[QGIS Commit] r11867 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org
Fri Oct 30 05:34:46 EDT 2009
Author: mhugent
Date: 2009-10-30 05:34:45 -0400 (Fri, 30 Oct 2009)
New Revision: 11867
trunk/qgis/src/core/composer/qgscomposermap.cpp
trunk/qgis/src/core/composer/qgscomposermap.h
disable global composer map counter. Fixes ticket 2042
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-10-30 07:20:26 UTC (rev 11866)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-10-30 09:34:45 UTC (rev 11867)
@@ -39,8 +39,6 @@
#include <iostream>
#include <cmath>
-int QgsComposerMap::mCurrentComposerId = 0;
QgsComposerMap::QgsComposerMap( QgsComposition *composition, int x, int y, int width, int height )
: QgsComposerItem( x, y, width, height, composition ), mKeepLayerSet( false ), mGridEnabled( false ), mGridStyle( Solid ), \
mGridIntervalX( 0.0 ), mGridIntervalY( 0.0 ), mGridOffsetX( 0.0 ), mGridOffsetY( 0.0 ), mGridAnnotationPrecision( 3 ), mShowGridAnnotation( false ), \
@@ -48,8 +46,8 @@
mRotation( 0 ), mCrossLength( 3 )
mComposition = composition;
+ mId = mComposition->composerMapItems().size();
mMapRenderer = mComposition->mapRenderer();
- mId = mCurrentComposerId++;
mPreviewMode = QgsComposerMap::Rectangle;
mCurrentRectangle = rect();
@@ -87,7 +85,7 @@
@@ -560,6 +558,7 @@
QDomElement composerMapElem = doc.createElement( "ComposerMap" );
+ composerMapElem.setAttribute( "id", mId );
//previewMode
if ( mPreviewMode == Cache )
@@ -643,6 +642,11 @@
return false;
+ QString idRead = itemElem.attribute( "id", "not found" );
+ if ( idRead != "not found" )
+ mId = idRead.toInt();
mPreviewMode = Rectangle;
//previewMode
Modified: trunk/qgis/src/core/composer/qgscomposermap.h
--- trunk/qgis/src/core/composer/qgscomposermap.h 2009-10-30 07:20:26 UTC (rev 11866)
+++ trunk/qgis/src/core/composer/qgscomposermap.h 2009-10-30 09:34:45 UTC (rev 11867)
@@ -309,9 +309,6 @@
/**Stored layer list (used if layer live-link mKeepLayerSet is disabled)*/
QStringList mLayerSet;
- /**For the generation of new unique ids*/
- static int mCurrentComposerId;
/**Establishes signal/slot connection for update in case of layer change*/
void connectUpdateSlot();
