[QGIS Commit] r11540 - in trunk/qgis: python/gui src/app src/gui
src/plugins/georeferencer
svn_qgis at osgeo.org
Wed Sep 2 18:41:44 EDT 2009
Author: jef
Date: 2009-09-02 18:41:43 -0400 (Wed, 02 Sep 2009)
New Revision: 11540
trunk/qgis/python/gui/qgsmapcanvas.sip
trunk/qgis/python/gui/qgsmaptoolemitpoint.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/gui/qgsmapcanvas.h
trunk/qgis/src/gui/qgsmaptoolemitpoint.h
trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp
trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.h
fix python plugin crashes - changes GUI API
- QgsMapCanvas::xyCoordinates(QgsPoint & p) => xyCoordinates(const QgsPoint & p)
- QgsMapToolEmitPoint::canvasClicked(QgsPoint& point, Qt::MouseButton button) => canvasClicked( const QgsPoint& point, Qt::MouseButton button)
- might be a SIP 4.8 problem
Modified: trunk/qgis/python/gui/qgsmapcanvas.sip
--- trunk/qgis/python/gui/qgsmapcanvas.sip 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/python/gui/qgsmapcanvas.sip 2009-09-02 22:41:43 UTC (rev 11540)
@@ -224,9 +224,11 @@
signals:
/** Let the owner know how far we are with render operations */
void setProgress(int,int);
- /** emits current mouse position */
- void xyCoordinates(QgsPoint & p);
+ /** emits current mouse position
+ \note changed in 1.3 */
+ void xyCoordinates(const QgsPoint &p);
//! Emitted when the scale of the map changes
void scaleChanged(QString);
Modified: trunk/qgis/python/gui/qgsmaptoolemitpoint.sip
--- trunk/qgis/python/gui/qgsmaptoolemitpoint.sip 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/python/gui/qgsmaptoolemitpoint.sip 2009-09-02 22:41:43 UTC (rev 11540)
@@ -19,7 +19,7 @@
virtual void canvasReleaseEvent(QMouseEvent * e);
signals:
//! signal emitted on canvas click
- void canvasClicked(QgsPoint& point, Qt::MouseButton button);
+ // \note changed in 1.3
+ void canvasClicked( const QgsPoint &point, Qt::MouseButton button);
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-09-02 22:41:43 UTC (rev 11540)
@@ -1680,7 +1680,7 @@
mMapTools.mNodeTool, SLOT( currentLayerChanged( QgsMapLayer* ) ) );
//signal when mouse moved over window (coords display in status bar)
- connect( mMapCanvas, SIGNAL( xyCoordinates( QgsPoint & ) ), this, SLOT( showMouseCoordinate( QgsPoint & ) ) );
+ connect( mMapCanvas, SIGNAL( xyCoordinates( const QgsPoint & ) ), this, SLOT( showMouseCoordinate( const QgsPoint & ) ) );
connect( mMapCanvas->mapRenderer(), SIGNAL( drawingProgress( int, int ) ), this, SLOT( showProgress( int, int ) ) );
connect( mMapCanvas->mapRenderer(), SIGNAL( hasCrsTransformEnabled( bool ) ), this, SLOT( hasCrsTransformEnabled( bool ) ) );
connect( mMapCanvas->mapRenderer(), SIGNAL( destinationSrsChanged() ), this, SLOT( destinationSrsChanged() ) );
@@ -4641,7 +4641,7 @@
vlayer->triggerRepaint();
-void QgisApp::showMouseCoordinate( QgsPoint & p )
+void QgisApp::showMouseCoordinate( const QgsPoint & p )
if ( mMapTipsVisible )
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/app/qgisapp.h 2009-09-02 22:41:43 UTC (rev 11540)
@@ -394,7 +394,7 @@
/** toggles whether the current selected layer is in overview or not */
void isInOverview();
//! Slot to show the map coordinate position of the mouse cursor
- void showMouseCoordinate( QgsPoint & );
+ void showMouseCoordinate( const QgsPoint & );
//! Slot to show current map scale;
void showScale( double theScale );
//! Slot to handle user scale input;
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/gui/qgsmapcanvas.h 2009-09-02 22:41:43 UTC (rev 11540)
@@ -285,9 +285,11 @@
signals:
void setProgress( int, int );
- void xyCoordinates( QgsPoint & p );
+ void xyCoordinates( const QgsPoint & p );
void scaleChanged( double );
Modified: trunk/qgis/src/gui/qgsmaptoolemitpoint.h
--- trunk/qgis/src/gui/qgsmaptoolemitpoint.h 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/gui/qgsmaptoolemitpoint.h 2009-09-02 22:41:43 UTC (rev 11540)
@@ -47,7 +47,8 @@
signals:
- void canvasClicked( QgsPoint& point, Qt::MouseButton button );
+ void canvasClicked( const QgsPoint& point, Qt::MouseButton button );
#endif
Modified: trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp 2009-09-02 22:41:43 UTC (rev 11540)
@@ -40,8 +40,8 @@
mToolEmitPoint = new QgsMapToolEmitPoint( qgisCanvas );
mToolEmitPoint->setButton( btnPointFromCanvas );
- connect(( QgsMapToolEmitPoint* )mToolEmitPoint, SIGNAL( canvasClicked( QgsPoint&, Qt::MouseButton ) ),
- this, SLOT( maybeSetXY( QgsPoint&, Qt::MouseButton ) ) );
+ connect(( QgsMapToolEmitPoint* )mToolEmitPoint, SIGNAL( canvasClicked( const QgsPoint&, Qt::MouseButton ) ),
+ this, SLOT( maybeSetXY( const QgsPoint&, Qt::MouseButton ) ) );
connect( leXCoord, SIGNAL( textChanged( const QString& ) ), this, SLOT( updateOK() ) );
connect( leYCoord, SIGNAL( textChanged( const QString& ) ), this, SLOT( updateOK() ) );
@@ -73,7 +73,7 @@
reject();
-void MapCoordsDialog::maybeSetXY( QgsPoint & xy, Qt::MouseButton button )
+void MapCoordsDialog::maybeSetXY( const QgsPoint & xy, Qt::MouseButton button )
// Only LeftButton should set point
if ( Qt::LeftButton == button )
Modified: trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.h
--- trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.h 2009-09-02 19:52:16 UTC (rev 11539)
+++ trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.h 2009-09-02 22:41:43 UTC (rev 11540)
@@ -35,7 +35,7 @@
void on_btnPointFromCanvas_clicked();
- void maybeSetXY( QgsPoint &, Qt::MouseButton );
+ void maybeSetXY( const QgsPoint &, Qt::MouseButton );
void updateOK();
private:
