[QGIS Commit] r14000 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org
Mon Aug 2 21:47:01 EDT 2010
Author: kyngchaos
Date: 2010-08-03 01:47:01 +0000 (Tue, 03 Aug 2010)
New Revision: 14000
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
fix a bundling bug, missed lib subdir in config header
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-08-02 15:43:01 UTC (rev 13999)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-08-03 01:47:01 UTC (rev 14000)
@@ -2959,7 +2959,7 @@
isa = PBXContainerItemProxy;
containerPortal = 20286C28FDCF999611CA2CEA /* Project object */;
proxyType = 1;
- remoteGlobalIDString = 72E25B1F12070F9900E2895A /* bundling */;
+ remoteGlobalIDString = 72E25B1F12070F9900E2895A;
remoteInfo = bundling;
72E706F50F42612B00142011 /* PBXContainerItemProxy */ = {
@@ -15159,7 +15159,7 @@
runOnlyForDeploymentPostprocessing = 0;
shellPath = /bin/sh;
- shellScript = "mkdir -p \"$CONFIGURATION_BUILD_DIR/include\"\n\n# check if the files are generated, clean if need to regenerate\n\nif [ ! -f \"$CONFIGURATION_BUILD_DIR/include/qgsconfig.h\" ] || [ ../../cmake_templates/qgsconfig.h.in -nt \"$CONFIGURATION_BUILD_DIR/include/qgsconfig.h\" ] ; then\necho \"Generating qgsconfig.h...\"\nsed -e \"s,\\${CPACK_PACKAGE_VERSION_MAJOR},$QGIS_VERSION_MAJOR,g\" \\\n\t-e \"s,\\${CPACK_PACKAGE_VERSION_MINOR},$QGIS_VERSION_MINOR,g\" \\\n\t-e \"s,\\${CPACK_PACKAGE_VERSION_PATCH},$QGIS_VERSION_PATCH,g\" \\\n\t-e \"s,\\${RELEASE_NAME},$QGIS_RELEASE_NAME,g\" \\\n\t-e \"s,\\${QGIS_VERSION_INT},$QGIS_VERSION_INT,g\" \\\n\t-e \"s,\\${QGIS_PLUGIN_SUBDIR},$QGIS_PLUGIN_SUBDIR,g\" \\\n\t-e \"s,\\${QGIS_DATA_SUBDIR},$QGIS_DATA_SUBDIR,g\" \\\n\t-e \"s,\\${QGIS_LIBEXEC_SUBDIR},$QGIS_LIBEXEC_SUBDIR,g\" \\\n\t-e \"s,#cmakedefine,#define,g\" \\\n\t../../cmake_templates/qgsconfig.h.in > \"$CONFIGURATION_BUILD_DIR/include/qgsconfig.h\"\nfi\n\nif [ ! -f \"$C
ONFIGURATION_BUILD_DIR/include/qgssvnversion.h\" ] ; then\necho \"Generating qgssvnversion.h...\"\nsvnv=`which svnversion`\nif [ \"$svnv\" ] ; then\n\tsvnver=`svnversion $SRCROOT`\nelse\n\tsvnver=\"unknown\"\nfi\necho \"#define QGSSVNVERSION \\\"$svnver\\\"\" > \"$CONFIGURATION_BUILD_DIR/include/qgssvnversion.h\"\nfi\n\nexit 0";
+ shellScript = "mkdir -p \"$CONFIGURATION_BUILD_DIR/include\"\n\n# check if the files are generated, clean if need to regenerate\n\nif [ ! -f \"$CONFIGURATION_BUILD_DIR/include/qgsconfig.h\" ] || [ ../../cmake_templates/qgsconfig.h.in -nt \"$CONFIGURATION_BUILD_DIR/include/qgsconfig.h\" ] ; then\necho \"Generating qgsconfig.h...\"\nsed -e \"s,\\${CPACK_PACKAGE_VERSION_MAJOR},$QGIS_VERSION_MAJOR,g\" \\\n\t-e \"s,\\${CPACK_PACKAGE_VERSION_MINOR},$QGIS_VERSION_MINOR,g\" \\\n\t-e \"s,\\${CPACK_PACKAGE_VERSION_PATCH},$QGIS_VERSION_PATCH,g\" \\\n\t-e \"s,\\${RELEASE_NAME},$QGIS_RELEASE_NAME,g\" \\\n\t-e \"s,\\${QGIS_VERSION_INT},$QGIS_VERSION_INT,g\" \\\n\t-e \"s,\\${QGIS_PLUGIN_SUBDIR},$QGIS_PLUGIN_SUBDIR,g\" \\\n\t-e \"s,\\${QGIS_DATA_SUBDIR},$QGIS_DATA_SUBDIR,g\" \\\n\t-e \"s,\\${QGIS_LIBEXEC_SUBDIR},$QGIS_LIBEXEC_SUBDIR,g\" \\\n\t-e \"s,\\${QGIS_LIB_SUBDIR},$QGIS_LIB_SUBDIR,g\" \\\n\t-e \"s,#cmakedefine,#define,g\" \\\n\t../../cmake_templates/qgsconfig.h.in > \"$CONFIGURATIO
N_BUILD_DIR/include/qgsconfig.h\"\nfi\n\nif [ ! -f \"$CONFIGURATION_BUILD_DIR/include/qgssvnversion.h\" ] ; then\necho \"Generating qgssvnversion.h...\"\nsvnv=`which svnversion`\nif [ \"$svnv\" ] ; then\n\tsvnver=`svnversion $SRCROOT`\nelse\n\tsvnver=\"unknown\"\nfi\necho \"#define QGSSVNVERSION \\\"$svnver\\\"\" > \"$CONFIGURATION_BUILD_DIR/include/qgssvnversion.h\"\nfi\n\nexit 0";
showEnvVarsInLog = 0;
7223B7830F96A96500D905B4 /* Script - ui */ = {
@@ -15624,7 +15624,7 @@
- shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\necho \"Copying Qt frameworks...\"\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] && [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/V
ersions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto -X $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIn
s/imageformats/libqjpeg.dylib\"\nfi\nmkdir -p \"$APPDIRC/PlugIns/codecs\"\nfor c in cn jp kr tw\ndo\n\tif [ ! -f \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$QT_PLUGINS_DIR/codecs/libq$c\"\"codecs.dylib\" \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\tfi\ndone\n\n# Qwt\n\necho \"Copying Qwt and updating library paths...\"\nQWTROOT=\"$QWT_PREFIX/lib\"\nif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\tditto -X $QARCHS \"$QWTROOT/libqwt.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tqlib=`otool -L \"$QWTROOT/libqwt.dylib\" | grep -E -m 1 \"libqwt.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tQWT_CHG=\"-change $qlib @executable_path/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\techo \"install_name_tool $QWT_CHG \\\"$APPDIR/Qgis\\\"\"\n\tinstall_name_tool $QWT_CHG \"$APPDIR/Qgis\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\techo \"Copying PyQt library paths...\"\n\t
mkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto -X $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\techo \"Copying PyQwt and updating library paths...\"\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\t\techo \
"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# GRASS plugin libexec stuff may link Qt\nif [ -d \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin\" ] ; then\n\tln -sfh ../$QGIS_LIBEXEC_REL/$QGIS_FW_SUBDIR \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/Frameworks\"\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls libqgis*.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\necho \"Updating Qt library paths...\"\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tif [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; t
hen\n\t\tqq=`otool -L \"$QT_PREFIX_FW/$q.framework/$q\" | grep -E -m 1 \"$q.framework.*\\(\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tq_chg=\"-change $qq @executable_path/$QGIS_FW_SUBDIR/$q.framework/$q\"\n\t\t# app\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/Qgis\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/Qgis\"\n\t\t# qgis_help qt linking done with symlinks\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t\t# libs\n\t\tfor ql in $qgliblist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIB_SUBDIR/$ql\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\t\tdone\n\t\t# GRASS libexec stuff\n\t\tif [ -f \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIBEXEC_SUB
DIR/grass/bin/qgis.g.browser\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\"\n\t\tfi\n\t\t# plugins\n\t\tfor qp in $pluglist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\t\tdone\n\t\t# qt fw\n\t\tfor qf in $QTLISTQG\n\t\tdo\n\t\t\tif [ -d \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework\" ] ; then\n\t\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\t\t\tfi\n\t\tdone\n\t\t# qt plugs\n\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t\tfor c in cn jp kr tw\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/codecs/libq$c\\\"\\\"code
cs.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\t\tdone\n\t\t# Qwt\n\t\tif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t\tfi\n\t\t# PyQt\n\t\tif [ \"$PYSITE\" ] ; then\n\t\t\tfor pq in $PYQTLIST\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\t\tdone\n\t\t\tfor pg in $qgpylist\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/qgis/$pg\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/qgis/$pg\"\n\t\t\tdone\n\t\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\t\tfor pw in _iqt Qwt\n\t\t\t\tdo\n\t\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\\\"\"\n\t\t\t\t\ti
nstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\t\tdone\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n";
+ shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\necho \"Copying Qt frameworks...\"\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] && [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/V
s/imageformats/libqjpeg.dylib\"\nfi\nmkdir -p \"$APPDIRC/PlugIns/codecs\"\nfor c in cn jp kr tw\ndo\n\tif [ ! -f \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$QT_PLUGINS_DIR/codecs/libq$c\"\"codecs.dylib\" \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\tfi\ndone\n\n# Qwt\n\necho \"Copying Qwt and updating library paths...\"\nQWTROOT=\"$QWT_PREFIX/lib\"\nif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\tditto -X $QARCHS \"$QWTROOT/libqwt.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tqlib=`otool -L \"$QWTROOT/libqwt.dylib\" | grep -E -m 1 \"libqwt.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tQWT_CHG=\"-change $qlib @executable_path/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\techo \"install_name_tool $QWT_CHG \\\"$APPDIR/Qgis\\\"\"\n\tinstall_name_tool $QWT_CHG \"$APPDIR/Qgis\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\techo \"Copying PyQt librar
y paths...\"\n\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto -X $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\techo \"Copying PyQwt and updating library paths...\"\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWV
ER\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# GRASS plugin libexec stuff may link Qt\nif [ -d \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin\" ] ; then\n\tln -sfh ../$QGIS_LIBEXEC_REL/$QGIS_FW_SUBDIR \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/Frameworks\"\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls libqgis*.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\necho \"Updating Qt library paths...\"\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tif [ -d \"$QT_PREFIX_FW/$q.f
ramework\" ] ; then\n\t\tqq=`otool -L \"$QT_PREFIX_FW/$q.framework/$q\" | grep -E -m 1 \"$q.framework.*\\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tq_chg=\"-change $qq @executable_path/$QGIS_FW_SUBDIR/$q.framework/$q\"\n\t\t# app\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/Qgis\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/Qgis\"\n\t\t# qgis_help qt linking done with symlinks\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t\t# libs\n\t\tfor ql in $qgliblist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIB_SUBDIR/$ql\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\t\tdone\n\t\t# GRASS libexec stuff\n\t\tif [ -f \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\" ] ; then\n\t\t\techo \"install_name_tool $q_chg
\\\"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\"\n\t\tfi\n\t\t# plugins\n\t\tfor qp in $pluglist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\t\tdone\n\t\t# qt fw\n\t\tfor qf in $QTLISTQG\n\t\tdo\n\t\t\tif [ -d \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework\" ] ; then\n\t\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\t\t\tfi\n\t\tdone\n\t\t# qt plugs\n\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t\tfor c in cn jp kr tw\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/Plug
Ins/codecs/libq$c\\\"\\\"codecs.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\t\tdone\n\t\t# Qwt\n\t\tif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t\tfi\n\t\t# PyQt\n\t\tif [ \"$PYSITE\" ] ; then\n\t\t\tfor pq in $PYQTLIST\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\t\tdone\n\t\t\tfor pg in $qgpylist\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/qgis/$pg\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/qgis/$pg\"\n\t\t\tdone\n\t\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\t\tfor pw in _iqt Qwt\n\t\t\t\tdo\n\t\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/Q
wt5/$pw.so\\\"\"\n\t\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\t\tdone\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n";
72E25B2412070FFB00E2895A /* Script - bundle extras */ = {
@@ -15639,7 +15639,7 @@
- shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths. ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\techo \"Copying libpq...\"\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executab
le_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDAL_PREFIX/lib/libgdal.dylib\" ] ; then\n\techo \"Copying GDAL...\"\n\tditto -X $QARCHS \"$GDAL_PREFIX/lib/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tditto -X $QARCHS \"$PYSITE/osgeo\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tfor p in gdal gdalconst gdalnumeric ogr osr\n\tdo\n\t\tditto -X $QARCHS \"$PYSITE/$p.py\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tdone\n\tfor p in $GDAL_PROGS\n\tdo\n\t\tif [ -e \"$GDAL_PREFIX/bin/$p\" ] ; then\n\t\t\tditto -X $QARCHS \"$GDAL_PREFIX/bin/$p\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\t\tfi\n\tdone\n\tglib=`otool -L \"$GDAL_PREFIX/lib/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_pa
th/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJ_PREFIX/lib/libproj.dylib\" ] ; then\n\techo \"Copying PROJ...\"\n\tditto -X $QARCHS \"$PROJ_PREFIX/lib/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJ_PREFIX/lib/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\techo \"Copying GEOS...\"\n\tditto -X $QARCHS \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -
d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite & SpatiaLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\techo \"Copying Sqlite3...\"\n\tditto -X $QARCHS \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tif [ -f \"$SQLITEROOT/libspatialite.dylib\" ] ; the
n\n\t\tditto -X $QARCHS \"$SQLITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\t\tslib=`otool -L \"$SQLITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tfi\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\techo \"Copying GSL...\"\n\tditto -X $QARCHS \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tditto -X $QARCHS \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E
-m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"Updating bundled library paths...\"\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\techo \"install_name
_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR\"\n# clean out pyc\nfind python -name *.pyc -print0 | xargs -0 rm -f\n# python binary modules\npymodlist=`find -x python -name *.so`\nfor p in $pymodlist\ndo\n\techo \"install_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \\\"$p\\\"\"\n\tinstall_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \"$p\"\ndone\n\n# change bundled progs from above bundling\n# will get error on qgis_help.app\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\nbinlist=`ls`\nfor p in $binlist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\\\"\"\n\tinst
all_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\"\ndone\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\ncd \"$PROJECT_DIR\"\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
+ shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths. ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\techo \"Copying libpq...\"\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change
$plib @executable_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDAL_PREFIX/lib/libgdal.dylib\" ] ; then\n\techo \"Copying GDAL...\"\n\tditto -X $QARCHS \"$GDAL_PREFIX/lib/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tditto -X $QARCHS \"$PYSITE/osgeo\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tfor p in gdal gdalconst gdalnumeric ogr osr\n\tdo\n\t\tditto -X $QARCHS \"$PYSITE/$p.py\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tdone\n\tfor p in $GDAL_PROGS\n\tdo\n\t\tif [ -e \"$GDAL_PREFIX/bin/$p\" ] ; then\n\t\t\tditto -X $QARCHS \"$GDAL_PREFIX/bin/$p\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\t\tfi\n\tdone\n\tglib=`otool -L \"$GDAL_PREFIX/lib/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CH
G=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJ_PREFIX/lib/libproj.dylib\" ] ; then\n\techo \"Copying PROJ...\"\n\tditto -X $QARCHS \"$PROJ_PREFIX/lib/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJ_PREFIX/lib/libproj.dylib\" | grep -E -m 1 \"libproj.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\techo \"Copying GEOS...\"\n\tditto -X $QARCHS \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libge
os.dylib\" | grep -E -m 1 \"libgeos.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite & SpatiaLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\techo \"Copying Sqlite3...\"\n\tditto -X $QARCHS \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable
_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tif [ -f \"$SQLITEROOT/libspatialite.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$SQLITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\t\tslib=`otool -L \"$SQLITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tfi\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\techo \"Copying GSL...\"\n\tditto -X $QARCHS \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tditto -X $QARCHS \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \\(compatibility\" | cu
t -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \\(compatibility\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"Updating bundled library paths...\"\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_
CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR\"\n# clean out pyc\nfind python -name *.pyc -print0 | xargs -0 rm -f\n# python binary modules\npymodlist=`find -x python -name *.so`\nfor p in $pymodlist\ndo\n\techo \"install_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \\\"$p\\\"\"\n\tinstall_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \"$p\"\ndone\n\n# change bundled progs from above bundling\n# will get error on qgis_help.app\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\nbinlist=`ls`\nfor p in $binlist\ndo\n\techo \"install_name
_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\"\ndone\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\ncd \"$PROJECT_DIR\"\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
72E706ED0F42589900142011 /* fix linking */ = {
