[QGIS Commit] r11731 - trunk/qgis/src/providers/spatialite
svn_qgis at osgeo.org
Tue Sep 29 03:24:28 EDT 2009
Author: jef
Date: 2009-09-29 03:24:26 -0400 (Tue, 29 Sep 2009)
New Revision: 11731
trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
apply #1936
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-09-28 21:46:04 UTC (rev 11730)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp 2009-09-29 07:24:26 UTC (rev 11731)
@@ -44,12 +44,13 @@
QgsSpatiaLiteProvider::QgsSpatiaLiteProvider( QString const &uri ): QgsVectorDataProvider( uri ),
geomType( QGis::WKBUnknown ), sqliteHandle( NULL ), sqliteStatement( NULL ), mSrid( -1 ), spatialIndexRTree( false ), spatialIndexMbrCache( false )
- QgsDataSourceURI mUri = QgsDataSourceURI( uri );
+ QgsDataSourceURI anUri = QgsDataSourceURI( uri );
// parsing members from the uri structure
- mTableName = mUri.table();
- geometryColumn = mUri.geometryColumn();
- mSqlitePath = mUri.database();
+ mTableName = anUri.table();
+ geometryColumn = anUri.geometryColumn();
+ mSqlitePath = anUri.database();
+ mSubsetString = anUri.sql();
// trying to open the SQLite DB
spatialite_init( 0 );
@@ -464,6 +465,24 @@
return true;
+QString QgsSpatiaLiteProvider::subsetString()
+ return mSubsetString;
+void QgsSpatiaLiteProvider::setSubsetString( QString theSQL )
+ mSubsetString = theSQL;
+ // update URI
+ QgsDataSourceURI uri = QgsDataSourceURI(dataSourceUri());
+ uri.setSql( theSQL );
+ setDataSourceUri( uri.uri() );
+ // update feature count and extents
+ getTableSummary();
void QgsSpatiaLiteProvider::select( QgsAttributeList fetchAttributes, QgsRectangle rect, bool fetchGeometry, bool useIntersect )
// preparing the SQL statement
@@ -545,6 +564,19 @@
if ( !whereClause.isEmpty() )
sql += whereClause;
+ if ( !mSubsetString.isEmpty() )
+ if ( !whereClause.isEmpty() )
+ sql += " AND ";
+ else
+ sql += " WHERE ";
+ sql += "( " + mSubsetString + ")";
mFetchGeom = fetchGeometry;
mAttributesToFetch = fetchAttributes;
strcpy( xSql, sql.toUtf8().constData() );
@@ -654,6 +686,11 @@
QString sql = QString( "SELECT Min(%1) FROM %2" ).arg( fld.name() ).arg( quotedValue( mTableName ) );
+ sql += " WHERE ( " + mSubsetString + ")";
ret = sqlite3_get_table( sqliteHandle, xSql, &results, &rows, &columns, &errMsg );
if ( ret != SQLITE_OK )
@@ -709,6 +746,11 @@
QString sql = QString( "SELECT Max(%1) FROM %2" ).arg( fld.name() ).arg( quotedValue( mTableName ) );
@@ -763,6 +805,11 @@
sql = QString( "SELECT DISTINCT %1 FROM %2 ORDER BY %1" ).arg( fld.name() ).arg( quotedValue( mTableName ) );
// SQLite prepared statement
if ( sqlite3_prepare_v2( sqliteHandle, xSql, strlen( xSql ), &stmt, NULL ) != SQLITE_OK )
@@ -1542,6 +1589,11 @@
QString sql = QString( "SELECT Min(MbrMinX(%1)), Min(MbrMinY(%1)), "
"Max(MbrMaxX(%1)), Max(MbrMaxY(%1)), Count(*) " "FROM %2" ).arg( geometryColumn ).arg( quotedValue( mTableName ) );
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h 2009-09-28 21:46:04 UTC (rev 11730)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.h 2009-09-29 07:24:26 UTC (rev 11731)
@@ -74,6 +74,13 @@
virtual bool featureAtId( int featureId,
QgsFeature & feature, bool fetchGeometry = true, QgsAttributeList fetchAttributes = QgsAttributeList() );
+ /** Accessor for sql where clause used to limit dataset */
+ virtual QString subsetString();
+ /** mutator for sql where clause used to limit dataset size */
+ virtual void setSubsetString( QString theSQL );
/** Select features based on a bounding rectangle. Features can be retrieved with calls to nextFeature.
* @param fetchAttributes list of attributes which should be fetched
* @param rect spatial filter
@@ -286,6 +293,10 @@
sqlite3_stmt *sqliteStatement;
+ * String used to define a subset of the layer
+ QString mSubsetString;
* Spatial reference id of the layer
int mSrid;
