[QGIS Commit] r11825 - in trunk/qgis: python/core src/app src/core
src/ui
svn_qgis at osgeo.org
Wed Oct 21 10:59:45 EDT 2009
Author: timlinux
Date: 2009-10-21 10:59:44 -0400 (Wed, 21 Oct 2009)
New Revision: 11825
trunk/qgis/python/core/qgspoint.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/core/qgis.h
trunk/qgis/src/core/qgspoint.cpp
trunk/qgis/src/core/qgspoint.h
trunk/qgis/src/core/qgsscalecalculator.cpp
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
[FEATURE] Added option to display position as Degrees,Minutes,Seconds in the status bar
Modified: trunk/qgis/python/core/qgspoint.sip
--- trunk/qgis/python/core/qgspoint.sip 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/python/core/qgspoint.sip 2009-10-21 14:59:44 UTC (rev 11825)
@@ -52,6 +52,14 @@
//! As above but with precision for string representaiton of a point
QString toString(int thePrecision) const;
+ /** Return a string representation as degrees minutes seconds.
+ * Its up to the calling function to ensure that this point can
+ * be meaningfully represented in this form.
+ * @note added in QGIS 1.4
+ QString toDegreesMinutesSeconds( int thePrecision ) const;
/*! Return the well known text representation for the point.
* The wkt is created without an SRID.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-10-21 14:59:44 UTC (rev 11825)
@@ -4593,7 +4593,14 @@
else
- mCoordsEdit->setText( p.toString( mMousePrecisionDecimalPlaces ) );
+ if ( mMapCanvas->mapUnits() == QGis::DegreesMinutesSeconds )
+ mCoordsEdit->setText( p.toDegreesMinutesSeconds( mMousePrecisionDecimalPlaces ) );
+ else
+ mCoordsEdit->setText( p.toString( mMousePrecisionDecimalPlaces ) );
if ( mCoordsEdit->width() > mCoordsEdit->minimumWidth() )
mCoordsEdit->setMinimumWidth( mCoordsEdit->width() );
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2009-10-21 14:59:44 UTC (rev 11825)
@@ -289,6 +289,10 @@
radFeet->setChecked( true );
+ else if ( unit == QGis::DegreesMinutesSeconds )
+ radDMS->setChecked( true );
else
radDecimalDegrees->setChecked( true );
@@ -326,6 +330,10 @@
mapUnit = QGis::Feet;
+ else if ( radDMS->isChecked() )
+ mapUnit = QGis::DegreesMinutesSeconds;
else
mapUnit = QGis::Degrees;
Modified: trunk/qgis/src/core/qgis.h
--- trunk/qgis/src/core/qgis.h 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/core/qgis.h 2009-10-21 14:59:44 UTC (rev 11825)
@@ -74,13 +74,18 @@
//! description strings for feature types
static const char *qgisFeatureTypes[];
- //! map units that qgis supports
+ /** Map units that qgis supports
+ * @note that QGIS < 1.4 api had only Meters, Feet, Degrees and UnknownUnit
enum UnitType
- Meters,
- Feet,
- Degrees,
- UnknownUnit
+ Meters = 0,
+ Feet = 1,
+ Degrees = 2, //for 1.0 api backwards compatibility
+ DecimalDegrees = 2,
+ DegreesMinutesSeconds = 4,
+ DegreesDecimalMinutes = 5,
+ UnknownUnit = 3
//! User defined event types
Modified: trunk/qgis/src/core/qgspoint.cpp
--- trunk/qgis/src/core/qgspoint.cpp 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/core/qgspoint.cpp 2009-10-21 14:59:44 UTC (rev 11825)
@@ -20,6 +20,7 @@
#include "qgspoint.h"
#include <cmath>
#include <QTextStream>
+#include <QObject> // for tr()
QgsPoint::QgsPoint( const QgsPoint& p )
@@ -44,7 +45,32 @@
return rep;
+QString QgsPoint::toDegreesMinutesSeconds( int thePrecision ) const
+ int myDegreesX = int( std::abs( m_x ) );
+ float myFloatMinutesX = float( ( std::abs( m_x ) - myDegreesX ) * 60 );
+ int myIntMinutesX = int( myFloatMinutesX );
+ float mySecondsX = float ( myFloatMinutesX - myIntMinutesX ) * 60;
+ int myDegreesY = int( std::abs( m_y ) );
+ float myFloatMinutesY = float( ( std::abs( m_y ) - myDegreesY ) * 60 );
+ int myIntMinutesY = int( myFloatMinutesY );
+ float mySecondsY = float ( myFloatMinutesY - myIntMinutesY ) * 60;
+ QString myXHemisphere = m_x < 0 ? QObject::tr("W") : QObject::tr("E");
+ QString myYHemisphere = m_y < 0 ? QObject::tr("S") : QObject::tr("N");
+ QString rep = QString::number( myDegreesX ) + QChar(176) +
+ QString::number( myIntMinutesX ) + QString("'") +
+ QString::number( mySecondsX, 'f', thePrecision ) + QString( "\"" ) +
+ myXHemisphere + QString( "," ) +
+ QString::number( myDegreesY ) + QChar(176) +
+ QString::number( myIntMinutesY ) + QString("'") +
+ QString::number( mySecondsY, 'f', thePrecision ) + QString( "\"" ) +
+ myYHemisphere;
+ return rep;
QString QgsPoint::wellKnownText() const
return QString( "POINT(%1 %2)" ).arg( QString::number( m_x, 'f', 18 ) ).arg( QString::number( m_y, 'f', 18 ) );
Modified: trunk/qgis/src/core/qgspoint.h
--- trunk/qgis/src/core/qgspoint.h 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/core/qgspoint.h 2009-10-21 14:59:44 UTC (rev 11825)
@@ -93,6 +93,14 @@
QString toString( int thePrecision ) const;
* @return Well known text in the form POINT(x y)
Modified: trunk/qgis/src/core/qgsscalecalculator.cpp
--- trunk/qgis/src/core/qgsscalecalculator.cpp 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/core/qgsscalecalculator.cpp 2009-10-21 14:59:44 UTC (rev 11825)
@@ -68,11 +68,21 @@
conversionFactor = 12.0;
delta = mapExtent.xMaximum() - mapExtent.xMinimum();
break;
- case QGis::Degrees:
+ case QGis::DecimalDegrees:
// degrees require conversion to meters first
conversionFactor = 39.3700787;
delta = calculateGeographicDistance( mapExtent );
break;
+ case QGis::DegreesMinutesSeconds:
+ // degrees require conversion to meters first
+ conversionFactor = 39.3700787;
+ delta = calculateGeographicDistance( mapExtent );
+ break;
+ case QGis::DegreesDecimalMinutes:
+ break;
default:
assert( "bad map units" );
break;
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-10-21 11:22:09 UTC (rev 11824)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-10-21 14:59:44 UTC (rev 11825)
@@ -1,87 +1,86 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
+<ui version="4.0" >
<class>QgsProjectPropertiesBase</class>
- <widget class="QDialog" name="QgsProjectPropertiesBase">
- <property name="geometry">
+ <widget class="QDialog" name="QgsProjectPropertiesBase" >
+ <property name="geometry" >
<rect>
<x>0</x>
<y>0</y>
- <width>451</width>
- <height>515</height>
+ <width>492</width>
+ <height>557</height>
</rect>
</property>
- <property name="windowTitle">
+ <property name="windowTitle" >
<string>Project Properties</string>
</property>
- <property name="sizeGripEnabled">
+ <property name="sizeGripEnabled" >
<bool>true</bool>
</property>
- <property name="modal">
+ <property name="modal" >
<bool>true</bool>
</property>
- <layout class="QGridLayout">
- <item row="2" column="0">
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="orientation">
+ <layout class="QGridLayout" >
+ <item row="2" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
- <property name="standardButtons">
- <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
- <item row="0" column="0">
- <widget class="QTabWidget" name="tabWidget">
- <property name="currentIndex">
+ <item row="0" column="0" >
+ <widget class="QTabWidget" name="tabWidget" >
+ <property name="currentIndex" >
<number>0</number>
</property>
- <widget class="QWidget" name="tab1">
- <attribute name="title">
+ <widget class="QWidget" name="tab1" >
+ <attribute name="title" >
<string>General</string>
</attribute>
- <widget class="QGroupBox" name="titleBox">
- <property name="title">
+ <widget class="QGroupBox" name="titleBox" >
+ <property name="title" >
<string>General settings</string>
</property>
- <widget class="QLabel" name="label_2">
- <property name="text">
+ <widget class="QLabel" name="label_2" >
+ <property name="text" >
<string>Project title</string>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="3">
- <widget class="QLineEdit" name="titleEdit">
- <property name="toolTip">
+ <item row="0" column="1" colspan="3" >
+ <widget class="QLineEdit" name="titleEdit" >
+ <property name="toolTip" >
<string>Descriptive project name</string>
</property>
<string>Default project title</string>
</property>
</widget>
</item>
- <item row="1" column="0">
- <widget class="QLabel" name="textLabel1">
+ <item row="1" column="0" >
+ <widget class="QLabel" name="textLabel1" >
<string>Selection color</string>
</property>
- <property name="buddy">
+ <property name="buddy" >
<cstring>pbnSelectionColour</cstring>
</property>
</widget>
</item>
- <item row="1" column="2">
+ <item row="1" column="2" >
<spacer>
</property>
- <property name="sizeType">
+ <property name="sizeType" >
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" stdset="0">
+ <property name="sizeHint" >
<size>
<width>40</width>
<height>20</height>
@@ -89,35 +88,35 @@
</property>
</spacer>
</item>
- <item row="1" column="3">
- <widget class="QgsColorButton" name="pbnSelectionColour">
- <property name="minimumSize">
+ <item row="1" column="3" >
+ <widget class="QgsColorButton" name="pbnSelectionColour" >
+ <property name="minimumSize" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="2">
- <widget class="QLabel" name="label">
+ <item row="2" column="0" colspan="2" >
+ <widget class="QLabel" name="label" >
<string>Background color</string>
</property>
<cstring>pbnCanvasColor</cstring>
</property>
</widget>
</item>
- <item row="2" column="2">
+ <item row="2" column="2" >
<spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -125,46 +124,46 @@
</property>
</spacer>
</item>
- <item row="2" column="3">
- <widget class="QgsColorButton" name="pbnCanvasColor">
+ <item row="2" column="3" >
+ <widget class="QgsColorButton" name="pbnCanvasColor" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <item row="3" column="3">
- <widget class="QComboBox" name="cbxAbsolutePath">
+ <item row="3" column="3" >
+ <widget class="QComboBox" name="cbxAbsolutePath" >
<item>
<string>absolute</string>
</property>
</item>
<item>
<string>relative</string>
</property>
</item>
</widget>
</item>
- <item row="3" column="0">
- <widget class="QLabel" name="label_3">
+ <item row="3" column="0" >
+ <widget class="QLabel" name="label_3" >
<string>Save paths</string>
</property>
</widget>
</item>
- <item row="3" column="2">
- <spacer name="horizontalSpacer">
+ <item row="3" column="2" >
+ <spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -175,96 +174,100 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="btnGrpMapUnits">
+ <widget class="QGroupBox" name="btnGrpMapUnits" >
<string>Layer units (only used when CRS transformation is disabled)</string>
</property>
- <layout class="QHBoxLayout">
- <property name="margin">
- <number>11</number>
- </property>
- <item>
- <widget class="QRadioButton" name="radMeters">
+ <widget class="QRadioButton" name="radMeters" >
<string>Meters</string>
</property>
- <property name="checked">
+ <property name="checked" >
<bool>true</bool>
</property>
</widget>
</item>
- <item>
- <widget class="QRadioButton" name="radFeet">
+ <item row="0" column="1" >
+ <widget class="QRadioButton" name="radFeet" >
<string>Feet</string>
</property>
</widget>
</item>
- <item>
- <widget class="QRadioButton" name="radDecimalDegrees">
+ <item row="0" column="2" >
+ <widget class="QRadioButton" name="radDecimalDegrees" >
<string>Decimal degrees</string>
</property>
</widget>
</item>
+ <item row="0" column="3" >
+ <widget class="QRadioButton" name="radDMS" >
+ <string>Degrees, Minutes, Seconds</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="btnGrpPrecision">
+ <widget class="QGroupBox" name="btnGrpPrecision" >
<string>Precision</string>
</property>
- <widget class="QRadioButton" name="radAutomatic">
+ <widget class="QRadioButton" name="radAutomatic" >
<string>Automatically sets the number of decimal places in the mouse position display</string>
</property>
- <property name="whatsThis">
+ <property name="whatsThis" >
<string>The number of decimal places that are used when displaying the mouse position is automatically set to be enough so that moving the mouse by one pixel gives a change in the position display</string>
</property>
<string>Automatic</string>
</property>
<bool>true</bool>
</property>
</widget>
</item>
- <item row="0" column="1">
- <widget class="QRadioButton" name="radManual">
+ <widget class="QRadioButton" name="radManual" >
<string>Sets the number of decimal places to use for the mouse position display</string>
</property>
</property>
<string>Manual</string>
</property>
</widget>
</item>
- <item row="0" column="2">
- <widget class="QSpinBox" name="spinBoxDP">
+ <widget class="QSpinBox" name="spinBoxDP" >
<string>The number of decimal places for the manual option</string>
</property>
</property>
</widget>
</item>
- <item row="0" column="3">
- <widget class="QLabel" name="textLabel3">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <widget class="QLabel" name="textLabel3" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<string>decimal places</string>
</property>
</widget>
@@ -272,35 +275,35 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="grpDigitizing">
- <sizepolicy hsizetype="Preferred" vsizetype="Expanding">
+ <widget class="QGroupBox" name="grpDigitizing" >
+ <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
</sizepolicy>
</property>
<string>Digitizing</string>
</property>
- <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox">
+ <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
<string>Enable topological editing</string>
</property>
</widget>
</item>
- <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox">
+ <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
<string>Avoid intersections of new polygons</string>
</property>
</widget>
</item>
- <widget class="QPushButton" name="mSnappingOptionsPushButton">
+ <widget class="QPushButton" name="mSnappingOptionsPushButton" >
<string>Snapping options...</string>
</property>
</widget>
@@ -310,71 +313,59 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab2">
+ <widget class="QWidget" name="tab2" >
<string>Coordinate Reference System (CRS)</string>
</attribute>
- <property name="leftMargin">
+ <property name="leftMargin" >
<number>3</number>
</property>
- <property name="topMargin">
+ <property name="topMargin" >
<number>11</number>
</property>
- <property name="rightMargin">
+ <property name="rightMargin" >
<number>3</number>
</property>
- <property name="bottomMargin">
+ <property name="bottomMargin" >
<number>11</number>
</property>
- <widget class="QCheckBox" name="cbxProjectionEnabled">
+ <widget class="QCheckBox" name="cbxProjectionEnabled" >
<string>Enable 'on the fly' CRS transformation</string>
</property>
</widget>
</item>
- <widget class="QgsProjectionSelector" name="projectionSelector" native="true"/>
+ <widget class="QgsProjectionSelector" native="1" name="projectionSelector" />
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab3">
+ <widget class="QWidget" name="tab3" >
<string>Identifiable layers</string>
</attribute>
- <layout class="QHBoxLayout" name="horizontalLayout">
+ <layout class="QHBoxLayout" >
<item>
- <widget class="QTableWidget" name="twIdentifyLayers">
- <property name="sortingEnabled">
+ <widget class="QTableWidget" name="twIdentifyLayers" >
+ <property name="sortingEnabled" >
<bool>true</bool>
</property>
- <attribute name="horizontalHeaderVisible">
- <bool>false</bool>
- </attribute>
- <attribute name="horizontalHeaderShowSortIndicator" stdset="0">
- </attribute>
- <attribute name="horizontalHeaderStretchLastSection">
- <bool>true</bool>
- </attribute>
<column>
<string>Layer</string>
</property>
</column>
<column>
<string>Type</string>
</property>
</column>
<column>
<string>Identifiable</string>
</property>
- <property name="textAlignment">
- <set>AlignHCenter|AlignVCenter|AlignCenter</set>
- </property>
</column>
</widget>
</item>
@@ -384,7 +375,7 @@
</item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11"/>
+ <layoutdefault spacing="6" margin="11" />
<customwidgets>
<customwidget>
<class>QgsColorButton</class>
@@ -402,18 +393,21 @@
<tabstop>titleEdit</tabstop>
<tabstop>pbnSelectionColour</tabstop>
<tabstop>pbnCanvasColor</tabstop>
+ <tabstop>cbxAbsolutePath</tabstop>
<tabstop>radMeters</tabstop>
<tabstop>radFeet</tabstop>
<tabstop>radDecimalDegrees</tabstop>
+ <tabstop>radDMS</tabstop>
<tabstop>radAutomatic</tabstop>
<tabstop>radManual</tabstop>
<tabstop>spinBoxDP</tabstop>
<tabstop>mEnableTopologicalEditingCheckBox</tabstop>
<tabstop>mAvoidIntersectionsCheckBox</tabstop>
<tabstop>mSnappingOptionsPushButton</tabstop>
+ <tabstop>buttonBox</tabstop>
<tabstop>cbxProjectionEnabled</tabstop>
+ <tabstop>twIdentifyLayers</tabstop>
<tabstop>tabWidget</tabstop>
- <tabstop>buttonBox</tabstop>
</tabstops>
<resources/>
<connections>
@@ -423,11 +417,11 @@
<receiver>spinBoxDP</receiver>
<slot>setEnabled(bool)</slot>
<hints>
- <hint type="sourcelabel">
+ <hint type="sourcelabel" >
<x>229</x>
<y>280</y>
</hint>
- <hint type="destinationlabel">
+ <hint type="destinationlabel" >
<x>416</x>
<y>286</y>
</hint>
@@ -439,11 +433,11 @@
<receiver>textLabel3</receiver>
<hints>
<x>240</x>
<y>281</y>
</hint>
<x>583</x>
<y>290</y>
</hint>
@@ -455,11 +449,11 @@
<slot>setDisabled(bool)</slot>
<hints>
<x>100</x>
<y>290</y>
</hint>
<x>395</x>
<y>285</y>
</hint>
@@ -471,11 +465,11 @@
<hints>
<x>87</x>
<y>284</y>
</hint>
<x>589</x>
<y>285</y>
</hint>
