[QGIS Commit] r11805 - trunk/qgis/src/core
    svn_qgis at osgeo.org
    Wed Oct 14 08:44:00 EDT 2009
Author: jef
Date: 2009-10-14 08:43:57 -0400 (Wed, 14 Oct 2009)
New Revision: 11805
   trunk/qgis/src/core/qgssearchtreenode.cpp
will you ever learn to run prepare-commit.sh before commiting?
Modified: trunk/qgis/src/core/qgssearchtreenode.cpp
--- trunk/qgis/src/core/qgssearchtreenode.cpp	2009-10-14 11:52:13 UTC (rev 11804)
+++ trunk/qgis/src/core/qgssearchtreenode.cpp	2009-10-14 12:43:57 UTC (rev 11805)
@@ -252,7 +252,7 @@
     case opLike:
       if ( !getValue( value1, mLeft, fields, attributes ) ||
-				   !getValue( value2, mRight, fields, attributes ) )
+           !getValue( value2, mRight, fields, attributes ) )
         return false;
       // value1 is string to be matched
@@ -274,11 +274,7 @@
         str.replace( "_", "." );
-      QRegExp re( str );
-			res = re.exactMatch( value1.string() );
-      QgsDebugMsgLevel( "REGEXP: " + str + " ~ " + value2.string(), 2 );
-      QgsDebugMsgLevel( "   res: " + res, 2 );
-      return res;
+      return QRegExp( str ).exactMatch( value1.string() );
     default:
