[QGIS Commit] r11725 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Mon Sep 28 13:48:15 EDT 2009
Author: borysiasty
Date: 2009-09-28 13:48:13 -0400 (Mon, 28 Sep 2009)
New Revision: 11725
trunk/qgis/src/ui/qgsoptionsbase.ui
Remove confusing descriptions in the Options dialog
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-28 16:29:22 UTC (rev 11724)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-28 17:48:13 UTC (rev 11725)
@@ -195,15 +195,21 @@
</widget>
</item>
<item row="1" column="0" colspan="2" >
- <widget class="QLabel" name="textLabel1_5" >
- <property name="text" >
- <string><b>Note: </b>Theme changes take effect the next time QGIS is started</string>
+ <spacer name="verticalSpacer">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
</property>
- <property name="alignment" >
- <set>Qt::AlignVCenter</set>
+ <property name="sizeType">
+ <enum>QSizePolicy::Fixed</enum>
</property>
- </widget>
- </item>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>10</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
<item row="2" column="0" colspan="2" >
<widget class="QCheckBox" name="capitaliseCheckBox" >
@@ -782,7 +788,7 @@
<widget class="QLabel" name="mDefaultSnappingToleranceTextLabel" >
- <string>Default snapping tolerance in layer units</string>
+ <string>Default snapping tolerance</string>
</property>
</widget>
</item>
@@ -812,7 +818,7 @@
<item row="2" column="0" colspan="3" >
<widget class="QLabel" name="mVertexSearchRadiusVertexEditLabel" >
- <string>Search radius for vertex edits in layer units</string>
+ <string>Search radius for vertex edits</string>
</property>
</widget>
</item>
