[QGIS Commit] r11729 - in trunk/qgis: python/core src/app src/core
src/providers/spatialite src/ui
svn_qgis at osgeo.org
Mon Sep 28 17:38:26 EDT 2009
Author: jef
Date: 2009-09-28 17:38:25 -0400 (Mon, 28 Sep 2009)
New Revision: 11729
trunk/qgis/python/core/qgsdatasourceuri.sip
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/core/qgsdatasourceuri.cpp
trunk/qgis/src/core/qgsdatasourceuri.h
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgsproject.cpp
trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
- fix load of layers saved with relative paths on *x
- also save relative paths to spatialite databases
- show path mode as combobox
- add QgsDataSourceURI::setDatabase()
Modified: trunk/qgis/python/core/qgsdatasourceuri.sip
--- trunk/qgis/python/core/qgsdatasourceuri.sip 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/python/core/qgsdatasourceuri.sip 2009-09-28 21:38:25 UTC (rev 11729)
@@ -38,6 +38,10 @@
const QString& aUsername,
const QString& aPassword,
SSLmode sslmode = SSLprefer );
+ //! Set database
+ //! \note added in 1.4
+ void setDatabase( const QString &database );
//! Set all data source related members at once
void setDataSource(const QString& aSchema,
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2009-09-28 21:38:25 UTC (rev 11729)
@@ -83,7 +83,7 @@
radManual->setChecked( true );
- cbxAbsolutePath->setChecked( QgsProject::instance()->readBoolEntry( "Paths", "/Absolute", true ) );
+ cbxAbsolutePath->setCurrentIndex( QgsProject::instance()->readBoolEntry( "Paths", "/Absolute", true ) ? 0 : 1 );
int dp = QgsProject::instance()->readNumEntry( "PositionPrecision", "/DecimalPlaces" );
spinBoxDP->setValue( dp );
@@ -373,7 +373,7 @@
// Announce that we may have a new display precision setting
emit displayPrecisionChanged();
- QgsProject::instance()->writeEntry( "Paths", "/Absolute", cbxAbsolutePath->isChecked() );
+ QgsProject::instance()->writeEntry( "Paths", "/Absolute", cbxAbsolutePath->currentIndex()==0 );
//set the colour for selections
QColor myColour = pbnSelectionColour->color();
Modified: trunk/qgis/src/core/qgsdatasourceuri.cpp
--- trunk/qgis/src/core/qgsdatasourceuri.cpp 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/core/qgsdatasourceuri.cpp 2009-09-28 21:38:25 UTC (rev 11729)
@@ -432,3 +432,8 @@
mSql = sql;
mKeyColumn = keyColumn;
+void QgsDataSourceURI::setDatabase( const QString &database )
+ mDatabase = database;
Modified: trunk/qgis/src/core/qgsdatasourceuri.h
--- trunk/qgis/src/core/qgsdatasourceuri.h 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/core/qgsdatasourceuri.h 2009-09-28 21:38:25 UTC (rev 11729)
@@ -57,6 +57,10 @@
+ //! Set database
+ // \note added in 1.4
void setDataSource( const QString& aSchema,
const QString& aTable,
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2009-09-28 21:38:25 UTC (rev 11729)
@@ -40,6 +40,7 @@
#include "qgsproject.h"
#include "qgslogger.h"
#include "qgsdatasourceuri.h"
+#include "qgsvectorlayer.h"
QgsMapLayer::QgsMapLayer( QgsMapLayer::LayerType type,
QString lyrname,
@@ -145,14 +146,30 @@
QDomElement element = layer_node.toElement();
- // XXX not needed? QString type = element.attribute("type");
+ QDomNode mnl;
+ QDomElement mne;
+ // read provider
+ QString provider;
+ mnl = layer_node.namedItem( "provider" );
+ mne = mnl.toElement();
+ provider = mne.text();
// set data source
- QDomNode mnl = layer_node.namedItem( "datasource" );
- QDomElement mne = mnl.toElement();
+ mnl = layer_node.namedItem( "datasource" );
mDataSource = mne.text();
- mDataSource = QgsProject::instance()->readPath( mDataSource );
+ if ( provider == "spatialite" )
+ QgsDataSourceURI uri( mDataSource );
+ uri.setDatabase( QgsProject::instance()->readPath( uri.database() ) );
+ mDataSource = uri.uri();
+ else
+ mDataSource = QgsProject::instance()->readPath( mDataSource );
// Set the CRS from project file, asking the user if necessary.
// Make it the saved CRS to have WMS layer projected correctly.
@@ -268,7 +285,18 @@
QString src = source();
- src = QgsProject::instance()->writePath( src );
+ QgsVectorLayer *vlayer = dynamic_cast<QgsVectorLayer *>( this );
+ if ( vlayer && vlayer->providerType() == "spatialite" )
+ QgsDataSourceURI uri( src );
+ QString database = QgsProject::instance()->writePath( uri.database() );
+ uri.setConnection( uri.host(), uri.port(), database, uri.username(), uri.password() );
+ src = uri.uri();
+ else
+ src = QgsProject::instance()->writePath( src );
QDomText dataSourceText = document.createTextNode( src );
dataSource.appendChild( dataSourceText );
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/core/qgsproject.cpp 2009-09-28 21:38:25 UTC (rev 11729)
@@ -1373,6 +1373,11 @@
projElems.removeAt( pos - 1 );
+#if !defined(Q_OS_WIN)
+ // make path absolute
+ projElems.prepend( "" );
+#endif
return projElems.join( "/" );
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-09-28 21:38:25 UTC (rev 11729)
@@ -49,17 +49,8 @@
// parsing members from the uri structure
mTableName = mUri.table();
geometryColumn = mUri.geometryColumn();
+ mSqlitePath = mUri.database();
- // extracting the DB path
- int idx = uri.indexOf( "dbname='" );
- if ( idx >= 0 )
- mSqlitePath = uri.mid( idx + 8 );
- else
- mSqlitePath = uri;
- idx = mSqlitePath.indexOf( "' table=" );
- if ( idx > 0 )
- mSqlitePath.truncate( idx );
// trying to open the SQLite DB
spatialite_init( 0 );
valid = true;
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-09-28 18:44:31 UTC (rev 11728)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-09-28 21:38:25 UTC (rev 11729)
@@ -138,13 +138,40 @@
</property>
</widget>
</item>
- <item row="3" column="0" colspan="4">
- <widget class="QCheckBox" name="cbxAbsolutePath">
+ <item row="3" column="3">
+ <widget class="QComboBox" name="cbxAbsolutePath">
+ <item>
+ <property name="text">
+ <string>absolute</string>
+ </property>
+ </item>
+ <item>
+ <string>relative</string>
+ </property>
+ </item>
+ </widget>
+ </item>
+ <item row="3" column="0">
+ <widget class="QLabel" name="label_3">
- <string>Save absolute paths</string>
+ <string>Save paths</string>
</property>
</widget>
</item>
+ <item row="3" column="2">
+ <spacer name="horizontalSpacer">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
</item>
@@ -331,9 +358,6 @@
<attribute name="horizontalHeaderStretchLastSection">
<bool>true</bool>
</attribute>
- <attribute name="horizontalHeaderVisible">
- <bool>false</bool>
- </attribute>
<column>
<string>Layer</string>
