>
-       </property>
-      </widget>
-     </item>
-     <item row="0" column="1" colspan="2" >
-      <widget class="QLineEdit" name="mWidthLineEdit" />
-     </item>
-      <widget class="QLabel" name="textLabel4" >
-        </sizepolicy>
-       </property>
-        <string>Height:</string>
-       </property>
-        <bool>true</bool>
-       </property>
-      </widget>
-     </item>
-      <widget class="QLineEdit" name="mHeightLineEdit" />
-     </item>
-     <item row="2" column="0" colspan="2" >
-      <widget class="QLabel" name="mRotationLabel" >
-        </sizepolicy>
-       </property>
-        <string>Rotation:</string>
-       </property>
-        <bool>true</bool>
-       </property>
-      </widget>
-     </item>
-     <item row="2" column="2" >
-      <widget class="QDoubleSpinBox" name="mRotationSpinBox" />
-     </item>
-    </layout>
+    <widget class="QLabel" name="textLabel3" >
+      <sizepolicy vsizetype="Preferred" hsizetype="Minimum" >
+      </sizepolicy>
+     </property>
+     </property>
+      <bool>true</bool>
+     </property>
+     </property>
+    </widget>
    </item>
+   <item row="3" column="1" colspan="3" >
+   </item>
+   <item row="4" column="0" >
+    <widget class="QLabel" name="textLabel4" >
+      </sizepolicy>
+     </property>
+     </property>
+      <bool>true</bool>
+     </property>
+     </property>
+    </widget>
+   </item>
+   <item row="4" column="1" colspan="3" >
+   </item>
+   <item row="5" column="0" colspan="2" >
+    <widget class="QLabel" name="mRotationLabel" >
+      </sizepolicy>
+     </property>
+      <string>Rotation</string>
+     </property>
+      <bool>true</bool>
+     </property>
+      <cstring>mRotationSpinBox</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="5" column="2" colspan="2" >
+    <widget class="QDoubleSpinBox" name="mRotationSpinBox" />
+   </item>
   </layout>
  </widget>
  <tabstops>
+  <tabstop>mSearchDirectoriesComboBox</tabstop>
+  <tabstop>mAddDirectoryButton</tabstop>
+  <tabstop>mRemoveDirectoryButton</tabstop>
+  <tabstop>mPreviewListWidget</tabstop>
+  <tabstop>mPictureLineEdit</tabstop>
   <tabstop>mPictureBrowseButton</tabstop>
-  <tabstop>mPictureLineEdit</tabstop>
+  <tabstop>mWidthLineEdit</tabstop>
+  <tabstop>mHeightLineEdit</tabstop>
+  <tabstop>mRotationSpinBox</tabstop>
  </tabstops>
  <resources/>
  <connections/>
Modified: trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2009-10-03 20:44:45 UTC (rev 11746)
+++ trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2009-10-03 21:47:14 UTC (rev 11747)
@@ -22,11 +22,14 @@
     <widget class="QLabel" name="mSegmentSizeLabel" >
-      <string>Segment size (map units):</string>
+      <string>Segment size (map units)</string>
      </property>
       <bool>true</bool>
      </property>
+      <cstring>mSegmentSizeSpinBox</cstring>
+     </property>
     </widget>
    </item>
@@ -42,11 +45,14 @@
    <item row="0" column="2" colspan="2" >
     <widget class="QLabel" name="mMapUnitsPerBarUnitLabel" >
-      <string>Map units per bar unit:</string>
+      <string>Map units per bar unit</string>
      </property>
       <bool>true</bool>
      </property>
+      <cstring>mMapUnitsPerBarUnitSpinBox</cstring>
+     </property>
     </widget>
    </item>
@@ -59,11 +65,14 @@
     <widget class="QLabel" name="mNumbereOfSegmentsLabel" >
-      <string>Number of segments:</string>
+      <string>Number of segments</string>
      </property>
       <bool>true</bool>
      </property>
+      <cstring>mNumberOfSegmentsSpinBox</cstring>
+     </property>
     </widget>
    </item>
@@ -72,8 +81,11 @@
     <widget class="QLabel" name="mSegmentsLeftLabel" >
-      <string>Segments left:</string>
+      <string>Segments left</string>
      </property>
+      <cstring>mSegmentsLeftSpinBox</cstring>
+     </property>
     </widget>
    </item>
@@ -82,8 +94,11 @@
     <widget class="QLabel" name="mStyleLabel" >
-      <string>Style:</string>
+      <string>Style</string>
      </property>
+      <cstring>mStyleComboBox</cstring>
+     </property>
     </widget>
    </item>
@@ -98,7 +113,7 @@
       </sizepolicy>
      </property>
-      <string>Map:</string>
      </property>
       <bool>true</bool>
@@ -124,8 +139,11 @@
     <widget class="QLabel" name="mHeightLabel" >
-      <string>Height (mm):</string>
+      <string>Height (mm)</string>
      </property>
+      <cstring>mHeightSpinBox</cstring>
+     </property>
     </widget>
    </item>
    <item row="3" column="1" >
@@ -134,7 +152,7 @@
    <item row="3" column="2" colspan="2" >
     <widget class="QLabel" name="mLineWidthLabel" >
-      <string>Line width:</string>
+      <string>Line width</string>
      </property>
       <bool>true</bool>
@@ -166,8 +184,11 @@
     <widget class="QLabel" name="mLabelBarSpaceLabel" >
-      <string>Label space:</string>
+      <string>Label space</string>
      </property>
+      <cstring>mLabelBarSpaceSpinBox</cstring>
+     </property>
     </widget>
    </item>
    <item row="4" column="1" >
@@ -176,8 +197,11 @@
    <item row="4" column="2" colspan="2" >
      </property>
+      <cstring>mBoxSizeSpinBox</cstring>
+     </property>
     </widget>
    </item>
    <item row="4" column="4" >
@@ -186,7 +210,7 @@
    <item row="5" column="0" >
     <widget class="QLabel" name="mUnitLabelLabel" >
-      <string>Unit label:</string>
+      <string>Unit label</string>
      </property>
       <bool>true</bool>
@@ -223,9 +247,19 @@
  </widget>
  <tabstops>
+  <tabstop>mSegmentSizeSpinBox</tabstop>
+  <tabstop>mMapUnitsPerBarUnitSpinBox</tabstop>
+  <tabstop>mNumberOfSegmentsSpinBox</tabstop>
+  <tabstop>mSegmentsLeftSpinBox</tabstop>
+  <tabstop>mStyleComboBox</tabstop>
+  <tabstop>mMapComboBox</tabstop>
+  <tabstop>mHeightSpinBox</tabstop>
+  <tabstop>mLineWidthSpinBox</tabstop>
+  <tabstop>mLabelBarSpaceSpinBox</tabstop>
+  <tabstop>mBoxSizeSpinBox</tabstop>
   <tabstop>mUnitLabelLineEdit</tabstop>
-  <tabstop>mMapComboBox</tabstop>
+  <tabstop>mColorPushButton</tabstop>
  </tabstops>
  <resources/>
  <connections/>
More information about the QGIS-commit mailing list
