[QGIS Commit] r11603 - in trunk/qgis: python/plugins/osm
python/plugins/osm/images python/plugins/osm/styles
python/plugins/osm/ui_files src/providers/osm src/python
svn_qgis at osgeo.org
Wed Sep 9 08:16:25 EDT 2009
Author: jef
Date: 2009-09-09 08:16:24 -0400 (Wed, 09 Sep 2009)
New Revision: 11603
Added:
trunk/qgis/python/plugins/osm/images/osm_clearUndoRedo.png
trunk/qgis/python/plugins/osm/images/osm_generateTags.png
trunk/qgis/python/plugins/osm/images/osm_removeFeat.png
trunk/qgis/python/plugins/osm/images/osm_removeMember.png
trunk/qgis/python/plugins/osm/images/osm_removeTag.png
trunk/qgis/python/plugins/osm/OsmAddRelationDlg.py
trunk/qgis/python/plugins/osm/OsmDatabaseManager.py
trunk/qgis/python/plugins/osm/OsmFeatureDW.py
trunk/qgis/python/plugins/osm/OsmLoadDlg.py
trunk/qgis/python/plugins/osm/OsmPlugin.py
trunk/qgis/python/plugins/osm/OsmSaveDlg.py
trunk/qgis/python/plugins/osm/OsmUndoRedoDW.py
trunk/qgis/python/plugins/osm/OsmUploadDlg.py
trunk/qgis/python/plugins/osm/__init__.py
trunk/qgis/python/plugins/osm/images/osm_identify.png
trunk/qgis/python/plugins/osm/images/osm_move.png
trunk/qgis/python/plugins/osm/images/osm_questionMark.png
trunk/qgis/python/plugins/osm/images/osm_urDetails.png
trunk/qgis/python/plugins/osm/resources.qrc
trunk/qgis/python/plugins/osm/styles/big_scale.style
trunk/qgis/python/plugins/osm/styles/medium_scale.style
trunk/qgis/python/plugins/osm/styles/small_scale.style
trunk/qgis/python/plugins/osm/ui_files/OsmAddRelationDlg.ui
trunk/qgis/python/plugins/osm/ui_files/OsmFeatureDW.ui
trunk/qgis/src/providers/osm/osmhandler.cpp
trunk/qgis/src/providers/osm/osmprovider.cpp
trunk/qgis/src/providers/osm/osmprovider.h
trunk/qgis/src/python/qgspythonutilsimpl.cpp
OSM plugin & provider update from Lukas Berka:
- new OSM style files !! map looks pretty good now... (finally)
- new icons !
- some texts on dialogs were changed and completed
- "Saving OSM into file" functionality was improved a little...
- now OSM Plugin verify if osm provider is available...
- fixed some problems with encoding... ascii --> utf-8
- removing all OSM layers automatically after disabling OSM plugin in plugin manager
- some dialogs has been renamed
- other small bugfixes ...
Thanks.
Modified: trunk/qgis/python/plugins/osm/OsmAddRelationDlg.py
--- trunk/qgis/python/plugins/osm/OsmAddRelationDlg.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmAddRelationDlg.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -18,6 +18,7 @@
from qgis.gui import *
import sqlite3
+import unicodedata
@@ -47,9 +48,9 @@
# set icons for tool buttons (identify,move,createPoint,createLine,createPolygon)
self.chooseMemberButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_identify.png"))
- self.removeMemberButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_remove.png"))
- self.removeTagButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_remove.png"))
- self.loadStandardTagsButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_star.png"))
+ self.removeMemberButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_removeMember.png"))
+ self.removeTagButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_removeTag.png"))
+ self.loadStandardTagsButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_generateTags.png"))
self.typeInfoButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_questionMark.png"))
self.info = dict()
@@ -101,6 +102,7 @@
self.relTagsTable.setSelectionMode(QAbstractItemView.ExtendedSelection)
self.relMembersTable.setSelectionBehavior(QAbstractItemView.SelectRows)
self.relTagsTable.setSelectionBehavior(QAbstractItemView.SelectRows)
+ self.typeInfoButton.setEnabled(False)
def connectDlgSignals(self):
@@ -283,6 +285,11 @@
# adding new tag to table
if column==0:
+ # only ascii keys are allowed
+ nkfd_form=unicodedata.normalize('NFKD', unicode(key.toUtf8(),'utf-8'))
+ key_only_ascii=nkfd_form.encode('ASCII', 'ignore')
newLastRow = row+1
self.relTagsTable.setRowCount(row+2)
self.relTagsTable.setItem(newLastRow,0,QTableWidgetItem(self.newTagLabel))
@@ -292,6 +299,7 @@
self.relTagsTable.item(row,0).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled)
self.relTagsTable.item(row,1).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled | Qt.ItemIsEditable)
+ self.relTagsTable.item(row,0).setText(QString(key_only_ascii))
def __onMembersCellChanged(self,row,column):
@@ -426,8 +434,10 @@
# if non-standard typename was set up, loadStandardTagsButton is useless
if typeName.toAscii().data() in self.relationTypes:
self.loadStandardTagsButton.setEnabled(True)
+ self.typeInfoButton.setEnabled(True)
else:
self.loadStandardTagsButton.setEnabled(False)
def determineSuitableMemberRoles(self,relType):
Modified: trunk/qgis/python/plugins/osm/OsmDatabaseManager.py
--- trunk/qgis/python/plugins/osm/OsmDatabaseManager.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmDatabaseManager.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -40,7 +40,6 @@
Initializes inner structures of OsmDatabaseManager and connect signals to appropriate slots.
self.plugin=plugin
self.canvas=plugin.canvas
@@ -50,6 +49,7 @@
self.polygonLayers={}
self.currentKey=None
self.removing=False
+ self.mapReg=QgsMapLayerRegistry.instance()
QObject.connect(self.plugin.iface,SIGNAL("currentLayerChanged(QgsMapLayer*)"),self.currLayerChanged)
QObject.connect(QgsMapLayerRegistry.instance(),SIGNAL("layerWillBeRemoved(QString)"),self.layerRemoved)
@@ -72,14 +72,18 @@
# set new currentKey and tell all other plugin components
if not layer:
- self.plugin.undoredo.databaseChanged(None)
- self.plugin.dockWidget.databaseChanged(None)
+ if self.plugin.undoredo<>None:
+ self.plugin.undoredo.databaseChanged(None)
+ if self.plugin.dockWidget<>None:
+ self.plugin.dockWidget.databaseChanged(None)
return
if layer.type() != QgsMapLayer.VectorLayer or layer.dataProvider().name()<>"osm":
return
# find out filename of new current database
@@ -89,12 +93,18 @@
if dbFileName not in self.dbConns.keys():
return
if dbFileName.toLatin1().data()<>self.currentKey:
self.currentKey=dbFileName.toLatin1().data()
- self.plugin.undoredo.databaseChanged(self.currentKey)
- self.plugin.dockWidget.databaseChanged(self.currentKey)
+ self.plugin.undoredo.databaseChanged(self.currentKey)
+ self.plugin.dockWidget.databaseChanged(self.currentKey)
def layerRemoved(self,layerID):
@@ -112,7 +122,7 @@
return
# get appropriate qgsvectorlayer object
- layer=QgsMapLayerRegistry.instance().mapLayer(layerID)
+ layer=self.mapReg.mapLayer(layerID)
if not layer:
return # strange situation
@@ -126,23 +136,51 @@
dbFileName=layerSource.left(pos)+".db"
key=dbFileName.toLatin1().data()
- # remove all map layers that belong to dbFileName database
+ # remove map layers that belong to dbFileName database
+ if key in self.lineLayers.keys() and layer.getLayerID()==self.lineLayers[key].getLayerID():
+ del self.lineLayers[key]
+ elif key in self.pointLayers.keys() and layer.getLayerID()==self.pointLayers[key].getLayerID():
+ del self.pointLayers[key]
+ if key in self.lineLayers.keys():
+ if self.lineLayers[key]:
+ lineLayID=self.lineLayers[key].getLayerID()
+ self.mapReg.removeMapLayer(lineLayID,True)
+ elif key in self.polygonLayers.keys() and layer.getLayerID()==self.polygonLayers[key].getLayerID():
+ del self.polygonLayers[key]
+ if key in self.pointLayers.keys():
+ if self.pointLayers[key]:
+ pointLayID=self.pointLayers[key].getLayerID()
+ self.mapReg.removeMapLayer(pointLayID,True)
+ if key in self.dbConns.keys():
+ del self.dbConns[key]
+ def removeAllOsmLayers(self):
+ # remove all map layers with osm provider set
self.removing=True
- if layer.getLayerID()<>self.pointLayers[key].getLayerID():
- QgsMapLayerRegistry.instance().removeMapLayer(self.pointLayers[key].getLayerID(),True)
- if layer.getLayerID()<>self.lineLayers[key].getLayerID():
- QgsMapLayerRegistry.instance().removeMapLayer(self.lineLayers[key].getLayerID(),True)
- if layer.getLayerID()<>self.polygonLayers[key].getLayerID():
- QgsMapLayerRegistry.instance().removeMapLayer(self.polygonLayers[key].getLayerID(),True)
+ allLayers=QgsMapLayerRegistry.instance().mapLayers()
+ for ix in allLayers.keys():
+ layer=allLayers[ix] # layer object
+ if not layer:
+ continue
+ if layer.type()==QgsMapLayer.VectorLayer and layer.dataProvider().name()=="osm":
+ QgsMapLayerRegistry.instance().removeMapLayer(layer.getLayerID(),True)
+ self.dbConns={} # map dbFileName->sqlite3ConnectionObject
+ self.pointLayers={}
+ self.lineLayers={}
+ self.polygonLayers={}
+ self.currentKey=None
self.removing=False
- # removed map items of key <dbFileName>
- del self.dbConns[key]
- del self.pointLayers[key]
- del self.lineLayers[key]
- del self.polygonLayers[key]
def addDatabase(self,dbFileName,pointLayer,lineLayer,polygonLayer):
"""Function provides possibility to add new OSM data.
@@ -1661,7 +1699,7 @@
,{"objId":str(featId),"objType":str(osmType)})
for tagRec in c:
- tags.append((tagRec[0],tagRec[1]))
+ tags.append((tagRec[0],tagRec[1].encode('utf-8')))
c.close()
return tags
@@ -1709,7 +1747,7 @@
c=self.getConnection().cursor()
c.execute("update tag set val=:tagVal where object_id=:objId and object_type=:objType and key=:tagKey and u=1"
- ,{"tagVal":tagValue,"objId":str(featId),"objType":osmType,"tagKey":tagKey})
+ ,{"tagVal":unicode(tagValue,'utf-8'),"objId":str(featId),"objType":osmType,"tagKey":tagKey})
for rec in c:
val=rec[0]
@@ -1889,7 +1927,7 @@
osmType=self.convertToOsmType(featType)
c.execute("update tag set val=:val where object_id=:objId and object_type=:objType and key=:key and u=1"
- ,{"val":value,"objId":str(featId),"objType":osmType,"key":key})
+ ,{"val":unicode(value,'utf-8'),"objId":str(featId),"objType":osmType,"key":str(key)})
c.close()
self.commit()
@@ -1902,6 +1940,11 @@
@return True if given tag already exists for given feature; False otherwise
+ if key==None:
+ return False
+ if len(key)==0:
+ return False
tagEx=False
@@ -1990,10 +2033,14 @@
@param doCommit if True then commit is performed after tag insertion
+ val=''
+ if value<>None:
+ val=unicode(value,'utf-8')
c.execute("insert into tag (object_id, object_type, key, val) values (:objId, :objType, :key, :val)"
- ,{"objId":str(featId),"objType":osmType,"key":key,"val":value})
+ ,{"objId":str(featId),"objType":osmType,"key":str(key),"val":val})
c.close()
if doCommit:
self.commit()
@@ -2029,7 +2076,7 @@
c.execute("delete from tag where object_id=:objId and object_type=:objType and key=:key and u=1"
- ,{"objId":str(featId),"objType":osmType,"key":key})
+ ,{"objId":str(featId),"objType":osmType,"key":str(key)})
c.close()
self.commit()
Modified: trunk/qgis/python/plugins/osm/OsmFeatureDW.py
--- trunk/qgis/python/plugins/osm/OsmFeatureDW.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmFeatureDW.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-99
"""@package OsmFeatureDW
This module is descendant of "OSM Feature" dockable widget and makes user able
to view and edit information on selected OSM feature.
@@ -24,6 +25,7 @@
from map_tools.OsmCreatePolygonMT import OsmCreatePolygonMT
from map_tools.OsmMoveMT import OsmMoveMT
from map_tools.OsmIdentifyMT import OsmIdentifyMT
+import unicodedata
class OsmFeatureDW(QDockWidget, Ui_OsmFeatureDW, object):
@@ -54,8 +56,8 @@
self.createLineButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_createLine.png"))
self.createPolygonButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_createPolygon.png"))
self.createRelationButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_createRelation.png"))
- self.removeButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_remove.png"))
- self.deleteTagsButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_remove.png"))
+ self.removeButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_removeFeat.png"))
+ self.deleteTagsButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_removeTag.png"))
self.undoButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_undo.png"))
self.redoButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_redo.png"))
self.addRelationButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_addRelation.png"))
@@ -432,7 +434,7 @@
# store tag's change into database
self.plugin.undoredo.startAction("Change tag value.")
- self.plugin.dbm.changeTagValue(self.feature.id(),self.featureType,key.toUtf8().data(),value.toUtf8().data())
+ self.plugin.dbm.changeTagValue(self.feature.id(),self.featureType,key.toAscii().data(),value.toUtf8())
else:
key = self.tagTable.item(row,0).text()
if key=="" or key==self.newTagLabel:
@@ -441,23 +443,28 @@
# adding new tag and setting its key
if column==0:
# store it into database
- isAlreadyDef=self.plugin.dbm.isTagDefined(self.feature.id(),self.featureType,key.toUtf8().data())
+ isAlreadyDef=self.plugin.dbm.isTagDefined(self.feature.id(),self.featureType,key_only_ascii)
if isAlreadyDef:
# such a key already exists for this relation
self.tagTable.setItem(row,0,QTableWidgetItem(self.newTagLabel))
QMessageBox.information(self, self.tr("OSM Feature Dock Widget")
- ,self.tr("Property '%1' cannot be added twice.").arg(key.toUtf8().data()))
+ ,self.tr(QString("Property '").append(key_only_ascii).append("' cannot be added twice.")))
return
# well, insert new tag into database
self.plugin.undoredo.startAction("Insert new tag.")
- self.plugin.dbm.insertTag(self.feature.id(),self.featureType,key.toUtf8().data(),'')
+ self.plugin.dbm.insertTag(self.feature.id(),self.featureType,key_only_ascii,None)
self.__tagsLoaded=False
self.tagTable.item(row,0).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled)
self.tagTable.item(row,1).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled | Qt.ItemIsEditable)
+ self.tagTable.item(row,0).setText(QString(key_only_ascii))
newLastRow = row+1
self.tagTable.setRowCount(row+2)
@@ -488,7 +495,8 @@
self.plugin.dbm.recacheAffectedNow(affected)
# refresh map canvas so that changes take effect
- self.plugin.canvas.refresh()
+ if column==1:
+ self.plugin.canvas.refresh()
def __onTagsItemDoubleClicked(self,item):
@@ -1236,7 +1244,7 @@
self.plugin.dbm.changeRelationStatus(self.feature.id(),'N','U')
# perform tag removing
- self.plugin.dbm.removeTag(self.feature.id(),self.featureType,key.toUtf8().data())
+ self.plugin.dbm.removeTag(self.feature.id(),self.featureType,key.toAscii().data())
self.tagTable.removeRow(ix)
@@ -1425,8 +1433,8 @@
self.tagTable.setHorizontalHeaderItem(1,QTableWidgetItem("Value"))
for i in range(0,rowCount):
- self.tagTable.setItem(i,0,QTableWidgetItem(tableData[i][0]))
- self.tagTable.setItem(i,1,QTableWidgetItem(tableData[i][1]))
+ self.tagTable.setItem(i,0,QTableWidgetItem(QString.fromUtf8(tableData[i][0])))
+ self.tagTable.setItem(i,1,QTableWidgetItem(QString.fromUtf8(tableData[i][1])))
self.tagTable.item(i,0).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled)
self.tagTable.item(i,1).setFlags(Qt.ItemIsSelectable | Qt.ItemIsEnabled | Qt.ItemIsEditable)
Modified: trunk/qgis/python/plugins/osm/OsmLoadDlg.py
--- trunk/qgis/python/plugins/osm/OsmLoadDlg.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmLoadDlg.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -214,11 +214,9 @@
st=self.styles[self.styleCombo.currentIndex()]
if st=="Small scale":
- rect=QgsRectangle(midX-rX/6,midY-rY/6,midX+rX/6,midY+rY/6)
+ rect=QgsRectangle(midX-rX/5,midY-rY/5,midX+rX/5,midY+rY/5)
elif st=="Medium scale":
- rect=QgsRectangle(midX-rX/3,midY-rY/3,midX+rX/3,midY+rY/3)
- else:
- rect=QgsRectangle(midX-rX/1.2,midY-rY/1.2,midX+rX/1.2,midY+rY/1.2)
+ rect=QgsRectangle(midX-rX/2,midY-rY/2,midX+rX/2,midY+rY/2)
self.canvas.setExtent(rect)
self.canvas.refresh()
@@ -310,6 +308,7 @@
self.progress = None
QMessageBox.information(self,"Error",QString("Failed to load layers: %1")
.arg(self.property("osm_failure").toString()))
+ self.buttonBox.setEnabled(True)
qApp.processEvents()
return QDialog.event(self,e)
Modified: trunk/qgis/python/plugins/osm/OsmPlugin.py
--- trunk/qgis/python/plugins/osm/OsmPlugin.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmPlugin.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -34,6 +34,15 @@
+def versionNumber():
+ """Returns current version number of OpenStreetMap plugin.
+ @return current version number of the plugin
+ return "0.5"
class OsmPlugin:
"""OsmPlugin is the main class OSM Plugin module.
@@ -164,11 +173,16 @@
del self.dockWidget
del self.undoredo
+ self.dockWidget=None
+ self.undoredo=None
# remove toolbar
del self.toolBar
+ # w/o osm plugin we don't need osm layers
+ self.dbm.removeAllOsmLayers()
def loadOsmFromFile(self):
"""Function shows up the "Load OSM from file" dialog.
@@ -206,6 +220,10 @@
according to dialog's return code.
+ if 'osm' not in QgsProviderRegistry.instance().providerList():
+ QMessageBox.critical(None, "Sorry", "You don't have OSM provider installed!")
+ return
if not self.dbm.currentKey:
QMessageBox.information(QWidget(), QString("OSM Save to file")
,"No OSM data are loaded/downloaded or no OSM layer is selected in Layers panel. \
@@ -227,6 +245,10 @@
+ return
self.dlgDownload=OsmDownloadDlg(self)
self.dlgDownload.exec_()
if not self.dlgDownload.httpSuccess:
@@ -270,6 +292,10 @@
+ return
# first check if there are some data; if not upload doesn't have sense
QMessageBox.information(QWidget(), QString("OSM Upload")
@@ -288,6 +314,10 @@
+ return
if self.dbm.currentKey is None:
QMessageBox.information(self.iface.mainWindow(), "OSM Import"
Modified: trunk/qgis/python/plugins/osm/OsmSaveDlg.py
--- trunk/qgis/python/plugins/osm/OsmSaveDlg.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmSaveDlg.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -14,7 +14,6 @@
from PyQt4 import *
from sip import unwrapinstance
from qgis.core import QgsVectorLayer, QgsMapLayerRegistry
-#from sip import *
import sqlite3
@@ -44,6 +43,10 @@
self.progressDialog.setModal(True)
self.progressDialog.setAutoClose(False)
+ # variables for identifiers of all objects that will be saved to output file
+ self.nodeIds=set()
+ # connecting dialog and progressbar signals
QObject.connect(self.browseOSMButton,SIGNAL("clicked()"),self.showSaveFileDialog)
QObject.connect(self.buttonBox,SIGNAL("accepted()"),self.onOK)
QObject.connect(self.progressDialog, SIGNAL("canceled()"), self.cancelSaving)
@@ -62,15 +65,10 @@
self.outFile.remove()
self.outFile=None
-# if self.xml.device().isOpen():
-# self.xml.device().close()
# close the whole Save OSM dialog
self.close()
- # todo: segfault... why????
def showSaveFileDialog(self):
"""Function opens dialog for selecting XML file.
@@ -98,7 +96,8 @@
It performs all actions neccessary for OSM data saving.
- # after closing a dialog, we want to save data into osm
+ # prepare data
self.fname=self.OSMFileEdit.text()
self.outFile=QFile(self.fname)
@@ -118,8 +117,7 @@
self.xml.setCodec(QTextCodec.codecForName("utf-8"))
self.xml.setAutoFormatting(True)
- self.dbConnection=sqlite3.connect(self.plugin.dbFileName.toLatin1().data())
- c=self.dbConnection.cursor()
+ c=self.dbm.getConnection().cursor()
cntPoints=cntLines=cntPolys=cntRels=0
c.execute("select count(*) from node")
@@ -146,23 +144,36 @@
self.progressDialog.setValue(0)
self.progressDialog.show()
- # todo: <bounds> element?
- # todo: and what about uid? changeset? are they compulsory?
+ # <bounds> element
+ dataExtent=self.plugin.canvas.extent()
+ self.xml.writeEmptyElement("bounds")
+ self.xml.writeAttribute("minlat",str(dataExtent.yMinimum()))
+ self.xml.writeAttribute("minlon",str(dataExtent.xMinimum()))
+ self.xml.writeAttribute("maxlat",str(dataExtent.yMaximum()))
+ self.xml.writeAttribute("maxlon",str(dataExtent.xMaximum()))
+ # todo: uid and changeset attributes are not compulsory! support for them in future!
if points:
self.progressDialog.setLabelText(self.tr("Saving nodes..."))
self.progressDialog.setMaximum(cntPoints)
i=0
- c.execute("select n.id,n.lat,n.lon,v.version_id,n.user,n.timestamp from \
- node n,version v where v.object_id=n.id and v.object_type='node'")
- for rec in c:
+ c.execute("select n.id,n.lat,n.lon,v.version_id,n.user,n.timestamp from node n, version v \
+ where n.status<>'R' and n.u=1 and v.object_id=n.id and v.object_type='node' \
+ and n.lat>=:minLat AND n.lat<=:maxLat AND n.lon>=:minLon AND n.lon<=:maxLon"
+ ,{"minLat":dataExtent.yMinimum(),"maxLat":dataExtent.yMaximum()
+ ,"minLon":dataExtent.xMinimum(),"maxLon":dataExtent.xMaximum()})
+ for (nid,lat,lon,ver,usr,tms) in c:
anyTags=False
tagList=[]
+ self.nodeIds.add(nid)
if tags:
- tagList=self.dbm.getFeatureTags(rec[0],'Point')
+ tagList=self.dbm.getFeatureTags(nid,'Point')
if len(tagList)>0:
anyTags=True
@@ -171,22 +182,22 @@
else:
self.xml.writeEmptyElement("node")
- self.xml.writeAttribute("id",str(rec[0]))
- self.xml.writeAttribute("lat",str(rec[1]))
- self.xml.writeAttribute("lon",str(rec[2]))
- self.xml.writeAttribute("version",str(rec[3]))
- self.xml.writeAttribute("user",rec[4])
+ self.xml.writeAttribute("id",str(nid))
+ self.xml.writeAttribute("lat",str(lat))
+ self.xml.writeAttribute("lon",str(lon))
+ self.xml.writeAttribute("version",str(ver))
+ if usr<>"":
+ self.xml.writeAttribute("user",usr)
self.xml.writeAttribute("visible","true")
- self.xml.writeAttribute("timestamp",rec[5])
+ self.xml.writeAttribute("timestamp",tms)
if anyTags:
for r in tagList:
self.xml.writeEmptyElement("tag")
self.xml.writeAttribute("k",r[0])
self.xml.writeAttribute("v",r[1])
+ self.xml.writeEndElement()
- if anyTags:
- self.xml.writeEndElement()
i=i+1
self.progressDialog.setValue(i)
@@ -197,31 +208,90 @@
i=0
c.execute("select w.id,v.version_id,w.user,w.timestamp from way w,version v \
- where w.closed=0 and v.object_id=w.id and v.object_type='way'")
- for rec in c:
+ where w.closed=0 and w.status<>'R' and w.u=1 and v.object_id=w.id and v.object_type='way' \
+ and (((w.max_lat between :minLat and :maxLat) or (w.min_lat between :minLat and :maxLat) or (w.min_lat<:minLat and w.max_lat>:maxLat)) \
+ and ((w.max_lon between :minLon and :maxLon) or (w.min_lon between :minLon and :maxLon) or (w.min_lon<:minLon and w.max_lon>:maxLon)))"
+ for (lid,ver,usr,tms) in c:
+ geom=self.dbm.getFeatureGeometry(lid,'Line')
+ if not geom.intersects(dataExtent):
+ continue
self.xml.writeStartElement("way")
+ self.xml.writeAttribute("id",str(lid))
- self.xml.writeAttribute("timestamp",rec[3])
- self.xml.writeAttribute("version",str(rec[1]))
- self.xml.writeAttribute("user",rec[2])
+ if usr<>"":
- d=self.dbConnection.cursor()
- d.execute("select node_id from way_member where way_id=:wayId",{"wayId":rec[0]})
+ d=self.dbm.getConnection().cursor()
+ d.execute("select node_id from way_member where way_id=:wayId",{"wayId":lid})
for r in d:
- self.xml.writeStartElement("nd")
+ self.xml.writeEmptyElement("nd")
self.xml.writeAttribute("ref",str(r[0]))
d.close()
if tags:
- tagList=self.dbm.getFeatureTags(rec[0],'Line')
+ tagList=self.dbm.getFeatureTags(lid,'Line')
for r in tagList:
+ for r in d:
+ if r[0] not in self.nodeIds:
+ e=self.dbm.getConnection().cursor()
+ e.execute("select n.id,n.lat,n.lon,v.version_id,n.user,n.timestamp from node n, version v \
+ where n.id=:nid",{"nid":r[0]})
+ for nodeRec in e:
+ nid=nodeRec[0]
+ lat=nodeRec[1]
+ lon=nodeRec[2]
+ ver=nodeRec[3]
+ usr=nodeRec[4]
+ tms=nodeRec[5]
+ e.close()
+ anyTags=False
+ tagList=[]
+ if tags:
+ if len(tagList)>0:
+ anyTags=True
+ if anyTags:
+ self.xml.writeStartElement("node")
+ else:
+ self.xml.writeEmptyElement("node")
+ if usr<>"":
+ self.xml.writeAttribute("visible","true")
+ if anyTags:
+ for r in tagList:
+ self.xml.writeEmptyElement("tag")
+ self.xml.writeAttribute("k",r[0])
+ self.xml.writeAttribute("v",r[1])
+ d.close()
i=i+1
@@ -232,32 +302,95 @@
i=0
- where w.closed=1 and v.object_id=w.id and v.object_type='way'")
- for rec in c:
+ where w.closed=1 and w.status<>'R' and w.u=1 and v.object_id=w.id and v.object_type='way' \
+ for (pid,ver,usr,tms) in c:
+ geom=self.dbm.getFeatureGeometry(pid,'Polygon')
+ continue
+ self.xml.writeAttribute("id",str(pid))
+ if usr<>"":
+ d.execute("select node_id from way_member where way_id=:wayId",{"wayId":pid})
+ first=None
for r in d:
+ if first==None:
+ first=r[0]
d.close()
+ self.xml.writeAttribute("ref",str(first))
if tags:
- tagList=self.dbm.getFeatureTags(rec[0],'Polygon')
+ tagList=self.dbm.getFeatureTags(pid,'Polygon')
for r in tagList:
+ for r in d:
+ for nodeRec in e:
+ nid=nodeRec[0]
+ lat=nodeRec[1]
+ lon=nodeRec[2]
+ ver=nodeRec[3]
+ usr=nodeRec[4]
+ tms=nodeRec[5]
+ e.close()
+ anyTags=False
+ tagList=[]
+ if tags:
+ anyTags=True
+ if anyTags:
+ else:
+ if usr<>"":
+ if anyTags:
+ for r in tagList:
+ d.close()
i=i+1
@@ -268,36 +401,52 @@
i=0
c.execute("select r.id,v.version_id,r.user,r.timestamp from relation r,version v \
- where v.object_id=r.id and v.object_type='relation'")
- for rec in c:
+ where r.status<>'R' and r.u=1 and v.object_id=r.id and v.object_type='relation' \
+ and ( \
+ exists ( \
+ select 1 from node n, relation_member rm \
+ where rm.relation_id=r.id and n.status<>'R' and n.u=1 and rm.member_id=n.id and rm.member_type='node' \
+ and n.lat>=:minLat and n.lat<=:maxLat and n.lon>=:minLon and n.lon<=:maxLon ) \
+ or exists ( \
+ select 1 from way w, relation_member rm \
+ where rm.relation_id=r.id and w.status<>'R' and w.u=1 and rm.member_id=w.id and rm.member_type='way' \
+ and ((w.max_lon between :minLon and :maxLon) or (w.min_lon between :minLon and :maxLon) or (w.min_lon<:minLon and w.max_lon>:maxLon))) \
+ for (rid,ver,usr,tms) in c:
self.xml.writeStartElement("relation")
+ self.xml.writeAttribute("id",str(rid))
+ if usr<>"":
- d.execute("select member_id,member_type,role from relation_member where relation_id=:relId",{"relId":rec[0]})
+ d.execute("select member_id,member_type,role from relation_member where relation_id=:relId",{"relId":rid})
for r in d:
- self.xml.writeStartElement("member")
+ self.xml.writeEmptyElement("member")
self.xml.writeAttribute("type",r[1])
self.xml.writeAttribute("role",r[2])
d.close()
if tags:
- tagList=self.dbm.getFeatureTags(rec[0],'Relation')
+ tagList=self.dbm.getFeatureTags(rid,'Relation')
for r in tagList:
i=i+1
self.xml.writeEndElement() # osm
self.xml.writeEndDocument()
Modified: trunk/qgis/python/plugins/osm/OsmUndoRedoDW.py
--- trunk/qgis/python/plugins/osm/OsmUndoRedoDW.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmUndoRedoDW.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -43,7 +43,7 @@
- self.clearButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_remove.png"))
+ self.clearButton.setIcon(QIcon(":/plugins/osm_plugin/images/osm_clearUndoRedo.png"))
self.iface=plugin.iface
Modified: trunk/qgis/python/plugins/osm/OsmUploadDlg.py
--- trunk/qgis/python/plugins/osm/OsmUploadDlg.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/OsmUploadDlg.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -16,6 +16,7 @@
from ui_OsmUploadDlg import Ui_OsmUploadDlg
+import OsmPlugin
from PyQt4.QtCore import *
from PyQt4.QtGui import *
@@ -24,7 +25,6 @@
from sys import *
class OsmUploadDlg(QDialog, Ui_OsmUploadDlg):
"""Class provides simple way of uploading current OSM data.
@@ -917,7 +917,7 @@
userCommentBytes=userComment.toUtf8()
# create http request's body (create XML with info about uploaded way)
- requestXml=QString("<osm>\n<changeset>\n<tag k=\"created_by\" v=\"QGIS OSM v0.5\"/>\n<tag k=\"comment\" v=\""+userCommentBytes.data()+"\"/>\n</changeset>\n</osm>")
+ requestXml=QString("<osm>\n<changeset>\n<tag k=\"created_by\" v=\"QGIS OSM v"+OsmPlugin.versionNumber()+"\"/>\n<tag k=\"comment\" v=\""+userCommentBytes.data()+"\"/>\n</changeset>\n</osm>")
# send prepared request
requestBytes=requestXml.toAscii()
Modified: trunk/qgis/python/plugins/osm/__init__.py
--- trunk/qgis/python/plugins/osm/__init__.py 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/__init__.py 2009-09-09 12:16:24 UTC (rev 11603)
@@ -38,10 +38,10 @@
@return version of this plugin
+ from OsmPlugin import versionNumber
+ return "Version "+versionNumber()
- return "Version 0.5"
def qgisMinimumVersion():
"""Function returns information on what minimum version
of Quantum GIS this plugin works with.
@@ -58,7 +58,6 @@
@return instance of OSM Plugin
- # load TestPlugin class from file testplug.py
from OsmPlugin import OsmPlugin
# return object of our plugin with reference to QGIS interface as the only argument
return OsmPlugin(iface)
Added: trunk/qgis/python/plugins/osm/images/osm_clearUndoRedo.png
(Binary files differ)
Property changes on: trunk/qgis/python/plugins/osm/images/osm_clearUndoRedo.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/qgis/python/plugins/osm/images/osm_generateTags.png
Property changes on: trunk/qgis/python/plugins/osm/images/osm_generateTags.png
Modified: trunk/qgis/python/plugins/osm/images/osm_identify.png
Modified: trunk/qgis/python/plugins/osm/images/osm_move.png
Modified: trunk/qgis/python/plugins/osm/images/osm_questionMark.png
Added: trunk/qgis/python/plugins/osm/images/osm_removeFeat.png
Property changes on: trunk/qgis/python/plugins/osm/images/osm_removeFeat.png
Added: trunk/qgis/python/plugins/osm/images/osm_removeMember.png
Property changes on: trunk/qgis/python/plugins/osm/images/osm_removeMember.png
Added: trunk/qgis/python/plugins/osm/images/osm_removeTag.png
Property changes on: trunk/qgis/python/plugins/osm/images/osm_removeTag.png
Modified: trunk/qgis/python/plugins/osm/images/osm_urDetails.png
Modified: trunk/qgis/python/plugins/osm/resources.qrc
--- trunk/qgis/python/plugins/osm/resources.qrc 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/resources.qrc 2009-09-09 12:16:24 UTC (rev 11603)
@@ -51,9 +51,18 @@
<file>images/osm_remove.png</file>
</qresource>
<qresource prefix="/plugins/osm_plugin" >
- <file>images/osm_star.png</file>
+ <file>images/osm_removeFeat.png</file>
</qresource>
+ <file>images/osm_removeTag.png</file>
+ </qresource>
+ <qresource prefix="/plugins/osm_plugin" >
+ <file>images/osm_removeMember.png</file>
+ </qresource>
+ <file>images/osm_generateTags.png</file>
+ </qresource>
<file>images/osm_questionMark.png</file>
</qresource>
@@ -62,4 +71,7 @@
<file>images/osm_redo.png</file>
</qresource>
+ <file>images/osm_clearUndoRedo.png</file>
+ </qresource>
</RCC>
Modified: trunk/qgis/python/plugins/osm/styles/big_scale.style
--- trunk/qgis/python/plugins/osm/styles/big_scale.style 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/styles/big_scale.style 2009-09-09 12:16:24 UTC (rev 11603)
@@ -1,34 +1,62 @@
#LINE
-highway trunk 3 1 150,0,0
-highway primary 2 1 219,112,147
-highway secondary 1 1 255,120,0
-highway tertiary 0 0 238,230,133
-highway pedestrian 0 0 255,255,0
-highway residential 0 0 100,100,100
-highway footway 0 0 170,170,170
-highway * 1 1 210,200,210
-railway subway 1 2 131,111,255
-railway rail 1 4 0,0,0
-railway * 1 0 0,0,0
+highway trunk 1.3 1 170,221,170
+highway trunk_link 1.3 1 170,221,170
+highway primary 1.2 1 219,112,147
+highway secondary 1.2 1 255,221,170
+highway tertiary 1 1 238,230,133
+highway pedestrian 0.02 1 230,214,182
+highway residential 0.02 1 100,100,100
+highway living_street 0.05 1 207,207,190
+highway cycleway 0.05 3 0,115,255
+highway construction 0.05 2 204,238,221
+tracktype grade2 0.05 3 0,115,255
+highway track 0.04 2 181,164,130
+highway unsurfaced 0.08 2 230,214,182
+railway subway 0.01 2 187,187,187
+railway rail 0.01 4 120,120,120
+railway tram 0.01 1 119,136,119
+railway preserved 0.05 2 187,187,187
boundary administrative 1 3 85,26,139
-power line 1 0 139,139,131
+waterway drain 0.2 1 135,206,255
+power line 0.1 1 139,139,131
#POLYGON
-leisure park 0 1 0,0,0 88,245,168
-leisure garden 0 1 0,0,0 88,245,168
-landuse forest 0 1 0,0,0 88,245,168
-landuse allotments 0 1 0,0,0 222,184,135
-tourism zoo 0 1 0,0,0 108,255,185
-building yes 0 1 0,0,0 226,226,226
-natural water 0 1 0,0,0 135,206,255
-waterway riverbank 0 1 0,0,0 135,206,255
-place island 0 1 0,0,0 255,255,255
-highway trunk 3 1 150,0,0 255,255,255
-highway primary 2 1 219,112,147 255,255,255
-highway secondary 1 1 255,120,0 255,255,255
-highway tertiary 0 0 238,230,133 255,255,255
-highway pedestrian 0 0 255,255,0 255,255,255
-highway residential 0 0 100,100,100 255,255,255
-highway footway 0 0 170,170,170 255,255,255
-* * 1 1 0,0,255 255,255,255
+leisure park 0 0 0,0,0 88,245,168
+leisure garden 0 0 0,0,0 88,245,168
+leisure pitch 0 0 0,0,0 136,204,170
+leisure track 0 0 0,0,0 119,221,187
+leisure playground 0 0 0,0,0 221,255,255
+leisure golf_course 0 0 0,0,0 187,221,187
+leisure stadium 0 0 0,0,0 102,204,170
+landuse forest 0 0 0,0,0 139,207,102
+landuse allotments 0 0 0,0,0 222,184,135
+landuse construction 0 0 0,0,0 153,153,102
+landuse cemetery 0 0 0,0,0 170,204,170
+landuse brownfield 0 0 0,0,0 153,153,102
+landuse village_green 0 0 0,0,0 204,238,170
+landuse industrial 0 0 0,0,0 221,221,238
+landuse recreation_ground 0 0 0,0,0 204,238,170
+tourism zoo 0 0 0,0,0 180,238,180
+natural water 0 0 0,0,0 135,206,255
+natural wood 0.1 1 40,40,40 170,204,153
+natural land 0 0 0,0,0 170,170,170
+waterway riverbank 0 0 0,0,0 135,206,255
+place island 0.2 1 0,0,0 255,255,255
+highway trunk 3 1 150,0,0 170,221,170
+highway primary 3 1 219,112,147 255,255,255
+highway secondary 1.5 1 255,120,0 255,255,255
+highway tertiary 2 1 238,230,133 255,255,255
+highway pedestrian 0.8 1 230,214,182 255,255,255
+highway residential 1 1 100,100,100 235,235,235
+highway service 1 1 100,100,100 235,235,235
+highway footway 1.4 3 255,160,140 255,255,255
+amenity place_of_worship 0 0 0,0,0 123,140,123
+amenity grave_yard 0 0 0,0,0 157,191,157
+amenity school 0 0 0,0,0 221,221,170
+power station 0 0 0,0,0 187,187,187
+area yes 0.2 1 100,100,100 235,235,235
+building yes 0 0 0,0,0 204,153,153
+amenity parking 0 0 0,0,0 255,255,153
+boundary administrative 0.8 3 85,26,139 255,255,255
+* * 0.01 1 40,40,40 255,255,255
#POINT
amenity hospital emergency/amenity=hospital.svg 6
Modified: trunk/qgis/python/plugins/osm/styles/medium_scale.style
--- trunk/qgis/python/plugins/osm/styles/medium_scale.style 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/styles/medium_scale.style 2009-09-09 12:16:24 UTC (rev 11603)
@@ -1,45 +1,70 @@
#LINE
-highway trunk 6 1 150,0,0
-highway primary 6 1 219,112,147
-highway secondary 4.5 1 255,120,0
-highway tertiary 3 1 238,230,133
-highway pedestrian 1 1 255,255,0
-highway residential 1 1 100,100,100
-highway footway 2 3 170,170,170
-highway * 1 1 0,255,0
-railway rail 2 4 0,0,0
-boundary administrative 2 3 85,26,139
-power line 2 1 139,139,131
+highway trunk 2.7 1 170,221,170
+highway trunk_link 2.7 1 170,221,170
+highway primary 2.5 1 219,112,147
+highway secondary 2.3 1 255,221,170
+highway tertiary 2.0 1 238,230,133
+highway pedestrian 0.25 1 230,214,182
+highway residential 0.25 1 100,100,100
+highway unclassified 0.25 1 100,100,100
+highway service 0.25 1 100,100,100
+highway footway 0.15 3 255,160,140
+highway path 0.15 3 255,160,140
+highway steps 0.15 3 255,160,140
+highway living_street 0.8 1 207,207,190
+highway cycleway 0.8 3 0,115,255
+highway construction 0.5 2 204,238,221
+tracktype grade2 0.8 3 0,115,255
+highway track 1.4 2 181,164,130
+highway unsurfaced 0.8 2 230,214,182
+highway * 0.5 1 0,255,0
+railway subway 0.1 2 187,187,187
+railway tram 0.1 1 119,136,119
+railway * 0.1 0 0,0,0
+boundary administrative 1 3 85,26,139
+waterway drain 0.5 1 135,206,255
+power line 1.4 1 139,139,131
+* * 1 1 200,200,200
#POLYGON
+leisure track 0.05 1 40,40,40 119,221,187
+leisure playground 0.05 1 40,40,40 221,255,255
-building yes 0.01 1 0,0,0 226,226,226
place island 1 1 0,0,0 255,255,255
-highway trunk 6 1 150,0,0 255,255,255
+highway trunk 6 1 150,0,0 170,221,170
highway primary 6 1 219,112,147 255,255,255
highway secondary 4.5 1 255,120,0 255,255,255
highway tertiary 3 1 238,230,133 255,255,255
-highway pedestrian 1 1 255,255,0 255,255,255
-highway residential 1 1 100,100,100 255,255,255
-highway footway 2 3 170,170,170 255,255,255
+amenity place_of_worship 0.02 1 0,0,0 123,140,123
+amenity school 0.05 1 160,160,110 221,221,170
+power station 0.05 1 170,170,170 187,187,187
+boundary administrative 1 3 85,26,139 255,255,255
#POINT
-source:addr uir_adr gpsicons/house.svg 15
-power tower symbol/Cross4.svg 15
-amenity hospital emergency/amenity=hospital.svg 15
-amenity parking transport/amenity=parking.svg 15
-amenity bus_station transport/highway=bus_stop.svg 15
-amenity restaurant entertainment/amenity=restaurant.svg 15
-amenity theatre entertainment/amenity=theatre.svg 15
-amenity pub entertainment/amenity=pub.svg 15
-amenity fast_food entertainment/amenity=fast_food.svg 15
-amenity cinema entertainment/amenity=cinema.svg 15
-amenity cafe entertainment/amenity=cafe.svg 15
-amenity bar entertainment/amenity=bar.svg 15
+amenity hospital emergency/amenity=hospital.svg 6
Modified: trunk/qgis/python/plugins/osm/styles/small_scale.style
--- trunk/qgis/python/plugins/osm/styles/small_scale.style 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/styles/small_scale.style 2009-09-09 12:16:24 UTC (rev 11603)
@@ -1,41 +1,74 @@
#LINE
-highway trunk 4.3 1 150,0,0
+highway trunk 4.6 1 170,221,170
+highway trunk_link 4.6 1 170,221,170
highway primary 4.3 1 219,112,147
-highway secondary 3.5 1 255,120,0
-highway tertiary 2.2 1 238,230,133
-highway pedestrian 0.8 1 255,255,0
+highway secondary 4 1 255,221,170
+highway tertiary 2.8 1 238,230,133
highway residential 0.8 1 100,100,100
-highway footway 1.4 3 170,170,170
+highway unclassified 0.8 1 100,100,100
+highway service 0.8 1 100,100,100
+highway path 1.4 3 255,160,140
+highway steps 1.4 3 255,160,140
+highway living_street 2.2 1 207,207,190
+highway cycleway 2 3 0,115,255
+highway construction 3 2 204,238,221
+tracktype grade2 2 3 0,115,255
+highway track 2 2 181,164,130
+highway unsurfaced 2 2 230,214,182
-railway subway 0.7 2 131,111,255
+railway subway 1.5 2 187,187,187
-railway tram 1 4 175,0,0
+railway tram 1.5 1 119,136,119
+railway preserved 1.5 2 187,187,187
railway * 0.7 0 0,0,0
+waterway drain 1 1 135,206,255
* * 1 1 200,200,200
#POLYGON
+amenity place_of_worship 0.1 1 0,0,0 123,140,123
+area yes 1 1 100,100,100 235,235,235
#POINT
-source:addr uir_adr gpsicons/point.svg 7
power tower symbol/Cross4.svg 10
amenity hospital emergency/amenity=hospital.svg 10
+amenity police emergency/amenity=police.svg 10
amenity parking transport/amenity=parking.svg 10
amenity bus_station transport/highway=bus_stop.svg 10
amenity restaurant entertainment/amenity=restaurant.svg 10
@@ -45,4 +78,11 @@
amenity cinema entertainment/amenity=cinema.svg 10
amenity cafe entertainment/amenity=cafe.svg 10
amenity bar entertainment/amenity=bar.svg 10
-* * gpsicons/point.svg 7
\ No newline at end of file
+amenity pharmacy services/amenity=pharmacy.svg 10
+amenity telephone services/amenity=telephone.svg 10
+amenity atm services/amenity=atm.svg 10
+amenity bank gpsicons/bank.svg 10
+amenity post_box services/amenity=post_box.svg 10
+tourism hostel services/tourism=hotel.svg 10
+source:addr uir_adr gpsicons/point.svg 5
+* * gpsicons/point.svg 5
Modified: trunk/qgis/python/plugins/osm/ui_files/OsmAddRelationDlg.ui
--- trunk/qgis/python/plugins/osm/ui_files/OsmAddRelationDlg.ui 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/ui_files/OsmAddRelationDlg.ui 2009-09-09 12:16:24 UTC (rev 11603)
@@ -39,7 +39,7 @@
<property name="sizeType" >
<enum>QSizePolicy::Fixed</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0" >
<size>
<width>24</width>
<height>20</height>
@@ -74,6 +74,15 @@
</item>
<item>
<widget class="QToolButton" name="typeInfoButton" >
+ <property name="toolTip" >
+ <string>Show type description</string>
+ </property>
+ <property name="statusTip" >
+ <string>Shows brief description of selected relation type.</string>
+ </property>
+ <property name="whatsThis" >
+ </property>
<property name="text" >
<string>...</string>
</property>
@@ -84,7 +93,7 @@
<property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -112,7 +121,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -122,6 +131,15 @@
</item>
<item>
<widget class="QToolButton" name="loadStandardTagsButton" >
+ <string>Generate tags</string>
+ </property>
+ <string>Fills tag table with tags that are typical for relation of specified type.</string>
+ </property>
+ </property>
</property>
@@ -129,6 +147,15 @@
</item>
<item>
<widget class="QToolButton" name="removeTagButton" >
+ <string>Remove all selected tags</string>
+ </property>
+ <string>Removes all selected tags.</string>
+ </property>
+ </property>
</property>
@@ -164,7 +191,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -174,6 +201,15 @@
</item>
<item>
<widget class="QToolButton" name="chooseMemberButton" >
+ <string>Select member on map</string>
+ </property>
+ <string>Starts process of selecting next relation member on map.</string>
+ </property>
+ </property>
</property>
@@ -184,6 +220,15 @@
</item>
<item>
<widget class="QToolButton" name="removeMemberButton" >
+ <string>Remove all selected members</string>
+ </property>
+ <string>Removes all selected members.</string>
+ </property>
+ </property>
</property>
@@ -234,7 +279,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
Modified: trunk/qgis/python/plugins/osm/ui_files/OsmFeatureDW.ui
--- trunk/qgis/python/plugins/osm/ui_files/OsmFeatureDW.ui 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/python/plugins/osm/ui_files/OsmFeatureDW.ui 2009-09-09 12:16:24 UTC (rev 11603)
@@ -37,6 +37,14 @@
<string>OSM Feature</string>
</property>
<widget class="QWidget" name="dockWidgetContents" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>21</y>
+ <width>265</width>
+ <height>715</height>
+ </rect>
+ </property>
<layout class="QVBoxLayout" >
<item>
<layout class="QHBoxLayout" >
@@ -89,13 +97,13 @@
<enum>Qt::NoFocus</enum>
</property>
- <string>Identify object</string>
+ <string>Identify feature</string>
</property>
</property>
</property>
@@ -123,8 +131,14 @@
</property>
- <string>Move object</string>
+ <string>Move feature</string>
</property>
+ </property>
+ </property>
</property>
@@ -348,12 +362,9 @@
</property>
<item>
<layout class="QGridLayout" >
- <property name="horizontalSpacing" >
+ <property name="spacing" >
<number>0</number>
</property>
- <property name="verticalSpacing" >
- <number>0</number>
- </property>
<item row="0" column="0" >
<widget class="QLabel" name="label" >
@@ -405,13 +416,13 @@
</size>
</property>
- <string>Remove feature</string>
+ <string>Remove this feature</string>
</property>
</property>
</property>
@@ -456,6 +467,14 @@
<number>1</number>
</property>
<widget class="QWidget" name="Properties" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>640</width>
+ <height>320</height>
+ </rect>
+ </property>
<attribute name="title" >
<string>Properties</string>
</attribute>
@@ -492,7 +511,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -521,6 +540,14 @@
</layout>
</widget>
<widget class="QWidget" name="Relations" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>243</width>
+ <height>534</height>
+ </rect>
+ </property>
<string>Relations</string>
</attribute>
@@ -607,7 +634,7 @@
<enum>QSizePolicy::Minimum</enum>
</property>
<size>
<width>26</width>
<height>0</height>
Modified: trunk/qgis/src/providers/osm/osmhandler.cpp
--- trunk/qgis/src/providers/osm/osmhandler.cpp 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/src/providers/osm/osmhandler.cpp 2009-09-09 12:16:24 UTC (rev 11603)
@@ -90,6 +90,9 @@
OsmHandler::~OsmHandler()
sqlite3_finalize( mStmtInsertTag );
+ sqlite3_finalize( mStmtInsertNode );
+ sqlite3_finalize( mStmtInsertWay );
+ sqlite3_finalize( mStmtInsertWayMember );
sqlite3_finalize( mStmtInsertRelation );
sqlite3_finalize( mStmtInsertRelationMember );
sqlite3_finalize( mStmtInsertVersion );
@@ -170,11 +173,6 @@
else if ( name == "way" )
- if ( mObjectType != "way" )
- sqlite3_finalize( mStmtInsertNode );
mObjectId = pAttrs.value( "id" );
mObjectType = "way";
mPosId = 1;
@@ -227,12 +225,6 @@
else if ( name == "relation" )
- if ( mObjectType != "relation" )
- sqlite3_finalize( mStmtInsertWay );
- sqlite3_finalize( mStmtInsertWayMember );
mRelationType = "";
mObjectType = "relation";
@@ -305,7 +297,6 @@
else if ( name == "bounds" )
// e.g. <bounds minlat="41.388625" minlon="2.15426" maxlat="41.391732" maxlon="2.158192"/>
- // notice: getting boundaries from OSM file <bounds> tag was not correct for some maps - cannot be used
// xMin = pAttrs.value("minlon").toDouble();
// xMax = pAttrs.value("maxlon").toDouble();
Modified: trunk/qgis/src/providers/osm/osmprovider.cpp
--- trunk/qgis/src/providers/osm/osmprovider.cpp 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/src/providers/osm/osmprovider.cpp 2009-09-09 12:16:24 UTC (rev 11603)
@@ -27,7 +27,9 @@
#include <QDateTime>
#include <QByteArray>
+using namespace std;
static const QString TEXT_PROVIDER_KEY = "osm";
static const QString TEXT_PROVIDER_DESCRIPTION = "Open Street Map data provider";
static const QString DATE_TIME_FMT = "dd.MM.yyyy HH:mm:ss";
@@ -142,8 +144,11 @@
// flag determining if OSM file parsing is neccessary
bool shouldParse = true;
+ if ( mFeatureType != PolygonType )
+ shouldParse = false;
// test if db file that belongs to source OSM file already exists and if it has the right version
- if ( databaseExists && isDatabaseCompatibleWithInput( mFileName ) && isDatabaseCompatibleWithPlugin() )
+ if ( shouldParse && databaseExists && isDatabaseCompatibleWithInput( mFileName ) && isDatabaseCompatibleWithProvider() )
if ( shouldParse )
@@ -178,16 +183,16 @@
// no OSM file parsing was done, we must find out default area boundaries from database meta information
char sqlSelectBoundary[] = "SELECT val FROM meta WHERE key='default-area-boundaries';";
sqlite3_stmt *stmtSelectBoundary;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectBoundary, sizeof(sqlSelectBoundary), &stmtSelectBoundary, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectBoundary, sizeof( sqlSelectBoundary ), &stmtSelectBoundary, 0 ) != SQLITE_OK )
QgsDebugMsg( "Getting default area boundary failed." );
// don't worry, we just let default values in xMax, yMax, xMin and yMin variables
else
- if (sqlite3_step( stmtSelectBoundary ) != SQLITE_ROW)
+ if ( sqlite3_step( stmtSelectBoundary ) != SQLITE_ROW )
- QgsDebugMsg("Getting default area boundary failed.");
+ QgsDebugMsg( "Getting default area boundary failed." );
// don't worry again, we just let default values in boundary variables
else
@@ -213,35 +218,35 @@
// prepare statement for tag retrieval
char sqlSelectTags[] = "SELECT key, val FROM tag WHERE object_id=? AND object_type=?";
- int rc = sqlite3_prepare_v2( mDatabase, sqlSelectTags, sizeof(sqlSelectTags), &mTagsStmt, 0 );
+ int rc = sqlite3_prepare_v2( mDatabase, sqlSelectTags, sizeof( sqlSelectTags ), &mTagsStmt, 0 );
if ( rc != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for feature tags selection - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for feature tags selection - prepare failed." );
return;
char sqlSelectTagValue[] = "SELECT val FROM tag WHERE object_id=? AND object_type=? AND key=?";
- rc = sqlite3_prepare_v2( mDatabase, sqlSelectTagValue, sizeof(sqlSelectTagValue), &mCustomTagsStmt, 0 );
+ rc = sqlite3_prepare_v2( mDatabase, sqlSelectTagValue, sizeof( sqlSelectTagValue ), &mCustomTagsStmt, 0 );
- QgsDebugMsg("sqlite3 statement for tag value selection - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for tag value selection - prepare failed." );
return;
// prepare statements for feature retrieval
char sqlSelectWay[] = "SELECT id, wkb, timestamp, user FROM way WHERE id=? AND status<>'R' AND u=1";
- rc = sqlite3_prepare_v2( mDatabase, sqlSelectWay, sizeof(sqlSelectWay), &mWayStmt, 0 );
+ rc = sqlite3_prepare_v2( mDatabase, sqlSelectWay, sizeof( sqlSelectWay ), &mWayStmt, 0 );
- QgsDebugMsg("sqlite3 statement for way retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for way retrieval - prepare failed." );
return;
char sqlSelectNode[] = "SELECT id, lat, lon, timestamp, user FROM node WHERE id=? AND usage=0 AND status<>'R' AND u=1";
- rc = sqlite3_prepare_v2( mDatabase, sqlSelectNode, sizeof(sqlSelectNode), &mNodeStmt, 0 );
+ rc = sqlite3_prepare_v2( mDatabase, sqlSelectNode, sizeof( sqlSelectNode ), &mNodeStmt, 0 );
- QgsDebugMsg("sqlite3 statement for node retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for node retrieval - prepare failed." );
return;
@@ -251,14 +256,14 @@
char sqlSelectPointsIn[] = "SELECT id, lat, lon, timestamp, user FROM node WHERE usage=0 AND status<>'R' AND u=1 \
AND lat>=? AND lat<=? AND lon>=? AND lon<=?";
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectPoints, sizeof(sqlSelectPoints), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectPoints, sizeof( sqlSelectPoints ), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for points retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for points retrieval - prepare failed." );
return;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectPointsIn, sizeof(sqlSelectPointsIn), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectPointsIn, sizeof( sqlSelectPointsIn ), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for points in boundary retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for points in boundary retrieval - prepare failed." );
return;
@@ -267,16 +272,16 @@
char sqlSelectLines[] = "SELECT w.id, w.wkb, w.timestamp, w.user FROM way w WHERE w.closed=0 AND w.status<>'R' AND w.u=1";
char sqlSelectLinesIn[] = "SELECT w.id, w.wkb, w.timestamp, w.user FROM way w WHERE w.closed=0 AND w.status<>'R' AND w.u=1 \
AND (((w.max_lat between ? AND ?) OR (w.min_lat between ? AND ?) OR (w.min_lat<? AND w.max_lat>?)) \
- OR ((w.max_lon between ? AND ?) OR (w.min_lon between ? AND ?) OR (w.min_lon<? AND w.max_lon>?)))";
+ AND ((w.max_lon between ? AND ?) OR (w.min_lon between ? AND ?) OR (w.min_lon<? AND w.max_lon>?)))";
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectLines, sizeof(sqlSelectLines), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectLines, sizeof( sqlSelectLines ), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for lines retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for lines retrieval - prepare failed." );
return;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectLinesIn, sizeof(sqlSelectLinesIn), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectLinesIn, sizeof( sqlSelectLinesIn ), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for lines in boundary retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for lines in boundary retrieval - prepare failed." );
return;
@@ -285,16 +290,16 @@
char sqlSelectPolys[] = "SELECT w.id, w.wkb, w.timestamp, w.user FROM way w WHERE w.closed=1 AND w.status<>'R' AND w.u=1";
char sqlSelectPolysIn[] = "SELECT w.id, w.wkb, w.timestamp, w.user FROM way w WHERE w.closed=1 AND w.status<>'R' AND w.u=1 \
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectPolys, sizeof(sqlSelectPolys), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectPolys, sizeof( sqlSelectPolys ), &mSelectFeatsStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for polygons retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for polygons retrieval - prepare failed." );
return;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectPolysIn, sizeof(sqlSelectPolysIn), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectPolysIn, sizeof( sqlSelectPolysIn ), &mSelectFeatsInStmt, 0 ) != SQLITE_OK )
- QgsDebugMsg("sqlite3 statement for polygons in boundary retrieval - prepare failed.");
+ QgsDebugMsg( "sqlite3 statement for polygons in boundary retrieval - prepare failed." );
return;
@@ -318,7 +323,10 @@
sqlite3_finalize( mSelectFeatsInStmt );
// close opened sqlite3 database
- closeDatabase();
+ if ( mDatabase )
+ closeDatabase();
@@ -331,9 +339,9 @@
char sqlSelectLastModif[] = "SELECT val FROM meta WHERE key='osm-file-last-modified';";
sqlite3_stmt *stmtSelectLastModif;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectLastModif, sizeof(sqlSelectLastModif), &stmtSelectLastModif, 0 ) == SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectLastModif, sizeof( sqlSelectLastModif ), &stmtSelectLastModif, 0 ) == SQLITE_OK )
- if ( sqlite3_step(stmtSelectLastModif) == SQLITE_ROW )
+ if ( sqlite3_step( stmtSelectLastModif ) == SQLITE_ROW )
QString oldOsmLastModifString = ( const char * ) sqlite3_column_text( stmtSelectLastModif, 0 );
QDateTime oldOsmFileLastModif = QDateTime::fromString( oldOsmLastModifString, DATE_TIME_FMT );
@@ -354,28 +362,28 @@
-bool QgsOSMDataProvider::isDatabaseCompatibleWithPlugin()
+bool QgsOSMDataProvider::isDatabaseCompatibleWithProvider()
- char sqlSelectPluginVer[] = "SELECT val FROM meta WHERE key='osm-plugin-version';";
- sqlite3_stmt *stmtSelectPluginVer;
+ char sqlSelectProviderVer[] = "SELECT val FROM meta WHERE key='osm-provider-version';";
+ sqlite3_stmt *stmtSelectProviderVer;
- if ( sqlite3_prepare_v2( mDatabase, sqlSelectPluginVer, sizeof(sqlSelectPluginVer), &stmtSelectPluginVer, 0 ) == SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlSelectProviderVer, sizeof( sqlSelectProviderVer ), &stmtSelectProviderVer, 0 ) == SQLITE_OK )
- if ( sqlite3_step( stmtSelectPluginVer ) == SQLITE_ROW )
+ if ( sqlite3_step( stmtSelectProviderVer ) == SQLITE_ROW )
- QString osmPluginVersion = ( const char * ) sqlite3_column_text( stmtSelectPluginVer, 0 );
+ QString osmProviderVersion = ( const char * ) sqlite3_column_text( stmtSelectProviderVer, 0 );
// each OSM database schema carry info on version of QGIS OSM plugin from which database was created;
// this provider must be of the same version to be able to manage OSM data correctly
- if ( osmPluginVersion == PROVIDER_VERSION )
+ if ( osmProviderVersion == PROVIDER_VERSION )
- sqlite3_finalize( stmtSelectPluginVer );
+ sqlite3_finalize( stmtSelectProviderVer );
return true;
// destroy database statement
return false;
@@ -470,7 +478,7 @@
char sqlWayMemberCnt[] = "SELECT count(n.id) FROM way_member wm, node n WHERE wm.way_id=? AND wm.node_id=n.id AND wm.u=1 AND n.u=1;";
sqlite3_stmt *stmtWayMemberCnt;
- if ( sqlite3_prepare_v2( mDatabase, sqlWayMemberCnt, sizeof(sqlWayMemberCnt), &stmtWayMemberCnt, 0 ) != SQLITE_OK )
+ if ( sqlite3_prepare_v2( mDatabase, sqlWayMemberCnt, sizeof( sqlWayMemberCnt ), &stmtWayMemberCnt, 0 ) != SQLITE_OK )
QgsDebugMsg( "sqlite3 statement for selecting waymember count - prepare failed." );
sqlite3_finalize( stmtWayMemberCnt );
@@ -579,11 +587,11 @@
if ( fetchGeometry )
char* geo = new char[21];
- memset( geo, 0, 21 );
+ std::memset( geo, 0, 21 );
geo[0] = QgsApplication::endian();
geo[geo[0] == QgsApplication::NDR ? 1 : 4] = QGis::WKBPoint;
- memcpy( geo + 5, &selLon, sizeof( double ) );
- memcpy( geo + 13, &selLat, sizeof( double ) );
+ std::memcpy( geo + 5, &selLon, sizeof( double ) );
+ std::memcpy( geo + 13, &selLat, sizeof( double ) );
feature.setGeometryAndOwnership(( unsigned char * )geo, 24 ); // 24 is size of wkb point structure!
@@ -1009,11 +1017,11 @@
( *geo ) = new char[9 + 16 * memberCnt];
( *geolen ) = 9 + 16 * memberCnt;
- memset(( *geo ), 0, 9 + 16 * memberCnt );
+ std::memset(( *geo ), 0, 9 + 16 * memberCnt );
( *geo )[0] = QgsApplication::endian();
( *geo )[( *geo )[0] == QgsApplication::NDR ? 1 : 4] = QGis::WKBLineString;
- memcpy(( *geo ) + 5, &memberCnt, 4 );
+ std::memcpy(( *geo ) + 5, &memberCnt, 4 );
sqlite3_bind_int( stmtSelectMembers, 1, wayId );
@@ -1035,8 +1043,8 @@
if ( selLat > maxLat ) maxLat = selLat;
if ( selLon > maxLon ) maxLon = selLon;
- memcpy(( *geo ) + 9 + 16 * i, &selLon, sizeof( double ) );
- memcpy(( *geo ) + 9 + 16 * i + 8, &selLat, sizeof( double ) );
+ std::memcpy(( *geo ) + 9 + 16 * i, &selLon, sizeof( double ) );
+ std::memcpy(( *geo ) + 9 + 16 * i + 8, &selLat, sizeof( double ) );
i++;
@@ -1049,11 +1057,11 @@
memberCnt++;
( *geo ) = new char[13 + 16 * memberCnt];
( *geolen ) = 13 + 16 * memberCnt;
- memset(( *geo ), 0, 13 + 16 * memberCnt );
+ std::memset(( *geo ), 0, 13 + 16 * memberCnt );
( *geo )[( *geo )[0] == QgsApplication::NDR ? 1 : 4] = QGis::WKBPolygon;
- memcpy(( *geo ) + 5, &ringsCnt, 4 );
- memcpy(( *geo ) + 9, &memberCnt, 4 );
+ std::memcpy(( *geo ) + 5, &ringsCnt, 4 );
+ std::memcpy(( *geo ) + 9, &memberCnt, 4 );
@@ -1077,8 +1085,8 @@
- memcpy(( *geo ) + 13 + 16 * i, &selLon, sizeof( double ) );
- memcpy(( *geo ) + 13 + 16 * i + 8, &selLat, sizeof( double ) );
+ std::memcpy(( *geo ) + 13 + 16 * i, &selLon, sizeof( double ) );
+ std::memcpy(( *geo ) + 13 + 16 * i + 8, &selLat, sizeof( double ) );
if ( firstLat == -1000.0 )
firstLat = selLat;
@@ -1087,8 +1095,8 @@
i++;
// add last polygon line
- memcpy(( *geo ) + 13 + 16 * i, &firstLon, sizeof( double ) );
- memcpy(( *geo ) + 13 + 16 * i + 8, &firstLat, sizeof( double ) );
+ std::memcpy(( *geo ) + 13 + 16 * i, &firstLon, sizeof( double ) );
+ std::memcpy(( *geo ) + 13 + 16 * i + 8, &firstLat, sizeof( double ) );
sqlite3_bind_blob( stmtUpdateWay, 1, ( *geo ), 13 + 16 * memberCnt, SQLITE_TRANSIENT );
@@ -1360,17 +1368,17 @@
if ( sqlite3_exec( mDatabase, ptr, 0, 0, 0 ) != SQLITE_OK )
- QgsDebugMsg("Storing osm-file-last-modified info into database failed.");
+ cout << "Storing osm-file-last-modified info into database failed." << endl;
// its not fatal situation, lets continue..
- QString cmd2 = "INSERT INTO meta ( key, val ) VALUES ('osm-plugin-version','" + PROVIDER_VERSION + "');";
+ QString cmd2 = "INSERT INTO meta ( key, val ) VALUES ('osm-provider-version','" + PROVIDER_VERSION + "');";
QByteArray cmd_bytes2 = cmd2.toAscii();
const char *ptr2 = cmd_bytes2.data();
if ( sqlite3_exec( mDatabase, ptr2, 0, 0, 0 ) != SQLITE_OK )
- QgsDebugMsg("Storing osm-plugin-version info into database failed.");
+ cout << "Storing osm-provider-version info into database failed." << endl;
return false;
@@ -1388,7 +1396,7 @@
if ( sqlite3_exec( mDatabase, ptr3, 0, 0, 0 ) != SQLITE_OK )
- QgsDebugMsg("Storing default area boundaries information into database failed.");
+ cout << "Storing default area boundaries information into database failed." << endl;
// its not critical situation
@@ -1655,6 +1663,7 @@
mError = ( char * ) "Closing SQLite3 database failed.";
return false;
+ mDatabase = NULL;
return true;
Modified: trunk/qgis/src/providers/osm/osmprovider.h
--- trunk/qgis/src/providers/osm/osmprovider.h 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/src/providers/osm/osmprovider.h 2009-09-09 12:16:24 UTC (rev 11603)
@@ -24,6 +24,7 @@
class QgsOSMDataProvider: public QgsVectorDataProvider
Q_OBJECT
private:
//! provider manages features with one of three geometry types; variable determines feature type of this provider
@@ -237,17 +238,17 @@
private:
- * Finds out if database (provider is connected to) belongs to (was created from) specified input file.
+ * Finds out if current database belongs to (was created from) specified input file.
* @param mFileName name of input OSM file
* @return answer to that question
bool isDatabaseCompatibleWithInput( QString mFileName );
- * Finds out if database and provider versions are compatible.
+ * Finds out if current database and provider versions are compatible.
- bool isDatabaseCompatibleWithPlugin();
+ bool isDatabaseCompatibleWithProvider();
* Creates Open Street Map database schema, using c++ library for attempt to sqlite database.
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-09-09 09:20:05 UTC (rev 11602)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-09-09 12:16:24 UTC (rev 11603)
@@ -16,6 +16,11 @@
// python should be first include
// otherwise issues some warnings
+#ifdef _MSC_VER
+#ifdef _DEBUG
+#undef _DEBUG
+#endif
+#endif
#include <Python.h>
#include "qgspythonutilsimpl.h"
