[QGIS Commit] r11767 - in trunk/qgis: i18n src/app
src/providers/postgres
svn_qgis at osgeo.org
Thu Oct 8 07:53:10 EDT 2009
Author: jef
Date: 2009-10-08 07:53:09 -0400 (Thu, 08 Oct 2009)
New Revision: 11767
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/app/qgsdbtablemodel.cpp
trunk/qgis/src/app/qgspgsourceselect.cpp
trunk/qgis/src/app/qgspgsourceselect.h
trunk/qgis/src/app/qgsquerybuilder.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
postgres fixes:
- allow editing of where clause in database selection dialog
- don't open query builder with invalid layer
- reallow oid type as primary key type
- preset where clause with current one in query builder
- actually show error message when QgsPostgresProvider::getGeometryDetails() fails
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/i18n/qgis_de.ts 2009-10-08 11:53:09 UTC (rev 11767)
@@ -17347,7 +17347,7 @@
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2899"/>
<source>Unable to get feature type and srid</source>
- <translation>Kann den Fearture-Typ und die SRID nicht ermitteln</translation>
+ <translation>Kann den Objekttyp und die SRID nicht ermitteln</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2188"/>
Modified: trunk/qgis/src/app/qgsdbtablemodel.cpp
--- trunk/qgis/src/app/qgsdbtablemodel.cpp 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/src/app/qgsdbtablemodel.cpp 2009-10-08 11:53:09 UTC (rev 11767)
@@ -73,7 +73,7 @@
pkItem->setData( pkCols );
pkItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable );
QStandardItem* sqlItem = new QStandardItem( sql );
- sqlItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
+ sqlItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable );
childItemList.push_back( schemaNameItem );
childItemList.push_back( tableItem );
Modified: trunk/qgis/src/app/qgspgsourceselect.cpp
--- trunk/qgis/src/app/qgspgsourceselect.cpp 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/src/app/qgspgsourceselect.cpp 2009-10-08 11:53:09 UTC (rev 11767)
@@ -67,7 +67,7 @@
mTablesTreeView->setEditTriggers( QAbstractItemView::CurrentChanged );
- mTablesTreeView->setItemDelegateForColumn( QgsDbTableModel::dbtmPkCol, new QgsPgSourceSelectDelegate( this ) );
+ mTablesTreeView->setItemDelegate( new QgsPgSourceSelectDelegate( this ) );
QSettings settings;
mTablesTreeView->setSelectionMode( settings.value( "/qgis/addPostgisDC", false ).toBool() ?
@@ -325,9 +325,9 @@
uri += QString( " table=\"%1\".\"%2\" (%3) sql=%4" )
- .arg( schemaName ).arg( tableName )
- .arg( geomColumnName )
- .arg( sql );
+ .arg( schemaName ).arg( tableName )
+ .arg( geomColumnName )
+ .arg( sql );
return uri;
@@ -341,7 +341,7 @@
QModelIndexList::const_iterator selected_it = selectedIndices.constBegin();
for ( ; selected_it != selectedIndices.constEnd(); ++selected_it )
- if ( !selected_it->parent().isValid() || selected_it->column()>0 )
+ if ( !selected_it->parent().isValid() || selected_it->column() > 0 )
//top level items only contain the schema names
continue;
@@ -501,18 +501,23 @@
void QgsPgSourceSelect::setSql( const QModelIndex &index )
- QgsDebugMsg( QString("%1,%2").arg( index.row() ).arg( index.column() ) );
if ( !index.parent().isValid() )
QgsDebugMsg( "schema item found" );
return;
QgsVectorLayer *vlayer = new QgsVectorLayer( layerURI( mProxyModel.mapToSource( index ) ), "querybuilder", "postgres" );
+ if ( !vlayer->isValid() )
+ delete vlayer;
+ return;
// create a query builder object
QgsQueryBuilder *gb = new QgsQueryBuilder( vlayer, this );
- if( gb->exec() )
+ if ( gb->exec() )
mTableModel.setSql( mProxyModel.mapToSource( index ), gb->sql() );
@@ -537,7 +542,7 @@
QStringList cols;
cols << QString::null;
- QString sql = QString( "select attname from pg_attribute join pg_type on atttypid=pg_type.oid WHERE pg_type.typname='int4' AND attrelid=regclass('\"%1\".\"%2\"')" ).arg( schemaName ).arg( viewName );
+ QString sql = QString( "select attname from pg_attribute join pg_type on atttypid=pg_type.oid WHERE pg_type.typname IN ('int4','oid') AND attrelid=regclass('\"%1\".\"%2\"')" ).arg( schemaName ).arg( viewName );
QgsDebugMsg( sql );
PGresult *colRes = PQexec( pg, sql.toUtf8() );
@@ -614,7 +619,7 @@
as = type = "WAITING";
- mTableModel.addTableEntry( type, schemaName, tableName, column, relkind=="v" ? pkCandidates( pg, schemaName, tableName ) : QStringList(), "" );
+ mTableModel.addTableEntry( type, schemaName, tableName, column, relkind == "v" ? pkCandidates( pg, schemaName, tableName ) : QStringList(), "" );
n++;
@@ -694,7 +699,7 @@
addSearchGeometryColumn( schema, table, column );
//details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
- mTableModel.addTableEntry( "Waiting", schema, table, column, relkind=="v" ? pkCandidates( pg, schema, table ) : QStringList(), "" );
+ mTableModel.addTableEntry( "Waiting", schema, table, column, relkind == "v" ? pkCandidates( pg, schema, table ) : QStringList(), "" );
n++;
Modified: trunk/qgis/src/app/qgspgsourceselect.h
--- trunk/qgis/src/app/qgspgsourceselect.h 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/src/app/qgspgsourceselect.h 2009-10-08 11:53:09 UTC (rev 11767)
@@ -1,5 +1,5 @@
- qgdbsourceselect.h - description
+ qgpgsourceselect.h - description
begin : Sat Jun 22 2002
copyright : (C) 2002 by Gary E.Sherman
@@ -53,13 +53,25 @@
const QStyleOptionViewItem &option,
const QModelIndex &index ) const
- QStringList values = index.data( Qt::UserRole + 1 ).toStringList();
+ if ( index.column() == QgsDbTableModel::dbtmSql )
+ QLineEdit *le = new QLineEdit( parent );
+ le->setText( index.data( Qt::DisplayRole ).toString() );
+ return le;
- if( values.size()> 0 )
+ if ( index.column() == QgsDbTableModel::dbtmPkCol )
- QComboBox *cb = new QComboBox( parent );
- cb->addItems( values );
- return cb;
+ QStringList values = index.data( Qt::UserRole + 1 ).toStringList();
+ if ( values.size() > 0 )
+ QComboBox *cb = new QComboBox( parent );
+ cb->addItems( values );
+ cb->setCurrentIndex( cb->findText( index.data( Qt::DisplayRole ).toString() ) );
+ return cb;
return NULL;
@@ -68,9 +80,12 @@
void setModelData( QWidget *editor, QAbstractItemModel *model, const QModelIndex &index ) const
QComboBox *cb = dynamic_cast<QComboBox *>( editor );
- if ( !cb )
- return;
- model->setData( index, cb->currentText() );
+ if ( cb )
+ model->setData( index, cb->currentText() );
+ QLineEdit *le = dynamic_cast<QLineEdit *>( editor );
+ if ( le )
+ model->setData( index, le->text() );
Modified: trunk/qgis/src/app/qgsquerybuilder.cpp
--- trunk/qgis/src/app/qgsquerybuilder.cpp 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/src/app/qgsquerybuilder.cpp 2009-10-08 11:53:09 UTC (rev 11767)
@@ -39,6 +39,8 @@
mOrigSubsetString = layer->subsetString();
lblDataUri->setText( layer->publicSource() );
+ txtSQL->setText( mOrigSubsetString );
populateFields();
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-10-07 17:47:34 UTC (rev 11766)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-10-08 11:53:09 UTC (rev 11767)
@@ -1054,11 +1054,16 @@
Result result = connectionRO->PQexec( sql );
- if ( PQresultStatus( result ) != PGRES_TUPLES_OK ||
- PQntuples( result ) != 1 ||
- QString( PQgetvalue( result, 0, 0 ) ) != "int4" ||
- !uniqueData( mSchemaName, mTableName, primaryKey ) )
+ QString type;
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK &&
+ PQntuples( result ) == 1 )
+ type = PQgetvalue( result, 0, 0 );
+ if (( type != "int4" && type != "oid" ) ||
+ !uniqueData( mSchemaName, mTableName, primaryKey ) )
primaryKey = "";
@@ -2901,8 +2906,10 @@
else // something went wrong...
- log.prepend( tr( "Qgis was unable to determine the type and srid of column %1 in %2. The database communication log was:\n" )
- .arg( geometryColumn ).arg( mSchemaTableName ) );
+ log.prepend( tr( "Qgis was unable to determine the type and srid of column %1 in %2. The database communication log was:\n%3" )
+ .arg( geometryColumn )
+ .arg( mSchemaTableName )
+ .arg( QString::fromUtf8( PQresultErrorMessage( result ) ) ) );
showMessageBox( tr( "Unable to get feature type and srid" ), log );
