[QGIS Commit] r11580 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Mon Sep 7 05:42:29 EDT 2009
Author: jef
Date: 2009-09-07 05:42:28 -0400 (Mon, 07 Sep 2009)
New Revision: 11580
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/app/qgsmaptoolidentify.h
trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
trunk/qgis/src/core/qgsdistancearea.cpp
trunk/qgis/src/core/qgsscalecalculator.cpp
multi-layer identify:
- fix busy cursor
- add progress bar
- reduces CRS debugging noise
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-06 22:08:21 UTC (rev 11579)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-07 09:42:28 UTC (rev 11580)
@@ -31,6 +31,7 @@
#include "qgsvectorlayer.h"
#include "qgsproject.h"
#include "qgsmaplayerregistry.h"
+#include "qgisapp.h"
#include <QSettings>
#include <QMessageBox>
@@ -90,16 +91,26 @@
return;
+ QApplication::setOverrideCursor( Qt::WaitCursor );
res = identifyLayer( layer, e->x(), e->y() );
+ QApplication::restoreOverrideCursor();
else
+ connect( this, SIGNAL( identifyProgress( int, int ) ), QgisApp::instance(), SLOT( showProgress( int, int ) ) );
QStringList noIdentifyLayerIdList = QgsProject::instance()->readListEntry( "Identify", "/disabledLayers" );
for ( int i = 0; i < mCanvas->layerCount(); i++ )
QgsMapLayer *layer = mCanvas->layer( i );
+ emit identifyProgress( i, mCanvas->layerCount() );
if ( noIdentifyLayerIdList.contains( layer->getLayerID() ) )
continue;
@@ -110,6 +121,12 @@
break;
+ emit identifyProgress( mCanvas->layerCount(), mCanvas->layerCount() );
+ disconnect( this, SIGNAL( identifyProgress( int, int ) ), QgisApp::instance(), SLOT( showProgress( int, int ) ) );
if ( res )
@@ -178,8 +195,6 @@
calc.setEllipsoid( ellipsoid );
calc.setSourceCrs( layer->srs().srsid() );
- QApplication::setOverrideCursor( Qt::WaitCursor );
QgsFeatureList featureList;
// toLayerCoordinates will throw an exception for an 'invalid' point.
@@ -210,8 +225,6 @@
QgsDebugMsg( QString( "Caught CRS exception %1" ).arg( cse.what() ) );
- QApplication::restoreOverrideCursor();
QgsFeatureList::iterator f_it = featureList.begin();
for ( ; f_it != featureList.end(); ++f_it )
@@ -282,8 +295,6 @@
QgsDebugMsg( "Feature count on identify: " + QString::number( featureCount ) );
return featureCount > 0;
Modified: trunk/qgis/src/app/qgsmaptoolidentify.h
--- trunk/qgis/src/app/qgsmaptoolidentify.h 2009-09-06 22:08:21 UTC (rev 11579)
+++ trunk/qgis/src/app/qgsmaptoolidentify.h 2009-09-07 09:42:28 UTC (rev 11580)
@@ -61,6 +61,9 @@
virtual void deactivate();
+ signals:
+ void identifyProgress( int, int );
private:
bool identifyLayer( QgsMapLayer *layer, int x, int y );
bool identifyRasterLayer( QgsRasterLayer *layer, int x, int y );
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-09-06 22:08:21 UTC (rev 11579)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-09-07 09:42:28 UTC (rev 11580)
@@ -682,7 +682,10 @@
mCRS = OSRNewSpatialReference( NULL );
mIsValidFlag = OSRImportFromProj4( mCRS, theProj4String.toLatin1().constData() ) == OGRERR_NONE;
setMapUnits();
+#if defined(QGISDEBUG) && QGISDEBUG>=3
debugPrint();
+#endif
setlocale( LC_NUMERIC, oldlocale );
@@ -756,7 +759,7 @@
QgsDebugMsg( "Unsupported map units of " + unit );
mMapUnits = QGis::UnknownUnit;
- QgsDebugMsg( "Projection has angular units of " + unit );
+ QgsDebugMsgLevel( "Projection has angular units of " + unit, 3 );
@@ -882,11 +885,11 @@
if ( OSRExportToWkt( theSrs.mCRS, &otherStr ) == OGRERR_NONE )
- QgsDebugMsg( QString( "Comparing " ) + thisStr );
- QgsDebugMsg( QString( " with " ) + otherStr );
+ QgsDebugMsgLevel( QString( "Comparing " ) + thisStr, 3 );
+ QgsDebugMsgLevel( QString( " with " ) + otherStr, 3 );
if ( !strcmp( thisStr, otherStr ) )
- QgsDebugMsg( QString( "MATCHED!" ) + otherStr );
+ QgsDebugMsgLevel( QString( "MATCHED!" ) + otherStr, 3 );
CPLFree( thisStr );
CPLFree( otherStr );
return true;
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp 2009-09-06 22:08:21 UTC (rev 11579)
+++ trunk/qgis/src/core/qgsdistancearea.cpp 2009-09-07 09:42:28 UTC (rev 11580)
@@ -586,7 +586,7 @@
double Qbar1, Qbar2;
double area;
- QgsDebugMsg( "Ellipsoid: " + mEllipsoid );
+ QgsDebugMsgLevel( "Ellipsoid: " + mEllipsoid, 3 );
if (( ! mProjectionsEnabled ) || ( mEllipsoid == "NONE" ) )
return computePolygonFlatArea( points );
Modified: trunk/qgis/src/core/qgsscalecalculator.cpp
--- trunk/qgis/src/core/qgsscalecalculator.cpp 2009-09-06 22:08:21 UTC (rev 11579)
+++ trunk/qgis/src/core/qgsscalecalculator.cpp 2009-09-07 09:42:28 UTC (rev 11580)
@@ -47,7 +47,7 @@
QGis::UnitType QgsScaleCalculator::mapUnits() const
- QgsDebugMsg( QString( "Map units returned as %1" ).arg( QString::number( mMapUnits ) ) );
+ QgsDebugMsgLevel( QString( "Map units returned as %1" ).arg( QString::number( mMapUnits ) ), 3 );
return mMapUnits;
