[QGIS Commit] r11754 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Sun Oct 4 08:12:02 EDT 2009
Author: borysiasty
Date: 2009-10-04 08:12:01 -0400 (Sun, 04 Oct 2009)
New Revision: 11754
trunk/qgis/python/plugins/plugin_installer/LICENSE
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
plugin installer update: handle ports != 80 and add Bob Bruce's repository
Modified: trunk/qgis/python/plugins/plugin_installer/LICENSE
--- trunk/qgis/python/plugins/plugin_installer/LICENSE 2009-10-03 23:04:37 UTC (rev 11753)
+++ trunk/qgis/python/plugins/plugin_installer/LICENSE 2009-10-04 12:12:01 UTC (rev 11754)
@@ -1,5 +1,5 @@
Copyright (c) 2007 Matthew T. Perry
-Copyright (c) 2008 Borys Jurgiel
+Copyright (c) 2008-2009 Borys Jurgiel
Permission is hereby granted, free of charge, to any person obtaining a copy of
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-10-03 23:04:37 UTC (rev 11753)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-10-04 12:12:01 UTC (rev 11754)
@@ -14,7 +14,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.3"
+ return "Version 1.0.4"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-10-03 23:04:37 UTC (rev 11753)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-10-04 12:12:01 UTC (rev 11754)
@@ -29,7 +29,7 @@
"valid" bool,
"QPHttp" QPHttp,
"Relay" Relay, # Relay object for transmitting signals from QPHttp with adding the repoName information
- "xmlData" QDomDocument,
+ "xmlData" QBuffer,
"state" int, (0 - disabled, 1-loading, 2-loaded ok, 3-error (to be retried), 4-rejected)
"error" QString}}
mPlugins = dict of dicts {id : {"name" QString,
@@ -87,6 +87,7 @@
("Volkan Kepoglu's Repository","http://ggit.metu.edu.tr/~volkan/plugins.xml", ""),
("GIS-Lab Repository", "http://gis-lab.info/programs/qgis/qgis-repo.xml", ""),
("Marco Hugentobler's Repository","http://karlinapp.ethz.ch/python_plugins/python_plugins.xml", ""),
+ ("Bob Bruce's Repository", "http://www.mappinggeek.ca/QGISPythonPlugins/Bobs-QGIS-plugins.xml", ""),
("Sourcepole Repository", "http://build.sourcepole.ch/qgis/plugins.xml", "")]
@@ -376,7 +377,10 @@
self.mRepositories[key]["state"] = 1
url = QUrl(self.mRepositories[key]["url"])
path = QString(url.toPercentEncoding(url.path(), "!$&'()*+,;=:@/"))
- self.mRepositories[key]["QPHttp"] = QPHttp(url.host())
+ port = url.port()
+ if port < 0:
+ port = 80
+ self.mRepositories[key]["QPHttp"] = QPHttp(url.host(), port)
self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("requestFinished (int, bool)"), self.xmlDownloaded)
self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("stateChanged ( int )"), self.mRepositories[key]["Relay"].stateChanged)
self.connect(self.mRepositories[key]["QPHttp"], SIGNAL("dataReadProgress ( int , int )"), self.mRepositories[key]["Relay"].dataReadProgress)
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-10-03 23:04:37 UTC (rev 11753)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-10-04 12:12:01 UTC (rev 11754)
@@ -152,7 +152,10 @@
tmpDir = QDir.tempPath()
tmpPath = QDir.cleanPath(tmpDir+"/"+fileName)
self.file = QFile(tmpPath)
- self.http = QPHttp(url.host())
+ port = url.port()
+ if port < 0:
+ port = 80
+ self.http = QPHttp(url.host(), port)
self.connect(self.http, SIGNAL("stateChanged ( int )"), self.stateChanged)
self.connect(self.http, SIGNAL("dataReadProgress ( int , int )"), self.readProgress)
self.connect(self.http, SIGNAL("requestFinished (int, bool)"), self.requestFinished)
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-10-03 23:04:37 UTC (rev 11753)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-10-04 12:12:01 UTC (rev 11754)
@@ -187,4 +187,4 @@
def resetNewlyProcessedPlugins(self):
""" clear the dict of newly processed plugins """
- history.clear()
+ history.clear()
\ No newline at end of file
