[QGIS Commit] r11565 - in trunk/qgis/src: helpviewer plugins/coordinate_capture plugins/copyright_label plugins/delimited_text plugins/dxf2shp_converter plugins/gps_importer plugins/north_arrow plugins/scale_bar
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Sep 5 11:03:26 EDT 2009
Author: jef
Date: 2009-09-05 11:03:25 -0400 (Sat, 05 Sep 2009)
New Revision: 11565
   trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
   trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
   trunk/qgis/src/plugins/copyright_label/pluginguibase.ui
   trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui
   trunk/qgis/src/plugins/gps_importer/qgsgpspluginguibase.ui
   trunk/qgis/src/plugins/north_arrow/pluginguibase.ui
   trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
more ui cleanups
Modified: trunk/qgis/src/helpviewer/qgshelpviewerbase.ui
--- trunk/qgis/src/helpviewer/qgshelpviewerbase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/helpviewer/qgshelpviewerbase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>QGIS Help</string>
   </property>
   <property name="windowIcon" >
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
   <property name="sizeGripEnabled" >
    <bool>true</bool>
Modified: trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui
--- trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/coordinate_capture/coordinatecaptureguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>QGIS Plugin Template</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
   <layout class="QGridLayout" >
    <property name="margin" >
Modified: trunk/qgis/src/plugins/copyright_label/pluginguibase.ui
--- trunk/qgis/src/plugins/copyright_label/pluginguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/copyright_label/pluginguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>Copyright Label Plugin</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
    <property name="leftMargin" >
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextpluginguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>Create a Layer from a Delimited Text File</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -25,7 +25,9 @@
    <string>Dxf Importer</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
    <item row="0" column="0" >
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpspluginguibase.ui
--- trunk/qgis/src/plugins/gps_importer/qgsgpspluginguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpspluginguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>GPS Tools</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
Modified: trunk/qgis/src/plugins/north_arrow/pluginguibase.ui
--- trunk/qgis/src/plugins/north_arrow/pluginguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/north_arrow/pluginguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>North Arrow Plugin</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
Modified: trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
--- trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-09-05 14:57:15 UTC (rev 11564)
+++ trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-09-05 15:03:25 UTC (rev 11565)
@@ -13,7 +13,9 @@
    <string>Scale Bar Plugin</string>
   </property>
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
More information about the QGIS-commit mailing list
