[QGIS Commit] r11653 - branches/Release-1_3_0/i18n
svn_qgis at osgeo.org
Sun Sep 13 14:09:19 EDT 2009
Author: macho
Date: 2009-09-13 14:09:18 -0400 (Sun, 13 Sep 2009)
New Revision: 11653
branches/Release-1_3_0/i18n/qgis_uk.ts
still trying to get ukrainian in the release .. ;) should not break anything anyway ..
Modified: branches/Release-1_3_0/i18n/qgis_uk.ts
--- branches/Release-1_3_0/i18n/qgis_uk.ts 2009-09-13 15:51:03 UTC (rev 11652)
+++ branches/Release-1_3_0/i18n/qgis_uk.ts 2009-09-13 18:09:18 UTC (rev 11653)
@@ -3057,7 +3057,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="583"/>
<source>Print Composer</source>
- <translation>Компонування карти</translation>
+ <translation>Компонувальник карт</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="586"/>
@@ -4540,7 +4540,7 @@
<location filename="../src/app/qgisapp.cpp" line="4176"/>
<location filename="../src/app/qgisapp.cpp" line="4283"/>
<source>Layer not editable</source>
- <translation>Шар не редагується</translation>
+ <translation>Шар не підтримує редагування</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="4177"/>
@@ -4897,7 +4897,7 @@
<message>
<location filename="../src/app/qgsabout.cpp" line="220"/>
<source>Names</source>
- <translation type="unfinished">Імена</translation>
+ <translation>Імена</translation>
</message>
<message>
<location filename="../src/app/qgsabout.cpp" line="273"/>
@@ -5065,156 +5065,156 @@
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="19"/>
<source>Attribute Actions</source>
- <translation type="unfinished"></translation>
+ <translation>Дії з атрибутами</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="37"/>
<source>Action properties</source>
+ <translation>Властивості дії</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="43"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="59"/>
<source>Enter the name of an action here. The name should be unique (qgis will make it unique if necessary).</source>
+ <translation>Введіть ім'я дії тут. Ім'я повинно бути унікальним (QGIS зробить його унікальним, якщо це необхідно).</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="46"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="157"/>
<source>Name</source>
+ <translation>Ім'я</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="56"/>
<source>Enter the action name here</source>
+ <translation>Введіть ім'я дії тут</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="66"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="82"/>
<source>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if prefixed with a backslash</source>
+ <translation>Введіть дію тут. Це може бути будь-яка програма, сценарій чи команда, доступна на вашій системі. Коли дія викликається будь-який набір символів, які починаються з % і слідуючим за ним ім'ям поля будуть замінені на значення цього поля. Спеціальні символи %% буде замінено значенням обраного поля. Подвійні лапки групують текст в єдиний аргумент для програми, сценарію чи команди. Подвійні лапки будуть ігноруватись, якщо перед ними є \ (backslash)</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="69"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="162"/>
<source>Action</source>
+ <translation>Дія</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="79"/>
<source>Enter the action command here</source>
+ <translation>Введіть команду дії тут</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="89"/>
<source>Browse for action</source>
+ <translation>Огляд дії</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="92"/>
<source>Click to browse for an action</source>
+ <translation>Клацніть для огляду дії</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="95"/>
<source>Clicking the button will let you select an application to use as the action</source>
+ <translation>Клацання на клавіші дозволить вибрати програму для використанна як дії</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="98"/>
<source>...</source>
+ <translation>...</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="105"/>
<source>The valid attribute names for this layer</source>
+ <translation>Допустимі імена атрибутів для цього шару</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="112"/>
<source>Inserts the selected field into the action, prepended with a %</source>
+ <translation>Вставити вибране поле в дію з попереднім %</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="115"/>
<source>Insert field</source>
+ <translation>Вставити поле</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="122"/>
<source>Captures any output from the action</source>
+ <translation>Захвачувати будь-який вивід дії</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="125"/>
<source>Captures the standard output or error generated by the action and displays it in a dialog box</source>
+ <translation>Захвачувати стандартний вивід чи помилку згенеровану дією та показати це в діалоговому вікні</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="128"/>
<source>Capture output</source>
+ <translation>Захвачувати вивід</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="144"/>
<source>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</source>
+ <translation>Цей список містить всі дії, що були визначені для поточного шару. Додавайте дії вводячи деталі в елементи керування нижче і потім натискайте кнопку "Вставити дію". Дії можна редагувати двічі клацнувши на елементі списку.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="167"/>
<source>Capture</source>
+ <translation>Захвачувати</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="175"/>
<source>Inserts the action into the list above</source>
+ <translation>Вставити дію в список вище</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="178"/>
<source>Insert action</source>
+ <translation>Вставити дію</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="185"/>
<source>Update the selected action</source>
+ <translation>Оновити вибрану дію</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="188"/>
<source>Update action</source>
+ <translation>Оновити дію</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="211"/>
<source>Move the selected action up</source>
+ <translation>Перемістити вибрану дію вгору</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="214"/>
<source>Move up</source>
+ <translation>Перемістити вгору</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="221"/>
<source>Move the selected action down</source>
+ <translation>Перемістити вибрану дію вниз</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="224"/>
<source>Move down</source>
+ <translation>Перемістити вниз</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="247"/>
<source>Remove the selected action</source>
+ <translation>Видалити вибрану дію</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="250"/>
<source>Remove</source>
+ <translation>Видалити</translation>
</message>
</context>
<context>
@@ -5297,57 +5297,57 @@
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="76"/>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="82"/>
<source>Attribute table - %1</source>
+ <translation>Таблиця атрибутів - %1</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="417"/>
<source>Search string parsing error</source>
+ <translation>Помилка розбору пошукового запиту</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="424"/>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="481"/>
<source>Search results</source>
+ <translation>Результати пошуку</translation>
</message>
<message>
<source>You've supplied an empty search string.</source>
+ <translation>Ви ввели порожній пошуковий запит.</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="464"/>
<source>Error during search</source>
+ <translation>Помилка при пошуку</translation>
</message>
<message numerus="yes">
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="477"/>
<source>Found %d matching features.</source>
- <numerusform></numerusform>
+ <translation>
+ <numerusform>Знайдено %n відповідний об'єкт.</numerusform>
+ <numerusform>Знайдено %n відповідних об'єкта.</numerusform>
+ <numerusform>Знайдено %n відповідних об'єктів.</numerusform>
</translation>
</message>
<message>
<location filename="../src/app/attributetable/qgsattributetabledialog.cpp" line="479"/>
<source>No matching features found.</source>
+ <translation>Не знайдено відповідних об'єктів.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="13"/>
<source>Attribute Table</source>
+ <translation>Таблиця атрибутів</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="46"/>
<source>Remove selection</source>
+ <translation>Зняти виділення</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="68"/>
<source>Move selected to top</source>
+ <translation>Перемістити вибрані до початку</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="83"/>
@@ -5357,7 +5357,7 @@
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="90"/>
<source>Invert selection</source>
+ <translation>Звернути виділення</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="105"/>
@@ -5367,12 +5367,12 @@
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="112"/>
<source>Copy selected rows to clipboard (Ctrl+C)</source>
+ <translation>Копіювати вибрані рядки до буферу обміну (Ctrl+C)</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="115"/>
<source>Copies the selected rows to the clipboard</source>
+ <translation>Копіювати вибрані рядки до буферу обміну</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="130"/>
@@ -5382,12 +5382,12 @@
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="137"/>
<source>Zoom map to the selected rows (Ctrl-J)</source>
+ <translation>Збільшити карту до вибраних рядків (Ctrl-J)</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="140"/>
<source>Zoom map to the selected rows</source>
+ <translation>Збільшити карту до вибраних рядків</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="155"/>
@@ -5397,42 +5397,42 @@
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="162"/>
<source>Toggle editing mode</source>
+ <translation>Режим редагування</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="165"/>
<source>Click to toggle table editing</source>
+ <translation>Клацніть для переключення редагування таблиці</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="187"/>
<source>Look for</source>
+ <translation>Шукати</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="197"/>
<source>in</source>
+ <translation>в</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="207"/>
<source>&Search</source>
+ <translation>&Пошук</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="218"/>
<source>Show selected records only</source>
+ <translation>Показати тільки вибрані записи</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="225"/>
<source>Search selected records only</source>
+ <translation>Шукати тільки в вибраних записах</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="245"/>
<source>Advanced search</source>
+ <translation>Розширений пошук</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetabledialog.ui" line="252"/>
@@ -5461,176 +5461,177 @@
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="113"/>
<source>Select a file</source>
+ <translation>Вибрати файл</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="122"/>
<source>Error</source>
+ <translation>Помилка</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="123"/>
<source>Could not open file %1
Error was:%2</source>
+ <translation>Не вдалося відкрити файл %1
+Помилка:%2</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="288"/>
<location filename="../src/app/qgsattributetypedialog.cpp" line="309"/>
<source>Current minimum for this value is %1 and current maximum is %2.</source>
+ <translation>Поточний мінімум для цього значення %1 і поточний максимум %2.</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="314"/>
<source>Attribute has no integer or real type, therefore range is not usable.</source>
+ <translation>Тип атрибута не є цілим чи дійсним, тому використання елемента "діапазон" неможливе.</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="422"/>
<source>Enumeration is not available for this attribute</source>
+ <translation>Перелік недоступний для цього атрибуту</translation>
</message>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="513"/>
<location filename="../src/ui/qgsattributetypeedit.ui" line="14"/>
<source>Attribute Edit Dialog</source>
+ <translation>Діалог редагування атрибутів</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="21"/>
<source>Line edit</source>
+ <translation>Лінійне редагування</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="26"/>
<source>Classification</source>
+ <translation>Класифікація</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="31"/>
<source>Range</source>
+ <translation>Діапазон</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="36"/>
<source>Unique values</source>
+ <translation>Унікальні значення</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="41"/>
<source>File name</source>
+ <translation>Ім'я файла</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="46"/>
<source>Value map</source>
+ <translation>Карта значень</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="51"/>
<source>Enumeration</source>
+ <translation>Перелік</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="56"/>
<source>Immutable</source>
+ <translation>Незмінний</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="71"/>
<source>Simple edit box. This is the default editation widget.</source>
+ <translation>Просте поле введення. Це віджет редагування за умовчанням.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="95"/>
<source>Displays combo box containing values of attribute used for classification.</source>
+ <translation>Відображає випадаючий список, що містить значення атрибута, які використовуються для класифікації.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="124"/>
<source>Allows to set numeric values from a specified range. The edit widget can be either a slider or a spin box.</source>
+ <translation>Дозволяє встановити числові значення з зазначеного діапазону. Віджет редагування може бути повзунком чи полем вводу.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="136"/>
<source>Minimum</source>
+ <translation>Мінімум</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="143"/>
<source>Maximum</source>
+ <translation>Максимум</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="150"/>
<source>Step</source>
+ <translation>Крок</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="228"/>
<source>Slider</source>
+ <translation>Повзунок</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="238"/>
<location filename="../src/ui/qgsattributetypeedit.ui" line="273"/>
<source>Editable</source>
+ <translation>Підтримує редагування</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="245"/>
<source>Local minimum/maximum = 0/0</source>
+ <translation>Локальний мінімум/максимум = 0/0</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="263"/>
<source>The user can select one of the values already used in the attribute. If editable, a line edit is shown with autocompletion support, otherwise a combo box is used.</source>
+ <translation>Користувач може вибрати одне зі значень, вже використовуємих в атрибуті. Якщо підтримує редагування, лінійне редагування показується з підтримкою автодоповнення, інакше використовується випадаючий список.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="299"/>
<source>Simplifies file selection by adding a file chooser dialog.</source>
+ <translation>Спрощує вибір файлів, додаючи діалог вибору файлів.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="326"/>
<source>Combo box with predefined items. Value is stored in the attribute, description is shown in the combo box.</source>
+ <translation>Випадаючий список з наперед визначеними елементами. Значення зберігається в атрибуті, опис виводиться в списку.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="336"/>
<source>Load Data from layer</source>
+ <translation>Завантажити дані з шару</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="357"/>
<source>Value</source>
+ <translation>Значення</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="362"/>
<source>Description</source>
+ <translation>Опис</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="370"/>
<source>Remove Selected</source>
+ <translation>Видалити вибране</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="390"/>
<source>Load Data from CSV file</source>
+ <translation>Завантажити дані з файлу CSV</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="401"/>
<source>Combo box with values that can be used within the column's type. Must be supported by the provider.</source>
+ <translation>Випадаючий список значень допустимих для поля даного типу . Елемент повинен підтримуватися джерелом даних.</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="435"/>
<source>Immutable attribute is read-only - user is not able to modify the contents.</source>
+ <translation>Незмінний атрибут доступний тільки для читання - користувач не зможе змінити його значення.</translation>
</message>
</context>
<context>
@@ -5688,7 +5689,7 @@
<message>
<location filename="../src/ui/qgsbookmarksbase.ui" line="39"/>
<source>Extent</source>
- <translation type="unfinished">Межа</translation>
+ <translation>Межа</translation>
</message>
<message>
<location filename="../src/ui/qgsbookmarksbase.ui" line="44"/>
@@ -5701,205 +5702,205 @@
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="109"/>
<source>QGIS - print composer</source>
+ <translation>QGIS - компонувальник карт</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="120"/>
<source>QGIS</source>
+ <translation>QGIS</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="124"/>
<source>File</source>
+ <translation>Файл</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="125"/>
<source>Close</source>
+ <translation>Закрити</translation>
</message>
<message>
<source>Ctrl+W</source>
+ <translation>Ctrl+W</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="131"/>
<source>Edit</source>
+ <translation>Правка</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="132"/>
<source>&Undo</source>
+ <translation>В&ідмінити</translation>
</message>
<message>
<source>Ctrl+Z</source>
+ <translation>Ctrl+Z</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="135"/>
<source>Cu&t</source>
+ <translation>&Вирізати</translation>
</message>
<message>
<source>Ctrl+X</source>
+ <translation>Ctrl+X</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="137"/>
<source>&Copy</source>
+ <translation>&Копіювати</translation>
</message>
<message>
<source>Ctrl+C</source>
+ <translation>Ctrl+C</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="139"/>
<source>&Paste</source>
+ <translation>Вст&авити</translation>
</message>
<message>
<source>Ctrl+V</source>
+ <translation>Ctrl+V</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="141"/>
<source>Delete</source>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="144"/>
<source>View</source>
+ <translation>Вид</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="151"/>
<source>Layout</source>
+ <translation>Макет</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="207"/>
<source>Map 1</source>
+ <translation>Карта 1</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="442"/>
<location filename="../src/app/composer/qgscomposer.cpp" line="709"/>
<source>Choose a file name to save the map as</source>
+ <translation>Виберіть ім'я файла для збереження карти як</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="443"/>
<source>PDF Format</source>
+ <translation>Формат PDF</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="560"/>
<source>Big image</source>
+ <translation>Велике зображення</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="561"/>
<source>To create image %1 x %2 requires circa %3 MB of memory</source>
+ <translation>Для створення зображень %1 x %2 потрібно близько %3 МБ пам'яті</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="589"/>
<source>%1 format (*.%2 *.%3)</source>
+ <translation>Формат %1 (*.%2 *.%3)</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="613"/>
<source>Choose a file name to save the map image as</source>
+ <translation>Виберіть ім'я файла для збереження зображення карти як</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="683"/>
<source>SVG warning</source>
+ <translation>Попередження SVG</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="684"/>
<location filename="../src/app/composer/qgscomposer.cpp" line="1302"/>
<source>Don't show this message again</source>
+ <translation>Не показувати це повідомлення знову</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="688"/>
<source><p>The SVG export function in Qgis has several problems due to bugs and deficiencies in the </source>
+ <translation><p>Функція SVG експорта в QGIS має кілька проблем пов'язаних з помилками і недоліками у</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="691"/>
<source>Qt4 svg code. Of note, text does not appear in the SVG file and there are problems with the map bounding box clipping other items such as the legend or scale bar.</p></source>
+ <translation>Qt4 svg код. Зокрема, текст не зберігається в SVG-файл і існують проблеми з рамкою карти, що перетинає інші елементи (легенду або масштабну лінійку).</p></translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="696"/>
<source>Qt4 svg code. In particular, there are problems with layers not being clipped to the map bounding box.</p></source>
+ <translation>Qt4 svg код. Зокрема, існують проблеми з шарами, які не відсікаються рамкою карти.</p></translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="700"/>
<source>If you require a vector-based output file from Qgis it is suggested that you try printing to PostScript if the SVG output is not satisfactory.</p></source>
+ <translation>Якщо вам необхідно отримати векторний вихідний файл з QGIS, то передбачається, що ви намагаєтеся роздрукувати в PostScript, якщо вивід в SVG не є задовільним.</P></translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="710"/>
<source>SVG Format</source>
+ <translation>Формат SVG</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="806"/>
<source>save template</source>
+ <translation>Зберегти шаблон</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="832"/>
<source>Save error</source>
+ <translation>Помилка збереження</translation>
</message>
<message>
<source>Error, could not save file</source>
+ <translation>Помилка, не вдалося зберегти файл</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="840"/>
<source>Load template</source>
+ <translation>Завантажити шаблон</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="853"/>
<location filename="../src/app/composer/qgscomposer.cpp" line="860"/>
<source>Read error</source>
+ <translation>Помилка читання</translation>
</message>
<message>
<source>Error, could not read file</source>
+ <translation>Помилка, не вдалося прочитати файл</translation>
</message>
<message>
<source>Content of template file is not valid</source>
+ <translation>Невірний вміст файла шаблона</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="1300"/>
<source>Project contains WMS layers</source>
+ <translation>Проект містить WMS-шар</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="1301"/>
<source>Some WMS servers (e.g. UMN mapserver) have a limit for the WIDTH and HEIGHT parameter. Printing layers from such servers may exceed this limit. If this is the case, the WMS layer will not be printed</source>
+ <translation>Деякі WMS-сервери (наприклад, UMN mapserver) мають обмеження на значення параметрів ширини і висоти (WIDTH і HEIGHT). Під час друку шарів з цих серверів, ці ліміти можуть бути перевищені. У цьому випадку, WMS-шар не буде надрукований</translation>
</message>
</context>
<context>
@@ -5907,268 +5908,268 @@
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="16"/>
<source>MainWindow</source>
+ <translation>Головне Вікно</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="81"/>
<source>General</source>
+ <translation>Загальні</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="134"/>
<source>Composition</source>
+ <translation>Композиція</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="142"/>
<source>Item</source>
+ <translation>Елемент</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="194"/>
<source>Help</source>
+ <translation>Довідка</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="214"/>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="259"/>
<source>&Print...</source>
+ <translation>&Друк...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="267"/>
<source>Zoom Full</source>
+ <translation>Повне охоплення</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="275"/>
<source>Zoom In</source>
+ <translation>Збільшити</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="283"/>
<source>Zoom Out</source>
+ <translation>Зменшити</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="291"/>
<source>Add Map</source>
+ <translation>Додати карту</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="294"/>
<source>Add new map</source>
+ <translation>Додати нову карту</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="302"/>
<source>Add Label</source>
+ <translation>Додати текст</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="305"/>
<source>Add new label</source>
+ <translation>Додати новий текст</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="313"/>
<source>Add Vector Legend</source>
+ <translation>Додати легенду</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="316"/>
<source>Add new vect legend</source>
+ <translation>Додати нову легенду</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="324"/>
<source>Move Item</source>
+ <translation>Перемістити елемент</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="327"/>
<source>Select/Move item</source>
+ <translation>Вибрати/Перемістити елемент</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="335"/>
<source>Export as Image...</source>
+ <translation>Експортувати як зображення...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="343"/>
<source>Export as PDF...</source>
+ <translation>Експортувати як PDF...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="351"/>
<source>Export as SVG...</source>
+ <translation>Експортувати як SVG...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="359"/>
<source>Add Scalebar</source>
+ <translation>Додати масштабну лінійку</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="362"/>
<source>Add new scalebar</source>
+ <translation>Додати нову масштабну лінійку</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="370"/>
<source>Refresh</source>
+ <translation>Оновити</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="373"/>
<source>Refresh view</source>
+ <translation>Оновити вид</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="381"/>
<source>Add Image</source>
+ <translation>Додати зображення</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="386"/>
<source>Move Content</source>
+ <translation>Перемістити вміст</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="389"/>
<source>Move item content</source>
+ <translation>Перемістити вміст елемента</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="394"/>
<source>Group</source>
+ <translation>Згрупувати</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="397"/>
<source>Group items</source>
+ <translation>Згрупувати елементи</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="402"/>
<source>Ungroup</source>
+ <translation>Розгрупувати</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="405"/>
<source>Ungroup items</source>
+ <translation>Розгрупувати елементи</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="410"/>
<source>Raise</source>
+ <translation>Підняти</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="413"/>
<source>Raise selected items</source>
+ <translation>Підняти вибрані елементи</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="418"/>
<source>Lower</source>
+ <translation>Опустити</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="421"/>
<source>Lower selected items</source>
+ <translation>Опустити вибрані елементи</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="426"/>
<source>Bring to Front</source>
+ <translation>На передній план</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="429"/>
<source>Move selected items to top</source>
+ <translation>Перемістити вибрані елементи на передний план</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="434"/>
<source>Send to Back</source>
+ <translation>На задній план</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="437"/>
<source>Move selected items to bottom</source>
+ <translation>Перемістити вибрані елементи на задній план</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="442"/>
<source>Load From template</source>
+ <translation>Завантажити з шаблона</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="447"/>
<source>Save as template</source>
+ <translation>Зберегти як шаблон</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="452"/>
<source>Align left</source>
+ <translation>Вирівняти по лівому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="455"/>
<source>Align selected items left</source>
+ <translation>Вирівняти вибрані елементи по лівому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="460"/>
<source>Align center</source>
+ <translation>Вирівняти по центру</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="463"/>
<source>Align center horizontal</source>
+ <translation>Центрувати по горизонталі</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="468"/>
<source>Align right</source>
+ <translation>Вирівняти по правому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="471"/>
<source>Align selected items right</source>
+ <translation>Вирівняти вибрані елементи по правому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="476"/>
<source>Align top</source>
+ <translation>Вирівняти по верхньому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="479"/>
<source>Align selected items to top</source>
+ <translation>Вирівняти вибрані елементи по верхньому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="484"/>
<location filename="../src/ui/qgscomposerbase.ui" line="487"/>
<source>Align center vertical</source>
+ <translation>Центрувати по вертикалі</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="492"/>
<source>Align bottom</source>
+ <translation>Вирівняти по нижньому краю</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="495"/>
<source>Align selected items bottom</source>
+ <translation>Вирівняти вибрані елементи по нижньому краю</translation>
</message>
</context>
<context>
@@ -6176,47 +6177,47 @@
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="13"/>
<source>Form</source>
+ <translation>Форма</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="19"/>
<source>Composer item properties</source>
+ <translation>Властивості елемента</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="25"/>
<source>Color:</source>
+ <translation>Колір:</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="32"/>
<source>Frame...</source>
+ <translation>Рамка...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="39"/>
<source>Background...</source>
+ <translation>Фон...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="46"/>
<source>Opacity:</source>
+ <translation>Непрозорість:</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="63"/>
<source>Outline width: </source>
+ <translation>Ширина контуру:</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="73"/>
<source>Position...</source>
+ <translation>Позиція...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposeritemwidgetbase.ui" line="80"/>
<source>Frame</source>
+ <translation>Рамка</translation>
</message>
</context>
<context>
@@ -6224,7 +6225,7 @@
<message>
<location filename="../src/ui/qgscomposerlabelwidgetbase.ui" line="19"/>
<source>Label Options</source>
- <translation type="unfinished">Параметри текста</translation>
+ <translation>Параметри текста</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerlabelwidgetbase.ui" line="38"/>
