[QGIS Commit] r11872 - trunk/code_examples/2_basic_main_window
svn_qgis at osgeo.org
Sat Oct 31 17:31:34 EDT 2009
Author: timlinux
Date: 2009-10-31 17:31:32 -0400 (Sat, 31 Oct 2009)
New Revision: 11872
trunk/code_examples/2_basic_main_window/CMakeLists.txt
trunk/code_examples/2_basic_main_window/tutorial2.t2t
Remove cmake warnings and doc cleanups
Modified: trunk/code_examples/2_basic_main_window/CMakeLists.txt
--- trunk/code_examples/2_basic_main_window/CMakeLists.txt 2009-10-31 21:20:22 UTC (rev 11871)
+++ trunk/code_examples/2_basic_main_window/CMakeLists.txt 2009-10-31 21:31:32 UTC (rev 11872)
@@ -1,3 +1,4 @@
+cmake_minimum_required(VERSION 2.6)
PROJECT(timtut2)
SET(CMAKE_COLOR_MAKEFILE ON)
# set path to additional CMake modules
Modified: trunk/code_examples/2_basic_main_window/tutorial2.t2t
--- trunk/code_examples/2_basic_main_window/tutorial2.t2t 2009-10-31 21:20:22 UTC (rev 11871)
+++ trunk/code_examples/2_basic_main_window/tutorial2.t2t 2009-10-31 21:31:32 UTC (rev 11872)
@@ -38,7 +38,8 @@
tutorial where we show you how to use QgsMapTool - the base class for all tools
that need to interact with the canvas.
-**Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim**
+**Updated November 2008 to use cmake build system and the updated QGIS 1.0.0
+API. Tim**
[images/tutorial2.jpg]
@@ -64,9 +65,6 @@
including c++ sources, icons and a simple data file under data. There is also
the .ui file for the main window.
-**Note:** You will need to edit the .pro file in the above svn directory to
-match your system.
Since much of the code is the same as the previous tutorial, I will focus on
the MapTool specifics - the rest of the implementation details can be
investigated by checking out the project form SVN. A QgsMapTool is a class that
@@ -76,20 +74,20 @@
start of the file:
- // QGIS Map tools
- #include "qgsmaptoolpan.h"
- #include "qgsmaptoolzoom.h"
- // These are the other headers for available map tools
- // (not used in this example)
- //#include "qgsmaptoolcapture.h"
- //#include "qgsmaptoolidentify.h"
- //#include "qgsmaptoolselect.h"
- //#include "qgsmaptoolvertexedit.h"
- //#include "qgsmeasure.h"
+// QGIS Map tools
+#include "qgsmaptoolpan.h"
+#include "qgsmaptoolzoom.h"
+// These are the other headers for available map tools
+// (not used in this example)
+//#include "qgsmaptoolcapture.h"
+//#include "qgsmaptoolidentify.h"
+//#include "qgsmaptoolselect.h"
+//#include "qgsmaptoolvertexedit.h"
+//#include "qgsmeasure.h"
As you can see, I am only using two types of MapTool subclasses for this
@@ -97,36 +95,36 @@
MapTools to the canvas is very easy using the normal Qt4 signal/slot mechanism:
- //create the action behaviours
- connect(mActionPan, SIGNAL(triggered()), this, SLOT(panMode()));
- connect(mActionZoomIn, SIGNAL(triggered()), this, SLOT(zoomInMode()));
- connect(mActionZoomOut, SIGNAL(triggered()), this, SLOT(zoomOutMode()));
- connect(mActionAddLayer, SIGNAL(triggered()), this, SLOT(addLayer()));
+//create the action behaviours
+connect(mActionPan, SIGNAL(triggered()), this, SLOT(panMode()));
+connect(mActionZoomIn, SIGNAL(triggered()), this, SLOT(zoomInMode()));
+connect(mActionZoomOut, SIGNAL(triggered()), this, SLOT(zoomOutMode()));
+connect(mActionAddLayer, SIGNAL(triggered()), this, SLOT(addLayer()));
Next we make a small toolbar to hold our toolbuttons. Note that the mpAction*
actions were created in designer.
- //create a little toolbar
- mpMapToolBar = addToolBar(tr("File"));
- mpMapToolBar->addAction(mpActionAddLayer);
- mpMapToolBar->addAction(mpActionZoomIn);
- mpMapToolBar->addAction(mpActionZoomOut);
- mpMapToolBar->addAction(mpActionPan);
+//create a little toolbar
+mpMapToolBar = addToolBar(tr("File"));
+mpMapToolBar->addAction(mpActionAddLayer);
+mpMapToolBar->addAction(mpActionZoomIn);
+mpMapToolBar->addAction(mpActionZoomOut);
+mpMapToolBar->addAction(mpActionPan);
Thats really pretty straightforward Qt stuff too. Now we create our three map
tools:
- //create the maptools
- mpPanTool = new QgsMapToolPan(mpMapCanvas);
- mpPanTool->setAction(mpActionPan);
- mpZoomInTool = new QgsMapToolZoom(mpMapCanvas, FALSE); // false = in
- mpZoomInTool->setAction(mpActionZoomIn);
- mpZoomOutTool = new QgsMapToolZoom(mpMapCanvas, TRUE ); //true = out
- mpZoomOutTool->setAction(mpActionZoomOut);
+//create the maptools
+mpPanTool = new QgsMapToolPan(mpMapCanvas);
+mpPanTool->setAction(mpActionPan);
+mpZoomInTool = new QgsMapToolZoom(mpMapCanvas, FALSE); // false = in
+mpZoomInTool->setAction(mpActionZoomIn);
+mpZoomOutTool = new QgsMapToolZoom(mpMapCanvas, TRUE ); //true = out
+mpZoomOutTool->setAction(mpActionZoomOut);
Again nothing here is very complicated - we are creating tool instances, each
@@ -135,10 +133,10 @@
set. For example when the pan icon is clicked, we do this:
- void MainWindow::panMode()
- mpMapCanvas->setMapTool(mpPanTool);
+void MainWindow::panMode()
+ mpMapCanvas->setMapTool(mpPanTool);
@@ -148,12 +146,14 @@
using MapTools is really easy and only requires a few lines of code for each
MapTool you want to provide.
-You can check out and build this tutorial using SVN and CMake using the following steps:
+You can check out and build this tutorial using SVN and CMake using the
+following steps:
svn co https://svn.osgeo.org/qgis/trunk/code_examples/2_basic_main_window
cd 2_basic_main_window
mkdir build
+cd build
#optionally specify where your QGIS is installed (should work on all platforms)
#if your QGIS is installed to /usr or /usr/local you can leave this next step out
export LIB_DIR=/home/timlinux/apps
