[QGIS Commit] r11617 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Thu Sep 10 13:06:49 EDT 2009
Author: timlinux
Date: 2009-09-10 13:06:49 -0400 (Thu, 10 Sep 2009)
New Revision: 11617
trunk/qgis/src/app/qgsidentifyresults.cpp
trunk/qgis/src/app/qgsidentifyresults.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
[FEATURE] Added an option for docking the identify query results rather than having them float over the app. Default behaviour is not docked, but it can be enabled in the options panel
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-10 17:00:08 UTC (rev 11616)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-10 17:06:49 UTC (rev 11617)
@@ -36,9 +36,24 @@
#include <QSettings>
#include <QMenu>
#include <QClipboard>
+#include <QDockWidget>
#include "qgslogger.h"
+class QgsIdentifyResultsDock : public QDockWidget
+ public:
+ QgsIdentifyResultsDock( const QString & title, QWidget * parent = 0, Qt::WindowFlags flags = 0 )
+ : QDockWidget( title, parent, flags )
+ setObjectName( "IdentifyResultsTableDock" ); // set object name so the position can be saved
+ virtual void closeEvent( QCloseEvent * ev )
+ deleteLater();
// Tree hierachy
// layer [userrole: QgsMapLayer]
@@ -57,9 +72,20 @@
: QDialog( parent, f ),
mActionPopup( 0 ),
mRubberBand( 0 ),
- mCanvas( canvas )
+ mCanvas( canvas ),
+ mDock( NULL )
setupUi( this );
+ QSettings mySettings;
+ bool myDockFlag = mySettings.value( "/qgis/dockIdentifyResults", false ).toBool();
+ if ( myDockFlag )
+ mDock = new QgsIdentifyResultsDock( tr( "Identify Results" ) , QgisApp::instance() );
+ mDock->setAllowedAreas( Qt::LeftDockWidgetArea | Qt::RightDockWidgetArea );
+ mDock->setWidget( this );
+ QgisApp::instance()->addDockWidget( Qt::LeftDockWidgetArea, mDock );
+ buttonCancel->hide();
lstResults->setColumnCount( 2 );
setColumnText( 0, tr( "Feature" ) );
setColumnText( 1, tr( "Value" ) );
Modified: trunk/qgis/src/app/qgsidentifyresults.h
--- trunk/qgis/src/app/qgsidentifyresults.h 2009-09-10 17:00:08 UTC (rev 11616)
+++ trunk/qgis/src/app/qgsidentifyresults.h 2009-09-10 17:06:49 UTC (rev 11617)
@@ -34,6 +34,7 @@
class QgsVectorLayer;
class QgsRubberBand;
class QgsMapCanvas;
+class QDockWidget;
*@author Gary E.Sherman
@@ -117,6 +118,8 @@
void editFeature( QTreeWidgetItem *item );
void doAction( QTreeWidgetItem *item, int action );
+ QDockWidget *mDock;
#endif
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2009-09-10 17:00:08 UTC (rev 11616)
+++ trunk/qgis/src/app/qgsoptions.cpp 2009-09-10 17:06:49 UTC (rev 11617)
@@ -157,6 +157,7 @@
cbxLegendClassifiers->setChecked( settings.value( "/qgis/showLegendClassifiers", false ).toBool() );
cbxHideSplash->setChecked( settings.value( "/qgis/hideSplash", false ).toBool() );
cbxAttributeTableDocked->setChecked( settings.value( "/qgis/dockAttributeTable", false ).toBool() );
+ cbxIdentifyResultsDocked->setChecked( settings.value( "/qgis/dockIdentifyResults", false ).toBool() );
cbxAddPostgisDC->setChecked( settings.value( "/qgis/addPostgisDC", false ).toBool() );
//set the colour for selections
@@ -360,6 +361,7 @@
settings.setValue( "/qgis/showLegendClassifiers", cbxLegendClassifiers->isChecked() );
settings.setValue( "/qgis/hideSplash", cbxHideSplash->isChecked() );
settings.setValue( "/qgis/dockAttributeTable", cbxAttributeTableDocked->isChecked() );
+ settings.setValue( "/qgis/dockIdentifyResults", cbxIdentifyResultsDocked->isChecked() );
settings.setValue( "/qgis/addPostgisDC", cbxAddPostgisDC->isChecked() );
settings.setValue( "/qgis/new_layers_visible", chkAddedVisibility->isChecked() );
settings.setValue( "/qgis/enable_anti_aliasing", chkAntiAliasing->isChecked() );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-10 17:00:08 UTC (rev 11616)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-10 17:06:49 UTC (rev 11617)
@@ -1,8 +1,7 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
+<ui version="4.0" >
<class>QgsOptionsBase</class>
- <widget class="QDialog" name="QgsOptionsBase">
- <property name="geometry">
+ <widget class="QDialog" name="QgsOptionsBase" >
+ <property name="geometry" >
<rect>
<x>0</x>
<y>0</y>
@@ -10,60 +9,67 @@
<height>546</height>
</rect>
</property>
- <property name="windowTitle">
+ <property name="windowTitle" >
<string>QGIS Options</string>
</property>
- <property name="windowIcon">
- <iconset>
- <normaloff/>
- </iconset>
+ <property name="windowIcon" >
+ <iconset/>
</property>
- <property name="sizeGripEnabled">
+ <property name="sizeGripEnabled" >
<bool>true</bool>
</property>
- <property name="modal">
+ <property name="modal" >
<bool>true</bool>
</property>
- <layout class="QGridLayout">
- <item row="1" column="0">
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="orientation">
+ <layout class="QGridLayout" >
+ <item row="1" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
- <property name="standardButtons">
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
- <item row="0" column="0">
- <widget class="QTabWidget" name="tabWidget">
- <property name="currentIndex">
- <number>4</number>
+ <item row="0" column="0" >
+ <widget class="QTabWidget" name="tabWidget" >
+ <property name="currentIndex" >
+ <number>0</number>
</property>
- <widget class="QWidget" name="tabGeneral">
- <attribute name="title">
+ <widget class="QWidget" name="tabGeneral" >
+ <attribute name="title" >
<string>&General</string>
</attribute>
- <widget class="QGroupBox" name="groupBox_11">
- <property name="title">
+ <widget class="QGroupBox" name="groupBox_11" >
+ <property name="title" >
<string>Project files</string>
</property>
- <layout class="QVBoxLayout">
- <property name="margin">
+ <layout class="QVBoxLayout" >
+ <property name="leftMargin" >
<number>11</number>
</property>
+ <property name="topMargin" >
+ <number>11</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
<item>
- <widget class="QCheckBox" name="chbAskToSaveProjectChanges">
- <property name="text">
+ <widget class="QCheckBox" name="chbAskToSaveProjectChanges" >
+ <property name="text" >
<string>Prompt to save project changes when required</string>
</property>
</widget>
</item>
<item>
- <widget class="QCheckBox" name="chbWarnOldProjectVersion">
+ <widget class="QCheckBox" name="chbWarnOldProjectVersion" >
<string>Warn when opening a project file saved with an older version of QGIS</string>
</property>
</widget>
@@ -71,28 +77,28 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_9">
+ <widget class="QGroupBox" name="groupBox_9" >
<string>Default Map Appearance (overridden by project properties)</string>
</property>
- <widget class="QLabel" name="textLabel1_9">
+ <widget class="QLabel" name="textLabel1_9" >
<string>Selection color</string>
</property>
- <property name="buddy">
+ <property name="buddy" >
<cstring>pbnMeasureColour</cstring>
</property>
</widget>
</item>
- <item row="0" column="1">
+ <item row="0" column="1" >
<spacer>
</property>
- <property name="sizeHint" stdset="0">
+ <property name="sizeHint" >
<size>
<width>40</width>
<height>20</height>
@@ -100,35 +106,35 @@
</property>
</spacer>
</item>
- <item row="0" column="3">
- <widget class="QgsColorButton" name="pbnSelectionColour">
- <property name="minimumSize">
+ <item row="0" column="3" >
+ <widget class="QgsColorButton" name="pbnSelectionColour" >
+ <property name="minimumSize" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <widget class="QLabel" name="label">
+ <widget class="QLabel" name="label" >
<string>Background color</string>
</property>
<cstring>pbnCanvasColor</cstring>
</property>
</widget>
</item>
- <item row="1" column="2">
+ <item row="1" column="2" >
<spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -136,15 +142,15 @@
</property>
</spacer>
</item>
- <item row="1" column="3">
- <widget class="QgsColorButton" name="pbnCanvasColor">
+ <item row="1" column="3" >
+ <widget class="QgsColorButton" name="pbnCanvasColor" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
@@ -152,81 +158,88 @@
</layout>
</widget>
</item>
- <item row="2" column="0">
- <widget class="QGroupBox" name="groupBox">
+ <item row="2" column="0" >
+ <widget class="QGroupBox" name="groupBox" >
<string>&Application</string>
</property>
- <widget class="QLabel" name="textLabel1_4">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ <widget class="QLabel" name="textLabel1_4" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<string>Icon theme</string>
</property>
<cstring>cmbTheme</cstring>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cmbTheme">
- <property name="duplicatesEnabled">
+ <widget class="QComboBox" name="cmbTheme" >
+ <property name="duplicatesEnabled" >
<bool>false</bool>
</property>
<item>
<string/>
</property>
</item>
</widget>
</item>
- <item row="1" column="0" colspan="2">
- <widget class="QLabel" name="textLabel1_5">
- <string><b>Note: </b>Theme changes take effect the next time QGIS is started</string>
+ <item row="1" column="0" colspan="2" >
+ <widget class="QLabel" name="textLabel1_5" >
+ <string><b>Note: </b>Theme changes take effect the next time QGIS is started</string>
</property>
- <property name="alignment">
+ <property name="alignment" >
<set>Qt::AlignVCenter</set>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="2">
- <widget class="QCheckBox" name="capitaliseCheckBox">
+ <item row="2" column="0" colspan="2" >
+ <widget class="QCheckBox" name="capitaliseCheckBox" >
<string>Capitalise layer names in legend</string>
</property>
</widget>
</item>
- <item row="3" column="0" colspan="2">
- <widget class="QCheckBox" name="cbxLegendClassifiers">
+ <item row="3" column="0" colspan="2" >
+ <widget class="QCheckBox" name="cbxLegendClassifiers" >
<string>Display classification attribute names in legend</string>
</property>
</widget>
</item>
- <item row="4" column="0" colspan="2">
- <widget class="QCheckBox" name="cbxHideSplash">
+ <item row="4" column="0" colspan="2" >
+ <widget class="QCheckBox" name="cbxHideSplash" >
<string>Hide splash screen at startup</string>
</property>
</widget>
</item>
- <item row="5" column="0" colspan="2">
- <widget class="QCheckBox" name="cbxAttributeTableDocked">
+ <item row="5" column="0" >
+ <widget class="QCheckBox" name="cbxIdentifyResultsDocked" >
+ <string>Open identify results in a dock window (QGIS restart required)</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="0" colspan="2" >
+ <widget class="QCheckBox" name="cbxAttributeTableDocked" >
<string>Open attribute table in a dock window</string>
</property>
</widget>
</item>
- <item row="6" column="0" colspan="2">
- <widget class="QCheckBox" name="cbxAddPostgisDC">
+ <item row="7" column="0" colspan="2" >
+ <widget class="QCheckBox" name="cbxAddPostgisDC" >
<string>Add PostGIS layers with double click and select in extended mode</string>
</property>
</widget>
@@ -234,15 +247,15 @@
</layout>
</widget>
</item>
- <item row="3" column="0">
+ <item row="3" column="0" >
<spacer>
<enum>Qt::Vertical</enum>
</property>
- <property name="sizeType">
+ <property name="sizeType" >
<enum>QSizePolicy::Minimum</enum>
</property>
<size>
<width>577</width>
<height>21</height>
@@ -252,79 +265,88 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabRendering">
+ <widget class="QWidget" name="tabRendering" >
<string>&Rendering</string>
</attribute>
- <widget class="QGroupBox" name="groupBox_5">
+ <widget class="QGroupBox" name="groupBox_5" >
<string>Rendering behavior</string>
</property>
- <widget class="QCheckBox" name="chkAddedVisibility">
+ <widget class="QCheckBox" name="chkAddedVisibility" >
<string>By default new la&yers added to the map should be displayed</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_6">
+ <widget class="QLabel" name="textLabel1_6" >
<string>Number of features to draw before updating the display</string>
</property>
<cstring>spinBoxUpdateThreshold</cstring>
</property>
</widget>
</item>
- <item row="1" column="1">
- <widget class="QSpinBox" name="spinBoxUpdateThreshold">
- <property name="toolTip">
+ <item row="1" column="1" >
+ <widget class="QSpinBox" name="spinBoxUpdateThreshold" >
+ <property name="toolTip" >
<string>Map display will be updated (drawn) after this many features have been read from the data source</string>
</property>
- <property name="maximum">
+ <property name="maximum" >
<number>1000000</number>
</property>
- <property name="value">
+ <property name="value" >
<number>1000</number>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel3">
- <string><b>Note:</b> Use zero to prevent display updates until all features have been rendered</string>
+ <widget class="QLabel" name="textLabel3" >
+ <string><b>Note:</b> Use zero to prevent display updates until all features have been rendered</string>
</property>
</widget>
</item>
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_8">
+ <widget class="QGroupBox" name="groupBox_8" >
<string>Rendering quality</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item>
- <widget class="QCheckBox" name="chkAntiAliasing">
+ <widget class="QCheckBox" name="chkAntiAliasing" >
<string>Make lines appear less jagged at the expense of some drawing performance</string>
</property>
</widget>
</item>
<item>
- <widget class="QCheckBox" name="chkUseQPixmap">
+ <widget class="QCheckBox" name="chkUseQPixmap" >
<string>Selecting this will unselect the 'make lines less' jagged toggle</string>
</property>
<string>Fix problems with incorrectly filled polygons</string>
</property>
</widget>
@@ -332,12 +354,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>20</width>
<height>40</height>
@@ -347,70 +369,88 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabMap">
+ <widget class="QWidget" name="tabMap" >
<string>&Map tools</string>
</attribute>
<number>11</number>
</property>
- <widget class="QGroupBox" name="groupBox_10">
+ </property>
+ </property>
+ </property>
+ <widget class="QGroupBox" name="groupBox_10" >
<string>Panning and zooming</string>
</property>
<number>11</number>
</property>
- <widget class="QComboBox" name="cmbWheelAction">
+ </property>
+ </property>
+ </property>
+ <widget class="QComboBox" name="cmbWheelAction" >
<item>
<string>Zoom</string>
</property>
</item>
<item>
<string>Zoom and recenter</string>
</property>
</item>
<item>
<string>Zoom to mouse cursor</string>
</property>
</item>
<item>
<string>Nothing</string>
</property>
</item>
</widget>
</item>
- <widget class="QLabel" name="label_3">
+ <widget class="QLabel" name="label_3" >
<string>Zoom factor</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="label_2">
+ <widget class="QLabel" name="label_2" >
<string>Mouse wheel action</string>
</property>
</widget>
</item>
- <widget class="QDoubleSpinBox" name="spinZoomFactor">
- <property name="decimals">
+ <widget class="QDoubleSpinBox" name="spinZoomFactor" >
+ <property name="decimals" >
<number>1</number>
</property>
- <property name="minimum">
+ <property name="minimum" >
<double>1.100000000000000</double>
</property>
<double>2.000000000000000</double>
</property>
</widget>
@@ -418,21 +458,30 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_6">
+ <widget class="QGroupBox" name="groupBox_6" >
<string>Measure tool</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<spacer>
</property>
<size>
<width>191</width>
<height>20</height>
@@ -440,59 +489,59 @@
</property>
</spacer>
</item>
- <widget class="QgsColorButton" name="pbnMeasureColour">
+ <widget class="QgsColorButton" name="pbnMeasureColour" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="2">
- <widget class="QComboBox" name="cmbEllipsoid"/>
+ <item row="0" column="1" colspan="2" >
+ <widget class="QComboBox" name="cmbEllipsoid" />
</item>
- <widget class="QLabel" name="textLabel1_10">
+ <widget class="QLabel" name="textLabel1_10" >
<string>Rubberband color</string>
</property>
<cstring>cmbEllipsoid</cstring>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_8">
+ <widget class="QLabel" name="textLabel1_8" >
<string>Ellipsoid for distance calculations</string>
</property>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_11">
+ <widget class="QLabel" name="textLabel1_11" >
<string>Preferred measurements units</string>
</property>
</widget>
</item>
- <item row="2" column="1">
- <widget class="QRadioButton" name="radMeters">
+ <item row="2" column="1" >
+ <widget class="QRadioButton" name="radMeters" >
<string>Meters</string>
</property>
</widget>
</item>
- <item row="2" column="2">
- <widget class="QRadioButton" name="radFeet">
+ <item row="2" column="2" >
+ <widget class="QRadioButton" name="radFeet" >
<string>Feet</string>
</property>
</widget>
@@ -500,57 +549,66 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_7">
+ <widget class="QGroupBox" name="groupBox_7" >
<string>Identify</string>
</property>
<number>11</number>
</property>
- <widget class="QLabel" name="textLabel2">
- <string><b>Note:</b> Specify the search radius as a percentage of the map width</string>
+ </property>
+ </property>
+ </property>
+ <widget class="QLabel" name="textLabel2" >
+ <string><b>Note:</b> Specify the search radius as a percentage of the map width</string>
</property>
- <property name="wordWrap">
+ <property name="wordWrap" >
<bool>true</bool>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_3">
+ <widget class="QLabel" name="textLabel1_3" >
<string>Search radius for identifying features and displaying map tips</string>
</property>
<cstring>spinBoxIdentifyValue</cstring>
</property>
</widget>
</item>
- <widget class="QDoubleSpinBox" name="spinBoxIdentifyValue">
- <property name="suffix">
+ <widget class="QDoubleSpinBox" name="spinBoxIdentifyValue" >
+ <property name="suffix" >
<string>%</string>
</property>
<double>100.000000000000000</double>
</property>
- <property name="singleStep">
+ <property name="singleStep" >
<double>0.010000000000000</double>
</property>
<double>5.000000000000000</double>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cmbIdentifyMode"/>
+ <widget class="QComboBox" name="cmbIdentifyMode" />
</item>
- <widget class="QLabel" name="label_4">
+ <widget class="QLabel" name="label_4" >
<string>Mode</string>
</property>
</widget>
@@ -558,12 +616,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>20</width>
<height>40</height>
@@ -573,12 +631,12 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="mOverlayTab">
+ <widget class="QWidget" name="mOverlayTab" >
<string>Overlay</string>
</attribute>
- <widget class="QGroupBox" name="mPositionGroupBox">
+ <widget class="QGroupBox" name="mPositionGroupBox" >
<rect>
<x>10</x>
<y>10</y>
@@ -586,11 +644,11 @@
<height>111</height>
</rect>
</property>
<string>Position</string>
</property>
- <widget class="QWidget" name="layoutWidget">
+ <widget class="QWidget" name="layoutWidget" >
<rect>
<x>20</x>
<y>40</y>
@@ -598,23 +656,23 @@
<height>42</height>
</rect>
</property>
- <layout class="QHBoxLayout">
+ <layout class="QHBoxLayout" >
<item>
- <widget class="QLabel" name="mAlgorithmLabel">
+ <widget class="QLabel" name="mAlgorithmLabel" >
<string>Placement algorithm:</string>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="mOverlayAlgorithmComboBox"/>
+ <widget class="QComboBox" name="mOverlayAlgorithmComboBox" />
</item>
<item>
<spacer>
</property>
<size>
<width>221</width>
<height>20</height>
@@ -626,56 +684,56 @@
</widget>
</widget>
</widget>
- <widget class="QWidget" name="tabDigitizing">
+ <widget class="QWidget" name="tabDigitizing" >
<string>Digitizing</string>
</attribute>
- <layout class="QGridLayout" name="gridLayout_2">
- <widget class="QGroupBox" name="mRubberBandGroupBox">
+ <widget class="QGroupBox" name="mRubberBandGroupBox" >
<string>Rubberband</string>
</property>
- <widget class="QLabel" name="mLineWidthTextLabel">
+ <widget class="QLabel" name="mLineWidthTextLabel" >
<string>Line width</string>
</property>
<cstring>mLineWidthSpinBox</cstring>
</property>
</widget>
</item>
- <widget class="QSpinBox" name="mLineWidthSpinBox">
+ <widget class="QSpinBox" name="mLineWidthSpinBox" >
<string>Line width in pixels</string>
</property>
<number>1</number>
</property>
</widget>
</item>
- <widget class="QLabel" name="mLineColourTextLabel">
+ <widget class="QLabel" name="mLineColourTextLabel" >
<string>Line colour</string>
</property>
<cstring>mLineColourToolButton</cstring>
</property>
</widget>
</item>
- <widget class="QgsColorButton" name="mLineColourToolButton">
+ <widget class="QgsColorButton" name="mLineColourToolButton" >
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
@@ -683,25 +741,25 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mSnappingGroupBox">
+ <widget class="QGroupBox" name="mSnappingGroupBox" >
<string>Snapping</string>
</property>
- <widget class="QLabel" name="mDefaultSnapModeLabel">
+ <widget class="QLabel" name="mDefaultSnapModeLabel" >
<string>Default snap mode</string>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="3">
+ <item row="0" column="1" colspan="3" >
<spacer>
</property>
<size>
<width>311</width>
<height>20</height>
@@ -709,29 +767,29 @@
</property>
</spacer>
</item>
- <item row="0" column="4" colspan="2">
- <widget class="QComboBox" name="mDefaultSnapModeComboBox">
- <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ <item row="0" column="4" colspan="2" >
+ <widget class="QComboBox" name="mDefaultSnapModeComboBox" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
</sizepolicy>
</property>
</widget>
</item>
- <widget class="QLabel" name="mDefaultSnappingToleranceTextLabel">
+ <widget class="QLabel" name="mDefaultSnappingToleranceTextLabel" >
<string>Default snapping tolerance in layer units</string>
</property>
</widget>
</item>
- <item row="1" column="2" colspan="2">
+ <item row="1" column="2" colspan="2" >
<spacer>
</property>
<size>
<width>241</width>
<height>20</height>
@@ -739,29 +797,29 @@
</property>
</spacer>
</item>
- <item row="1" column="4">
- <widget class="QDoubleSpinBox" name="mDefaultSnappingToleranceSpinBox">
+ <item row="1" column="4" >
+ <widget class="QDoubleSpinBox" name="mDefaultSnappingToleranceSpinBox" >
<number>5</number>
</property>
<double>99999999.989999994635582</double>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="3">
- <widget class="QLabel" name="mVertexSearchRadiusVertexEditLabel">
+ <item row="2" column="0" colspan="3" >
+ <widget class="QLabel" name="mVertexSearchRadiusVertexEditLabel" >
<string>Search radius for vertex edits in layer units</string>
</property>
</widget>
</item>
- <item row="2" column="3">
+ <item row="2" column="3" >
<spacer>
</property>
<size>
<width>61</width>
<height>20</height>
@@ -769,45 +827,45 @@
</property>
</spacer>
</item>
- <item row="2" column="4">
- <widget class="QDoubleSpinBox" name="mSearchRadiusVertexEditSpinBox">
+ <item row="2" column="4" >
+ <widget class="QDoubleSpinBox" name="mSearchRadiusVertexEditSpinBox" >
<number>5</number>
</property>
</property>
</widget>
</item>
- <item row="1" column="5">
- <widget class="QComboBox" name="mDefaultSnappingToleranceComboBox">
+ <item row="1" column="5" >
+ <widget class="QComboBox" name="mDefaultSnappingToleranceComboBox" >
</sizepolicy>
</property>
<item>
<string>map units</string>
</property>
</item>
<item>
<string>pixels</string>
</property>
</item>
</widget>
</item>
- <item row="2" column="5">
- <widget class="QComboBox" name="mSearchRadiusVertexEditComboBox">
+ <item row="2" column="5" >
+ <widget class="QComboBox" name="mSearchRadiusVertexEditComboBox" >
<item>
</property>
</item>
<item>
</property>
</item>
@@ -816,32 +874,32 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mVertexMarkerGroupBox">
+ <widget class="QGroupBox" name="mVertexMarkerGroupBox" >
<string>Vertex markers</string>
</property>
- <layout class="QGridLayout" name="gridLayout_1">
- <item row="0" column="0" colspan="2">
- <widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox">
+ <item row="0" column="0" colspan="2" >
+ <widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox" >
<string>Show markers only for selected features</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="mMarkerStyleLabel">
+ <widget class="QLabel" name="mMarkerStyleLabel" >
<string>Marker style</string>
</property>
</widget>
</item>
<spacer>
</property>
<size>
<width>281</width>
<height>20</height>
@@ -849,42 +907,42 @@
</property>
</spacer>
</item>
- <widget class="QComboBox" name="mMarkerStyleComboBox">
+ <widget class="QComboBox" name="mMarkerStyleComboBox" >
</sizepolicy>
</property>
</widget>
</item>
- <widget class="QSpinBox" name="mMarkerSizeSpinBox">
- <property name="layoutDirection">
+ <widget class="QSpinBox" name="mMarkerSizeSpinBox" >
+ <property name="layoutDirection" >
<enum>Qt::LeftToRight</enum>
</property>
<number>3</number>
</property>
<number>2</number>
</property>
</widget>
</item>
- <widget class="QLabel" name="label_6">
+ <widget class="QLabel" name="label_6" >
<string>Marker size</string>
</property>
</widget>
</item>
- <spacer name="horizontalSpacer">
+ <spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -895,18 +953,18 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mEnterAttributeValuesGroupBox">
+ <widget class="QGroupBox" name="mEnterAttributeValuesGroupBox" >
<string>Enter attribute values</string>
</property>
<item>
- <widget class="QCheckBox" name="chkDisableAttributeValuesDlg">
+ <widget class="QCheckBox" name="chkDisableAttributeValuesDlg" >
<string>Suppress attributes pop-up windows after each created feature</string>
</property>
- <property name="tristate">
+ <property name="tristate" >
<bool>false</bool>
</property>
</widget>
@@ -914,12 +972,12 @@
</layout>
</widget>
</item>
- <item row="4" column="0">
+ <item row="4" column="0" >
<spacer>
</property>
<size>
<width>547</width>
<height>71</height>
@@ -929,20 +987,29 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabCRS">
+ <widget class="QWidget" name="tabCRS" >
<string>CRS</string>
</attribute>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<spacer>
</property>
<size>
<width>51</width>
<height>31</height>
@@ -950,42 +1017,51 @@
</property>
</spacer>
</item>
- <widget class="QPushButton" name="pbnSelectProjection">
+ <widget class="QPushButton" name="pbnSelectProjection" >
<string>Select Global Default ...</string>
</property>
</widget>
</item>
- <widget class="QTextBrowser" name="txtGlobalWkt"/>
+ <widget class="QTextBrowser" name="txtGlobalWkt" />
</item>
- <widget class="QGroupBox" name="grpProjectionBehaviour">
+ <widget class="QGroupBox" name="grpProjectionBehaviour" >
<string>When a new layer is created, or when a layer is loaded that has no coordinate reference system (CRS)</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item>
- <widget class="QRadioButton" name="radPromptForProjection">
+ <widget class="QRadioButton" name="radPromptForProjection" >
<string>Prompt for CRS</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radUseProjectProjection">
+ <widget class="QRadioButton" name="radUseProjectProjection" >
<string>Project wide default CRS will be used</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radUseGlobalProjection">
+ <widget class="QRadioButton" name="radUseGlobalProjection" >
<string>Global default CRS displa&yed below will be used</string>
</property>
</widget>
@@ -995,39 +1071,39 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabLocale">
+ <widget class="QWidget" name="tabLocale" >
<string>Locale</string>
</attribute>
- <widget class="QGroupBox" name="grpLocale">
+ <widget class="QGroupBox" name="grpLocale" >
<string>Override system locale</string>
</property>
- <property name="checkable">
+ <property name="checkable" >
<bool>true</bool>
</property>
- <widget class="QLabel" name="label_5">
+ <widget class="QLabel" name="label_5" >
<string>Locale to use instead</string>
</property>
<cstring>cboLocale</cstring>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cboLocale"/>
+ <widget class="QComboBox" name="cboLocale" />
</item>
- <widget class="QLabel" name="label_7">
- <string><b>Note:</b> Enabling / changing overide on local requires an application restart</string>
+ <widget class="QLabel" name="label_7" >
+ <string><b>Note:</b> Enabling / changing overide on local requires an application restart</string>
</property>
<bool>true</bool>
</property>
</widget>
@@ -1035,12 +1111,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>501</width>
<height>51</height>
@@ -1048,15 +1124,15 @@
</property>
</spacer>
</item>
- <widget class="QGroupBox" name="groupBox_12">
+ <widget class="QGroupBox" name="groupBox_12" >
<string>Additional Info</string>
</property>
- <widget class="QLabel" name="lblSystemLocale">
+ <widget class="QLabel" name="lblSystemLocale" >
<string>Detected active locale on your system:</string>
</property>
</widget>
@@ -1066,102 +1142,102 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab">
+ <widget class="QWidget" name="tab" >
<string>Proxy</string>
</attribute>
- <widget class="QGroupBox" name="grpProxy">
+ <widget class="QGroupBox" name="grpProxy" >
<string>Use proxy for web access</string>
</property>
- <property name="flat">
+ <property name="flat" >
<bool>false</bool>
</property>
<bool>true</bool>
</property>
- <widget class="QLabel" name="lblProxyHost">
+ <widget class="QLabel" name="lblProxyHost" >
<string>Host</string>
</property>
<cstring>leProxyHost</cstring>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="5">
- <widget class="QLineEdit" name="leProxyHost"/>
+ <item row="0" column="1" colspan="5" >
+ <widget class="QLineEdit" name="leProxyHost" />
</item>
- <widget class="QLabel" name="lblProxyPort">
+ <widget class="QLabel" name="lblProxyPort" >
<string>Port</string>
</property>
<cstring>leProxyPort</cstring>
</property>
</widget>
</item>
- <item row="1" column="1" colspan="5">
- <widget class="QLineEdit" name="leProxyPort"/>
+ <item row="1" column="1" colspan="5" >
+ <widget class="QLineEdit" name="leProxyPort" />
</item>
- <widget class="QLabel" name="lblUser">
+ <widget class="QLabel" name="lblUser" >
<string>User</string>
</property>
<cstring>leProxyUser</cstring>
</property>
</widget>
</item>
- <item row="2" column="1" colspan="5">
- <widget class="QLineEdit" name="leProxyUser">
+ <item row="2" column="1" colspan="5" >
+ <widget class="QLineEdit" name="leProxyUser" >
<string>Leave this blank if no proxy username / password are required</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="lblPassword">
+ <widget class="QLabel" name="lblPassword" >
<string>Password</string>
</property>
<cstring>leProxyPassword</cstring>
</property>
</widget>
</item>
- <item row="3" column="1" colspan="5">
- <widget class="QLineEdit" name="leProxyPassword">
+ <item row="3" column="1" colspan="5" >
+ <widget class="QLineEdit" name="leProxyPassword" >
</property>
- <property name="echoMode">
+ <property name="echoMode" >
<enum>QLineEdit::Password</enum>
</property>
</widget>
</item>
- <widget class="QLabel" name="mTypeLabel">
+ <widget class="QLabel" name="mTypeLabel" >
<string>Proxy type</string>
</property>
</widget>
</item>
- <item row="4" column="1" colspan="2">
- <widget class="QComboBox" name="mProxyTypeComboBox"/>
+ <item row="4" column="1" colspan="2" >
+ <widget class="QComboBox" name="mProxyTypeComboBox" />
</item>
- <item row="4" column="3" colspan="3">
+ <item row="4" column="3" colspan="3" >
<spacer>
</property>
<size>
<width>241</width>
<height>20</height>
@@ -1169,33 +1245,33 @@
</property>
</spacer>
</item>
- <widget class="QLabel" name="mExcludeUrlsLabel">
+ <item row="5" column="0" colspan="2" >
+ <widget class="QLabel" name="mExcludeUrlsLabel" >
<string>Exclude URLs:</string>
</property>
</widget>
</item>
- <item row="5" column="2" colspan="2">
- <widget class="QPushButton" name="mAddUrlPushButton">
+ <item row="5" column="2" colspan="2" >
+ <widget class="QPushButton" name="mAddUrlPushButton" >
<string>Add</string>
</property>
</widget>
</item>
- <item row="5" column="4">
- <widget class="QPushButton" name="mRemoveUrlPushButton">
+ <item row="5" column="4" >
+ <widget class="QPushButton" name="mRemoveUrlPushButton" >
<string>Remove</string>
</property>
</widget>
</item>
- <item row="5" column="5">
+ <item row="5" column="5" >
<spacer>
</property>
<size>
<width>391</width>
<height>20</height>
@@ -1203,8 +1279,8 @@
</property>
</spacer>
</item>
- <item row="6" column="0" colspan="6">
- <widget class="QListWidget" name="mExcludeUrlListWidget"/>
+ <item row="6" column="0" colspan="6" >
+ <widget class="QListWidget" name="mExcludeUrlListWidget" />
</item>
</layout>
</widget>
@@ -1215,7 +1291,7 @@
</item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11"/>
+ <layoutdefault spacing="6" margin="11" />
<customwidgets>
<customwidget>
<class>QgsColorButton</class>
