[QGIS Commit] r11773 - trunk/qgis/python/core
svn_qgis at osgeo.org
Thu Oct 8 12:10:36 EDT 2009
Author: jef
Date: 2009-10-08 12:10:36 -0400 (Thu, 08 Oct 2009)
New Revision: 11773
trunk/qgis/python/core/conversions.sip
fix #1959
Modified: trunk/qgis/python/core/conversions.sip
--- trunk/qgis/python/core/conversions.sip 2009-10-08 16:08:20 UTC (rev 11772)
+++ trunk/qgis/python/core/conversions.sip 2009-10-08 16:10:36 UTC (rev 11773)
@@ -79,17 +79,17 @@
for (int i = 0; i < PyList_GET_SIZE(sipPy); ++i)
int state;
- //TYPE *t = reinterpret_cast<TYPE *>(sipConvertToInstance(PyList_GET_ITEM(sipPy, i), sipClass_TYPE, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
+ //TYPE *t = reinterpret_cast<TYPE *>(sipConvertToInstance(PyList_GET_ITEM(sipPy, i), (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
QVector<TYPE> * t = reinterpret_cast< QVector<TYPE> * >(sipConvertToMappedType(PyList_GET_ITEM(sipPy, i), qvector_qgspoint, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
if (*sipIsErr)
- sipReleaseInstance(t, sipClass_TYPE, state);
+ sipReleaseInstance(t, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), state);
delete ql;
return 0;
ql->append(*t);
*sipCppPtr = ql;
@@ -155,17 +155,17 @@
int state;
QVector<QVector<TYPE> > * t = reinterpret_cast< QVector< QVector<TYPE> > * >(sipConvertToMappedType(PyList_GET_ITEM(sipPy, i), qvector_qgspoint, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
if (*sipIsErr)
delete ql;
return 0;
ql->append(*t);
*sipCppPtr = ql;
@@ -245,7 +245,7 @@
TYPE *t = new TYPE(*it);
PyObject *tobj;
- if ((tobj = sipConvertFromNewInstance(t, sipClass_TYPE, sipTransferObj)) == NULL)
+ if ((tobj = sipConvertFromNewInstance(t, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), sipTransferObj)) == NULL)
Py_DECREF(l);
delete t;
@@ -265,7 +265,7 @@
return 0;
- if (!sipCanConvertToInstance(PyList_GET_ITEM(sipPy, i), sipClass_TYPE, SIP_NOT_NONE))
+ if (!sipCanConvertToInstance(PyList_GET_ITEM(sipPy, i), (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), SIP_NOT_NONE))
return 0;
return 1;
@@ -276,16 +276,16 @@
int state;
- TYPE* t = reinterpret_cast<TYPE *>(sipConvertToInstance(PyList_GET_ITEM(sipPy, i), sipClass_TYPE, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
+ TYPE* t = reinterpret_cast<TYPE *>(sipConvertToInstance(PyList_GET_ITEM(sipPy, i), (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
if (*sipIsErr)
delete qset;
return 0;
qset->insert(*t);
*sipCppPtr = qset;
@@ -366,7 +366,7 @@
Py_ssize_t j = 0;
while (PyDict_Next(tobj, &j, &kobj2, &tobj2))
- if (!sipCanConvertToInstance(tobj2, sipClass_TYPE, SIP_NOT_NONE))
+ if (!sipCanConvertToInstance(tobj2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), SIP_NOT_NONE))
return 0;
@@ -393,17 +393,17 @@
int k2 = PyInt_AsLong(kobj2);
int state;
- TYPE* fa = reinterpret_cast<TYPE*>(sipConvertToInstance(tobj2, sipClass_TYPE, sipTransferObj,SIP_NOT_NONE,&state,sipIsErr));
+ TYPE* fa = reinterpret_cast<TYPE*>(sipConvertToInstance(tobj2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), sipTransferObj,SIP_NOT_NONE,&state,sipIsErr));
if (*sipIsErr)
- sipReleaseInstance(tobj2, sipClass_TYPE, state);
+ sipReleaseInstance(tobj2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE), state);
delete qm;
return 0;
qm2.insert(k2, *fa);
qm->insert(k, qm2);
@@ -434,7 +434,7 @@
QString *t1 = new QString(i.key());
- PyObject *t1obj = sipConvertFromNewInstance(t1, sipClass_QString, sipTransferObj);
+ PyObject *t1obj = sipConvertFromNewInstance(t1, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QString), sipTransferObj);
PyObject *t2obj = PyInt_FromLong( (long) i.value() );
if (t1obj == NULL || t2obj == NULL || PyDict_SetItem(d, t1obj, t2obj) < 0)
@@ -480,7 +480,7 @@
while (PyDict_Next(sipPy, &i, &t1obj, &t2obj))
- if (!sipCanConvertToInstance(t1obj, sipClass_QString, SIP_NOT_NONE))
+ if (!sipCanConvertToInstance(t1obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QString), SIP_NOT_NONE))
return 0;
@@ -493,19 +493,19 @@
int state;
- QString *t1 = reinterpret_cast<QString *>(sipConvertToInstance(t1obj, sipClass_QString, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
+ QString *t1 = reinterpret_cast<QString *>(sipConvertToInstance(t1obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QString), sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
QVariant::Type t2 = (QVariant::Type) PyInt_AsLong(t1obj);
if (*sipIsErr)
- sipReleaseInstance(t1, sipClass_QString, state);
+ sipReleaseInstance(t1, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QString), state);
delete qm;
return 0;
qm->insert(*t1, t2);
*sipCppPtr = qm;
@@ -536,8 +536,8 @@
TYPE1 *t1 = new TYPE1(i.key());
TYPE2 *t2 = i.value();
- PyObject *t1obj = sipConvertFromNewInstance(t1, sipClass_TYPE1, sipTransferObj);
- PyObject *t2obj = sipConvertFromInstance(t2, sipClass_TYPE2, sipTransferObj);
+ PyObject *t1obj = sipConvertFromNewInstance(t1, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE1), sipTransferObj);
+ PyObject *t2obj = sipConvertFromInstance(t2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE2), sipTransferObj);
@@ -581,10 +581,10 @@
- if (!sipCanConvertToInstance(t1obj, sipClass_TYPE1, SIP_NOT_NONE))
+ if (!sipCanConvertToInstance(t1obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE1), SIP_NOT_NONE))
return 0;
- if (!sipCanConvertToInstance(t2obj, sipClass_TYPE2, SIP_NOT_NONE))
+ if (!sipCanConvertToInstance(t2obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE2), SIP_NOT_NONE))
return 0;
@@ -597,13 +597,13 @@
int state1, state2;
- TYPE1 *t1 = reinterpret_cast<TYPE1 *>(sipConvertToInstance(t1obj, sipClass_TYPE1, sipTransferObj, SIP_NOT_NONE, &state1, sipIsErr));
- TYPE2 *t2 = reinterpret_cast<TYPE2 *>(sipConvertToInstance(t2obj, sipClass_TYPE2, sipTransferObj, SIP_NOT_NONE, &state2, sipIsErr));
+ TYPE1 *t1 = reinterpret_cast<TYPE1 *>(sipConvertToInstance(t1obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE1), sipTransferObj, SIP_NOT_NONE, &state1, sipIsErr));
+ TYPE2 *t2 = reinterpret_cast<TYPE2 *>(sipConvertToInstance(t2obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE2), sipTransferObj, SIP_NOT_NONE, &state2, sipIsErr));
if (*sipIsErr)
- sipReleaseInstance(t1, sipClass_TYPE1, state1);
- sipReleaseInstance(t2, sipClass_TYPE2, state2);
+ sipReleaseInstance(t1, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE1), state1);
+ sipReleaseInstance(t2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE2), state2);
delete qm;
return 0;
@@ -611,8 +611,8 @@
*sipCppPtr = qm;
@@ -644,7 +644,7 @@
const double t1 = i.key();
TYPE2 * t2 = &i.value();
PyObject *t1obj = PyFloat_FromDouble(t1);
if (PyDict_GetItem(d, t1obj) == NULL) {
PyObject *lst = PyList_New(0);
PyDict_SetItem(d, t1obj, lst);
@@ -697,7 +697,7 @@
for (int i = 0; i < PyList_GET_SIZE(t2obj); ++i) {
if (!sipCanConvertToInstance(PyList_GET_ITEM(t2obj, i),
- sipClass_TYPE2, SIP_NOT_NONE))
+ (sipWrapperType *) sipTypeAsPyTypeObject (sipType_TYPE2), SIP_NOT_NONE))
return 0;
@@ -714,7 +714,7 @@
TYPE2 *t2 =
reinterpret_cast<TYPE2 *>(sipConvertToInstance(PyList_GET_ITEM(t2obj,
i),
- sipClass_TYPE2,
sipTransferObj,
SIP_NOT_NONE,
&state2,
@@ -722,7 +722,7 @@
if (*sipIsErr)
delete qm;
return 0;
@@ -730,7 +730,7 @@
qm->insert(k, *t2);
@@ -759,7 +759,7 @@
QgsOverlayObject* oobj = new QgsOverlayObject(*it.value());
PyObject* keyobj = PyInt_FromLong(it.key());
- PyObject* pyOobj = sipConvertFromInstance(oobj, sipClass_QgsOverlayObject, sipTransferObj);
+ PyObject* pyOobj = sipConvertFromInstance(oobj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QgsOverlayObject), sipTransferObj);
PyDict_SetItem(d, keyobj, pyOobj);
if(pyOobj == NULL || keyobj == NULL || PyDict_SetItem(d, keyobj, pyOobj) < 0)
@@ -797,18 +797,18 @@
int state;
int t1 = (int)(PyFloat_AsDouble(t1obj));
- QgsOverlayObject* t2 = reinterpret_cast<QgsOverlayObject*>(sipConvertToInstance(t2obj, sipClass_QgsOverlayObject, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
+ QgsOverlayObject* t2 = reinterpret_cast<QgsOverlayObject*>(sipConvertToInstance(t2obj, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QgsOverlayObject), sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
if (*sipIsErr)
- sipReleaseInstance(t2, sipClass_QgsOverlayObject, state);
+ sipReleaseInstance(t2, (sipWrapperType *) sipTypeAsPyTypeObject (sipType_QgsOverlayObject), state);
delete qm;
return 0;
qm->insert(t1, t2);
*sipCppPtr = qm;
