[QGIS Commit] r11640 - trunk/qgis/python/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Sep 12 16:37:31 EDT 2009
Author: jef
Date: 2009-09-12 16:37:31 -0400 (Sat, 12 Sep 2009)
New Revision: 11640
   trunk/qgis/python/core/qgsdatasourceuri.sip
   trunk/qgis/python/core/qgsproviderregistry.sip
fix line endings
Modified: trunk/qgis/python/core/qgsdatasourceuri.sip
--- trunk/qgis/python/core/qgsdatasourceuri.sip	2009-09-12 20:10:44 UTC (rev 11639)
+++ trunk/qgis/python/core/qgsdatasourceuri.sip	2009-09-12 20:37:31 UTC (rev 11640)
@@ -1,72 +1,72 @@
-\struct QgsDataSourceURI
-\brief Structure for storing the component parts of a PostgreSQL/RDBMS datasource URI.
- This structure stores the database connection information, including host, database,
-  user name, password, schema, password, and sql where clause
-class QgsDataSourceURI
-%TypeHeaderCode
-#include <qgsdatasourceuri.h>
-%End
-public:
-  //! \note enumeration added in version 1.1
-  enum SSLmode { SSLprefer, SSLdisable, SSLallow, SSLrequire };
-  //! default constructor
-  QgsDataSourceURI();
-  //! constructor which parses input URI
-  QgsDataSourceURI(QString uri);
-  //! connection info
-  QString connectionInfo() const;
-  //! complete uri
-  QString uri() const;
-  //! quoted table name
-  QString quotedTablename() const;
-  //! Set all connection related members at once
-  //! \note This optional sslmode parameter has been added in version 1.1
-  void setConnection(const QString& aHost,
-                     const QString& aPort,
-                     const QString& aDatabase,
-                     const QString& aUsername,
-                     const QString& aPassword,
-                     SSLmode sslmode = SSLprefer );
-  //! Set all data source related members at once
-  void setDataSource(const QString& aSchema,
-                     const QString& aTable,
-                     const QString& aGeometryColumn,
-                     const QString& aSql = QString(),
-                     const QString& aKeyColumn = QString());
-  /** Removes password from uris
-   * @note this method was added in QGIS 1.1
-  static QString removePassword( const QString& aUri);
-  QString username() const;
-  QString schema() const;
-  QString table() const;
-  QString sql() const;
-  QString geometryColumn() const;
-  // added in 1.1
-  QString host() const;
-  QString database() const;
-  QString password() const;
-  QString port() const;
-  SSLmode sslMode() const;
-  void setSql(QString sql);
-  // added in 1.2
-  QString keyColumn() const;
-  void setKeyColumn(QString column);
+\struct QgsDataSourceURI
+\brief Structure for storing the component parts of a PostgreSQL/RDBMS datasource URI.
+ This structure stores the database connection information, including host, database,
+  user name, password, schema, password, and sql where clause
+class QgsDataSourceURI
+%TypeHeaderCode
+#include <qgsdatasourceuri.h>
+%End
+public:
+  //! \note enumeration added in version 1.1
+  enum SSLmode { SSLprefer, SSLdisable, SSLallow, SSLrequire };
+  //! default constructor
+  QgsDataSourceURI();
+  //! constructor which parses input URI
+  QgsDataSourceURI(QString uri);
+  //! connection info
+  QString connectionInfo() const;
+  //! complete uri
+  QString uri() const;
+  //! quoted table name
+  QString quotedTablename() const;
+  //! Set all connection related members at once
+  //! \note This optional sslmode parameter has been added in version 1.1
+  void setConnection(const QString& aHost,
+                     const QString& aPort,
+                     const QString& aDatabase,
+                     const QString& aUsername,
+                     const QString& aPassword,
+                     SSLmode sslmode = SSLprefer );
+  //! Set all data source related members at once
+  void setDataSource(const QString& aSchema,
+                     const QString& aTable,
+                     const QString& aGeometryColumn,
+                     const QString& aSql = QString(),
+                     const QString& aKeyColumn = QString());
+  /** Removes password from uris
+   * @note this method was added in QGIS 1.1
+  static QString removePassword( const QString& aUri);
+  QString username() const;
+  QString schema() const;
+  QString table() const;
+  QString sql() const;
+  QString geometryColumn() const;
+  // added in 1.1
+  QString host() const;
+  QString database() const;
+  QString password() const;
+  QString port() const;
+  SSLmode sslMode() const;
+  void setSql(QString sql);
+  // added in 1.2
+  QString keyColumn() const;
+  void setKeyColumn(QString column);
Modified: trunk/qgis/python/core/qgsproviderregistry.sip
--- trunk/qgis/python/core/qgsproviderregistry.sip	2009-09-12 20:10:44 UTC (rev 11639)
+++ trunk/qgis/python/core/qgsproviderregistry.sip	2009-09-12 20:37:31 UTC (rev 11640)
@@ -1,72 +1,72 @@
-/** canonical manager of data providers
-  This is a Singleton class that manages data provider access.
-class QgsProviderRegistry
-%TypeHeaderCode
-#include <qgsproviderregistry.h>
-%End
-  public:
-    /** means of accessing canonical single instance  */
-    static QgsProviderRegistry* instance(QString pluginPath = QString::null);
-    /** Virtual dectructor */
-    virtual ~QgsProviderRegistry();
-    QString library(const QString & providerKey) const;
-    QString pluginList(bool asHtml = false) const;
-    /** return library directory where plugins are found */
-    const QDir & libraryDirectory() const;
-    void setLibraryDirectory(const QDir & path);
-    QgsDataProvider * getProvider( const QString & providerKey,
-                                   const QString & dataSource );
-    /** Return list of available providers by their keys */
-    QStringList providerList() const;
-    /** Return metadata of the provider or NULL if not found */
-    const QgsProviderMetadata* providerMetadata(const QString& providerKey) const;
-    /** return vector file filter string
-      Returns a string suitable for a QFileDialog of vector file formats
-      supported by all data providers.
-      This walks through all data providers appending calls to their
-      fileVectorFilters to a string, which is then returned.
-      @note
-      It'd be nice to eventually be raster/vector neutral.
-    virtual QString fileVectorFilters() const;
-    /** return a string containing the available database drivers
-    virtual QString databaseDrivers() const;
-    /** return a string containing the available directory drivers
-    virtual QString directoryDrivers() const;
-    /** return a string containing the available protocol drivers
-    virtual QString protocolDrivers() const;
-  private:
-        /** ctor private since instance() creates it */
-        QgsProviderRegistry(QString pluginPath) /Default/ ;
-}; // class QgsProviderRegistry
+/** canonical manager of data providers
+  This is a Singleton class that manages data provider access.
+class QgsProviderRegistry
+%TypeHeaderCode
+#include <qgsproviderregistry.h>
+%End
+  public:
+    /** means of accessing canonical single instance  */
+    static QgsProviderRegistry* instance(QString pluginPath = QString::null);
+    /** Virtual dectructor */
+    virtual ~QgsProviderRegistry();
+    QString library(const QString & providerKey) const;
+    QString pluginList(bool asHtml = false) const;
+    /** return library directory where plugins are found */
+    const QDir & libraryDirectory() const;
+    void setLibraryDirectory(const QDir & path);
+    QgsDataProvider * getProvider( const QString & providerKey,
+                                   const QString & dataSource );
+    /** Return list of available providers by their keys */
+    QStringList providerList() const;
+    /** Return metadata of the provider or NULL if not found */
+    const QgsProviderMetadata* providerMetadata(const QString& providerKey) const;
+    /** return vector file filter string
+      Returns a string suitable for a QFileDialog of vector file formats
+      supported by all data providers.
+      This walks through all data providers appending calls to their
+      fileVectorFilters to a string, which is then returned.
+      @note
+      It'd be nice to eventually be raster/vector neutral.
+    virtual QString fileVectorFilters() const;
+    /** return a string containing the available database drivers
+    virtual QString databaseDrivers() const;
+    /** return a string containing the available directory drivers
+    virtual QString directoryDrivers() const;
+    /** return a string containing the available protocol drivers
+    virtual QString protocolDrivers() const;
+  private:
+        /** ctor private since instance() creates it */
+        QgsProviderRegistry(QString pluginPath) /Default/ ;
+}; // class QgsProviderRegistry
More information about the QGIS-commit mailing list
