[QGIS Commit] r11611 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Thu Sep 10 09:53:43 EDT 2009
Author: dassau
Date: 2009-09-10 09:53:41 -0400 (Thu, 10 Sep 2009)
New Revision: 11611
docs/trunk/english_us/user_guide/working_with_vector.tex
updated advanced editing part
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2009-09-10 13:41:16 UTC (rev 11610)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2009-09-10 13:53:41 UTC (rev 11611)
@@ -1257,9 +1257,7 @@
and will lead to unpredictable results elsewhere in QGIS, so don't do that.
\textbf{Warning:} A vertex is identified for deletion as soon as you click
-the mouse near an eligible feature. To undo, you will need to toggle Editing
-off and then discard your changes. (Of course this will mean that other
-unsaved changes will be lost, too.)
+the mouse near an eligible feature.
\minisec{Cutting, Copying and Pasting Features}
\index{vector layers!cut!feature}
@@ -1323,9 +1321,7 @@
If we want to delete an entire polygon, we can do that by first selecting
the polygon using the regular \toolbtntwo{mActionSelect}{Select Features} tool. You can select
multiple features for deletion. Once you have the selection set, use the
-\toolbtntwo{mActionDeleteSelected}{Delete Selected} tool to delete the features. There is no undo function,
-but remember your layer isn't really changed until you stop editing and choose
-to save your changes. So if you make a mistake, you can always cancel the save.
+\toolbtntwo{mActionDeleteSelected}{Delete Selected} tool to delete the features.
The \toolbtntwo{mActionEditCut}{Cut Features} tool on the digitizing toolbar can
also be used to delete features. This effectively deletes the feature but
@@ -1445,7 +1441,8 @@
\minisec{Delete Part}
\index{vector layers!delete!part}
-The \toolbtntwo{mActionDeletePart}{Delete Part} tool
+The \toolbtntwo{mActionDeletePart}{Delete Part} tool allows to delete parts
+from multifeatures (e.g. to delete polygons from a multipolygon feature).
\minisec{Split Features}
\index{vector layers!split!feature}
@@ -1462,11 +1459,20 @@
\minisec{Node Tool}
\index{vector layers!node!tool}
-The \toolbtntwo{mActionNodeTool}{Node Tool} allows to
+The \toolbtntwo{mActionNodeTool}{Node Tool} provides manipulation capabilites
+of feature vertices similar to CAD programs. It is possible to select
+multiple vertices at once and to move or delete them alltogether. The node
+tool also works with 'on the fly' projection turned on and supports
+the topological editing feature.
-Node tool now works also with on the fly projections turned on.
-Added support for topology editing in node toolAdded support for topology
-editing in node tool..
+%%FIXME (not yet implemented in QGIS 1.2)
+%\minisec{Reshape Tool}
+%\index{vector layers!reshape!tool}
+%The reshape tool replaces parts of linear or polygonal features. The part
+%between the first and last intersection of the reshape line and the feature
+%will be replaced.
\subsubsection{Creating a New Layer}\label{sec:create shape}\index{editing!creating a new layer}
