[QGIS Commit] r11538 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Tue Sep 1 13:50:56 EDT 2009
Author: jef
Date: 2009-09-01 13:50:56 -0400 (Tue, 01 Sep 2009)
New Revision: 11538
trunk/qgis/src/ui/qgsserversourceselectbase.ui
fix wms ui
Modified: trunk/qgis/src/ui/qgsserversourceselectbase.ui
--- trunk/qgis/src/ui/qgsserversourceselectbase.ui 2009-09-01 17:41:24 UTC (rev 11537)
+++ trunk/qgis/src/ui/qgsserversourceselectbase.ui 2009-09-01 17:50:56 UTC (rev 11538)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>510</width>
- <height>439</height>
+ <height>508</height>
</rect>
</property>
<property name="windowTitle">
@@ -272,7 +272,7 @@
</property>
</widget>
</item>
- <item row="3" column="1">
+ <item row="4" column="1">
<widget class="QPushButton" name="btnHelp">
<property name="enabled">
<bool>true</bool>
@@ -288,7 +288,7 @@
</property>
</widget>
</item>
- <item row="3" column="2">
+ <item row="4" column="2">
<spacer>
<property name="orientation">
<enum>Qt::Horizontal</enum>
@@ -304,7 +304,7 @@
</property>
</spacer>
</item>
- <item row="3" column="3">
+ <item row="4" column="3">
<widget class="QPushButton" name="btnAdd">
<bool>false</bool>
@@ -323,7 +323,7 @@
</property>
</widget>
</item>
- <item row="3" column="4">
+ <item row="4" column="4">
<widget class="QPushButton" name="btnCancel">
<property name="text">
<string>C&lose</string>
@@ -336,7 +336,7 @@
</property>
</widget>
</item>
- <item row="4" column="1" colspan="4">
+ <item row="5" column="1" colspan="4">
<widget class="QLabel" name="labelStatus">
<property name="sizePolicy">
<sizepolicy hsizetype="Ignored" vsizetype="Preferred">
@@ -352,7 +352,7 @@
</property>
</widget>
</item>
- <item row="2" column="4">
+ <item row="3" column="1" colspan="4">
<widget class="QGroupBox" name="gbCRS">
<property name="title">
<string>Coordinate Reference System</string>
@@ -394,7 +394,7 @@
</layout>
</widget>
</item>
- <item row="2" column="1" colspan="3">
+ <item row="2" column="1" colspan="4">
<widget class="QGroupBox" name="groupBox">
<string>Layer name</string>
