[QGIS Commit] r11795 - in trunk/qgis/src/app: . ogr
svn_qgis at osgeo.org
Mon Oct 12 04:55:13 EDT 2009
Author: mhugent
Date: 2009-10-12 04:55:12 -0400 (Mon, 12 Oct 2009)
New Revision: 11795
trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
Use native file dialogs (via static methods from QFileDialog)
Modified: trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp
--- trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp 2009-10-11 10:14:24 UTC (rev 11794)
+++ trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp 2009-10-12 08:55:12 UTC (rev 11795)
@@ -348,42 +348,28 @@
QVariant( QString::null ) ).toString();
QString lastUsedDir = settings.value( "/UI/" + filterName + "Dir", "." ).toString();
- //QString lastUsedEncoding = settings.value( "/UI/encoding" ).toString();
QgsDebugMsg( "Opening file dialog with filters: " + filters );
- QFileDialog* openFileDialog = new QFileDialog( 0,
- title, lastUsedDir, filters );
- // allow for selection of more than one file
- openFileDialog->setFileMode( QFileDialog::ExistingFiles );
- if ( haveLastUsedFilter ) // set the filter to the last one used
+ if ( haveLastUsedFilter )
- openFileDialog->selectFilter( lastUsedFilter );
+ selectedFiles = QFileDialog::getOpenFileNames( 0, title, lastUsedDir, filters, &lastUsedFilter );
+ else
+ selectedFiles = QFileDialog::getOpenFileNames( 0, title, lastUsedDir, filters );
- if ( openFileDialog->exec() == QDialog::Accepted )
+ if ( !selectedFiles.isEmpty() )
- selectedFiles = openFileDialog->selectedFiles();
- //enc = openFileDialog->encoding();
- // Fix by Tim - getting the dirPath from the dialog
- // directly truncates the last node in the dir path.
- // This is a workaround for that
QString myFirstFileName = selectedFiles.first();
QFileInfo myFI( myFirstFileName );
QString myPath = myFI.path();
QgsDebugMsg( "Writing last used dir: " + myPath );
- settings.setValue( "/UI/" + filterName, openFileDialog->selectedFilter() );
+ settings.setValue( "/UI/" + filterName, lastUsedFilter );
settings.setValue( "/UI/" + filterName + "Dir", myPath );
- //settings.setValue( "/UI/encoding", openFileDialog->encoding() );
- delete openFileDialog;
} // openFilesRememberingFilter_
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-10-11 10:14:24 UTC (rev 11794)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-10-12 08:55:12 UTC (rev 11795)
@@ -2304,8 +2304,6 @@
bool cancelAll = false )
- bool retVal = false;
bool haveLastUsedFilter = false; // by default, there is no last
// used filter
@@ -2319,28 +2317,9 @@
- QgsEncodingFileDialog* openFileDialog = new QgsEncodingFileDialog( 0,
- title, lastUsedDir, filters, QString( "" ) );
- // Check if we should add a cancel all button
- if ( cancelAll )
- openFileDialog->addCancelAll();
- enc = openFileDialog->encoding();
@@ -2350,17 +2329,11 @@
+ return true;
- else
- // Cancel or cancel all
- retVal = openFileDialog->cancelAll();
- return retVal;
+ return false;
@@ -3281,33 +3254,19 @@
// Retrieve last used project dir from persistent settings
QSettings settings;
QString lastUsedDir = settings.value( "/UI/lastProjectDir", "." ).toString();
- QFileDialog * openFileDialog = new QFileDialog( this,
- tr( "Choose a QGIS project file to open" ),
- lastUsedDir, tr( "QGis files (*.qgs)" ) );
- openFileDialog->setFileMode( QFileDialog::ExistingFile );
- QString fullPath;
+ QString fullPath = QFileDialog::getOpenFileName( this, tr( "Choose a QGIS project file to open" ), lastUsedDir, tr( "QGis files (*.qgs)" ) );
+ if ( fullPath.isNull() )
- fullPath = openFileDialog->selectedFiles().first();
- QFileInfo myFI( fullPath );
- QString myPath = myFI.path();
- // Persist last used project dir
- settings.setValue( "/UI/lastProjectDir", myPath );
- else
- // if they didn't select anything, just return
return;
+ // Fix by Tim - getting the dirPath from the dialog
+ // directly truncates the last node in the dir path.
+ // This is a workaround for that
+ QFileInfo myFI( fullPath );
+ QString myPath = myFI.path();
+ // Persist last used project dir
+ settings.setValue( "/UI/lastProjectDir", myPath );
delete mComposer;
mComposer = new QgsComposer( this );
@@ -3563,55 +3522,31 @@
QSettings settings;
- std::auto_ptr<QFileDialog> saveFileDialog( new QFileDialog( this,
- tr( "Choose a file name to save the QGIS project file as" ),
- lastUsedDir, tr( "QGis files (*.qgs)" ) ) );
- saveFileDialog->setFileMode( QFileDialog::AnyFile );
- saveFileDialog->setAcceptMode( QFileDialog::AcceptSave );
- saveFileDialog->setConfirmOverwrite( true );
- // if we don't have a file name, then obviously we need to get one; note
- // that the project file name is reset to null in fileNew()
- QFileInfo fullPath;
- if ( saveFileDialog->exec() == QDialog::Accepted )
+ QString saveFilePath = QFileDialog::getSaveFileName( this, tr( "Choose a file name to save the QGIS project file as" ), lastUsedDir, tr( "QGis files (*.qgs)" ) );
+ if ( saveFilePath.isNull() ) //canceled
- fullPath.setFile( saveFileDialog->selectedFiles().first() );
- QString myPath = fullPath.path();
- else
- // delete saveFileDialog; auto_ptr auto deletes
return;
+ QFileInfo myFI( saveFilePath );
// make sure the .qgs extension is included in the path name. if not, add it...
- if ( "qgs" != fullPath.suffix() )
+ if ( "qgs" != myFI.suffix() )
- QString newFilePath = fullPath.filePath() + ".qgs";
- fullPath.setFile( newFilePath );
+ saveFilePath = myFI.filePath() + ".qgs";
try
- QgsProject::instance()->setFileName( fullPath.filePath() );
+ QgsProject::instance()->setFileName( saveFilePath );
if ( QgsProject::instance()->write() )
setTitleBarText_( *this ); // update title bar
statusBar()->showMessage( tr( "Saved project to: %1" ).arg( QgsProject::instance()->fileName() ) );
// add this to the list of recently used project files
- saveRecentProjectPath( fullPath.filePath(), settings );
+ saveRecentProjectPath( saveFilePath, settings );
else
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-10-11 10:14:24 UTC (rev 11794)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-10-12 08:55:12 UTC (rev 11795)
@@ -956,60 +956,28 @@
QSettings myQSettings; // where we keep last used filter in persistant state
QString myLastUsedDir = myQSettings.value( "style/lastStyleDir", "." ).toString();
- //create a file dialog
- std::auto_ptr < QFileDialog > myFileDialog
- new QFileDialog(
- this,
- tr( "Load layer properties from style file (.qml)" ),
- myLastUsedDir,
- tr( "QGIS Layer Style File (*.qml)" )
- myFileDialog->setFileMode( QFileDialog::AnyFile );
- myFileDialog->setAcceptMode( QFileDialog::AcceptOpen );
- //prompt the user for a file name
- QString myFileName;
- if ( myFileDialog->exec() == QDialog::Accepted )
+ QString myFileName = QFileDialog::getOpenFileName( this, tr( "Load layer properties from style file (.qml)" ), myLastUsedDir, tr( "QGIS Layer Style File (*.qml)" ) );
+ if ( myFileName.isNull() )
- QStringList myFiles = myFileDialog->selectedFiles();
- if ( !myFiles.isEmpty() )
- myFileName = myFiles[0];
+ return;
- if ( !myFileName.isEmpty() )
+ bool defaultLoadedFlag = false;
+ QString myMessage = layer->loadNamedStyle( myFileName, defaultLoadedFlag );
+ //reset if the default style was loaded ok only
+ if ( defaultLoadedFlag )
- if ( myFileDialog->selectedFilter() == tr( "QGIS Layer Style File (*.qml)" ) )
- //ensure the user never omitted the extension from the file name
- if ( !myFileName.endsWith( ".qml", Qt::CaseInsensitive ) )
- myFileName += ".qml";
- bool defaultLoadedFlag = false;
- QString myMessage = layer->loadNamedStyle( myFileName, defaultLoadedFlag );
- //reset if the default style was loaded ok only
- if ( defaultLoadedFlag )
- reset();
- else
- //let the user know what went wrong
- QMessageBox::information( this, tr( "Saved Style" ), myMessage );
- else
- QMessageBox::warning( this, tr( "QGIS" ),
- tr( "Unknown style format: %1" ).arg( myFileDialog->selectedFilter() ) );
- myQSettings.setValue( "style/lastStyleDir", myFileDialog->directory().absolutePath() );
+ reset();
+ else
+ //let the user know what went wrong
+ QMessageBox::information( this, tr( "Saved Style" ), myMessage );
+ QFileInfo myFI( myFileName );
+ myQSettings.setValue( "style/lastStyleDir", myPath );
@@ -1017,64 +985,37 @@
+ QString myOutputFileName = QFileDialog::getSaveFileName( this, tr( "Save layer properties as style file (.qml)" ), myLastUsedDir, tr( "QGIS Layer Style File (*.qml)" ) );
+ if ( myOutputFileName.isNull() ) //dialog canceled
+ return;
- new QFileDialog(
- this,
- tr( "Save layer properties as style file (.qml)" ),
- myLastUsedDir,
- myFileDialog->setAcceptMode( QFileDialog::AcceptSave );
+ apply(); // make sure the qml to save is uptodate
- QString myOutputFileName;
+ //ensure the user never ommitted the extension from the file name
+ if ( !myOutputFileName.endsWith( ".qml", Qt::CaseInsensitive ) )
- myOutputFileName = myFiles[0];
+ myOutputFileName += ".qml";
- if ( !myOutputFileName.isEmpty() )
+ QString myMessage = layer->saveNamedStyle( myOutputFileName, defaultLoadedFlag );
- apply(); // make sure the qml to save is uptodate
- //ensure the user never ommitted the extension from the file name
- if ( !myOutputFileName.endsWith( ".qml", Qt::CaseInsensitive ) )
- myOutputFileName += ".qml";
- QString myMessage = layer->saveNamedStyle( myOutputFileName, defaultLoadedFlag );
- reset();
- else
- else
+ reset();
+ else
+ QFileInfo myFI( myOutputFileName );
+ // Persist last used dir
void QgsVectorLayerProperties::on_tblAttributes_cellChanged( int row, int column )
