[QGIS Commit] r11829 - in trunk/qgis/src: app app/attributetable ui
svn_qgis at osgeo.org
Thu Oct 22 09:39:02 EDT 2009
Author: wonder
Date: 2009-10-22 09:39:00 -0400 (Thu, 22 Oct 2009)
New Revision: 11829
trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
trunk/qgis/src/app/qgsfieldcalculator.cpp
trunk/qgis/src/ui/qgsattributetabledialog.ui
[UPDATE] Added field calculator also to attribute table to make it easier to discover.
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-22 12:24:36 UTC (rev 11828)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.cpp 2009-10-22 13:39:00 UTC (rev 11829)
@@ -31,8 +31,8 @@
#include "qgssearchquerybuilder.h"
#include "qgslogger.h"
#include "qgsmapcanvas.h"
+#include "qgsfieldcalculator.h"
class QgsAttributeTableDock : public QDockWidget
public:
@@ -87,9 +87,12 @@
mZoomMapToSelectedRowsButton->setIcon( getThemeIcon( "/mActionZoomToSelected.png" ) );
mInvertSelectionButton->setIcon( getThemeIcon( "/mActionInvertSelection.png" ) );
mToggleEditingButton->setIcon( getThemeIcon( "/mActionToggleEditing.png" ) );
+ mOpenFieldCalculator->setIcon( getThemeIcon( "/mActionCalculateField.png" ) );
// toggle editing
+ bool canChangeAttributes = mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::ChangeAttributeValues;
mToggleEditingButton->setCheckable( true );
- mToggleEditingButton->setEnabled( mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::ChangeAttributeValues );
+ mToggleEditingButton->setEnabled( canChangeAttributes );
+ mOpenFieldCalculator->setEnabled( canChangeAttributes && mLayer->isEditable() );
// info from table to application
connect( this, SIGNAL( editingToggled( QgsMapLayer * ) ), QgisApp::instance(), SLOT( toggleEditing( QgsMapLayer * ) ) );
@@ -522,6 +525,9 @@
mToggleEditingButton->setChecked( mLayer->isEditable() );
mToggleEditingButton->blockSignals( false );
// (probably reload data if user stopped editing - possible revert)
mModel->reload( mModel->index( 0, 0 ), mModel->index( mModel->rowCount(), mModel->columnCount() ) );
@@ -548,3 +554,13 @@
mModel->revert();
+void QgsAttributeTableDialog::on_mOpenFieldCalculator_clicked()
+ QgsFieldCalculator calc( mLayer );
+ if ( calc.exec() )
+ // update model - a field has been added or updated
+ mModel->reload( mModel->index( 0, 0 ), mModel->index( mModel->rowCount(), mModel->columnCount() ) );
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledialog.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-22 12:24:36 UTC (rev 11828)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledialog.h 2009-10-22 13:39:00 UTC (rev 11829)
@@ -132,6 +132,10 @@
* Starts editing mode
void startEditing();
+ * Opens field calculator dialog
+ void on_mOpenFieldCalculator_clicked();
signals:
Modified: trunk/qgis/src/app/qgsfieldcalculator.cpp
--- trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-22 12:24:36 UTC (rev 11828)
+++ trunk/qgis/src/app/qgsfieldcalculator.cpp 2009-10-22 13:39:00 UTC (rev 11829)
@@ -130,6 +130,8 @@
bool onlySelected = ( mOnlyUpdateSelectedCheckBox->checkState() == Qt::Checked );
QgsFeatureIds selectedIds = mVectorLayer->selectedFeaturesIds();
+ // block layerModified signals (that would trigger table update)
+ mVectorLayer->blockSignals( true );
mVectorLayer->select( mVectorLayer->pendingAllAttributesList(), QgsRectangle(), false, false );
while ( mVectorLayer->nextFeature( feature ) )
@@ -157,6 +159,10 @@
mVectorLayer->changeAttributeValue( feature.id(), attributeId, value.string(), false );
+ // stop blocking layerModified signals and make sure that one layerModified signal is emitted
+ mVectorLayer->setModified( true, false );
if ( !calculationSuccess )
Modified: trunk/qgis/src/ui/qgsattributetabledialog.ui
--- trunk/qgis/src/ui/qgsattributetabledialog.ui 2009-10-22 12:24:36 UTC (rev 11828)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui 2009-10-22 13:39:00 UTC (rev 11829)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsAttributeTableDialog</class>
- <widget class="QDialog" name="QgsAttributeTableDialog" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsAttributeTableDialog">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
@@ -9,229 +10,246 @@
<height>570</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Attribute Table</string>
</property>
- <layout class="QGridLayout" >
- <property name="leftMargin" >
- <number>0</number>
+ <layout class="QGridLayout">
+ <property name="horizontalSpacing">
+ <number>2</number>
</property>
- <property name="topMargin" >
+ <property name="verticalSpacing">
<number>0</number>
</property>
- <property name="rightMargin" >
+ <property name="margin">
<number>0</number>
</property>
- <property name="bottomMargin" >
- </property>
- <property name="horizontalSpacing" >
- <number>2</number>
- </property>
- <property name="verticalSpacing" >
- </property>
- <item row="0" column="0" >
- <widget class="QgsAttributeTableView" name="mView" >
- <property name="alternatingRowColors" >
+ <item row="0" column="0">
+ <widget class="QgsAttributeTableView" name="mView">
+ <property name="alternatingRowColors">
<bool>true</bool>
</property>
</widget>
</item>
- <item row="1" column="0" >
- <layout class="QHBoxLayout" >
+ <item row="1" column="0">
+ <layout class="QHBoxLayout">
<item>
- <widget class="QToolButton" name="mRemoveSelectionButton" >
- <property name="toolTip" >
+ <widget class="QToolButton" name="mRemoveSelectionButton">
+ <property name="toolTip">
<string>Unselect all</string>
</property>
- <property name="text" >
+ <property name="text">
<string/>
</property>
- <property name="icon" >
- <iconset>../../images/themes/default/mActionUnselectAttributes.png</iconset>
+ <property name="icon">
+ <iconset>
+ <normaloff>../../images/themes/default/mActionUnselectAttributes.png</normaloff>../../images/themes/default/mActionUnselectAttributes.png</iconset>
</property>
- <property name="iconSize" >
+ <property name="iconSize">
<size>
<width>18</width>
<height>18</height>
</size>
</property>
- <property name="shortcut" >
+ <property name="shortcut">
<string/>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mSelectedToTopButton" >
+ <widget class="QToolButton" name="mSelectedToTopButton">
<string>Move selection to top</string>
</property>
<string/>
</property>
- <iconset>../../images/themes/default/mActionSelectedToTop.png</iconset>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionSelectedToTop.png</normaloff>../../images/themes/default/mActionSelectedToTop.png</iconset>
</property>
<size>
<width>18</width>
<height>18</height>
</size>
</property>
<string>Ctrl+T</string>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mInvertSelectionButton" >
+ <widget class="QToolButton" name="mInvertSelectionButton">
<string>Invert selection</string>
</property>
<string/>
</property>
- <iconset>../../images/themes/default/mActionInvertSelection.png</iconset>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionInvertSelection.png</normaloff>../../images/themes/default/mActionInvertSelection.png</iconset>
</property>
<size>
<width>18</width>
<height>18</height>
</size>
</property>
<string>Ctrl+S</string>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mCopySelectedRowsButton" >
+ <widget class="QToolButton" name="mCopySelectedRowsButton">
<string>Copy selected rows to clipboard (Ctrl+C)</string>
</property>
- <property name="whatsThis" >
+ <property name="whatsThis">
<string>Copies the selected rows to the clipboard</string>
</property>
<string/>
</property>
- <iconset>../../images/themes/default/mActionEditCopy.png</iconset>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionEditCopy.png</normaloff>../../images/themes/default/mActionEditCopy.png</iconset>
</property>
<size>
<width>18</width>
<height>18</height>
</size>
</property>
<string>Ctrl+C</string>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mZoomMapToSelectedRowsButton" >
+ <widget class="QToolButton" name="mZoomMapToSelectedRowsButton">
<string>Zoom map to the selected rows (Ctrl-J)</string>
</property>
<string>Zoom map to the selected rows</string>
</property>
<string/>
</property>
- <iconset>../../images/themes/default/mActionZoomToSelected.png</iconset>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionZoomToSelected.png</normaloff>../../images/themes/default/mActionZoomToSelected.png</iconset>
</property>
<size>
<width>18</width>
<height>18</height>
</size>
</property>
<string>Ctrl+J</string>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mToggleEditingButton" >
+ <widget class="QToolButton" name="mToggleEditingButton">
<string>Toggle editing mode</string>
</property>
<string>Click to toggle table editing</string>
</property>
<string/>
</property>
- <iconset>../../images/themes/default/mActionToggleEditing.png</iconset>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionToggleEditing.png</normaloff>../../images/themes/default/mActionToggleEditing.png</iconset>
</property>
<size>
<width>18</width>
<height>18</height>
</size>
</property>
- <property name="checkable" >
+ <property name="checkable">
<bool>true</bool>
</property>
</widget>
</item>
<item>
- <widget class="QLabel" name="searchFor" >
+ <widget class="QToolButton" name="mOpenFieldCalculator">
+ <string>Open field calculator</string>
+ </property>
+ <string/>
+ </property>
+ <iconset>
+ <normaloff>../../images/themes/default/mActionCalculateField.png</normaloff>../../images/themes/default/mActionCalculateField.png</iconset>
+ </property>
+ <size>
+ <width>18</width>
+ <height>18</height>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="searchFor">
<string>Look for</string>
</property>
</widget>
</item>
<item>
- <widget class="QLineEdit" name="query" />
+ <widget class="QLineEdit" name="query"/>
</item>
<item>
- <widget class="QLabel" name="searchIn" >
+ <widget class="QLabel" name="searchIn">
<string>in</string>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="columnBox" />
+ <widget class="QComboBox" name="columnBox"/>
</item>
<item>
- <widget class="QPushButton" name="searchButton" >
+ <widget class="QPushButton" name="searchButton">
<string>&Search</string>
</property>
</widget>
</item>
</layout>
</item>
- <item row="2" column="0" >
+ <item row="2" column="0">
<item>
- <widget class="QCheckBox" name="cbxShowSelectedOnly" >
+ <widget class="QCheckBox" name="cbxShowSelectedOnly">
<string>Show selected records only</string>
</property>
</widget>
</item>
<item>
- <widget class="QCheckBox" name="cbxSearchSelectedOnly" >
+ <widget class="QCheckBox" name="cbxSearchSelectedOnly">
<string>Search selected records only</string>
</property>
</widget>
</item>
<item>
<spacer>
- <property name="orientation" >
+ <property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0">
<size>
<width>40</width>
<height>20</height>
@@ -240,18 +258,18 @@
</spacer>
</item>
<item>
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
<string>Advanced search</string>
</property>
</widget>
</item>
<item>
- <widget class="QToolButton" name="mAdvancedSearchButton" >
+ <widget class="QToolButton" name="mAdvancedSearchButton">
<string>...</string>
</property>
<size>
<width>12</width>
<height>12</height>
