[QGIS Commit] r11839 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sun Oct 25 11:18:30 EDT 2009
Author: mhugent
Date: 2009-10-25 11:18:29 -0400 (Sun, 25 Oct 2009)
New Revision: 11839
Added:
trunk/qgis/src/app/qgsavoidintersectionsdialog.cpp
trunk/qgis/src/app/qgsavoidintersectionsdialog.h
trunk/qgis/src/ui/qgsavoidintersectionsdialogbase.ui
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/qgsmaptooladdfeature.cpp
trunk/qgis/src/app/qgsmaptooladdfeature.h
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/app/qgsprojectproperties.h
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
[FEATURE]: Avoid intersections for polygons is now also possible to background layers
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/app/CMakeLists.txt 2009-10-25 15:18:29 UTC (rev 11839)
@@ -9,6 +9,7 @@
qgsattributeeditor.cpp
qgsattributetypedialog.cpp
qgsattributetypeloaddialog.cpp
+ qgsavoidintersectionsdialog.cpp
qgsbookmarkitem.cpp
qgsbookmarks.cpp
qgsclipboard.cpp
@@ -119,6 +120,7 @@
qgsattributeeditor.h
qgsattributetypedialog.h
qgsattributetypeloaddialog.h
+ qgsavoidintersectionsdialog.h
qgsbookmarks.h
qgscontinuouscolordialog.h
qgsconfigureshortcutsdialog.h
Added: trunk/qgis/src/app/qgsavoidintersectionsdialog.cpp
--- trunk/qgis/src/app/qgsavoidintersectionsdialog.cpp (rev 0)
+++ trunk/qgis/src/app/qgsavoidintersectionsdialog.cpp 2009-10-25 15:18:29 UTC (rev 11839)
@@ -0,0 +1,60 @@
+#include "qgsavoidintersectionsdialog.h"
+#include "qgsmapcanvas.h"
+#include "qgsvectorlayer.h"
+QgsAvoidIntersectionsDialog::QgsAvoidIntersectionsDialog( QgsMapCanvas* canvas, const QSet<QString>& enabledLayers, QWidget * parent, Qt::WindowFlags f ): \
+ QDialog( parent, f ), mMapCanvas( canvas )
+ setupUi( this );
+ int nLayers = mMapCanvas->layerCount();
+ QgsVectorLayer* currentLayer = 0;
+ QListWidgetItem* newItem = 0;
+ for ( int i = 0; i < nLayers; ++i )
+ currentLayer = dynamic_cast<QgsVectorLayer*>( mMapCanvas->layer( i ) );
+ if ( currentLayer )
+ //only consider polygon or multipolygon layers
+ if ( currentLayer->geometryType() == QGis::Polygon )
+ newItem = new QListWidgetItem( mLayersListWidget );
+ newItem->setText( currentLayer->name() );
+ newItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsUserCheckable );
+ newItem->setData( Qt::UserRole, currentLayer->getLayerID() );
+ if ( enabledLayers.contains( currentLayer->getLayerID() ) )
+ newItem->setCheckState( Qt::Checked );
+ else
+ newItem->setCheckState( Qt::Unchecked );
+QgsAvoidIntersectionsDialog::~QgsAvoidIntersectionsDialog()
+void QgsAvoidIntersectionsDialog::enabledLayers( QSet<QString>& enabledLayers )
+ enabledLayers.clear();
+ int itemCount = mLayersListWidget->count();
+ QListWidgetItem* currentItem = 0;
+ for ( int i = 0; i < itemCount; ++i )
+ currentItem = mLayersListWidget->item( i );
+ if ( currentItem->checkState() == Qt::Checked )
+ enabledLayers.insert( currentItem->data( Qt::UserRole ).toString() );
Added: trunk/qgis/src/app/qgsavoidintersectionsdialog.h
--- trunk/qgis/src/app/qgsavoidintersectionsdialog.h (rev 0)
+++ trunk/qgis/src/app/qgsavoidintersectionsdialog.h 2009-10-25 15:18:29 UTC (rev 11839)
@@ -0,0 +1,21 @@
+#ifndef QGSAVOIDINTERSECTIONSDIALOG_H
+#define QGSAVOIDINTERSECTIONSDIALOG_H
+#include "ui_qgsavoidintersectionsdialogbase.h"
+class QgsMapCanvas;
+class QgsAvoidIntersectionsDialog: public QDialog, private Ui::QgsAvoidIntersectionsDialogBase
+ Q_OBJECT
+ public:
+ QgsAvoidIntersectionsDialog( QgsMapCanvas* canvas, const QSet<QString>& enabledLayers, QWidget * parent = 0, Qt::WindowFlags f = 0 );
+ ~QgsAvoidIntersectionsDialog();
+ /**Returns ids of layers that are considered for the avoid intersection function*/
+ void enabledLayers( QSet<QString>& enabledLayers );
+ private:
+ QgsMapCanvas* mMapCanvas;
+#endif // QGSAVOIDINTERSECTIONSDIALOG_H
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.cpp
--- trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2009-10-25 15:18:29 UTC (rev 11839)
@@ -21,6 +21,7 @@
#include "qgsfield.h"
#include "qgsgeometry.h"
+#include "qgsmaplayerregistry.h"
#include "qgsproject.h"
#include "qgsrubberband.h"
#include "qgsvectordataprovider.h"
@@ -442,16 +443,27 @@
f->setGeometryAndOwnership( &wkb[0], size );
- //is automatic polygon intersection removal activated?
- int avoidPolygonIntersections = QgsProject::instance()->readNumEntry( "Digitizing", "/AvoidPolygonIntersections", 0 );
- if ( avoidPolygonIntersections != 0 )
+ int avoidIntersectionsReturn = avoidIntersectons( f->geometry() );
+ if ( avoidIntersectionsReturn == 1 )
- if ( vlayer->removePolygonIntersections( f->geometry() ) != 0 )
- QMessageBox::critical( 0, tr( "Error" ), tr( "Could not remove polygon intersection" ) );
+ //not a polygon type. Impossible to get there
+ else if ( avoidIntersectionsReturn == 2 )
+ //bail out...
+ QMessageBox::critical( 0, tr( "Error" ), tr( "The feature could not be added because removing the polygon intersections would change the geometry type" ) );
+ delete f;
+ delete mRubberBand;
+ mRubberBand = 0;
+ mCaptureList.clear();
+ return;
+ else if ( avoidIntersectionsReturn == 3 )
+ QMessageBox::critical( 0, tr( "Error" ), tr( "An error was reported during intersection removal" ) );
// add the fields to the QgsFeature
@@ -507,3 +519,47 @@
+int QgsMapToolAddFeature::avoidIntersectons( QgsGeometry* g )
+ int returnValue = 0;
+ //check if g has polygon type
+ if ( !g || g->type() != QGis::Polygon )
+ return 1;
+ QGis::WkbType geomTypeBeforeModification = g->wkbType();
+ //read avoid intersections list from project properties
+ bool listReadOk;
+ QStringList avoidIntersectionsList = QgsProject::instance()->readListEntry( "Digitizing", "/AvoidIntersectionsList", &listReadOk );
+ if ( !listReadOk )
+ return true; //no intersections stored in project does not mean error
+ //go through list, convert each layer to vector layer and call QgsVectorLayer::removePolygonIntersections for each
+ QStringList::const_iterator aIt = avoidIntersectionsList.constBegin();
+ for ( ; aIt != avoidIntersectionsList.constEnd(); ++aIt )
+ currentLayer = dynamic_cast<QgsVectorLayer*>( QgsMapLayerRegistry::instance()->mapLayer( *aIt ) );
+ if ( currentLayer->removePolygonIntersections( g ) != 0 )
+ returnValue = 3;
+ //make sure the geometry still has the same type (e.g. no change from polygon to multipolygon)
+ if ( g->wkbType() != geomTypeBeforeModification )
+ return 2;
+ return returnValue;
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.h
--- trunk/qgis/src/app/qgsmaptooladdfeature.h 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.h 2009-10-25 15:18:29 UTC (rev 11839)
@@ -24,4 +24,9 @@
QgsMapToolAddFeature( QgsMapCanvas* canvas, enum CaptureTool tool );
virtual ~QgsMapToolAddFeature();
void canvasReleaseEvent( QMouseEvent * e );
+ private:
+ /**Modifies geometry to avoid intersections with the layers specified in project properties
+ @return 0 in case of success, 1 if geometry is not of polygon type, 2 if avoid intersection would change the geometry type, \
+ 3 other error during intersection removal*/
+ int avoidIntersectons( QgsGeometry* g );
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2009-10-25 15:18:29 UTC (rev 11839)
@@ -20,6 +20,7 @@
#include "qgsprojectproperties.h"
//qgis includes
#include "qgscontexthelp.h"
#include "qgscoordinatetransform.h"
#include "qgslogger.h"
@@ -113,15 +114,17 @@
mEnableTopologicalEditingCheckBox->setCheckState( Qt::Unchecked );
+ bool avoidIntersectionListOk;
+ mAvoidIntersectionsSettings.clear();
+ QStringList avoidIntersectionsList = QgsProject::instance()->readListEntry( "Digitizing", "/AvoidIntersectionsList", &avoidIntersectionListOk );
+ if ( avoidIntersectionListOk )
- mAvoidIntersectionsCheckBox->setCheckState( Qt::Checked );
+ QStringList::const_iterator avoidIt = avoidIntersectionsList.constBegin();
+ for ( ; avoidIt != avoidIntersectionsList.constEnd(); ++avoidIt )
+ mAvoidIntersectionsSettings.insert( *avoidIt );
- else
- mAvoidIntersectionsCheckBox->setCheckState( Qt::Unchecked );
bool layerIdListOk, enabledListOk, toleranceListOk, toleranceUnitListOk, snapToListOk;
QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &layerIdListOk );
@@ -399,9 +402,17 @@
//write the digitizing settings
int topologicalEditingEnabled = ( mEnableTopologicalEditingCheckBox->checkState() == Qt::Checked ) ? 1 : 0;
QgsProject::instance()->writeEntry( "Digitizing", "/TopologicalEditing", topologicalEditingEnabled );
- int avoidPolygonIntersectionsEnabled = ( mAvoidIntersectionsCheckBox->checkState() == Qt::Checked ) ? 1 : 0;
- QgsProject::instance()->writeEntry( "Digitizing", "/AvoidPolygonIntersections", avoidPolygonIntersectionsEnabled );
+ //store avoid intersection layers
+ QStringList avoidIntersectionList;
+ QSet<QString>::const_iterator avoidIt = mAvoidIntersectionsSettings.constBegin();
+ for ( ; avoidIt != mAvoidIntersectionsSettings.constEnd(); ++avoidIt )
+ avoidIntersectionList.append( *avoidIt );
+ QgsProject::instance()->writeEntry( "Digitizing", "/AvoidIntersectionsList", avoidIntersectionList );
QMap<QString, LayerEntry>::const_iterator layerEntryIt;
//store the layer snapping settings as string lists
@@ -498,6 +509,15 @@
QgsContextHelp::run( context_id );
+void QgsProjectProperties::on_mAvoidIntersectionsPushButton_clicked()
+ QgsAvoidIntersectionsDialog d( mMapCanvas, mAvoidIntersectionsSettings );
+ if ( d.exec() == QDialog::Accepted )
+ d.enabledLayers( mAvoidIntersectionsSettings );
void QgsProjectProperties::on_mSnappingOptionsPushButton_clicked()
QgsSnappingDialog d( mMapCanvas, mSnappingLayerSettings );
Modified: trunk/qgis/src/app/qgsprojectproperties.h
--- trunk/qgis/src/app/qgsprojectproperties.h 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/app/qgsprojectproperties.h 2009-10-25 15:18:29 UTC (rev 11839)
@@ -89,7 +89,12 @@
void on_buttonBox_helpRequested();
- * Slot to show dialog for advanced editing options
+ void on_mAvoidIntersectionsPushButton_clicked();
+ * Slot to show dialog for the layer snapping options
void on_mSnappingOptionsPushButton_clicked();
@@ -114,7 +119,10 @@
snapping tolerance*/
QMap<QString, LayerEntry> mSnappingLayerSettings;
+ /**Stores ids of layers where intersections of new polygons is considered. Is passed to / read from QgsAvoidIntersectionsDialog*/
+ QSet<QString> mAvoidIntersectionsSettings;
* Function to save dialog window state
Added: trunk/qgis/src/ui/qgsavoidintersectionsdialogbase.ui
--- trunk/qgis/src/ui/qgsavoidintersectionsdialogbase.ui (rev 0)
+++ trunk/qgis/src/ui/qgsavoidintersectionsdialogbase.ui 2009-10-25 15:18:29 UTC (rev 11839)
@@ -0,0 +1,66 @@
+<ui version="4.0" >
+ <class>QgsAvoidIntersectionsDialogBase</class>
+ <widget class="QDialog" name="QgsAvoidIntersectionsDialogBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>365</width>
+ <height>300</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>Dialog</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout" >
+ <item row="0" column="0" >
+ <widget class="QListWidget" name="mLayersListWidget" />
+ </item>
+ <item row="1" column="0" >
+ <widget class="QDialogButtonBox" name="mButtonBox" >
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>mButtonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsAvoidIntersectionsDialogBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>248</x>
+ <y>254</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>157</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>316</x>
+ <y>260</y>
+ </hint>
+ <x>286</x>
+ <y>274</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-10-24 22:33:56 UTC (rev 11838)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-10-25 15:18:29 UTC (rev 11839)
@@ -5,7 +5,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>492</width>
+ <width>500</width>
<height>557</height>
</rect>
</property>
@@ -18,17 +18,7 @@
<property name="modal" >
<bool>true</bool>
</property>
- <layout class="QGridLayout" >
- <item row="2" column="0" >
- <widget class="QDialogButtonBox" name="buttonBox" >
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="standardButtons" >
- <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
+ <layout class="QGridLayout" name="gridLayout_2" >
<widget class="QTabWidget" name="tabWidget" >
<property name="currentIndex" >
@@ -80,7 +70,7 @@
<property name="sizeType" >
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0" >
<size>
<width>40</width>
<height>20</height>
@@ -116,7 +106,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -163,7 +153,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -286,7 +276,7 @@
<property name="title" >
<string>Digitizing</string>
</property>
<widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
<property name="text" >
@@ -295,9 +285,9 @@
</widget>
</item>
- <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
+ <widget class="QPushButton" name="mAvoidIntersectionsPushButton" >
- <string>Avoid intersections of new polygons</string>
+ <string>Avoid intersections of new polygons...</string>
</property>
</widget>
</item>
@@ -373,6 +363,16 @@
</widget>
</widget>
</item>
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ </property>
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
@@ -402,7 +402,6 @@
<tabstop>radManual</tabstop>
<tabstop>spinBoxDP</tabstop>
<tabstop>mEnableTopologicalEditingCheckBox</tabstop>
- <tabstop>mAvoidIntersectionsCheckBox</tabstop>
<tabstop>mSnappingOptionsPushButton</tabstop>
<tabstop>buttonBox</tabstop>
<tabstop>cbxProjectionEnabled</tabstop>
