[QGIS Commit] r11819 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Oct 16 19:56:31 EDT 2009
Author: kyngchaos
Date: 2009-10-16 19:56:30 -0400 (Fri, 16 Oct 2009)
New Revision: 11819
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
composition update (r11817)
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-10-16 09:18:23 UTC (rev 11818)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-10-16 23:56:30 UTC (rev 11819)
@@ -189,6 +189,7 @@
 		720383800F8BA8C50083B883 /* priorityqueue.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 720382F70F8B8B540083B883 /* priorityqueue.cpp */; };
 		720383810F8BA8C50083B883 /* problem.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 720382F90F8B8B540083B883 /* problem.cpp */; };
 		720383820F8BA8C50083B883 /* util.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 720382FD0F8B8B540083B883 /* util.cpp */; };
+		72038CA310893F3100439C44 /* qgscomposition.h in Sources */ = {isa = PBXBuildFile; fileRef = 7209E6730F39E57A003DC336 /* qgscomposition.h */; };
 		7209F03B0F39E6A1003DC336 /* ApplicationServices.framework in Frameworks */ = {isa = PBXBuildFile; fileRef = 7209F03A0F39E6A1003DC336 /* ApplicationServices.framework */; };
 		7209F1D70F39EA3E003DC336 /* qgsprovidercountcalcevent.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 7209E6B90F39E57A003DC336 /* qgsprovidercountcalcevent.cpp */; };
 		7209F1D80F39EA3E003DC336 /* qgsprovidermetadata.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 7209E6BD0F39E57A003DC336 /* qgsprovidermetadata.cpp */; };
@@ -4015,6 +4016,7 @@
 		720383580F8B905D0083B883 /* libdiagramoverlayplugin.so */ = {isa = PBXFileReference; explicitFileType = "compiled.mach-o.executable"; includeInIndex = 0; path = libdiagramoverlayplugin.so; sourceTree = BUILT_PRODUCTS_DIR; };
 		7203835A0F8B90B50083B883 /* qgsapplydialog.h */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.h; name = qgsapplydialog.h; path = ../../src/plugins/qgsapplydialog.h; sourceTree = SOURCE_ROOT; };
 		7203835B0F8B90B50083B883 /* qgsvectoroverlayplugin.h */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.h; name = qgsvectoroverlayplugin.h; path = ../../src/plugins/qgsvectoroverlayplugin.h; sourceTree = SOURCE_ROOT; };
+		72038CA210893EA900439C44 /* testqgscoordinatereferencesystem.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; name = testqgscoordinatereferencesystem.cpp; path = ../../tests/src/core/testqgscoordinatereferencesystem.cpp; sourceTree = SOURCE_ROOT; };
 		7209E56E0F39E477003DC336 /* qgis_settings.xcconfig */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xcconfig; path = qgis_settings.xcconfig; sourceTree = SOURCE_ROOT; };
 		7209E56F0F39E481003DC336 /* qgis_user.xcconfig */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.xcconfig; path = qgis_user.xcconfig; sourceTree = SOURCE_ROOT; };
 		7209E5BC0F39E57A003DC336 /* CMakeLists.txt */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = CMakeLists.txt; path = ../../src/app/CMakeLists.txt; sourceTree = SOURCE_ROOT; };
@@ -9365,6 +9367,7 @@
 				7209ECE70F39E5D8003DC336 /* test_suite_builder.sh */,
 				7209ECE80F39E5D8003DC336 /* test_template.cpp */,
 				7209ECE90F39E5D8003DC336 /* testcontrastenhancements.cpp */,
+				72038CA210893EA900439C44 /* testqgscoordinatereferencesystem.cpp */,
 				7209ECEA0F39E5D8003DC336 /* testqgsapplication.cpp */,
 				7209ECEB0F39E5D8003DC336 /* testqgsgeometry.cpp */,
 				7209ECEC0F39E5D8003DC336 /* testqgsmaplayer.cpp */,
@@ -13847,6 +13850,7 @@
 				729287460F71C2CB006D9489 /* qgscomposermap.h in Sources */,
 				729287470F71C2CB006D9489 /* qgscomposerpicture.h in Sources */,
 				729287480F71C2CB006D9489 /* qgscomposerscalebar.h in Sources */,
+				72038CA310893F3100439C44 /* qgscomposition.h in Sources */,
 				729287490F71C2CB006D9489 /* qgscontexthelp.h in Sources */,
 				7292874A0F71C2CB006D9489 /* qgscoordinatetransform.h in Sources */,
 				7292874B0F71C2CB006D9489 /* qgsdataprovider.h in Sources */,
@@ -17557,7 +17561,7 @@
 				COPY_PHASE_STRIP = NO;
 				GCC_GENERATE_DEBUGGING_SYMBOLS = YES;
 				GCC_OPTIMIZATION_LEVEL = 0;
-				QGIS_VERSION_BUILD = 20090930;
+				QGIS_VERSION_BUILD = 20091016;
 				STRIP_INSTALLED_PRODUCT = NO;
 			name = Debug;
@@ -17568,7 +17572,7 @@
 			buildSettings = {
 				COPY_PHASE_STRIP = YES;
 				GCC_GENERATE_DEBUGGING_SYMBOLS = NO;
 				STRIP_INSTALLED_PRODUCT = YES;
 			name = Release;
More information about the QGIS-commit mailing list
